[PATCH v3 06/10] bsps/arm: Break out linker script for AArch64
Kinsey Moore kinsey.moore at oarcorp.com
Sun Oct 4 04:18:50 UTC 2020
This breaks out the common section of the ARM linker script that is
usable by AArch64 BSPs to avoid duplication of the vast majority. To do
so, it was necessary to add a new linker path at bsps/shared/start.
 bsps/arm/shared/start/linkcmds.base      | 381 +-------------------
 bsps/shared/start/linkcmds-aarch.base    | 420 +++++++++++++++++++++++
 spec/build/bsps/arm/grp.yml              |   1 +
 spec/build/bsps/optldflagsbsp.yml        |   1 +
 testsuites/aclocal/rtems-bsp-linkcmds.m4 |   2 +
 testsuites/automake/compile.am           |   1 +
 6 files changed, 426 insertions(+), 380 deletions(-)
 create mode 100644 bsps/shared/start/linkcmds-aarch.base
diff --git a/bsps/arm/shared/start/linkcmds.base b/bsps/arm/shared/start/linkcmds.base
index 1f5f1ef959..d0c88f50d8 100644
--- a/bsps/arm/shared/start/linkcmds.base
+++ b/bsps/arm/shared/start/linkcmds.base
@@ -24,19 +24,10 @@ OUTPUT_FORMAT ("elf32-littlearm", "elf32-bigarm", "elf32-littlearm")
 OUTPUT_ARCH (arm)
-ENTRY (_start)
-STARTUP (start.o)
  * Global symbols that may be defined externally
-bsp_vector_table_size = DEFINED (bsp_vector_table_size) ? bsp_vector_table_size : 64;
-bsp_section_xbarrier_align = DEFINED (bsp_section_xbarrier_align) ? bsp_section_xbarrier_align : 1;
-bsp_section_robarrier_align = DEFINED (bsp_section_robarrier_align) ? bsp_section_robarrier_align : 1;
-bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1;
 bsp_stack_align = DEFINED (bsp_stack_align) ? bsp_stack_align : 8;
 bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size : 0;
@@ -48,374 +39,4 @@ bsp_stack_fiq_size = ALIGN (bsp_stack_fiq_size, bsp_stack_align);
 bsp_stack_und_size = DEFINED (bsp_stack_und_size) ? bsp_stack_und_size : 0;
 bsp_stack_und_size = ALIGN (bsp_stack_und_size, bsp_stack_align);
-bsp_stack_hyp_size = DEFINED (bsp_stack_hyp_size) ? bsp_stack_hyp_size : 0;
-bsp_stack_hyp_size = ALIGN (bsp_stack_hyp_size, bsp_stack_align);
-MEMORY {
-	UNEXPECTED_SECTIONS : ORIGIN = 0xffffffff, LENGTH = 0
-SECTIONS {
-	.start : ALIGN_WITH_INPUT {
-		bsp_section_start_begin = .;
-		KEEP (*(.bsp_start_text))
-		KEEP (*(.bsp_start_data))
-		bsp_section_start_end = .;
-	} > REGION_START AT > REGION_START
-	bsp_section_start_size = bsp_section_start_end - bsp_section_start_begin;
-	.xbarrier : ALIGN_WITH_INPUT {
-		. = ALIGN (bsp_section_xbarrier_align);
-	} > REGION_VECTOR AT > REGION_VECTOR
-	.text : ALIGN_WITH_INPUT {
-		bsp_section_text_begin = .;
-		*(.text.unlikely .text.*_unlikely)
-		*(.text .stub .text.* .gnu.linkonce.t.*)
-		/* .gnu.warning sections are handled specially by elf32.em.  */
-		*(.gnu.warning)
-		*(.glue_7t) *(.glue_7) *(.vfp11_veneer) *(.v4_bx)
-	} > REGION_TEXT AT > REGION_TEXT_LOAD
-	.init : ALIGN_WITH_INPUT {
-		KEEP (*(.init))
-	.fini : ALIGN_WITH_INPUT {
-		KEEP (*(.fini))
-		bsp_section_text_end = .;
-	bsp_section_text_size = bsp_section_text_end - bsp_section_text_begin;
-	bsp_section_text_load_begin = LOADADDR (.text);
-	bsp_section_text_load_end = bsp_section_text_load_begin + bsp_section_text_size;
-	.robarrier : ALIGN_WITH_INPUT {
-		. = ALIGN (bsp_section_robarrier_align);
-	} > REGION_RODATA AT > REGION_RODATA
-	.rodata : ALIGN_WITH_INPUT {
-		bsp_section_rodata_begin = .;
-		*(.rodata .rodata.* .gnu.linkonce.r.*)
-	} > REGION_RODATA AT > REGION_RODATA_LOAD
-	.rodata1 : ALIGN_WITH_INPUT {
-		*(.rodata1)
-	.ARM.extab : ALIGN_WITH_INPUT {
-		*(.ARM.extab* .gnu.linkonce.armextab.*)
-	.ARM.exidx : ALIGN_WITH_INPUT {
-		__exidx_start = .;
