[PATCH 4.11] sb: Back port the RTEMS 5 and 6 RSB engine.
chrisj at rtems.org chrisj at rtems.org
Tue Oct 6 03:19:22 UTC 2020
- Build GDb first as we do for RTEMS 5 and later
- Update GDB to 9.1 for all archs expect SPARC. The SIS patches
  only apply to 7.9. Disable Python for SPARC
Closes #4111
 rtems/config/4.11/rtems-arm.bset        |   2 +-
 rtems/config/4.11/rtems-avr.bset        |   2 +-
 rtems/config/4.11/rtems-bfin.bset       |   2 +-
 rtems/config/4.11/rtems-h8300.bset      |   2 +-
 rtems/config/4.11/rtems-i386.bset       |   2 +-
 rtems/config/4.11/rtems-lm32.bset       |   2 +-
 rtems/config/4.11/rtems-m32c.bset       |   2 +-
 rtems/config/4.11/rtems-m32r.bset       |   2 +-
 rtems/config/4.11/rtems-m68k.bset       |   2 +-
 rtems/config/4.11/rtems-microblaze.bset |   2 +-
 rtems/config/4.11/rtems-mips.bset       |   2 +-
 rtems/config/4.11/rtems-moxie.bset      |   2 +-
 rtems/config/4.11/rtems-nios2.bset      |   2 +-
 rtems/config/4.11/rtems-or1k.bset       |   2 +-
 rtems/config/4.11/rtems-powerpc.bset    |   2 +-
 rtems/config/4.11/rtems-sh.bset         |   2 +-
 rtems/config/4.11/rtems-sparc.bset      |   2 +-
 rtems/config/4.11/rtems-sparc64.bset    |   2 +-
 rtems/config/4.11/rtems-v850.bset       |   2 +-
 rtems/config/tools/rtems-gdb-7.9-1.cfg  |   6 +
 rtems/config/tools/rtems-gdb-9.1-1.cfg  |  12 +
 source-builder/config/autoconf-2-1.cfg  |   9 +-
 source-builder/config/automake-1-1.cfg  |   9 +-
 source-builder/config/binutils-2-1.cfg  |  17 +-
 source-builder/config/dtc-1-1.cfg       |   3 +-
 source-builder/config/expat-2-1.cfg     |   1 -
 source-builder/config/gcc-4.3-1.cfg     |  15 +-
 source-builder/config/gcc-4.4-1.cfg     |  10 +-
 source-builder/config/gcc-4.5-1.cfg     |   8 +-
 source-builder/config/gcc-4.6-1.cfg     |  10 +-
 source-builder/config/gcc-4.7-1.cfg     |   8 +-
 source-builder/config/gcc-4.8-1.cfg     |   8 +-
 source-builder/config/gcc-4.9-1.cfg     |   8 +-
 source-builder/config/gcc-common-1.cfg  |  53 +-
 source-builder/config/gdb-6-1.cfg       |  84 ++-
 source-builder/config/gdb-7-1.cfg       | 141 +----
 source-builder/config/gdb-common-1.cfg  | 286 +++++++++++
 source-builder/config/gettext-0-1.cfg   |   1 -
 source-builder/config/glib-2-1.cfg      |   4 +-
 source-builder/config/libffi-3-1.cfg    |   3 +-
 source-builder/config/libiconv-1-1.cfg  |   1 -
 source-builder/config/libjpeg-1.cfg     |   6 +-
 source-builder/config/libtool-2-1.cfg   |   4 +-
 source-builder/config/libusb-1-1.cfg    |   5 +-
 source-builder/config/m4-1-1.cfg        |   3 +-
 source-builder/config/net-snmp-5-1.cfg  |   4 +-
 source-builder/config/ntp-4-1.cfg       |   1 -
 source-builder/config/or1ksim-1-1.cfg   |   1 -
 source-builder/config/pixman-0-1.cfg    |   1 -
 source-builder/config/protobuf-2-1.cfg  |   3 +-
 source-builder/config/qemu-1-1.cfg      | 101 +---
 source-builder/config/sqlite-3-1.cfg    |  47 +-
 source-builder/defaults.mc              | 110 +++-
 source-builder/pkg-config               |  25 +-
 source-builder/sb-check                 |   8 +-
 source-builder/sb-defaults              |   9 +-
 source-builder/sb-get-sources           |  30 ++
 source-builder/sb-reports               |   9 +-
 source-builder/sb-rtems-config          |   9 +-
 source-builder/sb-set-builder           |   9 +-
 source-builder/sb-track                 |  29 ++
 source-builder/sb/__init__.py           |  20 +
 source-builder/sb/build.py              | 326 ++++++++----
 source-builder/sb/check.py              |  48 +-
 source-builder/sb/config.py             | 371 ++++++++++----
 source-builder/sb/cvs.py                |  10 +-
 source-builder/sb/darwin.py             |   3 +-
 source-builder/sb/download.py           |  79 +--
 source-builder/sb/ereport.py            |  64 +--
 source-builder/sb/error.py              |   4 +-
 source-builder/sb/execute.py            | 365 ++++++++++---
 source-builder/sb/freebsd.py            |  25 +-
 source-builder/sb/getsources.py         | 138 +++++
 source-builder/sb/git.py                |  73 ++-
 source-builder/sb/linux.py              |  48 +-
 source-builder/sb/log.py                |  17 +-
 source-builder/sb/macros.py             |  72 +--
 source-builder/sb/mailer.py             |  12 +-
 source-builder/sb/netbsd.py             |   4 +-
 source-builder/sb/options.py            | 130 +++--
 source-builder/sb/path.py               |  84 ++-
 source-builder/sb/pkgconfig.py          |  37 +-
 source-builder/sb/reports.py            |  87 ++--
 source-builder/sb/rtems-build-dep       | 169 ++++++
 source-builder/sb/rtems-check-command   |  26 +
