[PATCH 11/20] rtems: Move _Partition_Is_buffer_on_boundary()
Gedare Bloom
gedare at rtems.org
Fri Nov 20 16:10:10 UTC 2020
On Fri, Nov 20, 2020 at 4:16 AM Sebastian Huber
> It is used only by rtems_partition_return_buffer(). Make the PTCB the
> first parameter.
> cpukit/include/rtems/rtems/partimpl.h | 22 ----------------------
> cpukit/rtems/src/partreturnbuffer.c | 17 ++++++++++++++++-
> 2 files changed, 16 insertions(+), 23 deletions(-)
> diff --git a/cpukit/include/rtems/rtems/partimpl.h b/cpukit/include/rtems/rtems/partimpl.h
> index 23d5422bec..0d15d1e991 100644
> --- a/cpukit/include/rtems/rtems/partimpl.h
> +++ b/cpukit/include/rtems/rtems/partimpl.h
> @@ -19,7 +19,6 @@
> #define _RTEMS_RTEMS_PARTIMPL_H
> #include <rtems/rtems/partdata.h>
> -#include <rtems/score/address.h>
> #include <rtems/score/chainimpl.h>
> #include <rtems/score/objectimpl.h>
> @@ -35,27 +34,6 @@ extern "C" {
> - * @brief Checks whether is on a valid buffer boundary for the_partition.
> - * This function returns TRUE if the_buffer is on a valid buffer
> - * boundary for the_partition, and FALSE otherwise.
I think keep these two lines. This function is not so clear without
thinking through what it means to do pointer arithmetic (subtraction
and mod).
> -RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_on_boundary (
> - void *the_buffer,
> - Partition_Control *the_partition
> - intptr_t offset;
> - offset = _Addresses_Subtract(
> - the_buffer,
> - the_partition->starting_address
> - return ((offset % the_partition->buffer_size) == 0);
> RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_size_aligned(
> uint32_t buffer_size
> diff --git a/cpukit/rtems/src/partreturnbuffer.c b/cpukit/rtems/src/partreturnbuffer.c
> index 61900fa735..bc0d273719 100644
> --- a/cpukit/rtems/src/partreturnbuffer.c
> +++ b/cpukit/rtems/src/partreturnbuffer.c
> @@ -24,6 +24,21 @@
> +static bool _Partition_Is_buffer_on_boundary (
> + const Partition_Control *the_partition,
> + const void *the_buffer
> + intptr_t offset;
> + offset = _Addresses_Subtract(
> + the_buffer,
> + the_partition->starting_address
> + return ( ( offset % the_partition->buffer_size ) == 0);
> static bool _Partition_Is_buffer_valid(
> @@ -36,7 +51,7 @@ static bool _Partition_Is_buffer_valid(
> ending = _Addresses_Add_offset( starting, the_partition->length );
> return _Addresses_Is_in_range( the_buffer, starting, ending )
> - && _Partition_Is_buffer_on_boundary( the_buffer, the_partition );
> + && _Partition_Is_buffer_on_boundary( the_partition, the_buffer );
> static void _Partition_Free_buffer(
> 2.26.2
> devel mailing list
> devel at rtems.org
