BSP Build Sweep Report (5 Oct)
Mon Oct 5 12:56:52 UTC 2020
Hi
The build sweep completed overnight and there were a lot of BSPs which did
not build to completion. This is the summary:
BSPs:    192
Total:   1745 all-bsps-log.txt
Passed:  1532
Failed:  212
Failed autoconf:  178
Failed waf:       34
Failed (NOSMP):   78
The full summary with one line results per build is attached.
A breakdown per architecture is:
     66 arm
     12 powerpc
    114 riscv
     16 sparc
      4 x86_64
Execution time of the entire sweep on an 8 core Xeon. This is a mix of
autoconf, waf, and scripting:
356304.80user 89111.84system 41:43:26elapsed 296%CPU (0avgtext+0avgdata
184740maxresident)k
6859544inputs+3400037288outputs (6432major+33833619401minor)pagefaults
0swaps
It looks like there is a lot to resolve before the switchover can occur.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201005/5948f010/attachment-0001.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201005/5948f010/attachment-0001.obj>