-		*(.ARM.exidx* .gnu.linkonce.armexidx.*)
-		__exidx_end = .;
-	.eh_frame : ALIGN_WITH_INPUT {
-		KEEP (*(.eh_frame))
-	.gcc_except_table : ALIGN_WITH_INPUT {
-		*(.gcc_except_table .gcc_except_table.*)
-	.tdata : ALIGN_WITH_INPUT {
-		_TLS_Data_begin = .;
-		*(.tdata .tdata.* .gnu.linkonce.td.*)
-		_TLS_Data_end = .;
-	.tbss : ALIGN_WITH_INPUT {
-		_TLS_BSS_begin = .;
-		*(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
-		_TLS_BSS_end = .;
-	_TLS_Data_size = _TLS_Data_end - _TLS_Data_begin;
-	_TLS_Data_begin = _TLS_Data_size != 0 ? _TLS_Data_begin : _TLS_BSS_begin;
-	_TLS_Data_end = _TLS_Data_size != 0 ? _TLS_Data_end : _TLS_BSS_begin;
-	_TLS_BSS_size = _TLS_BSS_end - _TLS_BSS_begin;
-	_TLS_Size = _TLS_BSS_end - _TLS_Data_begin;
-	_TLS_Alignment = MAX (ALIGNOF (.tdata), ALIGNOF (.tbss));
-	.preinit_array : ALIGN_WITH_INPUT {
-		PROVIDE_HIDDEN (__preinit_array_start = .);
-		KEEP (*(.preinit_array))
-		PROVIDE_HIDDEN (__preinit_array_end = .);
-	.init_array : ALIGN_WITH_INPUT {
-		PROVIDE_HIDDEN (__init_array_start = .);
-		KEEP (*(SORT_BY_INIT_PRIORITY(.init_array.*) SORT_BY_INIT_PRIORITY(.ctors.*)))
-		KEEP (*(.init_array EXCLUDE_FILE (*crtbegin.o *crtbegin?.o *crtend.o *crtend?.o ) .ctors))
-		PROVIDE_HIDDEN (__init_array_end = .);
-	.fini_array : ALIGN_WITH_INPUT {
-		PROVIDE_HIDDEN (__fini_array_start = .);
-		KEEP (*(SORT_BY_INIT_PRIORITY(.fini_array.*) SORT_BY_INIT_PRIORITY(.dtors.*)))
-		KEEP (*(.fini_array EXCLUDE_FILE (*crtbegin.o *crtbegin?.o *crtend.o *crtend?.o ) .dtors))
-		PROVIDE_HIDDEN (__fini_array_end = .);
-	.data.rel.ro : ALIGN_WITH_INPUT {
-		*(.data.rel.ro.local* .gnu.linkonce.d.rel.ro.local.*)
-		*(.data.rel.ro* .gnu.linkonce.d.rel.ro.*)
-	.jcr : ALIGN_WITH_INPUT {
-		KEEP (*(.jcr))
-	.interp : ALIGN_WITH_INPUT {
-		*(.interp)
-	.note.gnu.build-id : ALIGN_WITH_INPUT {
-		*(.note.gnu.build-id)
-	.hash : ALIGN_WITH_INPUT {
-		*(.hash)
-	.gnu.hash : ALIGN_WITH_INPUT {
-		*(.gnu.hash)
-	.dynsym : ALIGN_WITH_INPUT {
-		*(.dynsym)
-	.dynstr : ALIGN_WITH_INPUT {
-		*(.dynstr)
-	.gnu.version : ALIGN_WITH_INPUT {
-		*(.gnu.version)
-	.gnu.version_d : ALIGN_WITH_INPUT {
-		*(.gnu.version_d)
-	.gnu.version_r : ALIGN_WITH_INPUT {
-		*(.gnu.version_r)
-	.rel.dyn : ALIGN_WITH_INPUT {
-		*(.rel.init)
-		*(.rel.text .rel.text.* .rel.gnu.linkonce.t.*)
-		*(.rel.fini)
-		*(.rel.rodata .rel.rodata.* .rel.gnu.linkonce.r.*)
-		*(.rel.data.rel.ro* .rel.gnu.linkonce.d.rel.ro.*)
-		*(.rel.data .rel.data.* .rel.gnu.linkonce.d.*)
-		*(.rel.tdata .rel.tdata.* .rel.gnu.linkonce.td.*)
-		*(.rel.tbss .rel.tbss.* .rel.gnu.linkonce.tb.*)
-		*(.rel.ctors)
-		*(.rel.dtors)
-		*(.rel.got)
-		*(.rel.bss .rel.bss.* .rel.gnu.linkonce.b.*)
-		PROVIDE_HIDDEN (__rel_iplt_start = .);
-		*(.rel.iplt)
-		PROVIDE_HIDDEN (__rel_iplt_end = .);
-		PROVIDE_HIDDEN (__rela_iplt_start = .);
-		PROVIDE_HIDDEN (__rela_iplt_end = .);
-	.rela.dyn : ALIGN_WITH_INPUT {
-		*(.rela.init)
-		*(.rela.text .rela.text.* .rela.gnu.linkonce.t.*)
-		*(.rela.fini)
-		*(.rela.rodata .rela.rodata.* .rela.gnu.linkonce.r.*)
-		*(.rela.data .rela.data.* .rela.gnu.linkonce.d.*)
-		*(.rela.tdata .rela.tdata.* .rela.gnu.linkonce.td.*)
-		*(.rela.tbss .rela.tbss.* .rela.gnu.linkonce.tb.*)
-		*(.rela.ctors)
-		*(.rela.dtors)
-		*(.rela.got)
-		*(.rela.bss .rela.bss.* .rela.gnu.linkonce.b.*)
-		*(.rela.rtemsroset*)
-		*(.rela.rtemsrwset*)
-		*(.rela.iplt)
-	.rel.plt : ALIGN_WITH_INPUT {
-		*(.rel.plt)
-	.rela.plt : ALIGN_WITH_INPUT {
-		*(.rela.plt)
-	.plt : ALIGN_WITH_INPUT {
-		*(.plt)
-	.iplt : ALIGN_WITH_INPUT {
-		*(.iplt)
-	.dynamic : ALIGN_WITH_INPUT {
-		*(.dynamic)
-	.tm_clone_table : ALIGN_WITH_INPUT {
