[PATCH] rtems: Canonicalize name and id check
Gedare Bloom
gedare at rtems.org
Thu Oct 1 15:50:22 UTC 2020
looks good
On Wed, Sep 30, 2020 at 8:27 AM Sebastian Huber
> Check the name followed by the id check in all create directives.
> Compare pointers against NULL. Fix formatting.
> cpukit/rtems/src/msgqconstruct.c | 8 +-
> cpukit/rtems/src/partcreate.c | 9 +-
> cpukit/rtems/src/regioncreate.c | 9 +-
> cpukit/rtems/src/taskconstruct.c | 10 +-
> .../validation/tc-message-construct-errors.c | 144 ++++++-------
> .../validation/tc-task-construct-errors.c | 192 +++++++++---------
> 6 files changed, 190 insertions(+), 182 deletions(-)
> diff --git a/cpukit/rtems/src/msgqconstruct.c b/cpukit/rtems/src/msgqconstruct.c
> index 61d0472e7c..82f6d2dfad 100644
> --- a/cpukit/rtems/src/msgqconstruct.c
> +++ b/cpukit/rtems/src/msgqconstruct.c
> @@ -63,14 +63,14 @@ rtems_status_code _Message_queue_Create(
> bool is_global;
> #endif
> - if ( id == NULL ) {
> - return RTEMS_INVALID_ADDRESS;
> if ( !rtems_is_name_valid( config->name ) ) {
> return RTEMS_INVALID_NAME;
> + if ( id == NULL ) {
> + return RTEMS_INVALID_ADDRESS;
> if ( config->maximum_pending_messages == 0 ) {
> return RTEMS_INVALID_NUMBER;
> diff --git a/cpukit/rtems/src/partcreate.c b/cpukit/rtems/src/partcreate.c
> index 9aa5e80bf1..4f43743f98 100644
> --- a/cpukit/rtems/src/partcreate.c
> +++ b/cpukit/rtems/src/partcreate.c
> @@ -38,14 +38,17 @@ rtems_status_code rtems_partition_create(
> Partition_Control *the_partition;
> - if ( !rtems_is_name_valid( name ) )
> + if ( !rtems_is_name_valid( name ) ) {
> - if ( !starting_address )
> - if ( !id )
> + if ( starting_address == NULL ) {
> if ( length == 0 )
> return RTEMS_INVALID_SIZE;
> diff --git a/cpukit/rtems/src/regioncreate.c b/cpukit/rtems/src/regioncreate.c
> index de8f165fe7..99752193ce 100644
> --- a/cpukit/rtems/src/regioncreate.c
> +++ b/cpukit/rtems/src/regioncreate.c
> @@ -38,14 +38,17 @@ rtems_status_code rtems_region_create(
> rtems_status_code return_status;
> Region_Control *the_region;
> - if ( !id )
> the_region = _Region_Allocate();
> diff --git a/cpukit/rtems/src/taskconstruct.c b/cpukit/rtems/src/taskconstruct.c
> index 76ef8ce5d6..9b1fdec3ae 100644
> --- a/cpukit/rtems/src/taskconstruct.c
> +++ b/cpukit/rtems/src/taskconstruct.c
> @@ -96,11 +96,13 @@ rtems_status_code _RTEMS_tasks_Create(
> RTEMS_API_Control *api;
> ASR_Information *asr;
> - if ( !id )
> - if ( !rtems_is_name_valid( config->name ) )
> + if ( !rtems_is_name_valid( config->name ) ) {
> * Core Thread Initialize insures we get the minimum amount of
> diff --git a/testsuites/validation/tc-message-construct-errors.c b/testsuites/validation/tc-message-construct-errors.c
> index 2dad91dae4..69378e27c7 100644
> --- a/testsuites/validation/tc-message-construct-errors.c
> +++ b/testsuites/validation/tc-message-construct-errors.c
> @@ -943,149 +943,149 @@ static const uint8_t RtemsMessageReqConstructErrors_TransitionMap[][ 1 ] = {
> RtemsMessageReqConstructErrors_Post_Status_InvAddress
> - RtemsMessageReqConstructErrors_Post_Status_InvAddress
> + RtemsMessageReqConstructErrors_Post_Status_InvName
> diff --git a/testsuites/validation/tc-task-construct-errors.c b/testsuites/validation/tc-task-construct-errors.c
> index 615186e092..981bacb07b 100644
> --- a/testsuites/validation/tc-task-construct-errors.c
> +++ b/testsuites/validation/tc-task-construct-errors.c
> @@ -1171,197 +1171,197 @@ static const uint8_t RtemsTaskReqConstructErrors_TransitionMap[][ 1 ] = {
> RtemsTaskReqConstructErrors_Post_Status_InvAddress
> - RtemsTaskReqConstructErrors_Post_Status_InvAddress
> + RtemsTaskReqConstructErrors_Post_Status_InvName
> 2.26.2
> devel mailing list
> devel at rtems.org
