[PATCH v3 07/10] spmsgq_err01: Use correct max values and fix 64bit
Kinsey Moore kinsey.moore at oarcorp.com
Sun Oct 4 04:18:51 UTC 2020
Fix spmsgq_err01 on systems with 64-bit pointers and correct max value
mismatches and inaccuracies that are more noticable on 64-bit systems.
 testsuites/sptests/spmsgq_err01/init.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/testsuites/sptests/spmsgq_err01/init.c b/testsuites/sptests/spmsgq_err01/init.c
index c68d30da16..9a6a8855be 100644
--- a/testsuites/sptests/spmsgq_err01/init.c
+++ b/testsuites/sptests/spmsgq_err01/init.c
@@ -101,7 +101,7 @@ rtems_task Init(
   /* not enough memory for messages */
   status = rtems_message_queue_create(
     Queue_name[ 1 ],
-    SIZE_MAX / ( sizeof( uintptr_t ) + sizeof( CORE_message_queue_Buffer ) ),
+    UINT_MAX / ( sizeof( uintptr_t ) + sizeof( CORE_message_queue_Buffer ) ),
     1,
     RTEMS_DEFAULT_ATTRIBUTES,
     &Queue_id[ 1 ]
@@ -116,8 +116,8 @@ rtems_task Init(
   /* too large a request for messages */
     Queue_name[ 1 ],
-    INT_MAX,
-    INT_MAX,
+    UINT_MAX,
+    SIZE_MAX - sizeof( uintptr_t ) + 1 - sizeof( CORE_message_queue_Buffer ),
     &Queue_id[ 1 ]
2.20.1
