[PATCH v3 07/10] spmsgq_err01: Use correct max values and fix 64bit
Joel Sherrill
joel at rtems.org
Mon Oct 5 12:19:53 UTC 2020
On Mon, Oct 5, 2020 at 2:18 AM Sebastian Huber <
> On 04/10/2020 06:18, Kinsey Moore wrote:
> > Fix spmsgq_err01 on systems with 64-bit pointers and correct max value
> > mismatches and inaccuracies that are more noticable on 64-bit systems.
> > testsuites/sptests/spmsgq_err01/init.c | 6 +++---
> > 1 file changed, 3 insertions(+), 3 deletions(-)
> > diff --git a/testsuites/sptests/spmsgq_err01/init.c
> b/testsuites/sptests/spmsgq_err01/init.c
> > index c68d30da16..9a6a8855be 100644
> > --- a/testsuites/sptests/spmsgq_err01/init.c
> > +++ b/testsuites/sptests/spmsgq_err01/init.c
> > @@ -101,7 +101,7 @@ rtems_task Init(
> > /* not enough memory for messages */
> > status = rtems_message_queue_create(
> > Queue_name[ 1 ],
> > - SIZE_MAX / ( sizeof( uintptr_t ) + sizeof(
> CORE_message_queue_Buffer ) ),
> > + UINT_MAX / ( sizeof( uintptr_t ) + sizeof(
> I think this should be UINT32_MAX. However, on a 64-bit system this test
> case doesn't produce the intended error case.
> > 1,
> I think we need here something like MIN(SIZE_MAX / UINT32_MAX, 1)).
> > RTEMS_DEFAULT_ATTRIBUTES,
> > &Queue_id[ 1 ]
> > @@ -116,8 +116,8 @@ rtems_task Init(
> > /* too large a request for messages */
> > Queue_name[ 1 ],
> > - INT_MAX,
> > - INT_MAX,
> > + UINT_MAX,
> UINT32_MAX?
The signature is his:
rtems_status_code rtems_message_queue_create(
rtems_name name,
uint32_t count,
size_t max_message_size,
rtems_attribute attribute_set,
rtems_id *id
UINT32_MAX is right for count.
SIZE_MAX is right for max_message_size.
> + SIZE_MAX - sizeof( uintptr_t ) + 1 - sizeof(
> CORE_message_queue_Buffer ),
> > &Queue_id[ 1 ]
> I am not sure about these changes.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201005/261a23ac/attachment.html>
