[PATCH v5 2/2] Add AArch64 documentation
Kinsey Moore kinsey.moore at oarcorp.com
Mon Oct 5 20:03:38 UTC 2020
 cpu-supplement/aarch64.rst | 134 +++++++++++++++++++++++++++++++++++++
 user/bsps/aarch64/a53.rst  |  26 +++++++
 user/bsps/bsps-aarch64.rst |   2 +-
 3 files changed, 161 insertions(+), 1 deletion(-)
 create mode 100644 cpu-supplement/aarch64.rst
 create mode 100644 user/bsps/aarch64/a53.rst
diff --git a/cpu-supplement/aarch64.rst b/cpu-supplement/aarch64.rst
new file mode 100644
index 0000000..b76895b
--- /dev/null
+++ b/cpu-supplement/aarch64.rst
@@ -0,0 +1,134 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 1988, 2020 On-Line Applications Research Corporation (OAR)
+AArch64 Specific Information
+This chapter discusses the dependencies of the
+*ARM AArch64 architecture*
+(https://en.wikipedia.org/wiki/ARM_architecture#AArch64_features) in this port
+of RTEMS.  The ARMv8-A versions are supported by RTEMS.  Processors with a MMU
+use a static configuration which is set up during system start.  SMP is not
+supported.
+**Architecture Documents**
+For information on the ARM AArch64 architecture refer to the *ARM Infocenter*
+(http://infocenter.arm.com/).
+CPU Model Dependent Features
+This section presents the set of features which vary across ARM AArch64
+implementations and are of importance to RTEMS.  The set of CPU model feature
+macros are defined in the file :file:`cpukit/score/cpu/aarch64/rtems/score/aarch64.h`
+based upon the particular CPU model flags specified on the compilation command
+line.
+CPU Model Name
+The macro ``CPU_MODEL_NAME`` is a string which designates the architectural
+level of this CPU model.  See in :file:`cpukit/score/cpu/aarch64/rtems/score/aarch64.h`
+for the values.
+Floating Point Unit and SIMD
+The Advanced SIMD (NEON) and Floating-point instruction set extension is
+supported and expected to be present since all ARMv8-A CPUs are expected to
+support it as per the *ARMv8-A Programmer's Guide Chapter 7 introduction*
+(https://developer.arm.com/docs/den0024/a/aarch64-floating-point-and-neon). As
+such, ``CPU_HARDWARE_FP`` will always be set to ``TRUE``.
+Multilibs
+The following multilib variants are available:
+#. ``ILP32``: AArch64 instruction set and registers using 32bit long int and pointers
+#. ``LP64``: AArch64 instruction set and registers using 64bit long int and pointers
+Use for example the following GCC options:
+.. code-block:: shell
+    -mcpu=cortex-a53 -mabi=ilp32
+to build an application or BSP for the ARMv8-A architecture and tune the code
+for a Cortex-A53 processor.  It is important to select the correct ABI.
+Calling Conventions
+Please refer to the *Procedure Call Standard for the ARM 64-bit Architecture*
+(https://github.com/ARM-software/abi-aa/releases/download/2019Q4/aapcs64.pdf).
+Memory Model
+A flat 64-bit or 32-bit memory model is supported depending on the selected multilib
+variant.  All AArch64 CPU variants support a built-in MMU for which basic initialization
+for a flat memory model is handled.
+Interrupt Processing
+The Reset Vector is determined using RVBAR and is Read-Only. RVBAR is set using
+configuration signals only sampled at reset.  The ARMv8 architecture has four
+exception types:
+- Synchronous Exception
+- Interrupt (IRQ)
+- Fast Interrupt (FIQ)
+- System Error Exception
+Of these types only the synchronous and IRQ exceptions have explicit operating
+system support.  It is intentional that the FIQ is not supported by the operating
+system.  Without operating system support for the FIQ it is not necessary to
+disable them during critical sections of the system.
+Interrupt Levels
+There are exactly two interrupt levels on ARMv8 with respect to RTEMS.  Level
+zero corresponds to interrupts enabled.  Level one corresponds to interrupts
+disabled.
+Interrupt Stack
+The board support package must initialize the interrupt stack. The memory for
+the stacks is usually reserved in the linker script.
+Default Fatal Error Processing
+The default fatal error handler for this architecture performs the following
+actions:
+- disables operating system supported interrupts (IRQ),
+- places the error code in ``x0``, and
+- executes an infinite loop to simulate a halt processor instruction.
+Symmetric Multiprocessing
+SMP is not currently supported on ARMv8-A.
+Thread-Local Storage
+Thread-local storage (TLS) is supported. AArch64 uses unmodified TLS variant I
+which is not explcitly stated, but can be inferred from the behavior of GCC and
+*Addenda to, and Errata in, the ABI for the Arm® Architecture*
+(https://developer.arm.com/documentation/ihi0045/g). This alters expectations
+for the size of the TLS Thread Control Block (TCB) such that, under the LP64
+multilib variant, the TCB is 16 bytes in size instead of 8 bytes.
diff --git a/user/bsps/aarch64/a53.rst b/user/bsps/aarch64/a53.rst
index 0000000..9f085b8
--- /dev/null
+++ b/user/bsps/aarch64/a53.rst
@@ -0,0 +1,26 @@
+.. Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
+.. _BSP_aarch64_qemu_a53_ilp32:
+.. _BSP_aarch64_qemu_a53_lp64:
+Qemu A53
+This BSP supports two variants, `qemu_a53_ilp32` and `qemu-a53_lp64`. The basic
+hardware initialization is performed by the BSP.
+Boot via ELF
+The executable image is booted by Qemu in ELF format.
+Clock Driver
+The clock driver uses the `ARM Generic Timer`.
+Console Driver
+The console driver supports the default Qemu emulated ARM PL011 PrimeCell UART.
diff --git a/user/bsps/bsps-aarch64.rst b/user/bsps/bsps-aarch64.rst
index 4b2e749..319310e 100644
--- a/user/bsps/bsps-aarch64.rst
+++ b/user/bsps/bsps-aarch64.rst
@@ -5,4 +5,4 @@
 aarch64 (AArch64)
-There are no AArch64 BSPs yet.
+.. include:: aarch64/a53.rst
2.20.1
