[PATCH v4] cpukit/librcxx: Add a C++ thread interface with attributes
Sun Oct 4 16:52:43 UTC 2020
It's OK to commit.
riscv and sparc leon3 should work with clang. But I also wondered  (didn't
mentioned) if you had tried this as a native wrapper. It may be testable on
FreeBSD or Linux as well. Ensuring that may give it a little more
visibility. One of the things users seem to like is the high portability.
--joel
On Sun, Oct 4, 2020 at 3:49 AM Chris Johns <chrisj at rtems.org> wrote:
> On 3/10/20 10:21 pm, Joel Sherrill wrote:
> > Will this show up in documentation somewhere?
> Yes this is what I am planing. I was thinking of adding a Languages
> section to
> the User manual and this would be part of the C++ section. We would need C
> and
> Ada added.
> > It does seem like we should say something about C++ threads and this.
> Yes I agree.
> > What about C11 threads?
> That is C? This is about c++17 support.
> > Test doesn't appear to cover much.
> It tests:
> - The standard C++ thread equivalent interface works:
>   thread_default = rtems::thread::thread(&test_thread::body, this,
>                                          "default",  1, 'D');
> This checks the right constructor is selected. This thread should have the
> same
> thread attributes and the standard library call.
> - Inherit the current thread attributes with this single line:
>   rtems::thread::attributes attr;
> - Modify the attributes:
>   attr.set_name("RTHREAD");
>   attr.set_priority(5);
>   attr.set_stack_size(32 * 1024);
> - Create a thread with these new attributes:
>   thread_attr = rtems::thread::thread(attr, &test_thread::body, this,
>                                       "attr", 2, 'R');
> Th test makes sure the hidden complexity needed to handle the variable
> template
> arguments, move those to a new thread context and then have them made
> available
> to thread body all work.
> - Some more of the attributes could be tested.
> > More interspersed
> Great, comments with them. Thanks for the review.
> Chris
> > On Sat, Oct 3, 2020, 1:23 AM <chrisj at rtems.org <mailto:chrisj at rtems.org>>
> wrote:
> >     From: Chris Johns <chrisj at rtems.org <mailto:chrisj at rtems.org>>
> >      cpukit/include/rtems/c++/error            |  65 +++
> >      cpukit/include/rtems/c++/thread           | 469
> >      cpukit/librtemscxx/error.cc               |  76 ++++
> >      cpukit/librtemscxx/thread.cc              | 416 +++++++++++++++++++
> >      spec/build/cpukit/grp.yml                 |   2 +
> >      spec/build/cpukit/librtemscxx.yml         |  21 +
> >      spec/build/testsuites/libtests/grp.yml    |   2 +
> >      spec/build/testsuites/libtests/rcxx01.yml |  22 +
> >      testsuites/libtests/rcxx01/init.c         |  69 ++++
> >      testsuites/libtests/rcxx01/rcxx01.doc     |  16 +
> >      testsuites/libtests/rcxx01/rcxx01.scn     |  13 +
> >      testsuites/libtests/rcxx01/thread.cc      |  90 +++++
> >      12 files changed, 1261 insertions(+)
> >      create mode 100644 cpukit/include/rtems/c++/error
> >      create mode 100644 cpukit/include/rtems/c++/thread
> >      create mode 100644 cpukit/librtemscxx/error.cc
> >      create mode 100644 cpukit/librtemscxx/thread.cc
> >      create mode 100644 spec/build/cpukit/librtemscxx.yml
> >      create mode 100644 spec/build/testsuites/libtests/rcxx01.yml
> >      create mode 100644 testsuites/libtests/rcxx01/init.c
> >      create mode 100644 testsuites/libtests/rcxx01/rcxx01.doc
> >      create mode 100644 testsuites/libtests/rcxx01/rcxx01.scn
> >      create mode 100644 testsuites/libtests/rcxx01/thread.cc
> >     diff --git a/cpukit/include/rtems/c++/error
> b/cpukit/include/rtems/c++/error
> >     new file mode 100644
> >     index 0000000000..8b9d875e0f
> >     --- /dev/null
> >     +++ b/cpukit/include/rtems/c++/error
> >     @@ -0,0 +1,65 @@
> >     +/* -*- C++ -*-
> >     + * SPDX-License-Identifier: BSD-2-Clause
> >     + * Copyright (C) 2020 Chris Johns (http://contemporary.software)
> >     + * Redistribution and use in source and binary forms, with or
> without
> >     + * modification, are permitted provided that the following
> conditions
> >     + * are met:
> >     + * 1. Redistributions of source code must retain the above copyright
> >     + *    notice, this list of conditions and the following disclaimer.
> >     + * 2. Redistributions in binary form must reproduce the above
> copyright
> in the
> >     + *    documentation and/or other materials provided with the
> distribution.
> >     + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
> CONTRIBUTORS "AS IS"
> >     + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
> LIMITED TO, THE
> >     + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
> PARTICULAR PURPOSE
> >     + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> >     + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
> OR
> >     + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
> PROCUREMENT OF
> >     + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> >     + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
> WHETHER IN
> >     + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> >     + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
> ADVISED OF THE
> >     + * POSSIBILITY OF SUCH DAMAGE.
> >     + * @file
> >     + * @ingroup RTEMSC++
> >     + * RTEMS Error exception.