 source-builder/sb/rtemsconfig.py        |  12 +-
 source-builder/sb/setbuilder.py         | 340 ++++++++----
 source-builder/sb/shell.py              |  74 +++
 source-builder/sb/simhost.py            | 656 ++++++++++++++++++++++++
 source-builder/sb/solaris.py            |   6 +-
 source-builder/sb/sources.py            |  55 +-
 source-builder/sb/track.py              | 250 +++++++++
 source-builder/sb/version.py            | 249 ++++++---
 source-builder/sb/windows.py            |  50 +-
 source-builder/sha512-base64            |   2 +
 95 files changed, 3832 insertions(+), 1223 deletions(-)
 create mode 100644 rtems/config/tools/rtems-gdb-9.1-1.cfg
 create mode 100644 source-builder/config/gdb-common-1.cfg
 create mode 100755 source-builder/sb-get-sources
 create mode 100755 source-builder/sb-track
 create mode 100644 source-builder/sb/__init__.py
 create mode 100644 source-builder/sb/getsources.py
 create mode 100755 source-builder/sb/rtems-build-dep
 create mode 100755 source-builder/sb/rtems-check-command
 create mode 100644 source-builder/sb/shell.py
 create mode 100644 source-builder/sb/simhost.py
 create mode 100644 source-builder/sb/track.py
 create mode 100755 source-builder/sha512-base64
diff --git a/rtems/config/4.11/rtems-arm.bset b/rtems/config/4.11/rtems-arm.bset
index d54570e..ec6cbf8 100644
--- a/rtems/config/4.11/rtems-arm.bset
+++ b/rtems/config/4.11/rtems-arm.bset
@@ -34,8 +34,8 @@
 4.11/rtems-autotools
 devel/expat-2.1.0-1
+tools/rtems-gdb-9.1-1
 tools/rtems-binutils-2.26-1
 tools/rtems-gcc-4.9.3-newlib-2.2.0-20150423-1
-tools/rtems-gdb-7.9-1
 tools/rtems-tools-4.11-1
 tools/rtems-kernel-4.11
diff --git a/rtems/config/4.11/rtems-avr.bset b/rtems/config/4.11/rtems-avr.bset
index 883120a..5cd1497 100644
--- a/rtems/config/4.11/rtems-avr.bset
+++ b/rtems/config/4.11/rtems-avr.bset
@@ -34,8 +34,8 @@
 devel/expat-2.1.0-1
diff --git a/rtems/config/4.11/rtems-bfin.bset b/rtems/config/4.11/rtems-bfin.bset
index 0a8bacd..6659f45 100644
--- a/rtems/config/4.11/rtems-bfin.bset
+++ b/rtems/config/4.11/rtems-bfin.bset
@@ -16,8 +16,8 @@
 devel/expat-2.1.0-1
 tools/rtems-gcc-4.8.3-newlib-2.2.0-20150423-1
diff --git a/rtems/config/4.11/rtems-h8300.bset b/rtems/config/4.11/rtems-h8300.bset
index 6e28f0b..984d09f 100644
--- a/rtems/config/4.11/rtems-h8300.bset
+++ b/rtems/config/4.11/rtems-h8300.bset
@@ -28,8 +28,8 @@
 devel/expat-2.1.0-1
diff --git a/rtems/config/4.11/rtems-i386.bset b/rtems/config/4.11/rtems-i386.bset
index 6a91672..5c26e94 100644
--- a/rtems/config/4.11/rtems-i386.bset
+++ b/rtems/config/4.11/rtems-i386.bset
@@ -16,8 +16,8 @@
 devel/expat-2.1.0-1
diff --git a/rtems/config/4.11/rtems-lm32.bset b/rtems/config/4.11/rtems-lm32.bset
index 6814268..81ee768 100644
--- a/rtems/config/4.11/rtems-lm32.bset
+++ b/rtems/config/4.11/rtems-lm32.bset
@@ -22,8 +22,8 @@
 devel/expat-2.1.0-1
diff --git a/rtems/config/4.11/rtems-m32c.bset b/rtems/config/4.11/rtems-m32c.bset
index 22e6d17..460a4b1 100644
--- a/rtems/config/4.11/rtems-m32c.bset
+++ b/rtems/config/4.11/rtems-m32c.bset
@@ -40,8 +40,8 @@
 devel/expat-2.1.0-1
diff --git a/rtems/config/4.11/rtems-m32r.bset b/rtems/config/4.11/rtems-m32r.bset
index 3d5d8ff..628ae30 100644
--- a/rtems/config/4.11/rtems-m32r.bset
+++ b/rtems/config/4.11/rtems-m32r.bset
@@ -16,8 +16,8 @@
 devel/expat-2.1.0-1
diff --git a/rtems/config/4.11/rtems-m68k.bset b/rtems/config/4.11/rtems-m68k.bset
index dea9e0f..9ffe528 100644
--- a/rtems/config/4.11/rtems-m68k.bset
+++ b/rtems/config/4.11/rtems-m68k.bset
@@ -16,8 +16,8 @@
 devel/expat-2.1.0-1
diff --git a/rtems/config/4.11/rtems-microblaze.bset b/rtems/config/4.11/rtems-microblaze.bset
index 94d5874..2ce9ae6 100644
--- a/rtems/config/4.11/rtems-microblaze.bset
+++ b/rtems/config/4.11/rtems-microblaze.bset
@@ -27,8 +27,8 @@
 devel/expat-2.1.0-1
diff --git a/rtems/config/4.11/rtems-mips.bset b/rtems/config/4.11/rtems-mips.bset
index 50ece5c..4a29e33 100644
--- a/rtems/config/4.11/rtems-mips.bset
+++ b/rtems/config/4.11/rtems-mips.bset
@@ -26,9 +26,9 @@
 devel/expat-2.1.0-1
 tools/rtems-mipstx39-gdb-7.9-1
diff --git a/rtems/config/4.11/rtems-moxie.bset b/rtems/config/4.11/rtems-moxie.bset
index c8f764e..f2e2017 100644
--- a/rtems/config/4.11/rtems-moxie.bset
+++ b/rtems/config/4.11/rtems-moxie.bset
@@ -22,8 +22,8 @@
 devel/expat-2.1.0-1
 devel/dtc-1.4.1-1
 tools/rtems-binutils-2.25-1
diff --git a/rtems/config/4.11/rtems-nios2.bset b/rtems/config/4.11/rtems-nios2.bset
index 82d45b2..83589bb 100644
--- a/rtems/config/4.11/rtems-nios2.bset
+++ b/rtems/config/4.11/rtems-nios2.bset
@@ -16,8 +16,8 @@
 devel/expat-2.1.0-1
