[PATCH v3 1/5] config: Clarify the use of pragmas
Wed Nov 25 07:12:19 UTC 2020
 cpukit/include/rtems/confdefs/wkspace.h | 10 +++++++++-
 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/cpukit/include/rtems/confdefs/wkspace.h b/cpukit/include/rtems/confdefs/wkspace.h
index 803d8bdc10..a08823fa17 100644
--- a/cpukit/include/rtems/confdefs/wkspace.h
+++ b/cpukit/include/rtems/confdefs/wkspace.h
@@ -137,7 +137,15 @@ const uintptr_t _Stack_Space_size = _CONFIGURE_STACK_SPACE_SIZE;
 #if defined(CONFIGURE_TASK_STACK_ALLOCATOR) \
   && defined(CONFIGURE_TASK_STACK_DEALLOCATOR)
-  /* Ignore potential warnings from the static assertions below */
+   * Ignore the following warnings from g++ and clang in the static assertions
+   * below:
+   * warning: the address of 'f()' will never be NULL [-Waddress]
+   * warning: comparison of function 'f' not equal to a null pointer is always
+   * true [-Wtautological-pointer-compare]
   #pragma GCC diagnostic push
   #pragma GCC diagnostic ignored "-Waddress"
   #pragma GCC diagnostic ignored "-Wpragmas"
2.26.2