> >     +#if !defined(RTEMS_CXX_ERROR)
> >     +#define RTEMS_CXX_ERROR
> >     +#include <stdexcept>
> >     +#include <string>
> >     +#include <rtems.h>
> >     +namespace rtems
> >     +  class runtime_error :
> >     +    public std::runtime_error
> >     +    const rtems_status_code sc;
> >     +  public:
> >     +    runtime_error (const rtems_status_code sc);
> >     +    runtime_error (const rtems_status_code sc, const std::string&
> what);
> >     +    runtime_error (const rtems_status_code sc, const char* what);
> >     +    ~runtime_error ();
> >     +   * Throw a rtems::runtime_error exception if the RTEMS status
> code is
> >     +   * not RTEMS_SUCCESSFUL.
> >     +  void runtime_error_check (const rtems_status_code sc);
> >     +  void runtime_error_check (const rtems_status_code sc, const
> std::string&
> >     what);
> >     +  void runtime_error_check (const rtems_status_code sc, const char*
> what);
> >     +#endif
> >     diff --git a/cpukit/include/rtems/c++/thread
> b/cpukit/include/rtems/c++/thread
> >     index 0000000000..c3f18ab3cf
> >     --- /dev/null
> >     +++ b/cpukit/include/rtems/c++/thread
> >     @@ -0,0 +1,469 @@
> >     +/* -*- C++ -*-
> without
> conditions
> >     + * are met:
> copyright
> in the
> distribution.
> LIMITED TO, THE
> PARTICULAR PURPOSE
> CONTRIBUTORS BE
> OR
> PROCUREMENT OF
> BUSINESS
> WHETHER IN
> OTHERWISE)
> ADVISED OF THE
> >     + * @file
> >     + * The C++ standard thread support with thread attribute control.
> >     + * The code requires the `-std=c++17` option to access
> `std::invoke()`.
> >     +#if !defined(RTEMS_CXX_THREAD)
> >     +#define RTEMS_CXX_THREAD
> >     +#include <functional>
> >     +#include <iostream>
> >     +#include <string>
> >     +#include <thread>
> >     +#include <utility>
> >     +namespace rtems
> >     +  namespace thread
> >     +     * @brief Manage the attributes of a thread.
> >     +    class attributes
> >     +    public:
> >     +       * The schedular modes.
> >     +      enum sched_mode {
> >     +        sched_inherit,    /**< Inhert the scheduler */
> >     +        sched_explicit    /**< Explicitly set the scheduler */
> >     +       * The schedular policies.
> >     +      enum sched_policy {
> >     +        sched_other,      /**< Other scheduler policy */
> >     +        sched_fifo,       /**< FIFO scheduler policy */
> >     +        sched_roundrobin, /**< Roundrobin scheduler policy */
> >     +        sched_sporadic    /**< Sporadic scheduler policy */
> >     +       * Construct a thread attributes object with the current
> settings of the
> >     +       * executing thread. The stack size is set to the configured
> minimum
> >     +       * stack size.
> >     +      attributes ();
> >     +       * Copy construct the thread attributes.
> >     +       * @param attr The attributes to copy.
> >     +      attributes (const attributes& attr);
> >     +       * Set the name of the thread. The thread is a classic API
> thread and
> >     +       * the name is only 4 characters.
> > The thread appears to be a POSIX thread.
> It uses `pthread_setname_np` to set the name.
> >     +       * @param name The name as a string.
> >     +      void set_name (const std::string& name);
> thread and
> >     +      void set_name (const char* name);
> >     +       * Get the name of the thread.
> >     +       * @retval const std::string& The name of the thread.
> >     +      const std::string& get_name () const;
> >     +       * Set the priority of the thread.
> >     +       * @param priority The POSIX API priority of the thread.
> >     +      void set_priority (int priority);
> >     +       * Get the POSIX API priority of the thread.
> >     +       * @retval int The POSIX API thread priority.
> >     +      int get_priority () const;
> >     +       * Set the stack size. If the size is less than the
> configured minimum
> >     +       * the minimum value is used.
> >     +       * @param size The stack size in bytes.
> >     +      void set_stack_size (size_t size);
> >     +       * Get the stack size.
> >     +       * @retval size_t The stack size in bytes.
> >     +      size_t get_stack_size () const;
> >     +       * Set the scheduler name. If not set no scheduler is set.
> >     +       * @parrm scheduler The name of the scheduler.
> >     +      void set_scheduler (const std::string& scheduler);
> >     +      void set_scheduler (const char* scheduler);
> >     +       * Get scheduler name.
> >     +      const std::string& get_scheduler ();
> >     +       * Get the attrobutes' scheduler mode for the thread.
> >     +       * @return sched_mode The attributes; scheduler mode
> >     +      sched_mode get_scheduler_mode () const;
> >     +       * Set the scheduler policy for the thread. This call sets the
> >     +       * schedular mode to @ref sched_explicit.
> >     +       * @param policy The scheduler policy.
> >     +      void set_scheduler_policy (sched_policy policyr);
> >     +       * Get the scheduler policy for the thread.
> >     +      sched_policy get_scheduler_policy () const;
> >     +       * Commit any changes to the executing thread. @note only the
> priority
> >     +       * and modes of a thread can be changedTheeeeee name and
> stack size are
> >     +       * ignored.
