[PATCH v3 1/2] cpu-supplement: Fix formatting and missing words
Kinsey Moore
kinsey.moore at oarcorp.com
Sun Oct 4 04:23:08 UTC 2020
cpu-supplement/arm.rst | 18 +++++++++---------
1 file changed, 9 insertions(+), 9 deletions(-)
diff --git a/cpu-supplement/arm.rst b/cpu-supplement/arm.rst
index 63aa532..ac9e8c6 100644
--- a/cpu-supplement/arm.rst
+++ b/cpu-supplement/arm.rst
@@ -34,10 +34,10 @@ for the values.
Count Leading Zeroes Instruction
-The ARMv5 and later has the count leading zeroes ``clz`` instruction which
-could be used to speed up the find first bit operation. The use of this
-instruction should significantly speed up the scheduling associated with a
-thread blocking. This is currently not used.
+The ARMv5 and later instruction sets have the count leading zeroes ``clz``
+instruction which could be used to speed up the find first bit operation. The
+use of this instruction should significantly speed up the scheduling associated
+with a thread blocking. This is currently not used.
Floating Point Unit
@@ -130,7 +130,7 @@ Memory Model
A flat 32-bit memory model is supported. The board support package must take
-care about the MMU if necessary.
+care of initializing the MMU if necessary.
Interrupt Processing
@@ -194,13 +194,13 @@ actions:
Symmetric Multiprocessing
-SMP is supported on ARMv7-A. Available platforms are
+SMP is supported on ARMv7-A. Available platforms are:
-- Altera Cyclone V,
+- Altera Cyclone V
-- NXP i.MX 7, and
+- NXP i.MX 7
-- Xilinx Zynq.
+- Xilinx Zynq
Thread-Local Storage
2.20.1