diff --git a/rtems/config/4.11/rtems-or1k.bset b/rtems/config/4.11/rtems-or1k.bset
index 06ba931..bd7d553 100644
--- a/rtems/config/4.11/rtems-or1k.bset
+++ b/rtems/config/4.11/rtems-or1k.bset
@@ -37,7 +37,7 @@
 devel/expat-2.1.0-1
 tools/rtems-gcc-4.9.3-newlib-2.2.0-20150423-1.cfg
diff --git a/rtems/config/4.11/rtems-powerpc.bset b/rtems/config/4.11/rtems-powerpc.bset
index 7c9bab8..b94e3ba 100644
--- a/rtems/config/4.11/rtems-powerpc.bset
+++ b/rtems/config/4.11/rtems-powerpc.bset
@@ -31,8 +31,8 @@
 devel/expat-2.1.0-1
diff --git a/rtems/config/4.11/rtems-sh.bset b/rtems/config/4.11/rtems-sh.bset
index 2e0f854..1b06520 100644
--- a/rtems/config/4.11/rtems-sh.bset
+++ b/rtems/config/4.11/rtems-sh.bset
@@ -16,8 +16,8 @@
 devel/expat-2.1.0-1
diff --git a/rtems/config/4.11/rtems-sparc.bset b/rtems/config/4.11/rtems-sparc.bset
index 18e3cfc..ebf061e 100644
--- a/rtems/config/4.11/rtems-sparc.bset
+++ b/rtems/config/4.11/rtems-sparc.bset
@@ -76,8 +76,8 @@
 devel/expat-2.1.0-1
+tools/rtems-gdb-7.9-1
diff --git a/rtems/config/4.11/rtems-sparc64.bset b/rtems/config/4.11/rtems-sparc64.bset
index 7c97c82..5917ed8 100644
--- a/rtems/config/4.11/rtems-sparc64.bset
+++ b/rtems/config/4.11/rtems-sparc64.bset
@@ -16,8 +16,8 @@
 devel/expat-2.1.0-1
diff --git a/rtems/config/4.11/rtems-v850.bset b/rtems/config/4.11/rtems-v850.bset
index 1e64d23..b28dc22 100644
--- a/rtems/config/4.11/rtems-v850.bset
+++ b/rtems/config/4.11/rtems-v850.bset
@@ -21,8 +21,8 @@
 devel/expat-2.1.0-1
diff --git a/rtems/config/tools/rtems-gdb-7.9-1.cfg b/rtems/config/tools/rtems-gdb-7.9-1.cfg
index 87db312..adf4a3c 100644
--- a/rtems/config/tools/rtems-gdb-7.9-1.cfg
+++ b/rtems/config/tools/rtems-gdb-7.9-1.cfg
@@ -22,6 +22,12 @@
  %hash  md5 patch-gdb-python-python-config.py c0260fcca4c1a5509635049c0094eee3
 %endif
+# Disable python because 7.9 needs python2 and that is now end-of-life and
+# available on some hosts
+%define without_python
 # The gdb build instructions. We use 7.xx Release 1.
diff --git a/rtems/config/tools/rtems-gdb-9.1-1.cfg b/rtems/config/tools/rtems-gdb-9.1-1.cfg
new file mode 100644
index 0000000..99e6571
--- /dev/null
+++ b/rtems/config/tools/rtems-gdb-9.1-1.cfg
@@ -0,0 +1,12 @@
+# GDB 9.1
+%include %{_configdir}/checks.cfg
+%include %{_configdir}/base.cfg
+%define gdb_version 9.1
+%define gdb_src_ext xz
+%hash sha512 gdb-%{gdb_version}.tar.xz hM3UCNgKP8V3neRZxbJhVNMbMp695+OqeHmfseskXYtkuMjuckI4Kh29lbTm+dhP70HRKgZGqnXT3uRwnqH25w==
+%include %{_configdir}/gdb-common-1.cfg
diff --git a/source-builder/config/autoconf-2-1.cfg b/source-builder/config/autoconf-2-1.cfg
index 5061cfd..2b9466c 100644
--- a/source-builder/config/autoconf-2-1.cfg
+++ b/source-builder/config/autoconf-2-1.cfg
@@ -6,9 +6,9 @@
 %ifn %{defined _internal_autotools}
   %define _internal_autotools no
-  %ifn %{defined _internal_autotools_path}
-    %define _internal_autotools_path %{nil}
-  %endif
+%endif
+%ifn %{defined _internal_autotools_path}
+  %define _internal_autotools_path %{_prefix}
 %endif
@@ -16,12 +16,11 @@ Summary:   Autoconf v%{autoconf_version} for host %{_host}
 Version:   %{autoconf_version}
 Release:   %{release}
 URL: 	   http://www.gnu.org/software/autoconf/
-BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
 # Source
-%source set autoconf ftp://ftp.gnu.org/gnu/autoconf/autoconf-%{autoconf_version}.tar.gz
+%source set autoconf https://ftp.gnu.org/gnu/autoconf/autoconf-%{autoconf_version}.tar.gz
 # Prepare the source code.
diff --git a/source-builder/config/automake-1-1.cfg b/source-builder/config/automake-1-1.cfg
index 6f45928..83473de 100644
--- a/source-builder/config/automake-1-1.cfg
+++ b/source-builder/config/automake-1-1.cfg
@@ -6,9 +6,9 @@
-  %endif
+%endif
 %endif
@@ -16,12 +16,11 @@ Summary:   Automake v%{automake_version} for host %{_host}
 Version:   %{automake_version}
 Release:   %{release}
 URL: 	   http://www.gnu.org/software/automake/
 # Source
-%source set automake ftp://ftp.gnu.org/gnu/automake/automake-%{automake_version}.tar.gz
+%source set automake https://ftp.gnu.org/gnu/automake/automake-%{automake_version}.tar.gz
diff --git a/source-builder/config/binutils-2-1.cfg b/source-builder/config/binutils-2-1.cfg
index 397dea5..a49fa2a 100644
--- a/source-builder/config/binutils-2-1.cfg
+++ b/source-builder/config/binutils-2-1.cfg
@@ -19,17 +19,26 @@ Summary:   Binutils v%{binutils_version} for target %{_target} on host %{_host}
 Version:   %{binutils_version}
 Release:   %{release}
 URL: 	   http://sources.redhat.com/binutils
 # Supports Candian Cross (Cxc).
 %define allow_cxc
+# Default gold and LTO to disable.
