[PATCH 13/20] rtems: Move _Partition_Is_buffer_area_aligned()
Sebastian Huber
Fri Nov 20 11:15:19 UTC 2020
It is only used by rtems_partition_create().
cpukit/include/rtems/rtems/partimpl.h | 7 -------
cpukit/rtems/src/partcreate.c | 5 +++++
2 files changed, 5 insertions(+), 7 deletions(-)
diff --git a/cpukit/include/rtems/rtems/partimpl.h b/cpukit/include/rtems/rtems/partimpl.h
index b9d57ae3c3..dcffe757c7 100644
--- a/cpukit/include/rtems/rtems/partimpl.h
+++ b/cpukit/include/rtems/rtems/partimpl.h
@@ -34,13 +34,6 @@ extern "C" {
-RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_area_aligned(
- const void *starting_address
- return (((uintptr_t) starting_address) % CPU_SIZEOF_POINTER) == 0;
* @brief Allocates a partition control block from the
* inactive chain of free partition control blocks.
diff --git a/cpukit/rtems/src/partcreate.c b/cpukit/rtems/src/partcreate.c
index 6673ce2c59..da791e2360 100644
--- a/cpukit/rtems/src/partcreate.c
+++ b/cpukit/rtems/src/partcreate.c
@@ -31,6 +31,11 @@ static bool _Partition_Is_buffer_size_aligned( size_t buffer_size )
return ( buffer_size % CPU_SIZEOF_POINTER ) == 0;
+static bool _Partition_Is_buffer_area_aligned( const void *starting_address )
+ return ( ( (uintptr_t) starting_address ) % CPU_SIZEOF_POINTER ) == 0;
rtems_status_code rtems_partition_create(
rtems_name name,
void *starting_address,
2.26.2