> > Is there a line break missing before the note?
> I will fix this.
> >     +      void commit ();
> >     +       * Update the attribute values from the executing thread. The
> attributes
> >     +       * are updated from the current thread when constructed and
> the values
> >     +       * returned are those held since then. If another thread
> changes the
> >     +       * attributes of the current thread those changes will not be
> seen until
> >     +       * this method is called. Except for the name and stack size
> any local
> >     +       * changes made will lost then the update call is made.
> >     +      void update ();
> >     +       * Copy operator.
> >     +      attributes& operator= (const attributes& attr);
> >     +       * The comparision operator does not check the name or stack
> size
> >     +       * of a thread.
> >     +      bool operator== (const attributes& attr) const;
> >     +    private:
> >     +      std::string  name;        /**< Name of the thread */
> >     +      int          priority;    /**< POSIX API priority */
> >     +      size_t       stack_size;  /**< Stack size in bytes */
> >     +      std::string  scheduler;   /**< Name of the scheduler */
> >     +      sched_mode   mode;        /**< Scheduler's mode */
> >     +      sched_policy policy;      /**< Scheduler's policy */
> >     +      /* affinity, cpu set size is? */
> >     +     * @brief Create a thread with thread attributes.
> >     +     * Create a thread optionally with thread attributes. The usage
> of this
> >     +     * class follows the C++ standard for std::thread. The standard
> support
> >     +     * for creating a thread does not let you control the
> attributes of a
> >     +     * thread and control is important in embedded real-time
> >     +     * applications. This class lets you control a thread
> attributes and use
> >     +     * the extensive an excellent thread support the C++ standard
> provides.
> >     +     * There is no indication attribute support for threads will be
> added to
> >     +     * the C++ standard and what it will look like. The support
> provided here
> >     +     * is designed to make as little impact on a code base as
> possible. While
> >     +     * the attributes supported are specific to RTEMS they are
> common to all
> >     +     * embedded operating systems.
> >     +     * The support provided here is specific to GCC due to the use
> of some
> >     +     * non-standard interfaces to get the indices of the template
> argument
> >     +     * pack in new thread's context. A standards only solution
> would be
> >     +     * preferred.
> > Since we have clang on some targets, any idea what it does and if this
> will
> > work? Should it disable itself for not GCC?
> Are there clang tools available? I would have tested clang if I could but
> I have
> no idea how to build clang for RTEMS and which BSPs are supported?
> I would prefer we support clang be supported. It should be hard to make
> this
> happen if you are able to follow how these templates work. It does get
> involved.
> >     +    class thread
> >     +      friend void* thread_generic_entry (void* arg);
> >     +       * Base state class to interface to derived template of the
> thread
> >     +       * state from the generic entry point for the thread.
> >     +      struct state_base
> >     +        virtual ~state_base ();
> >     +        virtual const attributes get_attributes () = 0;
> >     +        virtual void run () = 0;
> >     +       * The state is passed to the new thread context as a unique
> >     +       * pointer. This handles the hand over and clean up.
> >     +      using state_ptr = std::unique_ptr<state_base>;
> >     +    public:
> >     +       * Template check to see if the first argument of a thread is
> a set of
> >     +       * attributes.
> >     +      template <typename A, class DecayA = typename
> std::decay<A>::type>
> >     +      using enable_if_attributes = typename std::enable_if
> >     +        <std::is_same<DecayA, attributes>::value>::type;
> >     +       * We need our own id type so the thread class can access the
> pthread
> >     +       * handle to initialise it.
> >     +      class id {
> >     +      public:
> >     +        id () noexcept : id_ (0) { }
> >     +        explicit id (pthread_t id_) : id_ (id_) { }
> >     +      private:
> >     +        pthread_t id_;
> >     +        friend class thread;
> >     +        friend bool operator== (thread::id l, thread::id r)
> noexcept;
> >     +        template<class CharT, class Traits>
> >     +       friend std::basic_ostream<CharT, Traits>&
> >     +       operator<< (std::basic_ostream<CharT, Traits>& out,
> thread::id id_);
> >     +       * The default thread constructions.
> >     +      thread () noexcept = default;
> >     +       * The std::thread equivilant constructor. The attributes
> will be the
> > Equivalent
> I have spell checked the patch and fixed the mistakes.
> >     +       * same as the executing thread with a default thread name
> and the
> >     +       * configured minimum stack size.
> >     +      template<typename F, typename... Args>
> >     +      explicit thread (F&& func, Args&&... args);
> >     +       * Create a thread with the provided attributes. The entry
> point and
> >     +       * optional arguments are the same as std::thread.
> >     +      template <typename A, typename F, typename ...Args,
> >     +                class = enable_if_attributes<A>>
> >     +      explicit thread (A&& attr, F&& func, Args&&... args);
> >     +       * Move the thread id to this instance.
> >     +      thread& operator= (thread&& thread_);
> >     +      void swap(thread& thread_) noexcept;
> >     +      bool joinable() const noexcept;
> >     +       * Constrain use. These are not available.