+%ifn %{defined with_gold}
+ %define with_gold 0
+%endif
+%ifn %{defined with_lto}
+ %define with_lto 0
+%endif
 # Source
-%source set binutils ftp://ftp.gnu.org/gnu/binutils/binutils-%{binutils_version}.tar.bz2
+%source set binutils https://ftp.gnu.org/gnu/binutils/binutils-%{binutils_version}.tar.bz2
@@ -59,7 +68,11 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
     --build=%{_build} --host=%{_host} \
     --target=%{_target} \
     --verbose --disable-nls \
+    --disable-gdb --disable-libdecnumber --disable-readline --disable-sim \
     %{?with_deterministic_archives:--enable-deterministic-archives} \
+    %{?with_64_bit_bfd:--enable-64-bit-bfd} \
+    %{?with_gold:--enable-gold=yes} \
+    %{?with_lto:--enable-lto --enable-plugins}%{!?with_lto:--disable-lto} \
     --without-included-gettext \
     --disable-win32-registry \
     --disable-werror \
diff --git a/source-builder/config/dtc-1-1.cfg b/source-builder/config/dtc-1-1.cfg
index c9cb816..686a1e0 100644
--- a/source-builder/config/dtc-1-1.cfg
+++ b/source-builder/config/dtc-1-1.cfg
@@ -12,8 +12,7 @@ Name:      dtc-%{dtc_version}-%{_host}-%{release}
 Summary:   Device Tree Compiler v%{dtc_version} for target %{_target} on host %{_host}
 Version:   %{dtc_version}
 Release:   %{release}
-URL: 	   http://www.jdl.com/software/
+URL: 	   https://www.devicetree.org/
 # Source
diff --git a/source-builder/config/expat-2-1.cfg b/source-builder/config/expat-2-1.cfg
index 77774e7..2219d15 100644
--- a/source-builder/config/expat-2-1.cfg
+++ b/source-builder/config/expat-2-1.cfg
@@ -13,7 +13,6 @@ Summary:   Expat XML Parser v%{expat_version} for target %{_target} on host %{_h
 Version:   %{expat_version}
 Release:   %{release}
 URL: 	   http://expat.sourceforge.net/
 # Source
diff --git a/source-builder/config/gcc-4.3-1.cfg b/source-builder/config/gcc-4.3-1.cfg
index 4c7a335..69ea367 100644
--- a/source-builder/config/gcc-4.3-1.cfg
+++ b/source-builder/config/gcc-4.3-1.cfg
@@ -1,28 +1,33 @@
-# GCC 4.7 Version 1.
+# GCC 4.3.1 Version 1.
 # This configuration file configure's, make's and install's gcc. It uses
 # newlib, MPFR, MPC, and GMP in a one-tree build configuration.
+# Force the standard of C code for GCC.
+%define build_cflags %{build_cflags} --std=gnu89
 # Source
 # GCC core and G++
-%source set gcc ftp://ftp.gnu.org/gnu/gcc/gcc-%{gcc_version}/gcc-%{gcc_version}.tar.bz2
+%source set gcc https://ftp.gnu.org/gnu/gcc/gcc-%{gcc_version}/gcc-%{gcc_version}.tar.bz2
 # Newlib
-%source set newlib ftp://sourceware.org/pub/newlib/newlib-%{newlib_version}.tar.gz
+%source set newlib https://sourceware.org/pub/newlib/newlib-%{newlib_version}.tar.gz
 # Packages GCC requires
-%source set mpfr https://ftp.gnu.org/gnu/mpfr/mpfr-%{mpfr_version}.tar.bz2
-%source set mpc https://ftp.gnu.org/gnu/mpc/mpc-%{mpc_version}.tar.gz
+%source set mpfr http://www.mpfr.org/mpfr-%{mpfr_version}/mpfr-%{mpfr_version}.tar.bz2
+%source set mpc http://www.multiprecision.org/mpc/download/mpc-%{mpc_version}.tar.gz
 %source set gmp https://ftp.gnu.org/gnu/gmp/gmp-%{gmp_version}.tar.bz2
diff --git a/source-builder/config/gcc-4.4-1.cfg b/source-builder/config/gcc-4.4-1.cfg
index ecfa651..2c70919 100644
--- a/source-builder/config/gcc-4.4-1.cfg
+++ b/source-builder/config/gcc-4.4-1.cfg
@@ -11,22 +11,22 @@
 # GCC core and G++
-%source set gcc ftp://ftp.gnu.org/gnu/gcc/gcc-%{gcc_version}/gcc-core-%{gcc_version}.tar.bz2
+%source set gcc https://ftp.gnu.org/gnu/gcc/gcc-%{gcc_version}/gcc-core-%{gcc_version}.tar.bz2
 %if %{enable_cxx}
- %source add gcc ftp://ftp.gnu.org/gnu/gcc/gcc-%{gcc_version}/gcc-g++-%{gcc_version}.tar.gz
+ %source add gcc https://ftp.gnu.org/gnu/gcc/gcc-%{gcc_version}/gcc-g++-%{gcc_version}.tar.gz
 %endif
 # Newlib
diff --git a/source-builder/config/gcc-4.5-1.cfg b/source-builder/config/gcc-4.5-1.cfg
index acca717..fbff31c 100644
--- a/source-builder/config/gcc-4.5-1.cfg
+++ b/source-builder/config/gcc-4.5-1.cfg
@@ -11,18 +11,18 @@
 # GCC core and G++
 # Newlib
diff --git a/source-builder/config/gcc-4.6-1.cfg b/source-builder/config/gcc-4.6-1.cfg
index 4eff844..98f8d7e 100644
--- a/source-builder/config/gcc-4.6-1.cfg
+++ b/source-builder/config/gcc-4.6-1.cfg
@@ -11,22 +11,22 @@
 # GCC core and G++
 %if %{enable_cxx}
 %endif
 # Newlib
diff --git a/source-builder/config/gcc-4.7-1.cfg b/source-builder/config/gcc-4.7-1.cfg
index 25ac233..0eac21f 100644
--- a/source-builder/config/gcc-4.7-1.cfg
+++ b/source-builder/config/gcc-4.7-1.cfg
@@ -20,18 +20,18 @@
 # GCC core and G++
 # Newlib
diff --git a/source-builder/config/gcc-4.8-1.cfg b/source-builder/config/gcc-4.8-1.cfg
index a090717..aa62837 100644
--- a/source-builder/config/gcc-4.8-1.cfg
+++ b/source-builder/config/gcc-4.8-1.cfg
@@ -11,18 +11,18 @@
 # GCC core and G++
 # Newlib
+%source set mpc http://www.multiprecision.org/downloads/mpc-%{mpc_version}.tar.gz
diff --git a/source-builder/config/gcc-4.9-1.cfg b/source-builder/config/gcc-4.9-1.cfg
index c73850f..25e4247 100644
--- a/source-builder/config/gcc-4.9-1.cfg
+++ b/source-builder/config/gcc-4.9-1.cfg
@@ -11,18 +11,18 @@
 # GCC core and G++
 # Newlib
diff --git a/source-builder/config/gcc-common-1.cfg b/source-builder/config/gcc-common-1.cfg
index 9154026..4e13efc 100644
--- a/source-builder/config/gcc-common-1.cfg
+++ b/source-builder/config/gcc-common-1.cfg
@@ -19,7 +19,6 @@ Summary:   GCC v%{gcc_version} and Newlib v%{newlib_version} for target %{_targe
 Version:   %{gcc_version}
 Release:   %{release}
 URL: 	   http://gcc.gnu.org/
@@ -31,6 +30,13 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
 %global _gcclibdir %{_prefix}/lib
+# Default LTO to off.
