[PATCH v4 1/2] cpu-supplement: Fix formatting and missing words
Kinsey Moore kinsey.moore at oarcorp.com
Mon Oct 5 13:04:01 UTC 2020
 cpu-supplement/arm.rst | 18 +++++++++---------
 1 file changed, 9 insertions(+), 9 deletions(-)
diff --git a/cpu-supplement/arm.rst b/cpu-supplement/arm.rst
index 63aa532..ac9e8c6 100644
--- a/cpu-supplement/arm.rst
+++ b/cpu-supplement/arm.rst
@@ -34,10 +34,10 @@ for the values.
 Count Leading Zeroes Instruction
-The ARMv5 and later has the count leading zeroes ``clz`` instruction which
-could be used to speed up the find first bit operation.  The use of this
-instruction should significantly speed up the scheduling associated with a
-thread blocking.  This is currently not used.
+The ARMv5 and later instruction sets have the count leading zeroes ``clz``
+instruction which could be used to speed up the find first bit operation. The
+use of this instruction should significantly speed up the scheduling associated
+with a thread blocking.  This is currently not used.
 Floating Point Unit
@@ -130,7 +130,7 @@ Memory Model
 A flat 32-bit memory model is supported.  The board support package must take
-care about the MMU if necessary.
+care of initializing the MMU if necessary.
 Interrupt Processing
@@ -194,13 +194,13 @@ actions:
 Symmetric Multiprocessing
-SMP is supported on ARMv7-A.  Available platforms are
+SMP is supported on ARMv7-A.  Available platforms are:
-- Altera Cyclone V,
+- Altera Cyclone V
-- NXP i.MX 7, and
+- NXP i.MX 7
-- Xilinx Zynq.
+- Xilinx Zynq
 Thread-Local Storage
2.20.1