> >     +      thread (thread&) = delete;
> >     +      thread (const thread&) = delete;
> >     +      thread (const thread&&) = delete;
> >     +      thread& operator= (const thread&) = delete;
> >     +      std::thread::id get_id() const noexcept;
> >     +    private:
> >     +      id id_;
> >     +       * Invoke the thread's entry point with the parameter pack in
> the new
> >     +       * thread's context. This object holds the parameters copied
> onto the
> >     +       * new thread's stack making them available to entry point
> routine.
> >     +      template<typename Parms>
> >     +      struct invoker {
> >     +        Parms p;
> >     +        template<size_t Index>
> >     +        static std::__tuple_element_t<Index, Parms>&& declval ();
> >     +        template<size_t... Ind>
> >     +        auto invoke (std::_Index_tuple<Ind...>)
> >     +          noexcept (noexcept (std::invoke (declval<Ind>()...)))
> >     +          -> decltype (std::invoke (declval<Ind> ()...)) {
> >     +          return std::invoke (std::get<Ind> (std::move (p))...);
> >     +        using indices =
> >     +          typename
> >     std::_Build_index_tuple<std::tuple_size<Parms>::value>::__type;
> >     +        void run () {
> >     +          invoke (indices ());
> >     +       * The state holds the invoker with the parameters. The
> generic entry
> >     +       * point calls the virtual methods to get the attributes and
> to run the
> >     +       * new thread in the new thread's context..
> >     +      template<typename Invoker>
> >     +      struct state : state_base {
> >     +        const attributes attr;
> >     +        Invoker          i;
> >     +        state (const attributes& attr, Invoker&& i)
> >     +          : attr (attr),
> >     +            i (std::forward<Invoker> (i)) {
> >     +        const attributes get_attributes () override {
> >     +          return attr;
> >     +        void run () override {
> >     +          i.run ();
> >     +       * Make the state. This dynamic memory is managed by the
> unique pointer
> >     +       * and is passed to the generic thread entry point.
> >     +      static state_ptr
> >     +      make_state (const attributes& attr, Invoker&& i) {
> >     +        using state_impl = state<Invoker>;
> >     +        return state_ptr{ new state_impl (attr,
> std::forward<Invoker> (i)) };
> >     +       * Decay the parameters so they can be correctly packed into
> the
> >     +       * parameter tuple.
> >     +      template<typename... T>
> >     +      using decayed_tuple = std::tuple<typename
> std::decay<T>::type...>;
> >     +       * Make the invoker with the parameters.
> >     +      static invoker<decayed_tuple<F, Args...>>
> >     +      make_invoker (F&& func, Args&&... args)
> >     +        return {
> >     +          decayed_tuple<F, Args...> {
> >     +            std::forward<F> (func), std::forward<Args> (args)...
> >     +       * Create and start the thread.
> >     +      void start_thread (state_ptr s);
> >     +    template <class T>
> >     +    inline typename std::decay<T>::type
> >     +    decay_copy (T&& t) {
> >     +      return std::forward<T> (t);
> >     +    thread::thread (F&& func, Args&&... args)
> >     +      : id_ (0)  {
> >     +      attributes attr;
> >     +      start_thread (
> >     +        make_state (attr,
> >     +                    make_invoker (decay_copy (std::forward<F>
> (func)),
> >     +                                  decay_copy (std::forward<Args>
> (args))...))
> >     +    template<typename A, typename F, typename... Args,
> >     +             class = thread::enable_if_attributes<A>>
> >     +    thread::thread (A&& attr, F&& func, Args&&... args)
> >     +      : id_ (0) {
> >     +      start_thread (
> >     +        make_state (attr,
> (func)),
> (args))...))
> >     +    inline std::thread::id thread::get_id() const noexcept {
> >     +      return std::thread::id (id_.id_);
> >     +    inline bool
> >     +    operator== (thread::id l, thread::id r) noexcept {
> >     +      return l.id_ == r.id_;
> >     +    inline bool
> >     +    operator!= (thread::id l, thread::id r) noexcept {
> >     +      return !(l == r);
> >     +    template<class C, class T>
> >     +    inline std::basic_ostream<C, T>&
> >     +    operator<< (std::basic_ostream<C, T>& out, thread::id id_) {
> >     +      return out << std::thread::id (id_.id_);
> >     +#endif
> >     diff --git a/cpukit/librtemscxx/error.cc
> b/cpukit/librtemscxx/error.cc
> >     index 0000000000..c7b749803f
> >     --- /dev/null
> >     +++ b/cpukit/librtemscxx/error.cc
> >     @@ -0,0 +1,76 @@
> without
> conditions
> >     + * are met:
> copyright
> in the
> distribution.
