[PATCH 08/20] rtems: Remove _Partition_Free()
Fri Nov 20 11:15:14 UTC 2020
It was a trivial function call wrapper used only in one place.
 cpukit/include/rtems/rtems/partimpl.h | 14 --------------
 cpukit/rtems/src/partdelete.c         |  2 +-
 2 files changed, 1 insertion(+), 15 deletions(-)
diff --git a/cpukit/include/rtems/rtems/partimpl.h b/cpukit/include/rtems/rtems/partimpl.h
index 599db29c13..55de7b113d 100644
--- a/cpukit/include/rtems/rtems/partimpl.h
+++ b/cpukit/include/rtems/rtems/partimpl.h
@@ -136,20 +136,6 @@ RTEMS_INLINE_ROUTINE void _Partition_Destroy(
   _ISR_lock_Destroy( &the_partition->Lock );
- *  @brief Frees a partition control block to the
- *  inactive chain of free partition control blocks.
- *  This routine frees a partition control block to the
-RTEMS_INLINE_ROUTINE void _Partition_Free (
-   Partition_Control *the_partition
-  _Objects_Free( &_Partition_Information, &the_partition->Object );
  * @brief Calls _Objects_Get() using the ::_Partition_Information.
diff --git a/cpukit/rtems/src/partdelete.c b/cpukit/rtems/src/partdelete.c
index 12f6bd6025..4fc71aff2d 100644
--- a/cpukit/rtems/src/partdelete.c
+++ b/cpukit/rtems/src/partdelete.c
@@ -73,7 +73,7 @@ rtems_status_code rtems_partition_delete(
 #endif
   _Partition_Destroy( the_partition );
-  _Partition_Free( the_partition );
+  _Objects_Free( &_Partition_Information, &the_partition->Object );
   _Objects_Allocator_unlock();
   return RTEMS_SUCCESSFUL;
2.26.2
