[PATCH v2] c-user: Add CONFIGURE_INIT_TASK_STORAGE_SIZE
Sebastian Huber
Tue Nov 24 07:37:11 UTC 2020
Close #4181.
c-user/config/classic-init-task.rst | 59 ++++++++++++++++++++++++++++-
1 file changed, 58 insertions(+), 1 deletion(-)
diff --git a/c-user/config/classic-init-task.rst b/c-user/config/classic-init-task.rst
index 4d3bf81..7b28acb 100644
--- a/c-user/config/classic-init-task.rst
+++ b/c-user/config/classic-init-task.rst
@@ -229,7 +229,64 @@ DESCRIPTION:
Classic API initialization task.
NOTES:
- None.
+ The
+ * ``CONFIGURE_INIT_TASK_STACK_SIZE`` and
+ * :ref:`CONFIGURE_INIT_TASK_STORAGE_SIZE`
+ configuration options are mutually exclusive.
+.. Generated from spec:/acfg/if/init-task-storage-size
+.. index:: CONFIGURE_INIT_TASK_STORAGE_SIZE
+.. _CONFIGURE_INIT_TASK_STORAGE_SIZE:
+CONFIGURE_INIT_TASK_STORAGE_SIZE
+CONSTANT:
+ ``CONFIGURE_INIT_TASK_STORAGE_SIZE``
+OPTION TYPE:
+ This configuration option is an integer define.
+DEFAULT VALUE:
+ The default value is 0.
+VALUE CONSTRAINTS:
+ The value of this configuration option shall satisfy all of the following
+ constraints:
+ * It shall be greater than or equal to :ref:`CONFIGURE_MINIMUM_TASK_STACK_SIZE`.
+ * It shall be defined using
+ :c:func:`RTEMS_TASK_STORAGE_SIZE`.
+DESCRIPTION:
+ The value of this configuration option defines the task storage size of the
+ Classic API initialization task.
+NOTES:
+ A task storage area of the specified size is statically allocated for the
+ Classic API initialization task. It is defined by ``<rtems/confdefs.h>`.
+ If this configuration option is specified, then a maximum thread-local
+ storage size defined by :ref:`CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE` is used for
+ the Classic API initialization task.
+ If this configuration option is specified, then the Classic API
+ initialization task should be accounted for in
+ :ref:`CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE`.
+ The
+ * :ref:`CONFIGURE_INIT_TASK_STACK_SIZE` and
+ * ``CONFIGURE_INIT_TASK_STORAGE_SIZE``
.. Generated from spec:/acfg/if/rtems-init-tasks-table
2.26.2
