RTEMS 5.1 pc686 BSP malloc_info problem?
Joel Sherrill
joel at rtems.org
Mon Oct 5 15:57:51 UTC 2020
On Mon, Oct 5, 2020 at 10:34 AM Gedare Bloom <gedare at rtems.org> wrote:
> This is an SMP related bug? Can you send the rtems configure command,
> and the qemu run command?
> It might also help to know the number of tasks and their priorities.
> The CONFIGURE* macros might also help.
> My first guess is that the lock primitive is somehow broken in the
> pc686, maybe it gets caught in a buggy CAS/TAS loop? It would help if
> you can narrow down the task spinning to a particular section of code
> and send the disassembly (or file/line if it is in RTEMS)
Hmmm.. When did you build your i386 tools? git says 9/19 for the last change
but it was very much likely a few days after that when I pushed it.
--joel
> On Sun, Oct 4, 2020 at 2:06 PM Alan Cudmore <alan.cudmore at gmail.com>
> wrote:
> > Hi,
> > I have a problem in RTEMS 5.1 where the pc686 running on QEMU seems to
> > block or spin when trying to acquire a lock for the malloc_info call.
> > The CPU utilization goes up to 100 (on the QEMU host) leading me to
> > think the calling task is spinning waiting on the lock. Tasks with
> > lower priority than the calling task stop running as well. I also get
> > this problem when running the "malloc info" shell command.
> > I don't see this problem with the leon3 BSP built from the same source
> > tree and executed on QEMU.
> > Is there an SMP related initialization or perhaps QEMU option I might
> > be missing? I can run the same code without problems on the RTEMS 4.11
> > release (same QEMU binary and QEMU options)
> > Thanks,
> > Alan
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201005/ed2987dc/attachment-0001.html>
