[PATCH] c-user: Add CONFIGURE_INIT_TASK_STORAGE_SIZE
Fri Nov 20 09:36:24 UTC 2020
Close #4181.
 c-user/config/classic-init-task.rst | 52 ++++++++++++++++++++++++++++-
 1 file changed, 51 insertions(+), 1 deletion(-)
diff --git a/c-user/config/classic-init-task.rst b/c-user/config/classic-init-task.rst
index 4d3bf81..dc07068 100644
--- a/c-user/config/classic-init-task.rst
+++ b/c-user/config/classic-init-task.rst
@@ -229,7 +229,57 @@ DESCRIPTION:
     Classic API initialization task.
 NOTES:
-    None.
+    The
+    * ``CONFIGURE_INIT_TASK_STACK_SIZE`` and
+    * :ref:`CONFIGURE_INIT_TASK_STORAGE_SIZE`
+    configuration options are mutually exclusive.
+.. Generated from spec:/acfg/if/init-task-storage-size
+.. index:: CONFIGURE_INIT_TASK_STORAGE_SIZE
+.. _CONFIGURE_INIT_TASK_STORAGE_SIZE:
+CONFIGURE_INIT_TASK_STORAGE_SIZE
+CONSTANT:
+    ``CONFIGURE_INIT_TASK_STORAGE_SIZE``
+OPTION TYPE:
+    This configuration option is an integer define.
+DEFAULT VALUE:
+    The default value is 0.
+VALUE CONSTRAINTS:
+    The value of this configuration option shall satisfy all of the following
+    constraints:
+    * It shall be greater than or equal to :ref:`CONFIGURE_MINIMUM_TASK_STACK_SIZE`.
+    * It shall be defined using
+      :c:func:`RTEMS_TASK_STORAGE_SIZE`.
+DESCRIPTION:
+    The value of this configuration option defines the task storage size of the
+    Classic API initialization task.  If this configuration option is specified,
+    then the Classic API initialization task is constructed by
+    :c:func:`rtems_task_construct` instead of using
+    :c:func:`rtems_task_create`.
+NOTES:
+    A task storage area of the specified size is defined by the configuration for
+    the Classic API initialization task.  The
+    * :ref:`CONFIGURE_INIT_TASK_STACK_SIZE` and
+    * ``CONFIGURE_INIT_TASK_STORAGE_SIZE``
 .. Generated from spec:/acfg/if/rtems-init-tasks-table
2.26.2
