[PATCH v3 0/5] Add CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
Chris Johns
chrisj at rtems.org
Thu Nov 26 21:46:01 UTC 2020
On 25/11/20 6:12 pm, Sebastian Huber wrote:
> Currently, the Classic API initialization task is created with
> rtems_task_create(). In order to better support applications which use
> the new rtems_task_construct() directive add the
> CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE configuration option which constructs
> the Classic API initialization task with rtems_task_construct().
> v2:
> * Do not mention rtems_task_construct() in the
> CONFIGURE_INIT_TASK_STORAGE_SIZE documentation.
> * Ensure that CONFIGURE_INIT_TASK_STACK_SIZE is greater than or equal to
> CONFIGURE_MINIMUM_TASK_STACK_SIZE.
> v3:
> * Clarify use of pragmas.
> * Rename CONFIGURE_INIT_TASK_STORAGE_SIZE in
> CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE.
> Sebastian Huber (5):
> config: Clarify the use of pragmas
> Avoid INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL
> config: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
> config: Check CONFIGURE_INIT_TASK_STACK_SIZE
> Use CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
Looks good. Thanks.