> LIMITED TO, THE
> PARTICULAR PURPOSE
> CONTRIBUTORS BE
> OR
> PROCUREMENT OF
> BUSINESS
> WHETHER IN
> OTHERWISE)
> ADVISED OF THE
> >     +#include <rtems/c++/error>
> >     +namespace rtems
> >     +  runtime_error::runtime_error (const rtems_status_code sc)
> >     +    : std::runtime_error (::rtems_status_text (sc)),
> >     +      sc (sc)
> >     +  runtime_error::runtime_error (const rtems_status_code sc,
> >     +                                const std::string&      what)
> >     +    : std::runtime_error (what + ": " + ::rtems_status_text (sc)),
> >     +      sc (sc)
> >     +                                const char*             what)
> >     +    : std::runtime_error (std::string (what) + ": " +
> ::rtems_status_text
> >     (sc)),
> >     +      sc (sc)
> >     +  runtime_error::~runtime_error()
> >     +  void
> >     +  runtime_error_check (const rtems_status_code sc)
> >     +    if (sc != RTEMS_SUCCESSFUL)
> >     +      throw runtime_error (sc);
> >     +  void
> >     +  runtime_error_check (const rtems_status_code sc, const
> std::string& what)
> >     +      throw runtime_error (sc, what);
> >     +  void
> >     +  runtime_error_check (const rtems_status_code sc, const char* what)
> >     diff --git a/cpukit/librtemscxx/thread.cc
> b/cpukit/librtemscxx/thread.cc
> >     index 0000000000..79375a713c
> >     --- /dev/null
> >     +++ b/cpukit/librtemscxx/thread.cc
> >     @@ -0,0 +1,416 @@
> without
> conditions
> >     + * are met:
> copyright
> in the
> distribution.
> LIMITED TO, THE
> PARTICULAR PURPOSE
> CONTRIBUTORS BE
> OR
> PROCUREMENT OF
> BUSINESS
> WHETHER IN
> OTHERWISE)
> ADVISED OF THE
> >     +#if !defined(_GNU_SOURCE)
> >     +#define _GNU_SOURCE
> >     +#endif
> >     +#include <system_error>
> >     +#include <rtems/c++/thread>
> >     +#include <pthread.h>
> >     +#include <rtems.h>
> >     +#if HAVE_GET_SCHEDULER_NAME
> >     +extern "C" bool get_scheduler_name (rtems_id sid, char* name);
> >     +#endif
> >     +bool get_scheduler_name (rtems_id sid, char* name)
> >     +  name[0] = 'N';
> >     +  name[1] = 'O';
> >     +  name[2] = 'P';
> >     +  name[3] = '\0';
> >     +  return true;
> >     +#endif
> >     +namespace rtems
> >     +  namespace thread
> >     +    void
> >     +    system_error_check (int ec, const char* what)
> >     +      if (ec != 0)
> >     +        throw std::system_error (ec, std::system_category(), what);
> >     +    attributes::attributes ()
> >     +      : priority (-1),
> >     +        stack_size (RTEMS_MINIMUM_STACK_SIZE),
> >     +        mode (sched_inherit),
> >     +        policy (sched_fifo)
> >     +      update ();
> >     +    attributes::attributes (const attributes& attr)
> >     +      : name (attr.name <http://attr.name>),
> >     +        priority (attr.priority),
> >     +        stack_size (attr.stack_size),
> >     +        scheduler (attr.scheduler),
> >     +        mode (attr.mode),
> >     +        policy (attr.policy)
> >     +    void
> >     +    attributes::set_name (const std::string& name_)
> >     +      name = name_;
> >     +    void
> >     +    attributes::set_name (const char* name_)
> >     +      name = name_;
> >     +    attributes::get_name () const
> >     +      return name;
> >     +    void
> >     +    attributes::set_priority (int priority_)
> >     +      priority = priority_;
> >     +    int
> >     +    attributes::get_priority () const
> >     +      return priority;
> >     +    void
> >     +    attributes::set_stack_size(size_t size)
> >     +      stack_size = size;
> >     +    size_t
> >     +    attributes::get_stack_size () const
> >     +      return stack_size;
> >     +    void
> >     +    attributes::set_scheduler (const std::string& scheduler_)
> >     +      scheduler = scheduler_;
> >     +    void
> >     +    attributes::set_scheduler (const char* scheduler_)
> >     +    attributes::get_scheduler ()
> >     +      return scheduler;
> >     +    attributes::sched_mode
> >     +    attributes::get_scheduler_mode () const
> >     +      return mode;
> >     +    void
> >     +    attributes::set_scheduler_policy (sched_policy policy_)
> >     +      mode = sched_explicit;
> >     +      policy = policy_;
> >     +    attributes::sched_policy
> >     +    attributes::get_scheduler_policy () const
> >     +      return policy;
> >     +    void
> >     +    attributes::commit ()
> >     +      pthread_t pid = ::pthread_self ();
> >     +      system_error_check (::pthread_setname_np (pid, name.c_str ()),
> >     +                          "getting name");
> >     +      int                spolicy;
> >     +      struct sched_param sched_param;
> >     +      system_error_check (::pthread_getschedparam (::pthread_self
> >     +                                                   &spolicy,
> >     +                                                   &sched_param),
> >     +                          "getting scheduler parameters");
> >     +      switch (policy) {
> >     +      case sched_other:
> >     +        spolicy = SCHED_OTHER;
> >     +        break;
> >     +      case sched_fifo:
> >     +        spolicy = SCHED_FIFO;
> >     +        break;
> >     +      case sched_roundrobin:
> >     +        spolicy = SCHED_RR;
> >     +        break;
> >     +      case sched_sporadic:
> >     +        spolicy = SCHED_SPORADIC;
> >     +        break;
> >     +      default:
> >     +        system_error_check (EINVAL, "get scheduler policy");
> >     +        break;
> >     +      sched_param.sched_priority = priority;
> >     +      system_error_check (::pthread_setschedparam (::pthread_self
> >     +                                                   spolicy,
> >     +                                                   &sched_param),
> >     +      if (!scheduler.empty ()) {
> >     +        char sname[4] = { ' ', ' ', ' ', ' ' };
> >     +        for (size_t c = 0; c < sizeof (sname); ++c) {
> >     +          if (c >= scheduler.length ())
> >     +            break;
> >     +          sname[c] = scheduler[c];