-		*(.tm_clone_table)
-	.got : ALIGN_WITH_INPUT {
-		*(.got.plt) *(.igot.plt) *(.got) *(.igot)
-	.rtemsroset : ALIGN_WITH_INPUT {
-		/* Special FreeBSD linker set sections */
-		__start_set_sysctl_set = .;
-		*(set_sysctl_*);
-		__stop_set_sysctl_set = .;
-		*(set_domain_*);
-		*(set_pseudo_*);
-		KEEP (*(SORT(.rtemsroset.*)))
-		bsp_section_rodata_end = .;
-	bsp_section_rodata_size = bsp_section_rodata_end - bsp_section_rodata_begin;
-	bsp_section_rodata_load_begin = LOADADDR (.rodata);
-	bsp_section_rodata_load_end = bsp_section_rodata_load_begin + bsp_section_rodata_size;
-	.rwbarrier : ALIGN_WITH_INPUT {
-		. = ALIGN (bsp_section_rwbarrier_align);
-	} > REGION_DATA AT > REGION_DATA
-	.vector : ALIGN_WITH_INPUT {
-		bsp_section_vector_begin = .;
-		. = . + DEFINED (bsp_vector_table_in_start_section) ? 0 : bsp_vector_table_size;
-		bsp_section_vector_end = .;
-	bsp_section_vector_size = bsp_section_vector_end - bsp_section_vector_begin;
-	bsp_vector_table_begin = DEFINED (bsp_vector_table_in_start_section) ? bsp_section_start_begin : bsp_section_vector_begin;
-	bsp_vector_table_end = bsp_vector_table_begin + bsp_vector_table_size;
-	.fast_text : ALIGN_WITH_INPUT {
-		bsp_section_fast_text_begin = .;
-		*(.bsp_fast_text)
-		bsp_section_fast_text_end = .;
-	} > REGION_FAST_TEXT AT > REGION_FAST_TEXT_LOAD
-	bsp_section_fast_text_size = bsp_section_fast_text_end - bsp_section_fast_text_begin;
-	bsp_section_fast_text_load_begin = LOADADDR (.fast_text);
-	bsp_section_fast_text_load_end = bsp_section_fast_text_load_begin + bsp_section_fast_text_size;
-	.fast_data : ALIGN_WITH_INPUT {
-		bsp_section_fast_data_begin = .;
-		*(.bsp_fast_data)
-		bsp_section_fast_data_end = .;
-	} > REGION_FAST_DATA AT > REGION_FAST_DATA_LOAD
-	bsp_section_fast_data_size = bsp_section_fast_data_end - bsp_section_fast_data_begin;
-	bsp_section_fast_data_load_begin = LOADADDR (.fast_data);
-	bsp_section_fast_data_load_end = bsp_section_fast_data_load_begin + bsp_section_fast_data_size;
-	.data : ALIGN_WITH_INPUT {
-		bsp_section_data_begin = .;
-		*(.data .data.* .gnu.linkonce.d.*)
-		SORT(CONSTRUCTORS)
-	} > REGION_DATA AT > REGION_DATA_LOAD
-	.data1 : ALIGN_WITH_INPUT {
-		*(.data1)
-	.rtemsrwset : ALIGN_WITH_INPUT {
-		KEEP (*(SORT(.rtemsrwset.*)))
-		bsp_section_data_end = .;
-	bsp_section_data_size = bsp_section_data_end - bsp_section_data_begin;
-	bsp_section_data_load_begin = LOADADDR (.data);
-	bsp_section_data_load_end = bsp_section_data_load_begin + bsp_section_data_size;
-	.bss : ALIGN_WITH_INPUT {
-		bsp_section_bss_begin = .;
-		*(.dynbss)
-		*(.bss .bss.* .gnu.linkonce.b.*)
-		*(COMMON)
-		bsp_section_bss_end = .;
-	} > REGION_BSS AT > REGION_BSS
-	bsp_section_bss_size = bsp_section_bss_end - bsp_section_bss_begin;
-	.rtemsstack (NOLOAD) : ALIGN_WITH_INPUT {
-		bsp_section_rtemsstack_begin = .;
-		*(SORT_BY_ALIGNMENT (SORT_BY_NAME (.rtemsstack*)))
-		bsp_section_rtemsstack_end = .;
-	} > REGION_WORK AT > REGION_WORK
-	bsp_section_rtemsstack_size = bsp_section_rtemsstack_end - bsp_section_rtemsstack_begin;
-	.work : ALIGN_WITH_INPUT {
-		 * The work section will occupy the remaining REGION_WORK region and
-		 * contains the RTEMS work space and heap.
-		bsp_section_work_begin = .;
-		. += ORIGIN (REGION_WORK) + LENGTH (REGION_WORK) - ABSOLUTE (.);
-		bsp_section_work_end = .;
-	bsp_section_work_size = bsp_section_work_end - bsp_section_work_begin;
-	.stack : ALIGN_WITH_INPUT {
-		 * The stack section will occupy the remaining REGION_STACK region and may
-		 * contain the task stacks.  Depending on the region distribution this
-		 * section may be of zero size.
