rtems waf, examples, and RTEMS_POSIX_API
Sebastian Huber
Mon Nov 30 18:56:30 UTC 2020
Hello Joel,
On 30/11/2020 19:40, Joel Sherrill wrote:
> if rtems.check_posix(bld):
> bld.recurse('posix_hello_world')
> bld.recurse('both_hello')
if these examples don't use signals, I would just remove the check.
> I suspect rtems_check_posix() should always return true now and
> another method named rtems_check_posix_signals() should be added based
> on the flag.
> Similarly, RTEMS_POSIX_API should probably always be set and another
> macro provided for POSIX signals.
> The meaning changed without considering the impact. We need to account
> for this.
If RTEMS_POSIX_API is defined, then all POSIX APIs supported by RTEMS
are enabled. If you always define it, then this is no longer true.
Applications can use something like:
#if __RTEMS_MAJOR__ >= 5
POSIX threads are always enabled ...
#endif
I don't think we need new or changed defines.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
email: sebastian.hubere at embedded-brains.de
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
