[PATCH v1 0/1] xilinx_zynq: Enable support for 4kiB MMU pages
Jan.Sommer at dlr.de
Fri Nov 27 08:36:20 UTC 2020
> -----Original Message-----
> From: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Sent: Friday, November 27, 2020 9:27 AM
> To: Sommer, Jan <Jan.Sommer at dlr.de>; devel at rtems.org
> Subject: Re: [PATCH v1 0/1] xilinx_zynq: Enable support for 4kiB MMU pages
> On 26/11/2020 17:08, Jan Sommer wrote:
> > This should enable the support for small MMU tables for the
> > xilinx_zynq based BSPs and enable it by default.
> I would not enable it by default, since it makes the TLB cache less efficient
> and you more frequently have to access memory to get the MMU
> descriptors. You only need the 4KiB pages, if you do some extra stuff in your
> application.
Ok, I copied the behavior from the realview BSP. Should I change it to default disabled there too?
Cheers,
Jan
> > Would this also be something to backport to RTEMS5?
> > I could prepare a patch where it is not enabled by default, so that
> > there is no difference for users of 5.1.
> This would be fine from my side.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.hubere at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