-		bsp_section_stack_begin = .;
-		. += ORIGIN (REGION_STACK) + LENGTH (REGION_STACK) - ABSOLUTE (.);
-		bsp_section_stack_end = .;
-	} > REGION_STACK AT > REGION_STACK
-	bsp_section_stack_size = bsp_section_stack_end - bsp_section_stack_begin;
-	.nocache : ALIGN_WITH_INPUT {
-		bsp_section_nocache_begin = .;
-		*(SORT_BY_ALIGNMENT (SORT_BY_NAME (.bsp_nocache*)))
-		bsp_section_nocache_end = .;
-	} > REGION_NOCACHE AT > REGION_NOCACHE_LOAD
-	bsp_section_nocache_size = bsp_section_nocache_end - bsp_section_nocache_begin;
-	bsp_section_nocache_load_begin = LOADADDR (.nocache);
-	bsp_section_nocache_load_end = bsp_section_nocache_load_begin + bsp_section_nocache_size;
-	.nocachenoload (NOLOAD) : ALIGN_WITH_INPUT {
-		bsp_section_nocachenoload_begin = .;
-		*(SORT_BY_ALIGNMENT (SORT_BY_NAME (.bsp_noload_nocache*)))
-		bsp_section_nocacheheap_begin = .;
-		. += ORIGIN (REGION_NOCACHE) + LENGTH (REGION_NOCACHE) - ABSOLUTE (.);
-		bsp_section_nocacheheap_end = .;
-		bsp_section_nocachenoload_end = .;
-	bsp_section_nocacheheap_size = bsp_section_nocacheheap_end - bsp_section_nocacheheap_begin;
-	bsp_section_nocachenoload_size = bsp_section_nocachenoload_end - bsp_section_nocachenoload_begin;
-	/* FIXME */
-	RamBase = ORIGIN (REGION_WORK);
-	RamSize = LENGTH (REGION_WORK);
-	RamEnd = RamBase + RamSize;
-	WorkAreaBase = bsp_section_work_begin;
-	HeapSize = 0;
-	/* Stabs debugging sections.  */
-	.stab          0 : { *(.stab) }
-	.stabstr       0 : { *(.stabstr) }
-	.stab.excl     0 : { *(.stab.excl) }
-	.stab.exclstr  0 : { *(.stab.exclstr) }
-	.stab.index    0 : { *(.stab.index) }
-	.stab.indexstr 0 : { *(.stab.indexstr) }
-	.comment       0 : { *(.comment) }
-	/* DWARF debug sections.
-	   Symbols in the DWARF debugging sections are relative to the beginning
-	   of the section so we begin them at 0.  */
-	/* DWARF 1 */
-	.debug          0 : { *(.debug) }
-	.line           0 : { *(.line) }
-	/* GNU DWARF 1 extensions */
-	.debug_srcinfo  0 : { *(.debug_srcinfo) }
-	.debug_sfnames  0 : { *(.debug_sfnames) }
-	/* DWARF 1.1 and DWARF 2 */
-	.debug_aranges  0 : { *(.debug_aranges) }
-	.debug_pubnames 0 : { *(.debug_pubnames) }
-	/* DWARF 2 */
-	.debug_info     0 : { *(.debug_info .gnu.linkonce.wi.*) }
-	.debug_abbrev   0 : { *(.debug_abbrev) }
-	.debug_line     0 : { *(.debug_line) }
-	.debug_frame    0 : { *(.debug_frame) }
-	.debug_str      0 : { *(.debug_str) }
-	.debug_loc      0 : { *(.debug_loc) }
-	.debug_macinfo  0 : { *(.debug_macinfo) }
-	/* SGI/MIPS DWARF 2 extensions */
-	.debug_weaknames 0 : { *(.debug_weaknames) }
-	.debug_funcnames 0 : { *(.debug_funcnames) }
-	.debug_typenames 0 : { *(.debug_typenames) }
-	.debug_varnames  0 : { *(.debug_varnames) }
-	/* DWARF 3 */
-	.debug_pubtypes 0 : { *(.debug_pubtypes) }
-	.debug_ranges   0 : { *(.debug_ranges) }
-	/* DWARF extension */
-	.debug_macro    0 : { *(.debug_macro) }
-	.ARM.attributes 0 : { KEEP (*(.ARM.attributes)) KEEP (*(.gnu.attributes)) }
-	.note.gnu.arm.ident 0 : { KEEP (*(.note.gnu.arm.ident)) }
-	/DISCARD/ : { *(.note.GNU-stack) *(.gnu_debuglink) *(.gnu.lto_*) }
-	 * This is a RTEMS specific section to catch all unexpected input
-	 * sections.  In case you get an error like
-	 *   "section `.unexpected_sections' will not fit in region
-	 *   `UNEXPECTED_SECTIONS'"
-	 * you have to figure out the offending input section and add it to the
-	 * appropriate output section definition above.
-	.unexpected_sections : { *(*) } > UNEXPECTED_SECTIONS
+INCLUDE linkcmds-aarch.base
diff --git a/bsps/shared/start/linkcmds-aarch.base b/bsps/shared/start/linkcmds-aarch.base
new file mode 100644
index 0000000000..e69461a434
--- /dev/null
+++ b/bsps/shared/start/linkcmds-aarch.base
@@ -0,0 +1,420 @@
+ * @file
+ * @ingroup bsp_linker
+ * @brief Linker command base file for AArch32 and AArch64.
+ * Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+ENTRY (_start)
+STARTUP (start.o)
+ * Global symbols that may be defined externally
+bsp_vector_table_size = DEFINED (bsp_vector_table_size) ? bsp_vector_table_size : 64;
+bsp_section_xbarrier_align = DEFINED (bsp_section_xbarrier_align) ? bsp_section_xbarrier_align : 1;
+bsp_section_robarrier_align = DEFINED (bsp_section_robarrier_align) ? bsp_section_robarrier_align : 1;
+bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1;
+bsp_stack_hyp_size = DEFINED (bsp_stack_hyp_size) ? bsp_stack_hyp_size : 0;
+bsp_stack_hyp_size = ALIGN (bsp_stack_hyp_size, bsp_stack_align);
+MEMORY {
+	UNEXPECTED_SECTIONS : ORIGIN = 0xffffffff, LENGTH = 0
+SECTIONS {
+	.start : ALIGN_WITH_INPUT {
+		bsp_section_start_begin = .;
+		KEEP (*(.bsp_start_text))
+		KEEP (*(.bsp_start_data))
+		bsp_section_start_end = .;
+	} > REGION_START AT > REGION_START
+	bsp_section_start_size = bsp_section_start_end - bsp_section_start_begin;
+	.xbarrier : ALIGN_WITH_INPUT {
+		. = ALIGN (bsp_section_xbarrier_align);
+	} > REGION_VECTOR AT > REGION_VECTOR
+	.text : ALIGN_WITH_INPUT {
+		bsp_section_text_begin = .;
+		*(.text.unlikely .text.*_unlikely)
+		*(.text .stub .text.* .gnu.linkonce.t.*)
+		/* .gnu.warning sections are handled specially by elf32.em.  */
+		*(.gnu.warning)
+		*(.glue_7t) *(.glue_7) *(.vfp11_veneer) *(.v4_bx)
+	} > REGION_TEXT AT > REGION_TEXT_LOAD
+	.init : ALIGN_WITH_INPUT {
+		KEEP (*(.init))
+	.fini : ALIGN_WITH_INPUT {
+		KEEP (*(.fini))
+		bsp_section_text_end = .;
+	bsp_section_text_size = bsp_section_text_end - bsp_section_text_begin;
+	bsp_section_text_load_begin = LOADADDR (.text);
+	bsp_section_text_load_end = bsp_section_text_load_begin + bsp_section_text_size;
+	.robarrier : ALIGN_WITH_INPUT {
+		. = ALIGN (bsp_section_robarrier_align);
+	} > REGION_RODATA AT > REGION_RODATA
+	.rodata : ALIGN_WITH_INPUT {
+		bsp_section_rodata_begin = .;
+		*(.rodata .rodata.* .gnu.linkonce.r.*)
+	} > REGION_RODATA AT > REGION_RODATA_LOAD
+	.rodata1 : ALIGN_WITH_INPUT {
+		*(.rodata1)
+	.ARM.extab : ALIGN_WITH_INPUT {
+		*(.ARM.extab* .gnu.linkonce.armextab.*)
+	.ARM.exidx : ALIGN_WITH_INPUT {
+		__exidx_start = .;
+		*(.ARM.exidx* .gnu.linkonce.armexidx.*)
+		__exidx_end = .;
+	.eh_frame : ALIGN_WITH_INPUT {
+		KEEP (*(.eh_frame))
+	.gcc_except_table : ALIGN_WITH_INPUT {
+		*(.gcc_except_table .gcc_except_table.*)
+	.tdata : ALIGN_WITH_INPUT {
+		_TLS_Data_begin = .;
+		*(.tdata .tdata.* .gnu.linkonce.td.*)
+		_TLS_Data_end = .;
+	.tbss : ALIGN_WITH_INPUT {
+		_TLS_BSS_begin = .;
+		*(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
+		_TLS_BSS_end = .;
+	_TLS_Data_size = _TLS_Data_end - _TLS_Data_begin;
+	_TLS_Data_begin = _TLS_Data_size != 0 ? _TLS_Data_begin : _TLS_BSS_begin;
+	_TLS_Data_end = _TLS_Data_size != 0 ? _TLS_Data_end : _TLS_BSS_begin;
+	_TLS_BSS_size = _TLS_BSS_end - _TLS_BSS_begin;
+	_TLS_Size = _TLS_BSS_end - _TLS_Data_begin;
+	_TLS_Alignment = MAX (ALIGNOF (.tdata), ALIGNOF (.tbss));
+	.preinit_array : ALIGN_WITH_INPUT {
+		PROVIDE_HIDDEN (__preinit_array_start = .);
+		KEEP (*(.preinit_array))
+		PROVIDE_HIDDEN (__preinit_array_end = .);
+	.init_array : ALIGN_WITH_INPUT {
+		PROVIDE_HIDDEN (__init_array_start = .);
+		KEEP (*(SORT_BY_INIT_PRIORITY(.init_array.*) SORT_BY_INIT_PRIORITY(.ctors.*)))
+		KEEP (*(.init_array EXCLUDE_FILE (*crtbegin.o *crtbegin?.o *crtend.o *crtend?.o ) .ctors))
+		PROVIDE_HIDDEN (__init_array_end = .);
+	.fini_array : ALIGN_WITH_INPUT {
+		PROVIDE_HIDDEN (__fini_array_start = .);
+		KEEP (*(SORT_BY_INIT_PRIORITY(.fini_array.*) SORT_BY_INIT_PRIORITY(.dtors.*)))
+		KEEP (*(.fini_array EXCLUDE_FILE (*crtbegin.o *crtbegin?.o *crtend.o *crtend?.o ) .dtors))
