[PATCH] spec/a53: Set conditionally failing test state
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Nov 24 13:32:17 UTC 2020
The spintrcritical03-05 and psx12 tests are known to fail on Qemu when
the host system is heavily loaded. A single run of Qemu per core
during a testsuite run tends to yield positive results, but any
additional load on a system will result in test failures.
This patch also applies the correct expected test state for intermittent
failures so that those tests will still build.
spec/build/bsps/aarch64/a53/tsta53.yml | 36 ++++++++++++++++----------
1 file changed, 22 insertions(+), 14 deletions(-)
diff --git a/spec/build/bsps/aarch64/a53/tsta53.yml b/spec/build/bsps/aarch64/a53/tsta53.yml
index a40cc8671c..9135fac7f4 100644
--- a/spec/build/bsps/aarch64/a53/tsta53.yml
+++ b/spec/build/bsps/aarch64/a53/tsta53.yml
@@ -12,20 +12,28 @@ actions:
spmisc01: exclude
# tests that are passing intermittently
- spcpucounter01: exclude
- rtmonuse: exclude
- sp37: exclude
- sp68: exclude
- sp04: exclude
- sp20: exclude
- sp69: exclude
- rtmonusxtimes01: exclude
- spedfsched02: exclude
- psxtimes01: exclude
- sprmsched01: exclude
- sptimecounter02: exclude
- sptimecounter04: exclude
- ttest02: exclude
+ spcpucounter01: indeterminate
+ rtmonuse: indeterminate
+ sp37: indeterminate
+ sp68: indeterminate
+ sp04: indeterminate
+ sp20: indeterminate
+ sp69: indeterminate
+ rtmonusxtimes01: indeterminate
+ spedfsched02: indeterminate
+ spedfsched04: indeterminate
+ psxtimes01: indeterminate
+ sprmsched01: indeterminate
+ sptimecounter02: indeterminate
+ sptimecounter04: indeterminate
+ ttest02: indeterminate
+ # tests that pass nominally, but fail under Qemu when the host is under
+ # heavy load
+ psx12: indeterminate
+ spintrcritical03: indeterminate
+ spintrcritical04: indeterminate
+ spintrcritical05: indeterminate
build-type: option
copyrights:
- Copyright (C) 2020 On-Line Applications Research (OAR)
2.20.1
