[PATCH v3 1/2] cpu-supplement: Fix formatting and missing words
Mon Oct 5 15:05:14 UTC 2020
This seems fine. I'm not sure if there is any uniform guidance on how
to do lists. Documentation for writing documentation :)
On Sat, Oct 3, 2020 at 10:23 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
>  cpu-supplement/arm.rst | 18 +++++++++---------
>  1 file changed, 9 insertions(+), 9 deletions(-)
> diff --git a/cpu-supplement/arm.rst b/cpu-supplement/arm.rst
> index 63aa532..ac9e8c6 100644
> --- a/cpu-supplement/arm.rst
> +++ b/cpu-supplement/arm.rst
> @@ -34,10 +34,10 @@ for the values.
>  Count Leading Zeroes Instruction
> -The ARMv5 and later has the count leading zeroes ``clz`` instruction which
> -could be used to speed up the find first bit operation.  The use of this
> -instruction should significantly speed up the scheduling associated with a
> -thread blocking.  This is currently not used.
> +The ARMv5 and later instruction sets have the count leading zeroes ``clz``
> +instruction which could be used to speed up the find first bit operation. The
> +use of this instruction should significantly speed up the scheduling associated
> +with a thread blocking.  This is currently not used.
>  Floating Point Unit
> @@ -130,7 +130,7 @@ Memory Model
>  A flat 32-bit memory model is supported.  The board support package must take
> -care about the MMU if necessary.
> +care of initializing the MMU if necessary.
>  Interrupt Processing
> @@ -194,13 +194,13 @@ actions:
>  Symmetric Multiprocessing
> -SMP is supported on ARMv7-A.  Available platforms are
> +SMP is supported on ARMv7-A.  Available platforms are:
> -- Altera Cyclone V,
> +- Altera Cyclone V
> -- NXP i.MX 7, and
> +- NXP i.MX 7
> -- Xilinx Zynq.
> +- Xilinx Zynq
>  Thread-Local Storage
> 2.20.1
> devel mailing list
> devel at rtems.org
