[PATCH] eng: Add performance specification items
Chris Johns
chrisj at rtems.org
Thu Nov 26 21:48:01 UTC 2020
On 26/11/20 4:08 am, Gedare Bloom wrote:
> On Wed, Nov 25, 2020 at 7:38 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>>
> wrote:
> Hello,
> On 14/11/2020 12:59, Sebastian Huber wrote:
> > On 13/11/2020 20:03, Gedare Bloom wrote:
> >>> +Generic Non-Functional Requirement Item Type
> >>> +This type refines the following types:
> >>> +* :ref:`SpecTypeNonFunctionalRequirementItemType` though the
> >> through?
> > Nice an automatically generated typo.
> >>> + ``non-functional-type`` attribute if the value is
> >>> ``build-configuration``
> >>> + ``non-functional-type`` attribute if the value is ``constraint``
> >>> + ``non-functional-type`` attribute if the value is ``design``
> >>> + ``non-functional-type`` attribute if the value is ``documentation``
> >>> + ``non-functional-type`` attribute if the value is ``interface``
> >>> ``interface-requirement``
> >>> ``maintainability``
> >>> + ``non-functional-type`` attribute if the value is ``performance``
> >> Is there a specific kind of performance (metric) in mind? latency vs
> >> throughput? Or does it not matter
> > In the generic non-functional requirements, the requirements text is
> > in natural language. So, you can write whatever you want.
> > This patch introduces a specialization for performance requirements
> > which are expressed in limits of a sample set of some measured runtime
> > of an operation.
> > text: |
> > When a partition has exactly
> > ${../val/performance:/params/buffer-count} free
> > buffers, the ${.:limit-kind} runtime of exactly
> > ${../val/performance:/params/sample-count} successful calls to
> > ${../if/get-buffer:/name} in the ${.:/environment} shall be
> > ${.:limit-condition}.
> > In this item, the corresponding test code is also included.
> > test-body:
> > brief: |
> > Get a buffer.
> > code: |
> > ctx->status = rtems_partition_get_buffer( ctx->part_many,
> > &ctx->buffer );
> > description: null
> I think this can be checked in independent of the open discussion how a
> particular performance limit is identified. The item just uses a string
> to identify a set of performance limits. An open issue is how this
> string is generated and what data it includes.
> I already fixed the "though" -> "through" typo.
> Fine with me
And me
