[PATCH v4] c-user: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
Sebastian Huber
Wed Nov 25 17:39:18 UTC 2020
Document new configuration option
CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE.
Close #4181.
v4:
* Clarify default value.
* Remove comma.
c-user/config/classic-init-task.rst | 69 ++++++++++++++++++++++++++++-
1 file changed, 68 insertions(+), 1 deletion(-)
diff --git a/c-user/config/classic-init-task.rst b/c-user/config/classic-init-task.rst
index 4d3bf81..b331e40 100644
--- a/c-user/config/classic-init-task.rst
+++ b/c-user/config/classic-init-task.rst
@@ -79,6 +79,67 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/init-task-construct-storage-size
+.. index:: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
+.. _CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE:
+CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
+CONSTANT:
+ ``CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE``
+OPTION TYPE:
+ This configuration option is an integer define.
+DEFAULT VALUE:
+ This configuration option has no default value. If it is not specified, then
+ the Classic API initialization task will be created with the stack size
+ defined by the :ref:`CONFIGURE_INIT_TASK_STACK_SIZE` configuration option.
+VALUE CONSTRAINTS:
+ The value of this configuration option shall satisfy all of the following
+ constraints:
+ * It shall be greater than or equal to :ref:`CONFIGURE_MINIMUM_TASK_STACK_SIZE`.
+ * It shall be defined using
+ :c:func:`RTEMS_TASK_STORAGE_SIZE`.
+DESCRIPTION:
+ The value of this configuration option defines the task storage size of the
+ Classic API initialization task.
+NOTES:
+ If this configuration option is specified, then
+ * a task storage area of the specified size is statically allocated by
+ ``<rtems/confdefs.h>`` for the Classic API initialization task,
+ * the Classic API initialization task is constructed by
+ :c:func:`rtems_task_construct` instead of using
+ :c:func:`rtems_task_create`,
+ * the maximum thread-local storage size defined by
+ :ref:`CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE` is used for the Classic API
+ initialization task,
+ * the Classic API initialization task should be accounted for in
+ :ref:`CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE`, and
+ * the task storage area used for the Classic API initialization task is not
+ reclaimed by the system if the task is deleted.
+ The
+ * :ref:`CONFIGURE_INIT_TASK_STACK_SIZE` and
+ * ``CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE``
+ configuration options are mutually exclusive.
.. Generated from spec:/acfg/if/init-task-entrypoint
.. index:: CONFIGURE_INIT_TASK_ENTRY_POINT
@@ -229,7 +290,13 @@ DESCRIPTION:
NOTES:
- None.
+ The
+ * ``CONFIGURE_INIT_TASK_STACK_SIZE`` and
+ * :ref:`CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE`
.. Generated from spec:/acfg/if/rtems-init-tasks-table
2.26.2
