[PATCH v2 1/6] rtems: Move _Partition_Is_buffer_valid()
Mon Nov 23 10:35:40 UTC 2020
It is used only in one place.  Make the PTCB the first parameter.
Rename it to _Partition_Is_address_a_buffer_begin().
 cpukit/include/rtems/rtems/partimpl.h | 23 -----------------------
 cpukit/rtems/src/partreturnbuffer.c   | 18 +++++++++++++++++-
 2 files changed, 17 insertions(+), 24 deletions(-)
diff --git a/cpukit/include/rtems/rtems/partimpl.h b/cpukit/include/rtems/rtems/partimpl.h
index fc17311803..23d5422bec 100644
--- a/cpukit/include/rtems/rtems/partimpl.h
+++ b/cpukit/include/rtems/rtems/partimpl.h
@@ -56,29 +56,6 @@ RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_on_boundary (
   return ((offset % the_partition->buffer_size) == 0);
- *  @brief Checks whether the_buffer is a valid buffer from the_partition.
- *  This function returns TRUE if the_buffer is a valid buffer from
- *  the_partition, otherwise FALSE is returned.
-RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_valid (
-   Chain_Node        *the_buffer,
-   Partition_Control *the_partition
-  void *starting;
-  void *ending;
-  starting = the_partition->starting_address;
-  ending   = _Addresses_Add_offset( starting, the_partition->length );
-  return (
-    _Addresses_Is_in_range( the_buffer, starting, ending ) &&
-    _Partition_Is_buffer_on_boundary( the_buffer, the_partition )
 RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_size_aligned(
   uint32_t buffer_size
diff --git a/cpukit/rtems/src/partreturnbuffer.c b/cpukit/rtems/src/partreturnbuffer.c
index 9afda8f85e..08cbf9ecee 100644
--- a/cpukit/rtems/src/partreturnbuffer.c
+++ b/cpukit/rtems/src/partreturnbuffer.c
@@ -21,8 +21,24 @@
 #endif
 #include <rtems/rtems/partimpl.h>
+#include <rtems/score/address.h>
+static bool _Partition_Is_address_a_buffer_begin(
+   const Partition_Control *the_partition,
+   const void              *the_buffer
+  void *starting;
+  void *ending;
+  starting = the_partition->starting_address;
+  ending   = _Addresses_Add_offset( starting, the_partition->length );
+  return _Addresses_Is_in_range( the_buffer, starting, ending )
+    && _Partition_Is_buffer_on_boundary( the_buffer, the_partition );
 static void _Partition_Free_buffer(
   void              *the_buffer
@@ -51,7 +67,7 @@ rtems_status_code rtems_partition_return_buffer(
   _Partition_Acquire_critical( the_partition, &lock_context );
-  if ( !_Partition_Is_buffer_valid( buffer, the_partition ) ) {
+  if ( !_Partition_Is_address_a_buffer_begin( the_partition, buffer ) ) {
     _Partition_Release( the_partition, &lock_context );
     return RTEMS_INVALID_ADDRESS;
2.26.2