> >     +        rtems_name scheduler_name = rtems_build_name (sname[0],
> >     +                                                      sname[1],
> >     +                                                      sname[2],
> >     +                                                      sname[3]);
> >     +        rtems_id scheduler_id;
> >     +        runtime_error_check (::rtems_scheduler_ident
> (scheduler_name,
> &scheduler_id),
> >     +                             "get scheduler id");
> >     +        // runtime_error_check (::rtems_task_set_scheduler
> (RTEMS_SELF,
> scheduler_id,
> >     +        //                                                  1),
> >     +        //                      "set scheduler id");
> >     +    void
> >     +    attributes::update ()
> >     +      char buf[32];
> >     +      system_error_check (::pthread_getname_np (::pthread_self (),
> >     +                                                buf,
> >     +                                                sizeof (buf)),
> >     +                          "getting name");
> >     +      name = buf;
> >     +      int                spolicy;
> >     +                                                   &spolicy,
> >     +                                                   &sched_param),
> >     +      switch (spolicy) {
> >     +      case SCHED_OTHER:
> >     +        policy = sched_other;
> >     +        break;
> >     +      case SCHED_FIFO:
> >     +        policy = sched_fifo;
> >     +        break;
> >     +      case SCHED_RR:
> >     +        policy = sched_roundrobin;
> >     +        break;
> >     +      case SCHED_SPORADIC:
> >     +        policy = sched_sporadic;
> >     +        break;
> >     +      default:
> >     +        break;
> >     +      priority = sched_param.sched_priority;
> >     +      pthread_attr_t attr;
> >     +      system_error_check (::pthread_getattr_np (::pthread_self (),
> &attr),
> >     +                          "getting thread attributes");
> >     +      system_error_check (::pthread_attr_getstacksize (&attr,
> &stack_size),
> >     +                          "getting stack size");
> >     +      int inheritsched = 0;
> >     +      system_error_check (::pthread_attr_getinheritsched (&attr,
> >     &inheritsched),
> >     +                          "getting inherited sheduler mode");
> >     +      switch (inheritsched) {
> >     +      case PTHREAD_INHERIT_SCHED:
> >     +        mode = sched_inherit;
> >     +        break;
> >     +      case PTHREAD_EXPLICIT_SCHED:
> >     +        break;
> >     +      default:
> >     +        system_error_check (EINVAL, "get scheduler mode");
> >     +        break;
> >     +      runtime_error_check (::rtems_task_get_scheduler (RTEMS_SELF,
> >     &scheduler_id));
> >     +      char name[5];
> >     +      if (!get_scheduler_name (scheduler_id, &name[0]))
> >     +        system_error_check (ENOENT, "get scheduler name");
> >     +      scheduler = name;
> >     +#endif
> >     +    attributes&
> >     +    attributes::operator= (const attributes& attr)
> >     +      name = attr.name <http://attr.name>;
> >     +      priority = attr.priority;
> >     +      stack_size = attr.stack_size;
> >     +      mode = attr.mode;
> >     +      policy = attr.policy;
> >     +      return *this;
> >     +    bool
> >     +    attributes::operator== (const attributes& attr) const
> >     +      return
> >     +        name == attr.name <http://attr.name> &&
> >     +        priority == attr.priority &&
> >     +        stack_size == attr.stack_size &&
> >     +        mode == attr.mode &&
> >     +        policy == attr.policy;
> >     +    void*
> >     +    thread_generic_entry (void* arg)
> >     +      thread::state_ptr s{ static_cast<thread::state_base*> (arg) };
> >     +      try {
> >     +        s->run ();
> >     +      } catch (...) {
> >     +        std::terminate ();
> >     +      return nullptr;
> >     +    thread&
> >     +    thread::operator= (thread&& thread_)
> >     +      if (joinable ())
> >     +      swap(thread_);
> >     +      return *this;
> >     +    void
> >     +    thread::swap(thread& thread_) noexcept
> >     +      std::swap(id_, thread_.id_);
> >     +    bool
> >     +    thread::joinable() const noexcept
> >     +      return !(id_ == id());
> >     +    thread::state_base::~state_base () = default;
> >     +    void
> >     +    thread::start_thread (thread::state_ptr s)
> >     +      const attributes attr = s->get_attributes ();
> >     +      pthread_attr_t pattr;
> >     +      system_error_check (::pthread_attr_init (&pattr),
> >     +                          "attribute init");
> >     +      system_error_check (::pthread_attr_setdetachstate (&pattr,
> >      PTHREAD_CREATE_DETACHED),
> >     +                          "set detached state");
> >     +      struct sched_param param;
> >     +      param.sched_priority = attr.get_priority ();
> >     +      system_error_check (::pthread_attr_setschedparam (&pattr,
> &param),
> >     +                          "set ");
> >     +      int spolicy;
> >     +      switch (attr.get_scheduler_policy ()) {
> >     +      case attributes::sched_other:
> >     +        break;
> >     +      case attributes::sched_roundrobin:
> >     +        break;
> >     +      case attributes::sched_sporadic:
> >     +        break;
> >     +      default:
> >     +        break;
> >     +      system_error_check (::pthread_attr_setschedpolicy (&pattr,
> spolicy),
> >     +                          "set scheduler policy");
> >     +      if (attr.get_scheduler_mode () == attributes::sched_inherit)
> >     +        ::pthread_attr_setinheritsched (&pattr,
> PTHREAD_INHERIT_SCHED);
> >     +      else
> PTHREAD_EXPLICIT_SCHED);
> >     +      system_error_check (::pthread_attr_setstacksize(&pattr,
> attr.get_stack_size ()),
> >     +                          "set stack size");
> >     +       * Hold the new thread in the state's run handler until the
> rest
> >     +       * of the thread is set up after the create call.