+%endif
 # The GCC version depends on the type of build we are doing.
@@ -40,6 +46,16 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
  %define rtems_gcc_version %{rtems_version}
 %endif
+# Packages GCC requires
+%if %{defined cloog_version}
+%source set cloog https://gcc.gnu.org/pub/gcc/infrastructure/cloog-%{cloog_version}.tar.gz
+%endif
+%if %{defined isl_version}
+%source set isl https://gcc.gnu.org/pub/gcc/infrastructure/isl-%{isl_version}.tar.bz2
+%endif
@@ -59,8 +75,8 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
   cd ${build_top}
   # newlib
-  source_dir_newlib="newlib-%{newlib_version}"
-  %source setup newlib -q -D -n newlib-%{newlib_version}
+  source_dir_newlib=%{?newlib_external:%{newlib_expand_name}}%{!?newlib_external:"newlib-%{newlib_version}"}
+  %source setup newlib -q -D -n ${source_dir_newlib}
   %patch setup newlib -p1
   cd ${build_top}
@@ -68,6 +84,28 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
   %{__rmfile} ${source_dir_gcc}/newlib
   %{__ln_s} $PWD/${source_dir_newlib}/newlib ${source_dir_gcc}/newlib
+  # CLooG
+  source_dir_cloog="cloog-%{cloog_version}"
+  %source setup cloog -q -D -n cloog-%{cloog_version}
+  %patch setup cloog -p1
+  cd ${build_top}
+  # Build MPFR one-tree style
+  %{__rmfile} ${source_dir_gcc}/cloog
+  %{__ln_s} $PWD/${source_dir_cloog} ${source_dir_gcc}/cloog
+%endif
+  # ISL
+  source_dir_isl="isl-%{isl_version}"
+  %source setup isl -q -D -n isl-%{isl_version}
+  %patch setup isl -p1
+  cd ${build_top}
+  %{__rmfile} ${source_dir_gcc}/isl
+  %{__ln_s} $PWD/${source_dir_isl} ${source_dir_gcc}/isl
+%endif
   # MPFR
   source_dir_mpfr="mpfr-%{mpfr_version}"
   %source setup mpfr -q -D -n mpfr-%{mpfr_version}
@@ -131,12 +169,6 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
   languages="$languages,objc"
 %endif
-%if %{_host_os} == mingw32
-  zlib_option=""
-%else
-  zlib_option="--with-system-zlib"
-%endif
   %{host_build_flags}
   ../${source_dir_gcc}/configure \
@@ -154,11 +186,10 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
     --disable-libstdcxx-pch \
     --with-gnu-as --with-gnu-ld --verbose \
     --with-newlib \
-    "$zlib_option" \
     --disable-nls --without-included-gettext \
     --enable-version-specific-runtime-libs \
-    --disable-lto \
+    %{?with_lto:--enable-lto}%{!?with_lto:--disable-lto} \
     --enable-newlib-io-c99-formats \
     %{?disable_MAKEINFO:MAKEINFO=missing} \
     %{?with_iconv:--enable-newlib-iconv} \
diff --git a/source-builder/config/gdb-6-1.cfg b/source-builder/config/gdb-6-1.cfg
index deca448..70729b2 100644
--- a/source-builder/config/gdb-6-1.cfg
+++ b/source-builder/config/gdb-6-1.cfg
@@ -4,6 +4,24 @@
 # This configuration file configure's, make's and install's gdb.
+# See if the simulator has been disabled for Windows.
+%if %{_host_os} == win32
+ %if %{defined win32-gdb-disable-sim}
+  %define gdb-disable-sim 1
+  %endif
+%endif
+# Default to building simulators.
+%ifn %{defined gdb-disable-sim}
+ %define gdb-disable-sim 0
+%else
+ %undefine gdb-sim-options
+%endif
@@ -11,38 +29,62 @@ Summary:   GDB v%{gdb_version} for target %{_target} on host %{_host}
 Version:   %{gdb_version}
 Release:   %{release}
 URL: 	   http://www.gnu.org/software/gdb/
 # Source
 %source set gdb http://ftp.gnu.org/gnu/gdb/gdb-%{gdb_version}.tar.bz2
+# Disable Python on Cxc builds for now.
