[PATCH 18/20] rtems: Remove EVENT_SETS_NONE_PENDING
Fri Nov 20 13:32:15 UTC 2020
On 20/11/2020 14:30, Joel Sherrill wrote:
> On Fri, Nov 20, 2020, 5:16 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     This define was only used in one place.
>      cpukit/include/rtems/rtems/eventimpl.h | 8 +-------
>      1 file changed, 1 insertion(+), 7 deletions(-)
>     diff --git a/cpukit/include/rtems/rtems/eventimpl.h
>     b/cpukit/include/rtems/rtems/eventimpl.h
>     index 9ccee0adbd..c65c202de4 100644
>     --- a/cpukit/include/rtems/rtems/eventimpl.h
>     +++ b/cpukit/include/rtems/rtems/eventimpl.h
>     @@ -32,12 +32,6 @@ extern "C" {
>     - *  The following constant is the value of an event set which
>     - *  has no events pending.
>     -#define EVENT_SETS_NONE_PENDING 0
>      rtems_status_code _Event_Seize(
>        rtems_event_set    event_in,
>        rtems_option       option_set,
>     @@ -68,7 +62,7 @@ void _Event_Timeout(
>      RTEMS_INLINE_ROUTINE void _Event_Initialize( Event_Control *event )
>     -  event->pending_events = EVENT_SETS_NONE_PENDING;
>     +  event->pending_events = 0;
> This loses clarity to me. If you want to ditch the constant, you have
> to add a comment.
In patch 20 I added documentation for this function:
+ * @brief Initializes an event control block to have no pending events.
+ * @param event is the event control block to initialize.
embedded brains GmbH
Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 16
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