+		PROVIDE_HIDDEN (__fini_array_end = .);
+	.data.rel.ro : ALIGN_WITH_INPUT {
+		*(.data.rel.ro.local* .gnu.linkonce.d.rel.ro.local.*)
+		*(.data.rel.ro* .gnu.linkonce.d.rel.ro.*)
+	.jcr : ALIGN_WITH_INPUT {
+		KEEP (*(.jcr))
+	.interp : ALIGN_WITH_INPUT {
+		*(.interp)
+	.note.gnu.build-id : ALIGN_WITH_INPUT {
+		*(.note.gnu.build-id)
+	.hash : ALIGN_WITH_INPUT {
+		*(.hash)
+	.gnu.hash : ALIGN_WITH_INPUT {
+		*(.gnu.hash)
+	.dynsym : ALIGN_WITH_INPUT {
+		*(.dynsym)
+	.dynstr : ALIGN_WITH_INPUT {
+		*(.dynstr)
+	.gnu.version : ALIGN_WITH_INPUT {
+		*(.gnu.version)
+	.gnu.version_d : ALIGN_WITH_INPUT {
+		*(.gnu.version_d)
+	.gnu.version_r : ALIGN_WITH_INPUT {
+		*(.gnu.version_r)
+	.rel.dyn : ALIGN_WITH_INPUT {
+		*(.rel.init)
+		*(.rel.text .rel.text.* .rel.gnu.linkonce.t.*)
+		*(.rel.fini)
+		*(.rel.rodata .rel.rodata.* .rel.gnu.linkonce.r.*)
+		*(.rel.data.rel.ro* .rel.gnu.linkonce.d.rel.ro.*)
+		*(.rel.data .rel.data.* .rel.gnu.linkonce.d.*)
+		*(.rel.tdata .rel.tdata.* .rel.gnu.linkonce.td.*)
+		*(.rel.tbss .rel.tbss.* .rel.gnu.linkonce.tb.*)
+		*(.rel.ctors)
+		*(.rel.dtors)
+		*(.rel.got)
+		*(.rel.bss .rel.bss.* .rel.gnu.linkonce.b.*)
+		PROVIDE_HIDDEN (__rel_iplt_start = .);
+		*(.rel.iplt)
+		PROVIDE_HIDDEN (__rel_iplt_end = .);
+		PROVIDE_HIDDEN (__rela_iplt_start = .);
+		PROVIDE_HIDDEN (__rela_iplt_end = .);
+	.rela.dyn : ALIGN_WITH_INPUT {
+		*(.rela.init)
+		*(.rela.text .rela.text.* .rela.gnu.linkonce.t.*)
+		*(.rela.fini)
+		*(.rela.rodata .rela.rodata.* .rela.gnu.linkonce.r.*)
+		*(.rela.data .rela.data.* .rela.gnu.linkonce.d.*)
+		*(.rela.tdata .rela.tdata.* .rela.gnu.linkonce.td.*)
+		*(.rela.tbss .rela.tbss.* .rela.gnu.linkonce.tb.*)
+		*(.rela.ctors)
+		*(.rela.dtors)
+		*(.rela.got)
+		*(.rela.bss .rela.bss.* .rela.gnu.linkonce.b.*)
+		*(.rela.rtemsroset*)
+		*(.rela.rtemsrwset*)
+		*(.rela.iplt)
+	.rel.plt : ALIGN_WITH_INPUT {
+		*(.rel.plt)
+	.rela.plt : ALIGN_WITH_INPUT {
+		*(.rela.plt)
+	.plt : ALIGN_WITH_INPUT {
+		*(.plt)
+	.iplt : ALIGN_WITH_INPUT {
+		*(.iplt)
+	.dynamic : ALIGN_WITH_INPUT {
+		*(.dynamic)
+	.tm_clone_table : ALIGN_WITH_INPUT {
+		*(.tm_clone_table)
+	.got : ALIGN_WITH_INPUT {
+		*(.got.plt) *(.igot.plt) *(.got) *(.igot)
+	.rtemsroset : ALIGN_WITH_INPUT SUBALIGN(4) {
+		/* Special FreeBSD linker set sections */
+		__start_set_sysctl_set = .;
+		*(set_sysctl_*);
+		__stop_set_sysctl_set = .;
+		*(set_domain_*);
+		*(set_pseudo_*);
+		KEEP (*(SORT(.rtemsroset.*)))
+		bsp_section_rodata_end = .;
+	bsp_section_rodata_size = bsp_section_rodata_end - bsp_section_rodata_begin;
+	bsp_section_rodata_load_begin = LOADADDR (.rodata);
+	bsp_section_rodata_load_end = bsp_section_rodata_load_begin + bsp_section_rodata_size;
+	.rwbarrier : ALIGN_WITH_INPUT {
+		. = ALIGN (bsp_section_rwbarrier_align);
+	} > REGION_DATA AT > REGION_DATA
+	.vector : ALIGN_WITH_INPUT {
+		bsp_section_vector_begin = .;
+		. = . + DEFINED (bsp_vector_table_in_start_section) ? 0 : bsp_vector_table_size;
+		bsp_section_vector_end = .;
+	bsp_section_vector_size = bsp_section_vector_end - bsp_section_vector_begin;
+	bsp_vector_table_begin = DEFINED (bsp_vector_table_in_start_section) ? bsp_section_start_begin : bsp_section_vector_begin;
+	bsp_vector_table_end = bsp_vector_table_begin + bsp_vector_table_size;
+	.fast_text : ALIGN_WITH_INPUT {
+		bsp_section_fast_text_begin = .;
+		*(.bsp_fast_text)
+		bsp_section_fast_text_end = .;
+	} > REGION_FAST_TEXT AT > REGION_FAST_TEXT_LOAD
+	bsp_section_fast_text_size = bsp_section_fast_text_end - bsp_section_fast_text_begin;
+	bsp_section_fast_text_load_begin = LOADADDR (.fast_text);
+	bsp_section_fast_text_load_end = bsp_section_fast_text_load_begin + bsp_section_fast_text_size;
+	.fast_data : ALIGN_WITH_INPUT {