> >     +      system_error_check (::pthread_create (&id_.id_,
> >     +                                            &pattr,
> >     +                                            thread_generic_entry,
> >     +                                            s.get ()),
> >     +                          "create thread");
> >     +      system_error_check (::pthread_setname_np (id_.id_,
> >     +                                                attr.get_name
> ().c_str ()),
> >     +                          "setting thread name");
> >     +      ::pthread_attr_destroy (&pattr);
> >     +      s.release ();
> >     diff --git a/spec/build/cpukit/grp.yml b/spec/build/cpukit/grp.yml
> >     index 3a285d03fc..91fa2d9625 100644
> >     --- a/spec/build/cpukit/grp.yml
> >     +++ b/spec/build/cpukit/grp.yml
> >     @@ -27,6 +27,8 @@ links:
> >        uid: libpppd
> >      - role: build-dependency
> >        uid: librtemscpu
> >     +- role: build-dependency
> >     +  uid: librtemscxx
> >        uid: librtemsdfltcfg
> >     diff --git a/spec/build/cpukit/librtemscxx.yml
> >     b/spec/build/cpukit/librtemscxx.yml
> >     index 0000000000..769e5a7498
> >     --- /dev/null
> >     +++ b/spec/build/cpukit/librtemscxx.yml
> >     @@ -0,0 +1,21 @@
> >     +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> >     +build-type: library
> >     +cflags: []
> >     +copyrights:
> >     +- Copyright (C) 2020 Chris Johns (http://contemporary.software)
> >     +cppflags: []
> >     +cxxflags: [-std=c++17]
> >     +enabled-by: true
> >     +includes: []
> >     +install:
> >     +- destination: ${BSP_INCLUDEDIR}
> >     +  source:
> >     +  - cpukit/include/rtems/c++/error
> >     +  - cpukit/include/rtems/c++/thread
> >     +install-path: ${BSP_LIBDIR}
> >     +links: []
> >     +source:
> >     +- cpukit/librtemscxx/error.cc
> >     +- cpukit/librtemscxx/thread.cc
> >     +target: rtemscxx
> >     +type: build
> >     diff --git a/spec/build/testsuites/libtests/grp.yml
> >     b/spec/build/testsuites/libtests/grp.yml
> >     index 2b1f2727cf..b9ca014b0d 100644
> >     --- a/spec/build/testsuites/libtests/grp.yml
> >     +++ b/spec/build/testsuites/libtests/grp.yml
> >     @@ -214,6 +214,8 @@ links:
> >        uid: pwdgrp02
> >        uid: rbheap01
> >     +  uid: rcxx01
> >        uid: read
> >     diff --git a/spec/build/testsuites/libtests/rcxx01.yml
> >     b/spec/build/testsuites/libtests/rcxx01.yml
> >     index 0000000000..6d69feeb83
> >     --- /dev/null
> >     +++ b/spec/build/testsuites/libtests/rcxx01.yml
> >     @@ -0,0 +1,22 @@
> >     +build-type: test-program
> >     +cflags: []
> >     +copyrights:
> >     +cppflags: []
> >     +enabled-by: true
> >     +features: c cxx cxxprogram
> >     +includes: []
> >     +ldflags: []
> >     +links: []
> >     +source:
> >     +- testsuites/libtests/rcxx01/init.c
> >     +- testsuites/libtests/rcxx01/thread.cc
> >     +stlib: []
> >     +target: testsuites/libtests/rcxx01.exe
> >     +type: build
> >     +use-after: []
> >     +use-before:
> >     +- rtemsdefaultconfig
> >     +- rtemscxx
> >     diff --git a/testsuites/libtests/rcxx01/init.c
> >     b/testsuites/libtests/rcxx01/init.c
> >     index 0000000000..b3dfa9f0c1
> >     --- /dev/null
> >     +++ b/testsuites/libtests/rcxx01/init.c
> >     @@ -0,0 +1,69 @@
> >     + * Copyright (c) 2020 Chris Johns (http://contemporary.software)
> >     + * All rights reserved.
