[PATCH v4 6/9] spmsgq_err01: Use correct max values and fix 64bit
Kinsey Moore
kinsey.moore at oarcorp.com
Mon Oct 5 20:02:53 UTC 2020
Fix spmsgq_err01 on systems with 64-bit pointers and correct max value
mismatches and inaccuracies that are more noticable on 64-bit systems.
testsuites/sptests/spmsgq_err01/init.c | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/testsuites/sptests/spmsgq_err01/init.c b/testsuites/sptests/spmsgq_err01/init.c
index c68d30da16..cb1a82c0e1 100644
--- a/testsuites/sptests/spmsgq_err01/init.c
+++ b/testsuites/sptests/spmsgq_err01/init.c
@@ -101,7 +101,7 @@ rtems_task Init(
/* not enough memory for messages */
status = rtems_message_queue_create(
Queue_name[ 1 ],
- SIZE_MAX / ( sizeof( uintptr_t ) + sizeof( CORE_message_queue_Buffer ) ),
+ UINT32_MAX / ( sizeof( uintptr_t ) + sizeof( CORE_message_queue_Buffer ) ),
1,
RTEMS_DEFAULT_ATTRIBUTES,
&Queue_id[ 1 ]
@@ -116,8 +116,8 @@ rtems_task Init(
/* too large a request for messages */
Queue_name[ 1 ],
- INT_MAX,
- INT_MAX,
+ UINT32_MAX,
+ SIZE_MAX - sizeof( uintptr_t ) + 1 - sizeof( CORE_message_queue_Buffer ),
&Queue_id[ 1 ]
2.20.1
