Canonical List of BSPs with SMP Support?
Thu Oct 1 01:57:55 UTC 2020
On 1/10/20 8:29 am, Joel Sherrill wrote:
> I think we need to discuss what's the expected behavior when you configure SMP
> for a target that doesn't support SMP or BSP that doesn't in an architecture
> that does.
I believe configure process should only succeed if a valid build is possible.
These should also fail:
 ...../configure --target=powerpc-rtems6 --enable-bsp=erc32
 ...../configure --target=sparc-rtems4.11 --enable-bsp=erc32
The arch/bsp naming solves the first of these and I am not sure about the second.