+		bsp_section_fast_data_begin = .;
+		*(.bsp_fast_data)
+		bsp_section_fast_data_end = .;
+	} > REGION_FAST_DATA AT > REGION_FAST_DATA_LOAD
+	bsp_section_fast_data_size = bsp_section_fast_data_end - bsp_section_fast_data_begin;
+	bsp_section_fast_data_load_begin = LOADADDR (.fast_data);
+	bsp_section_fast_data_load_end = bsp_section_fast_data_load_begin + bsp_section_fast_data_size;
+	.data : ALIGN_WITH_INPUT {
+		bsp_section_data_begin = .;
+		*(.data .data.* .gnu.linkonce.d.*)
+		SORT(CONSTRUCTORS)
+	} > REGION_DATA AT > REGION_DATA_LOAD
+	.data1 : ALIGN_WITH_INPUT {
+		*(.data1)
+	.rtemsrwset : ALIGN_WITH_INPUT SUBALIGN(4) {
+		KEEP (*(SORT(.rtemsrwset.*)))
+		bsp_section_data_end = .;
+	bsp_section_data_size = bsp_section_data_end - bsp_section_data_begin;
+	bsp_section_data_load_begin = LOADADDR (.data);
+	bsp_section_data_load_end = bsp_section_data_load_begin + bsp_section_data_size;
+	.bss : ALIGN_WITH_INPUT {
+		bsp_section_bss_begin = .;
+		*(.dynbss)
+		*(.bss .bss.* .gnu.linkonce.b.*)
+		*(COMMON)
+		bsp_section_bss_end = .;
+	} > REGION_BSS AT > REGION_BSS
+	bsp_section_bss_size = bsp_section_bss_end - bsp_section_bss_begin;
+	.rtemsstack (NOLOAD) : ALIGN_WITH_INPUT {
+		bsp_section_rtemsstack_begin = .;
+		*(SORT_BY_ALIGNMENT (SORT_BY_NAME (.rtemsstack*)))
+		bsp_section_rtemsstack_end = .;
+	} > REGION_WORK AT > REGION_WORK
+	bsp_section_rtemsstack_size = bsp_section_rtemsstack_end - bsp_section_rtemsstack_begin;
+	.work : ALIGN_WITH_INPUT {
+		 * The work section will occupy the remaining REGION_WORK region and
+		 * contains the RTEMS work space and heap.
+		bsp_section_work_begin = .;
+		. += ORIGIN (REGION_WORK) + LENGTH (REGION_WORK) - ABSOLUTE (.);
+		bsp_section_work_end = .;
+	bsp_section_work_size = bsp_section_work_end - bsp_section_work_begin;
+	.stack : ALIGN_WITH_INPUT {
+		 * The stack section will occupy the remaining REGION_STACK region and may
+		 * contain the task stacks.  Depending on the region distribution this
+		 * section may be of zero size.
+		bsp_section_stack_begin = .;
+		. += ORIGIN (REGION_STACK) + LENGTH (REGION_STACK) - ABSOLUTE (.);
+		bsp_section_stack_end = .;
+	} > REGION_STACK AT > REGION_STACK
+	bsp_section_stack_size = bsp_section_stack_end - bsp_section_stack_begin;
+	.nocache : ALIGN_WITH_INPUT {
+		bsp_section_nocache_begin = .;
+		*(SORT_BY_ALIGNMENT (SORT_BY_NAME (.bsp_nocache*)))
+		bsp_section_nocache_end = .;
+	} > REGION_NOCACHE AT > REGION_NOCACHE_LOAD
+	bsp_section_nocache_size = bsp_section_nocache_end - bsp_section_nocache_begin;
+	bsp_section_nocache_load_begin = LOADADDR (.nocache);
+	bsp_section_nocache_load_end = bsp_section_nocache_load_begin + bsp_section_nocache_size;
+	.nocachenoload (NOLOAD) : ALIGN_WITH_INPUT {
+		bsp_section_nocachenoload_begin = .;
+		*(SORT_BY_ALIGNMENT (SORT_BY_NAME (.bsp_noload_nocache*)))
+		bsp_section_nocacheheap_begin = .;
+		. += ORIGIN (REGION_NOCACHE) + LENGTH (REGION_NOCACHE) - ABSOLUTE (.);
+		bsp_section_nocacheheap_end = .;
+		bsp_section_nocachenoload_end = .;
+	bsp_section_nocacheheap_size = bsp_section_nocacheheap_end - bsp_section_nocacheheap_begin;
+	bsp_section_nocachenoload_size = bsp_section_nocachenoload_end - bsp_section_nocachenoload_begin;
+	/* FIXME */
+	RamBase = ORIGIN (REGION_WORK);
+	RamSize = LENGTH (REGION_WORK);
+	RamEnd = RamBase + RamSize;
+	WorkAreaBase = bsp_section_work_begin;
+	HeapSize = 0;
+	/* Stabs debugging sections.  */
+	.stab          0 : { *(.stab) }
+	.stabstr       0 : { *(.stabstr) }
+	.stab.excl     0 : { *(.stab.excl) }
+	.stab.exclstr  0 : { *(.stab.exclstr) }
+	.stab.index    0 : { *(.stab.index) }
+	.stab.indexstr 0 : { *(.stab.indexstr) }
+	.comment       0 : { *(.comment) }
+	/* DWARF debug sections.
