[PATCH 00/20] Apply new Doxygen guidelines
Sebastian Huber
Fri Nov 20 11:15:06 UTC 2020
Adjust some high level Doxygen groups and rework the Partition Manager
and Events according to the new Doxygen guidelines.
Sebastian Huber (20):
doxygen: Rename Internal to Implementation
doxygen: Use common syntax for groups
libio: Move to RTEMS implementation group
rtems: Canonicalize partition file documentation
rtems: Update partition documentation
rtems: Move _Partition_Allocate_buffer()
rtems: Move _Partition_Free_buffer()
rtems: Remove _Partition_Free()
rtems: Remove _Partition_Destroy()
rtems: Move _Partition_Is_buffer_valid()
rtems: Move _Partition_Is_buffer_on_boundary()
rtems: Move _Partition_Is_buffer_size_aligned()
rtems: Move _Partition_Is_buffer_area_aligned()
rtems: Move _Partition_Initialize()
rtems: Move _Partition_Allocate()
rtems: Canonicalize task event file documentation
rtems: Remove unused EVENT_CURRENT
rtems: Remove EVENT_SETS_NONE_PENDING
rtems: Remove unused _Event_Timeout()
rtems: Update event documentation
bsps/shared/doxygen.h | 8 +-
cpukit/doxygen.h | 4 +-
cpukit/doxygen/top-level-groups.h | 11 +-
cpukit/include/rtems/confdefs.h | 2 +-
cpukit/include/rtems/extensionimpl.h | 2 +-
cpukit/include/rtems/libcsupport.h | 2 +-
cpukit/include/rtems/libio.h | 2 +
cpukit/include/rtems/posix/posixapi.h | 2 +-
cpukit/include/rtems/rtems/asrimpl.h | 2 +-
cpukit/include/rtems/rtems/attrimpl.h | 2 +-
cpukit/include/rtems/rtems/barrierimpl.h | 2 +-
cpukit/include/rtems/rtems/dpmemimpl.h | 2 +-
cpukit/include/rtems/rtems/eventdata.h | 9 +-
cpukit/include/rtems/rtems/eventimpl.h | 104 +++++++++-----
cpukit/include/rtems/rtems/messageimpl.h | 2 +-
cpukit/include/rtems/rtems/modesimpl.h | 2 +-
cpukit/include/rtems/rtems/objectimpl.h | 2 +-
cpukit/include/rtems/rtems/optionsimpl.h | 2 +-
cpukit/include/rtems/rtems/partdata.h | 94 ++++++++-----
cpukit/include/rtems/rtems/partimpl.h | 165 +++--------------------
cpukit/include/rtems/rtems/ratemonimpl.h | 2 +-
cpukit/include/rtems/rtems/regionimpl.h | 2 +-
cpukit/include/rtems/rtems/semimpl.h | 2 +-
cpukit/include/rtems/rtems/signalimpl.h | 2 +-
cpukit/include/rtems/rtems/statusimpl.h | 2 +-
cpukit/include/rtems/rtems/tasksimpl.h | 2 +-
cpukit/include/rtems/rtems/timerimpl.h | 2 +-
cpukit/include/rtems/score/object.h | 2 +-
cpukit/rtems/src/eventmp.c | 8 +-
cpukit/rtems/src/eventreceive.c | 5 +-
cpukit/rtems/src/eventseize.c | 5 +-
cpukit/rtems/src/eventsend.c | 8 +-
cpukit/rtems/src/eventsurrender.c | 8 +-
cpukit/rtems/src/part.c | 5 +-
cpukit/rtems/src/partcreate.c | 45 ++++++-
cpukit/rtems/src/partdelete.c | 12 +-
cpukit/rtems/src/partgetbuffer.c | 14 +-
cpukit/rtems/src/partident.c | 5 +-
cpukit/rtems/src/partmp.c | 5 +-
cpukit/rtems/src/partreturnbuffer.c | 52 ++++++-
cpukit/rtems/src/systemeventreceive.c | 5 +-
cpukit/rtems/src/systemeventsend.c | 5 +-
42 files changed, 345 insertions(+), 274 deletions(-)
2.26.2
