[PATCH v3] c-user: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
Gedare Bloom
gedare at rtems.org
Wed Nov 25 17:11:04 UTC 2020
On Wed, Nov 25, 2020 at 12:14 AM Sebastian Huber <
> Document new configuration option
> CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE.
> Close #4181.
> c-user/config/classic-init-task.rst | 67 ++++++++++++++++++++++++++++-
> 1 file changed, 66 insertions(+), 1 deletion(-)
> diff --git a/c-user/config/classic-init-task.rst
> b/c-user/config/classic-init-task.rst
> index 4d3bf81..d848546 100644
> --- a/c-user/config/classic-init-task.rst
> +++ b/c-user/config/classic-init-task.rst
> @@ -79,6 +79,65 @@ DESCRIPTION:
> NOTES:
> None.
> +.. Generated from spec:/acfg/if/init-task-construct-storage-size
> +.. index:: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
> +.. _CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE:
> +CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
> +CONSTANT:
> + ``CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE``
> +OPTION TYPE:
> + This configuration option is an integer define.
> +DEFAULT VALUE:
> + The default value is 0.
> +VALUE CONSTRAINTS:
> + The value of this configuration option shall satisfy all of the
> following
> + constraints:
> + * It shall be greater than or equal to
> :ref:`CONFIGURE_MINIMUM_TASK_STACK_SIZE`.
I guess the constraints don't apply to defaults? Or should an exception be
noted, like below .. "if specified"
> + * It shall be defined using
> + :c:func:`RTEMS_TASK_STORAGE_SIZE`.
> +DESCRIPTION:
> + The value of this configuration option defines the task storage size
> of the
> + Classic API initialization task.
> +NOTES:
> + If this configuration option is specified, then
> + * a task storage area of the specified size is statically allocated by
> + ``<rtems/confdefs.h>`` for the Classic API initialization task,
> + * the Classic API initialization task is constructed by
> + :c:func:`rtems_task_construct` instead of using
> + :c:func:`rtems_task_create`,
> + * the maximum thread-local storage size defined by
> + :ref:`CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE` is used for the
> Classic API
> + initialization task,
> + * the Classic API initialization task should be accounted for in
> + :ref:`CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE`, and
> + * the task storage area used for the Classic API initialization task
> is not
> + reclaimed by the system, if the task is deleted.
nit: remove comma
> + The
> + * :ref:`CONFIGURE_INIT_TASK_STACK_SIZE` and
> + * ``CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE``
> + configuration options are mutually exclusive.
> .. Generated from spec:/acfg/if/init-task-entrypoint
> .. index:: CONFIGURE_INIT_TASK_ENTRY_POINT
> @@ -229,7 +288,13 @@ DESCRIPTION:
> NOTES:
> - None.
> + The
> + * ``CONFIGURE_INIT_TASK_STACK_SIZE`` and
> + * :ref:`CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE`
> .. Generated from spec:/acfg/if/rtems-init-tasks-table
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201125/44fb014b/attachment-0001.html>