> >     +#ifdef HAVE_CONFIG_H
> >     +#include "config.h"
> >     +#endif
> >     +#include <bsp.h>
> >     +#include <stdlib.h>
> >     +#include <stdio.h>
> >     +#include <sys/types.h>
> >     +#include <sys/stat.h>
> >     +#include <fcntl.h>
> >     +#include <sys/ioctl.h>
> >     +#include <unistd.h>
> >     +#include "tmacros.h"
> >     +const char rtems_test_name[] = "RCXX 1";
> >     +/* forward declarations to avoid warnings */
> >     +rtems_task Init(rtems_task_argument argument);
> >     +void rcxx_run_test(void);
> >     +rtems_task Init(
> >     +  rtems_task_argument ignored
> >     +  TEST_BEGIN();
> >     +  rcxx_run_test();
> >     +  TEST_END();
> >     +  rtems_test_exit( 0 );
> >     +/* configuration information */
> >     +#include <rtems/serial_mouse.h>
> >     +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> >     +#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> >     +#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 5
> >     +#define CONFIGURE_MEMORY_OVERHEAD           (2024)
> >     +#define CONFIGURE_MAXIMUM_TASKS  1
> >     +#define CONFIGURE_MAXIMUM_POSIX_THREADS 2
> >     +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> >     +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> >     +#define CONFIGURE_INIT_TASK_STACK_SIZE (10U * 1024U)
> >     +#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
> >     +#include <rtems/confdefs.h>
> >     +/* end of file */
> >     diff --git a/testsuites/libtests/rcxx01/rcxx01.doc
> >     b/testsuites/libtests/rcxx01/rcxx01.doc
> >     index 0000000000..3fd41b029b
> >     --- /dev/null
> >     +++ b/testsuites/libtests/rcxx01/rcxx01.doc
> >     @@ -0,0 +1,16 @@
> >     +# Copyright (c) 2019 Chris Johns <chrisj at rtems.org <mailto:
> >     +This file describes the directives and concepts tested by this test
> set.
> >     +test set name: rcxx01
> >     +directives:
> >     +  rtems::thread::thread
> >     +  rtems::thread::attributes
> >     +concepts:
> >     ++ Create a thread using the default method, ie like std::thread.
> >     +* Create a thread with changed attributes.
> >     diff --git a/testsuites/libtests/rcxx01/rcxx01.scn
> >     b/testsuites/libtests/rcxx01/rcxx01.scn
> >     index 0000000000..37bf2d3f7a
> >     --- /dev/null
> >     +++ b/testsuites/libtests/rcxx01/rcxx01.scn
> >     @@ -0,0 +1,13 @@
> >     +*** BEGIN OF TEST RCXX 1 ***
> >     +*** TEST VERSION: 5.0.0.7ba04a62227286dcd3da20ea7319d9c64b8f5fd1
> >     +*** TEST STATE: EXPECTED-PASS
> >     +*** TEST BUILD:
> >     +*** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB
> >     ceb811fa19ddcfdd449a8da8f1107e6e592727b6, Newlib d14714c69)
> >     +Thread: start: default
> >     + 1 D
> >     +Thread: start: attr
> >     + 2 R
> >     +Thread: end: default
> >     +Thread: end: attr
> >     +*** END OF TEST RCXX 1 ***
> >     diff --git a/testsuites/libtests/rcxx01/thread.cc
> >     b/testsuites/libtests/rcxx01/thread.cc
> >     index 0000000000..7cb64cea5a
> >     --- /dev/null
> >     +++ b/testsuites/libtests/rcxx01/thread.cc
> >     @@ -0,0 +1,90 @@
> >     +#include <chrono>
> >     +#include <thread>
> >     +#include <mutex>
> >     +using namespace std::chrono_literals;
> >     +extern "C" void rcxx_run_test(void);
> >     +struct test_thread
> >     +  test_thread();
> >     +  void start();
> >     +  bool running();
> >     +  void body(const char* title, int i, char c);
> >     +  rtems::thread::thread thread_default;
> >     +  rtems::thread::thread thread_attr;
> >     +  std::mutex mutex;
> >     +  bool finished;
> >     +test_thread::test_thread()
> >     +  : finished(false)
> >     +void test_thread::start()
> >     +  thread_default = rtems::thread::thread(&test_thread::body, this,
> >     +                                         "default",  1, 'D');
> >     +  rtems::thread::attributes attr;
> >     +  attr.set_name("RTHREAD");
> >     +  attr.set_priority(5);
> >     +  attr.set_stack_size(32 * 1024);
> >     +  thread_attr = rtems::thread::thread(attr, &test_thread::body,
> this,
> >     +                                      "attr", 2, 'R');
> >     +void test_thread::body(const char* title, int i, char c)
> >     +  std::cout << "Thread: start: " << title << std::endl
> >     +            << ' ' << i << ' ' << c << std::endl;
> >     +  size_t count = 5;
> >     +  while (count--) {
> >     +    std::this_thread::sleep_for(1s);
> >     +  std::cout << "Thread: end: " << title << std::endl;
> >     +  std::lock_guard<std::mutex> lock(mutex);
> >     +  finished = true;
> >     +bool test_thread::running()
> >     +  return finished == false;
> >     +  try {
> >     +    test_thread tt;
> >     +    tt.start();
> >     +    while (tt.running())
> >     +  } catch (...) {
> >     +    std::cout << "Thread: ouch" << std::endl;
> >     +    throw;
> >     2.24.1
> >     _______________________________________________
> >     devel mailing list
> >     devel at rtems.org <mailto:devel at rtems.org>
> >     http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201004/51e282ae/attachment-0001.html>
