[PATCH] eng: Add performance specification items
Wed Nov 25 14:38:34 UTC 2020
Hello,
On 14/11/2020 12:59, Sebastian Huber wrote:
> On 13/11/2020 20:03, Gedare Bloom wrote:
>>> +Generic Non-Functional Requirement Item Type
>>> +This type refines the following types:
>>> +* :ref:`SpecTypeNonFunctionalRequirementItemType` though the
>> through?
> Nice an automatically generated typo.
>>> +  ``non-functional-type`` attribute if the value is
>>> ``build-configuration``
>>> +  ``non-functional-type`` attribute if the value is ``constraint``
>>> +  ``non-functional-type`` attribute if the value is ``design``
>>> +  ``non-functional-type`` attribute if the value is ``documentation``
>>> +  ``non-functional-type`` attribute if the value is ``interface``
>>> ``interface-requirement``
>>> ``maintainability``
>>> +  ``non-functional-type`` attribute if the value is ``performance``
>> Is there a specific kind of performance (metric) in mind? latency vs
>> throughput? Or does it not matter
> In the generic non-functional requirements, the requirements text is
> in natural language. So, you can write whatever you want.
> This patch introduces a specialization for performance requirements
> which are expressed in limits of a sample set of some measured runtime
> of an operation.
> text: |
>   When a partition has exactly
> ${../val/performance:/params/buffer-count} free
>   buffers, the ${.:limit-kind} runtime of exactly
>   ${../val/performance:/params/sample-count} successful calls to
>   ${../if/get-buffer:/name} in the ${.:/environment} shall be
>   ${.:limit-condition}.
> In this item, the corresponding test code is also included.
> test-body:
>   brief: |
>     Get a buffer.
>   code: |
>     ctx->status = rtems_partition_get_buffer( ctx->part_many,
> &ctx->buffer );
>   description: null
I think this can be checked in independent of the open discussion how a
particular performance limit is identified. The item just uses a string
to identify a set of performance limits. An open issue is how this
string is generated and what data it includes.
I already fixed the "though" -> "through" typo.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
email: sebastian.hubere at embedded-brains.de
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
