[PATCH 2/3] score: Add CONFIGURE_INIT_TASK_STORAGE_SIZE
Sun Nov 22 22:22:23 UTC 2020
On 20/11/20 7:31 pm, Sebastian Huber wrote:
> In order to better support applications which use the new
> rtems_task_construct() directive add the
> CONFIGURE_INIT_TASK_STORAGE_SIZE configuration option.  If this option
> is specified, then the Classic API initialization task is constructed
> with rtems_task_construct().
The name CONFIGURE_INIT_TASK_STORAGE_SIZE does not reflect the role described
here and is a little ambiguous unless you know the implementation detail.
CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE ?
