[PATCH 15/20] rtems: Move _Partition_Allocate()
Fri Nov 20 14:04:29 UTC 2020
Why are the comments being deleted?
I assume this is happening in all of the patches of this type. Please don't
do that.
On Fri, Nov 20, 2020 at 5:16 AM Sebastian Huber <
> It is only used by rtems_partition_create().
>  cpukit/include/rtems/rtems/partimpl.h | 12 ------------
>  cpukit/rtems/src/partcreate.c         |  5 +++++
>  2 files changed, 5 insertions(+), 12 deletions(-)
> diff --git a/cpukit/include/rtems/rtems/partimpl.h
> b/cpukit/include/rtems/rtems/partimpl.h
> index ab0bdc76f7..e2325bf8b5 100644
> --- a/cpukit/include/rtems/rtems/partimpl.h
> +++ b/cpukit/include/rtems/rtems/partimpl.h
> @@ -33,18 +33,6 @@ extern "C" {
> - *  @brief Allocates a partition control block from the
> - *  inactive chain of free partition control blocks.
> - *  This function allocates a partition control block from
> - *  the inactive chain of free partition control blocks.
> -RTEMS_INLINE_ROUTINE Partition_Control *_Partition_Allocate ( void )
> -  return (Partition_Control *) _Objects_Allocate( &_Partition_Information
>   * @brief Calls _Objects_Get() using the ::_Partition_Information.
> diff --git a/cpukit/rtems/src/partcreate.c b/cpukit/rtems/src/partcreate.c
> index a6824d5224..7caac4f796 100644
> --- a/cpukit/rtems/src/partcreate.c
> +++ b/cpukit/rtems/src/partcreate.c
> @@ -37,6 +37,11 @@ static bool _Partition_Is_buffer_area_aligned( const
> void *starting_address )
>    return ( ( (uintptr_t) starting_address ) % CPU_SIZEOF_POINTER ) == 0;
> +static Partition_Control *_Partition_Allocate( void )
> +  return (Partition_Control *) _Objects_Allocate( &_Partition_Information
>  static void _Partition_Initialize(
>    Partition_Control *the_partition,
>    void              *starting_address,
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201120/6ab03462/attachment.html>
