[PATCH 5/8] libtest: Allow assert checks during test begin
Kinsey Moore kinsey.moore at oarcorp.com
Sat Nov 21 00:47:02 UTC 2020
-----Original Message-----
From: devel <devel-bounces at rtems.org> On Behalf Of Sebastian Huber
Sent: Friday, November 13, 2020 04:08
To: devel at rtems.org
Subject: [PATCH 5/8] libtest: Allow assert checks during test begin
> Allow assert checks in test begin actions and setup fixture methods.
>  cpukit/include/rtems/test.h |  2 +-
>  cpukit/libtest/t-test.c     | 29 +++++++++++++++++------------
>  2 files changed, 18 insertions(+), 13 deletions(-)
This patch appears to have broken ttest01.exe for arm/xilinx-zynq as well as aarch64 targets. I suspect it has also broken other arm targets. I tried looking into the failure, but I'm unfamiliar with the test framework in use.
Test output from arm/xilinx-zynq:
$ qemu-system-arm -no-reboot -nographic -serial null -serial mon:stdio -machine xilinx-zynq-a9 -m 4096 -kernel build/arm/xilinx_zynq_a9_qemu/testsuites/libtests/ttest01.exe
*** BEGIN OF TEST TTEST 1 ***
*** TEST VERSION: 6.0.0.46bf926570503dec3d70a8f09d12e461fd7e0914
*** TEST STATE: EXPECTED_PASS
*** TEST BUILD:
*** TEST TOOLS: 10.2.1 20200918 (RTEMS 6, RSB 748525234945de047196f9974b866f8595efd66e, Newlib 749cbcc)
A:ttest01
S:Platform:RTEMS
S:Compiler:*
S:Version:*
S:BSP:*
S:RTEMS_DEBUG:*
S:RTEMS_MULTIPROCESSING:*
S:RTEMS_POSIX_API:*
S:RTEMS_PROFILING:*
S:RTEMS_SMP:*
B:zalloc_auto
P:0:0:UI1:test-malloc.c:35
P:1:0:UI1:test-malloc.c:36
P:2:0:UI1:test-malloc.c:26
E:zalloc_auto:N:3:F:0:D:0.001000
B:wrong_step
P:0:0:UI1:test-plan.c:6
F:1:0:UI1:test-plan.c:7:planned step (2)
E:wrong_step:N:2:F:1:D:0.001000
B:verbosity_changes
F:3:0:UI1:test-verbosity.c:12:normal: check fails -> with output
P:4:0:UI1:test-verbosity.c:14
F:5:0:UI1:test-verbosity.c:15:verbose: check fails -> with output
E:verbosity_changes:N:6:F:3:D:0.001000
B:timer
P:0:0:UI1:test-rtems.c:26
P:1:0:UI1:test-rtems.c:29
P:2:0:UI1:test-rtems.c:39
P:3:0:ISR:test-rtems.c:14
P:4:0:ISR:test-rtems.c:15
P:5:0:UI1:test-rtems.c:44
P:6:0:UI1:test-rtems.c:45
P:7:0:UI1:test-rtems.c:48
E:timer:N:8:F:0:D:0.001000
B:time_to_string
P:0:0:UI1:test-time.c:11
P:1:0:UI1:test-time.c:12
P:2:0:UI1:test-time.c:13
P:3:0:UI1:test-time.c:14
P:4:0:UI1:test-time.c:17
P:5:0:UI1:test-time.c:18
E:time_to_string:N:6:F:0:D:0.001000
B:time
P:0:0:UI1:test-time.c:55
P:1:0:UI1:test-time.c:56
P:2:0:UI1:test-time.c:57
P:3:0:UI1:test-time.c:58
P:4:0:UI1:test-time.c:61
P:5:0:UI1:test-time.c:63
P:6:0:UI1:test-time.c:64
P:7:0:UI1:test-time.c:67
P:8:0:UI1:test-time.c:69
P:9:0:UI1:test-time.c:70
P:10:0:UI1:test-time.c:73
P:11:0:UI1:test-time.c:75
P:12:0:UI1:test-time.c:76