+%if "%{_build}" != "%{_host}"
+  %define without_python
+%endif
 %prep
-  %source setup gdb -q -c -n %{name}-%{version}
-  cd gdb-%{gdb_version}
+  build_top=$(pwd)
+  gdb_source=%{?gdb_external:%{gdb_expand_name}}%{!?gdb_external:"gdb-%{gdb_version}"}
+  source_dir_gdb=${gdb_source}
+  %source setup gdb -q -n ${gdb_source}
   %patch setup gdb -p1
-  cd ..
+  cd ${build_top}
 %build
-  export PATH="%{_bindir}:${PATH}"
-  mkdir -p build
-  cd build
-%if "%{_build}" != "%{_host}"
-  CFLAGS_FOR_BUILD="-g -O2 -Wall" \
-%endif
-  CFLAGS="$SB_CFLAGS" \
-  ../gdb-%{gdb_version}/configure \
+  build_top=$(pwd)
+  %{build_directory}
+  mkdir -p ${build_dir}
+  cd ${build_dir}
+  %{host_build_flags}
+  if test "%{_build}" != "%{_host}" ; then
+    GDB_LIBS_STATIC="-lexpat"
+  else
+    GDB_LIBS="%{_forced_static}"
+  fi
+  LIBS_STATIC=${GDB_LIBS_STATIC} \
+  LIBS=${GDB_LIBS} \
+  ../${source_dir_gdb}/configure \
     --disable-werror \
-    --enable-sim \
+    %{!?gdb-disable-sim:--enable-sim}%{?gdb-disable-sim:--disable-sim} \
+    %{?gdb-sim-options:%{gdb-sim-options}} \
+    --without-zlib \
     --with-expat \
     %{!?without_python:--with-python} \
     --prefix=%{_prefix} --bindir=%{_bindir} \
@@ -51,19 +93,21 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
     --mandir=%{_mandir} --infodir=%{_infodir}
   %{__make} %{?_smp_mflags} all
-  cd ..
+  cd ${build_top}
 %install
-  rm -rf $SB_BUILD_ROOT
+  build_top=$(pwd)
+  %{__rmdir} $SB_BUILD_ROOT
-  cd build
+  cd ${build_dir}
   %{__make} DESTDIR=$SB_BUILD_ROOT install
   # Dropped in FSF-binutils-2.9.5, but Cygwin still ships it.
-  rm -rf $SB_BUILD_ROOT%{_infodir}/configure.info*
+  %{__rmdir} $SB_BUILD_ROOT%{_infodir}/configure.info*
-  rm -f $SB_BUILD_ROOT%{_infodir}/dir
+  %{__rmfile} $SB_BUILD_ROOT%{_infodir}/dir
   touch $SB_BUILD_ROOT%{_infodir}/dir
-  cd ..
+  cd ${build_top}
diff --git a/source-builder/config/gdb-7-1.cfg b/source-builder/config/gdb-7-1.cfg
index 21591b5..a415f51 100644
--- a/source-builder/config/gdb-7-1.cfg
+++ b/source-builder/config/gdb-7-1.cfg
@@ -4,143 +4,4 @@
-# See if the simulator has been disabled for Windows.
-# Build using the system's readline, it is in better shape
-# than GDB's one with MSYS2.
-%if %{_host_os} == win32
- %if %{defined win32-gdb-disable-sim}
-  %define gdb-disable-sim 1
- %endif
- %define with_system_readline 1
-%endif
-# Default to building simulators.
-%ifn %{defined gdb-disable-sim}
- %define gdb-disable-sim 0
-%else
- %undefine gdb-sim-options
-%endif
-%include %{_configdir}/checks.cfg
-# Select Snapshot Macro Maps
-%select gdb-snapshot
-%select expat-snapshot
-# The description.
-Name:      %{_target}-gdb-%{gdb_version}-%{_host}-%{release}
-Summary:   GDB v%{gdb_version} for target %{_target} on host %{_host}
-Version:   %{gdb_version}
-Release:   %{release}
-URL: 	   http://www.gnu.org/software/gdb/
-# GDB has changed it default extension.
-%ifn %{defined gdb_src_ext}
-  %define gdb_src_ext gz
-%endif
-# Source
-%source set gdb http://ftp.gnu.org/gnu/gdb/gdb-%{gdb_version}.tar.%{gdb_src_ext}
-# Disable Python on Cxc builds for now.
-  %define without_python
-%endif
-# The --with-python option is either the default which is auto or the path to
-# the specific python to be used.
-%if %{defined with_python_path}
-  %define with_python_option --with-python=%{with_python_path}
-%else
-%endif
-# Prepare the source code.
-%prep
-  build_top=$(pwd)
-  gdb_source=%{?gdb_external:%{gdb_expand_name}}%{!?gdb_external:"gdb-%{gdb_version}"}
-  source_dir_gdb=${gdb_source}
-  %source setup gdb -q -n ${gdb_source}
-  %patch setup gdb -p1
-  cd ${build_top}
-%build
-  build_top=$(pwd)
-  %{build_directory}
-  mkdir -p ${build_dir}
-  cd ${build_dir}
-  %{host_build_flags}
-  if test "%{_build}" != "%{_host}" ; then
-    GDB_LIBS_STATIC="-lexpat"
-  else
-    GDB_LIBS="%{_forced_static}"
-  fi
-  LIBS_STATIC=${GDB_LIBS_STATIC} \
-  LIBS=${GDB_LIBS} \
-  ../${source_dir_gdb}/configure \
-    --build=%{_build} --host=%{_host} \
-    --target=%{_target} \
-    --verbose --disable-nls \
-    %{?with_system_readline:--with-system-readline} \
-    --without-included-gettext \
-    --disable-win32-registry \
-    --disable-werror \
-    %{!?gdb-disable-sim:--enable-sim}%{?gdb-disable-sim:--disable-sim} \
-    %{?gdb-sim-options:%{gdb-sim-options}} \
-    --without-zlib \
-    --with-expat \
-    %{!?without_python:%{with_python_option}} \
-    --prefix=%{_prefix} --bindir=%{_bindir} \
-    --exec-prefix=%{_exec_prefix} \
-    --includedir=%{_includedir} --libdir=%{_libdir} \
-    --mandir=%{_mandir} --infodir=%{_infodir}
-  %{__make} %{?_smp_mflags} all
-  cd ${build_top}
-%install
-  build_top=$(pwd)
-  %{__rmdir} $SB_BUILD_ROOT
-  cd ${build_dir}
-  %{__make} DESTDIR=$SB_BUILD_ROOT install
-  # Dropped in FSF-binutils-2.9.5, but Cygwin still ships it.
