[PATCH 06/20] rtems: Move _Partition_Allocate_buffer()
Sebastian Huber
Fri Nov 20 11:15:12 UTC 2020
It is only used by rtems_partition_get_buffer().
cpukit/include/rtems/rtems/partimpl.h | 14 --------------
cpukit/rtems/src/partgetbuffer.c | 6 ++++++
2 files changed, 6 insertions(+), 14 deletions(-)
diff --git a/cpukit/include/rtems/rtems/partimpl.h b/cpukit/include/rtems/rtems/partimpl.h
index 9327188eea..fe9974d993 100644
--- a/cpukit/include/rtems/rtems/partimpl.h
+++ b/cpukit/include/rtems/rtems/partimpl.h
@@ -35,20 +35,6 @@ extern "C" {
- * @brief Allocate a buffer from the_partition.
- * This function attempts to allocate a buffer from the_partition.
- * If successful, it returns the address of the allocated buffer.
- * Otherwise, it returns NULL.
-RTEMS_INLINE_ROUTINE void *_Partition_Allocate_buffer (
- Partition_Control *the_partition
- return _Chain_Get_unprotected( &the_partition->Memory );
* @brief Frees the_buffer to the_partition.
diff --git a/cpukit/rtems/src/partgetbuffer.c b/cpukit/rtems/src/partgetbuffer.c
index c92664ef61..2061ff151e 100644
--- a/cpukit/rtems/src/partgetbuffer.c
+++ b/cpukit/rtems/src/partgetbuffer.c
@@ -21,6 +21,12 @@
#endif
#include <rtems/rtems/partimpl.h>
+#include <rtems/score/chainimpl.h>
+static void *_Partition_Allocate_buffer( Partition_Control *the_partition )
+ return _Chain_Get_unprotected( &the_partition->Memory );
rtems_status_code rtems_partition_get_buffer(
rtems_id id,
2.26.2