P:13:0:UI1:test-time.c:79
P:14:0:UI1:test-time.c:81
P:15:0:UI1:test-time.c:82
P:16:0:UI1:test-time.c:85
P:17:0:UI1:test-time.c:87
P:18:0:UI1:test-time.c:88
P:19:0:UI1:test-time.c:91
P:20:0:UI1:test-time.c:93
P:21:0:UI1:test-time.c:94
P:22:0:UI1:test-time.c:97
P:23:0:UI1:test-time.c:99
P:24:0:UI1:test-time.c:100
P:25:0:UI1:test-time.c:103
P:26:0:UI1:test-time.c:105
P:27:0:UI1:test-time.c:106
P:28:0:UI1:test-time.c:109
P:29:0:UI1:test-time.c:111
P:30:0:UI1:test-time.c:112
P:31:0:UI1:test-time.c:115
P:32:0:UI1:test-time.c:117
P:33:0:UI1:test-time.c:118
P:34:0:UI1:test-time.c:121
P:35:0:UI1:test-time.c:123
P:36:0:UI1:test-time.c:124
P:37:0:UI1:test-time.c:127
P:38:0:UI1:test-time.c:129
P:39:0:UI1:test-time.c:130
E:time:N:40:F:0:D:0.001000
B:ticks
P:0:0:UI1:test-time.c:147
P:1:0:UI1:test-time.c:151
P:2:0:UI1:test-time.c:152
P:3:0:UI1:test-time.c:172
P:4:0:UI1:test-time.c:173
P:5:0:UI1:test-time.c:174
P:6:0:UI1:test-time.c:175
E:ticks:N:7:F:0:D:0.001000
B:tick
P:0:0:UI1:test-time.c:44
E:tick:N:1:F:0:D:0.001000
B:test_psx_success
P:0:0:UI1:test-psx.c:31
F:1:0:UI1:test-psx.c:32:-1 == 0, 0
F:*:0:UI1:test-psx.c:34:-1 == 0, 0
P:2:0:UI1:test-psx.c:35
F:3:0:UI1:test-psx.c:36:-1 == 0, 0
E:
*** FATAL ***
fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)
R0   = 0xfffffff8 R8  = 0x00000000
R1   = 0x00000030 R9  = 0x00116d79
R2   = 0x00207798 R10 = 0x00000002
R3   = 0x00000001 R11 = 0x00204378
R4   = 0x00000000 R12 = 0xffffffff
R5   = 0xffecb9a8 SP  = 0x00207700
R6   = 0x00000030 LR  = 0x001108b3
R7   = 0x0013465a PC  = 0x00119f6c
CPSR = 0x600f0173 VEC = 0x00000004
FPEXC = 0x40000000
FPSCR = 0x00000000
D00 = 0x0000000000000000
D01 = 0x0000000000000000
D02 = 0x0000000000000000
D03 = 0x0000000000000000
D04 = 0x0000000000000000
D05 = 0x0000000000000000
D06 = 0x0000000000000000
D07 = 0x0000000000000000
D08 = 0x0000000000000000
D09 = 0x0000000000000000
D10 = 0x0000000000000000
D11 = 0x0000000000000000
D12 = 0x0000000000000000
D13 = 0x0000000000000000
D14 = 0x0000000000000000
D15 = 0x0000000000000000
D16 = 0x0000000000000000
D17 = 0x0000000000000000
D18 = 0x0000000000000000
D19 = 0x0000000000000000
D20 = 0x0000000000000000
D21 = 0x0000000000000000
D22 = 0x0000000000000000
D23 = 0x0000000000000000
D24 = 0x0000000000000000
D25 = 0x0000000000000000
D26 = 0x0000000000000000
D27 = 0x0000000000000000
D28 = 0x0000000000000000
D29 = 0x0000000000000000
D30 = 0x0000000000000000
D31 = 0x0000000000000000
RTEMS version: 6.0.0.46bf926570503dec3d70a8f09d12e461fd7e0914
RTEMS tools: 10.2.1 20200918 (RTEMS 6, RSB 748525234945de047196f9974b866f8595efd66e, Newlib 749cbcc)
executing thread ID: 0x08a010001
executing thread name: UI1