-  %{__rmdir} $SB_BUILD_ROOT%{_infodir}/configure.info*
-  %{__rmfile} $SB_BUILD_ROOT%{_infodir}/dir
-  touch $SB_BUILD_ROOT%{_infodir}/dir
-  cd ${build_top}
diff --git a/source-builder/config/gdb-common-1.cfg b/source-builder/config/gdb-common-1.cfg
index 0000000..cfddf53
--- /dev/null
+++ b/source-builder/config/gdb-common-1.cfg
@@ -0,0 +1,286 @@
+# GDB Common Version 1.
+# This configuration file configure's, make's and install's gdb.
+# Python
+# GDB uses python internally so we need to link to a suitable python
+# dev kit. The dev kit for python is the header and a library. These
+# files are versioned where the header file is located in a directory
+# based on:
+#  pythonM.m/Python.h
+# where 'M' is the major version number and 'm' is the minor verison
+# number. The library is:
+#  libpythonM.m.a
+# The python command is 'pythonM' which means we need to query it for
+# the minor number.
+# The python running the RSB may not be suitable, for example a MSC,
+# MSYS or Cygwin version on Windows when we want the MinGW python dev
+# file. A specific version cannot be forced because older versions of
+# GDB can only link to 'python2'.
+# Host support can perform a complex query of the system, for example
+# Windows and set '%{gdb_python2}' and '%{gdb_python3}' with the full
+# path to that version's executable.
+# A configuration of GDB can set the version required by setting
+# '%{gdb-python-version}' to the versions command, eg python2.
+# The procedure is:
+# 1. If the macros '%{gdb_python2}' or '%{gdb_python3}' are present
+#    use that path they contain. Assume the path is valid.
+# 2. Does the version of gdb specify a version of python that must be
+#    used. Override with '%define gdb-python-version python2'.
+# 3. Search for 'python2' and if not found search for 'python3'.
+%if !%{defined without_python}
+  %if %{defined gdb-python2}
+    %define gdb-enable-python %{gdb_python2}
+  %else
+    %if %{defined gdb-python3}
+      %define gdb-enable-python %{gdb_python3}
+    %else
+      %if %{defined gdb-python-version}
+        %define gdb-enable-python %(command -v %{gdb-python-version} || true)
+      %else
+        %define gdb-enable-python %(command -v python2 || true)
+        %if %{gdb-enable-python} == %{nil}
+          %define gdb-enable-python %(command -v python3 || true)
+        %endif
+          %define gdb-enable-python %(command -v python || true})
+        %endif
+      %endif
+        %error "gdb: python: no valid version of python found"
+      %endif
+    %endif
+  %endif
+  # Get the Python's major and minor version from the python
+  # command. The headers and libraries are installed under a major/minor
+  # (mm) version path and name.
+  # The library file name can vary across the hosts so wildcard the search.
+  %if %{!defined gdb-python-config}
+    %define gdb-python-config %{nil}
+  %endif
+  %if %{gdb-python-config} == %{nil}
+   %define gdb-python-config %(command -v %{gdb-enable-python}-config || true)
+  %endif
+  %define gdb-python-ver-mm %(%{gdb-enable-python} --version 2>&1 | sed -e 's/.* //g' | rev | cut -d'.' -f2- | rev)
+  %define gdb-python-header Python.h
+  %define gdb-python-ver-header python%{gdb-python-ver-mm}/%{gdb-python-header}
+  %define gdb-python-ver-lib libpython%{gdb-python-ver-mm}.*
+  %if %{host_includes} == %{nil}
+    %define gdb-host-incs %{nil}
+  %else
+    %define gdb-host-incs -I '%{host_includes}'
+  %endif
+  %if %{gdb-python-config} != %{nil}
+    %define gdb-python-config-incs -I '%(%{gdb-python-config} --includes)'
+    %define gdb-python-header-check %(%{_sbdir}/sb/rtems-build-dep -c %{__cc} %{gdb-host-incs} %{gdb-python-config-incs} -H %{gdb-python-header})
+  %else
+    %define gdb-python-header-check %(%{_sbdir}/sb/rtems-build-dep -c %{__cc} %{gdb-host-incs} -H %{gdb-python-ver-header})
+  %endif
+  %if %{gdb-python-header-check} == not-found && !%{_rsb_getting_source}
+    %error "gdb: python: header file not found: %{gdb-python-ver-header}, please install"
+  %endif
+  # Too hard to find on MacOS (darwin), the header is good enough.
+  %ifnos darwin
+    %if %{host_ldflags} == %{nil}
+      %define gdb-host-libs %{nil}
+    %else
+      %define gdb-host-libs -L '%{host_ldflags}'
+    %endif
+      %define gdb-python-lib-filter awk 'BEGIN{FS=" "}/python/{for(i=1;i<NF;++i)if(match($i,".*lpython.*")) print "lib"substr($i,3)"*";}'
+      %if %{gdb-python-ver-mm} < 3.8
+          %define gdb-python-config-lib-check-flags --ldflags
+      %else
+          %define gdb-python-config-lib-check-flags --ldflags --embed
+      %endif
+      %define gdb-python-config-libs %(%{gdb-python-config} %{gdb-python-config-lib-check-flags} | %{gdb-python-lib-filter})
+      %define gdb-python-lib-check %(%{_sbdir}/sb/rtems-build-dep -c %{__cc} %{gdb-host-libs} -l %{gdb-python-config-libs})
+    %else
+      %define gdb-python-lib-check %(%{_sbdir}/sb/rtems-build-dep -c %{__cc} %{gdb-host-libs} -l %{gdb-python-ver-lib})
+    %endif
+    %if %{gdb-python-lib-check} == not-found && !%{_rsb_getting_source}
+      %error "gdb: python: library file not found: %{gdb-python-ver-lib}, please install"
+    %endif
+  %endif
+%endif
+# Build using the system's readline, it is in better shape
+# than GDB's one with MSYS2.
+ %endif
+ %define with_system_readline 1
+%endif
+%else
+%endif
+# Select Snapshot Macro Maps
+%select gdb-snapshot
+%select expat-snapshot
+# The description.