+	   Symbols in the DWARF debugging sections are relative to the beginning
+	   of the section so we begin them at 0.  */
+	/* DWARF 1 */
+	.debug          0 : { *(.debug) }
+	.line           0 : { *(.line) }
+	/* GNU DWARF 1 extensions */
+	.debug_srcinfo  0 : { *(.debug_srcinfo) }
+	.debug_sfnames  0 : { *(.debug_sfnames) }
+	/* DWARF 1.1 and DWARF 2 */
+	.debug_aranges  0 : { *(.debug_aranges) }
+	.debug_pubnames 0 : { *(.debug_pubnames) }
+	/* DWARF 2 */
+	.debug_info     0 : { *(.debug_info .gnu.linkonce.wi.*) }
+	.debug_abbrev   0 : { *(.debug_abbrev) }
+	.debug_line     0 : { *(.debug_line) }
+	.debug_frame    0 : { *(.debug_frame) }
+	.debug_str      0 : { *(.debug_str) }
+	.debug_loc      0 : { *(.debug_loc) }
+	.debug_macinfo  0 : { *(.debug_macinfo) }
+	/* SGI/MIPS DWARF 2 extensions */
+	.debug_weaknames 0 : { *(.debug_weaknames) }
+	.debug_funcnames 0 : { *(.debug_funcnames) }
+	.debug_typenames 0 : { *(.debug_typenames) }
+	.debug_varnames  0 : { *(.debug_varnames) }
+	/* DWARF 3 */
+	.debug_pubtypes 0 : { *(.debug_pubtypes) }
+	.debug_ranges   0 : { *(.debug_ranges) }
+	/* DWARF extension */
+	.debug_macro    0 : { *(.debug_macro) }
+	.ARM.attributes 0 : { KEEP (*(.ARM.attributes)) KEEP (*(.gnu.attributes)) }
+	.note.gnu.arm.ident 0 : { KEEP (*(.note.gnu.arm.ident)) }
+	/DISCARD/ : { *(.note.GNU-stack) *(.gnu_debuglink) *(.gnu.lto_*) }
+	 * This is a RTEMS specific section to catch all unexpected input
+	 * sections.  In case you get an error like
+	 *   "section `.unexpected_sections' will not fit in region
+	 *   `UNEXPECTED_SECTIONS'"
+	 * you have to figure out the offending input section and add it to the
+	 * appropriate output section definition above.
+	.unexpected_sections : { *(*) } > UNEXPECTED_SECTIONS
diff --git a/spec/build/bsps/arm/grp.yml b/spec/build/bsps/arm/grp.yml
index dd7694be83..5610b87b33 100644
--- a/spec/build/bsps/arm/grp.yml
+++ b/spec/build/bsps/arm/grp.yml
@@ -55,6 +55,7 @@ install:
   - bsps/arm/shared/start/linkcmds.armv4
   - bsps/arm/shared/start/linkcmds.armv7m
   - bsps/arm/shared/start/linkcmds.base
+  - bsps/shared/start/linkcmds-aarch.base
 ldflags: []
 links: []
 type: build
diff --git a/spec/build/bsps/optldflagsbsp.yml b/spec/build/bsps/optldflagsbsp.yml
index 74f15bd559..97ea71fec4 100644
--- a/spec/build/bsps/optldflagsbsp.yml
+++ b/spec/build/bsps/optldflagsbsp.yml
@@ -1,6 +1,7 @@
 SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
 actions:
 - set-value:
+  - -L${TOP}/bsps/shared/start
   - -L${TOP}/bsps/${ARCH}/shared/start
   - -L${TOP}/bsps/${ARCH}/${BSP_FAMILY}/start
 - substitute: null
diff --git a/testsuites/aclocal/rtems-bsp-linkcmds.m4 b/testsuites/aclocal/rtems-bsp-linkcmds.m4
index 0ad8867f9d..d5e7049e7f 100644
--- a/testsuites/aclocal/rtems-bsp-linkcmds.m4
+++ b/testsuites/aclocal/rtems-bsp-linkcmds.m4
@@ -18,8 +18,10 @@ AC_MSG_CHECKING([BSP linkcmds])
 RTEMS_BSP_ARCH_PATH="${RTEMS_SOURCE_ROOT}/bsps/${RTEMS_CPU}"
 RTEMS_BSP_ARCH_LINKCMDS_PATH="${RTEMS_BSP_ARCH_PATH}/shared/start"
+RTEMS_BSP_SHARED_LINKCMDS_PATH="${RTEMS_SOURCE_ROOT}/bsps/shared/start"
 RTEMS_BSP_LIBBSP_PATH="${RTEMS_BUILD_ROOT}/lib/libbsp/${RTEMS_CPU}/${RTEMS_BSP_FAMILY}"
 AC_SUBST(RTEMS_BSP_ARCH_LINKCMDS_PATH)
+AC_SUBST(RTEMS_BSP_SHARED_LINKCMDS_PATH)
 AC_SUBST(RTEMS_BSP_LIBBSP_PATH)
diff --git a/testsuites/automake/compile.am b/testsuites/automake/compile.am
index 66ea9a8421..e049e6db4b 100644
--- a/testsuites/automake/compile.am
+++ b/testsuites/automake/compile.am
@@ -20,6 +20,7 @@ AM_LDFLAGS += -B$(RTEMS_ROOT)lib/libbsp/@RTEMS_CPU@/@RTEMS_BSP_FAMILY@
 AM_LDFLAGS += $(GCCSPECS)
 AM_LDFLAGS += -L$(RTEMS_ROOT)cpukit
 AM_LDFLAGS += -L$(RTEMS_BSP_ARCH_LINKCMDS_PATH)
+AM_LDFLAGS += -L$(RTEMS_BSP_SHARED_LINKCMDS_PATH)
 AM_LDFLAGS += $(TEST_LD_FLAGS)
 LDADD =
2.20.1