+Name:      %{_target}-gdb-%{gdb_version}-%{_host}-%{release}
+Summary:   GDB v%{gdb_version} for target %{_target} on host %{_host}
+Version:   %{gdb_version}
+Release:   %{release}
+URL:       http://www.gnu.org/software/gdb/
+# GDB has changed it default extension.
+%ifn %{defined gdb_src_ext}
+  %define gdb_src_ext gz
+%endif
+# Source
+%source set gdb http://ftp.gnu.org/gnu/gdb/gdb-%{gdb_version}.tar.%{gdb_src_ext}
+%endif
+# The --with-python option is either the default which is auto or the path to
+# the specific python to be used.
+  %if %{defined with_python_path}
+    %define with_python_option --with-python=%{with_python_path}
+  %else
+    %if %{defined gdb-enable-python}
+      %define with_python_option --with-python=%{gdb-enable-python}
+    %else
+    %endif
+  %endif
+%endif
+# Fix the mess iconv is on FreeBSD 10.0 and higher.
+%if %{defined iconv_prefix}
+ %define iconv_opts --with-libiconv-prefix=%{iconv_prefix}
+%else
+ %define iconv_opts %{nil}
+%endif
+# Prepare the source code.
+%prep
+  build_top=$(pwd)
+  %patch setup gdb -p1
+  cd ${build_top}
+%build
+  build_top=$(pwd)
+  cd ${build_dir}
+  else
+  fi
+    --build=%{_build} --host=%{_host} \
+    --target=%{_target} \
+    --verbose --disable-nls \
+    --disable-gas --disable-binutils --disable-ld --disable-gold --disable-gprof \
+    %{?with_system_readline:--with-system-readline} \
+    --without-included-gettext \
+    --disable-win32-registry \
+    --disable-werror \
+    --without-zlib \
+    --with-expat \
+    --with-guile=no \
+    %{iconv_opts} \
+    %{?without_python:--without-python} \
+    %{!?without_python:%{with_python_option}} \
+    --prefix=%{_prefix} --bindir=%{_bindir} \
+    --exec-prefix=%{_exec_prefix} \
+    --includedir=%{_includedir} --libdir=%{_libdir} \
+    --mandir=%{_mandir} --infodir=%{_infodir}
+  %{__make} %{?_smp_mflags} all
+  cd ${build_top}
+%install
+  build_top=$(pwd)
+  cd ${build_dir}
+  %{__make} DESTDIR=$SB_BUILD_ROOT install
+  # Dropped in FSF-binutils-2.9.5, but Cygwin still ships it.
+  touch $SB_BUILD_ROOT%{_infodir}/dir
+  cd ${build_top}
diff --git a/source-builder/config/gettext-0-1.cfg b/source-builder/config/gettext-0-1.cfg
index 7758d7b..19402b6 100644
--- a/source-builder/config/gettext-0-1.cfg
+++ b/source-builder/config/gettext-0-1.cfg
@@ -14,7 +14,6 @@ Summary:   GetText offers to programmers, translators, and even users, a well
 Version:   %{gettext_version}
 Release:   %{release}
 URL: 	   http://www.gnu.org/software/gettext/
 # Source
diff --git a/source-builder/config/glib-2-1.cfg b/source-builder/config/glib-2-1.cfg
index 6c40be2..09b43fa 100644
--- a/source-builder/config/glib-2-1.cfg
+++ b/source-builder/config/glib-2-1.cfg
@@ -14,7 +14,6 @@ Summary:   GLib provides the core application building blocks for
 Version:   %{glib_version}
 Release:   %{release}
 URL: 	   https://developer.gnome.org/glib/
 # Source
@@ -60,7 +59,8 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
     --datadir=%{_datadir} \
     --with-sysroot=$SYSROOT \
-    --disable-dtrace
+    --disable-dtrace \
+    --with-pcre=internal
   %{_ld_library_path}=$SYSROOT/lib \
diff --git a/source-builder/config/libffi-3-1.cfg b/source-builder/config/libffi-3-1.cfg
index d258acb..a201485 100644
--- a/source-builder/config/libffi-3-1.cfg
+++ b/source-builder/config/libffi-3-1.cfg
@@ -14,12 +14,11 @@ Summary:   LibFFI provides a portable, high level programming interface to
 Version:   %{libffi_version}
 Release:   %{release}
 URL: 	   https://sourceware.org/libffi/
 # Source
-%source set libffi ftp://sourceware.org/pub/libffi/libffi-%{libffi_version}.tar.gz
+%source set libffi https://sourceware.org/pub/libffi/libffi-%{libffi_version}.tar.gz
diff --git a/source-builder/config/libiconv-1-1.cfg b/source-builder/config/libiconv-1-1.cfg
index 1ccecd4..fd2d738 100644
--- a/source-builder/config/libiconv-1-1.cfg
+++ b/source-builder/config/libiconv-1-1.cfg
@@ -15,7 +15,6 @@ Summary:   Provides an iconv() implementation, for use on systems which
 Version:   %{libiconv_version}
 Release:   %{release}
 URL: 	   http://www.gnu.org/software/libiconv/
 # Source
diff --git a/source-builder/config/libjpeg-1.cfg b/source-builder/config/libjpeg-1.cfg
index e6af6ae..6acb02f 100644
--- a/source-builder/config/libjpeg-1.cfg
+++ b/source-builder/config/libjpeg-1.cfg
@@ -9,11 +9,10 @@
 %endif
-Summary:   libjpeg is the Independent JPEG Group jpeg library
+Summary:   libjpeg is the Independent JPEG Group jpeg library
 Version:   %{libjpeg_version}
 Release:   %{release}
 URL: 	   http://www.ijg.org/
 # NTP Source
@@ -53,8 +52,7 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
     --mandir=%{_mandir} \
     --infodir=%{_infodir} \
-    --disable-shared \
-    --disable-programs
+    --disable-shared
diff --git a/source-builder/config/libtool-2-1.cfg b/source-builder/config/libtool-2-1.cfg
index 0d1f972..e834e87 100644
--- a/source-builder/config/libtool-2-1.cfg
+++ b/source-builder/config/libtool-2-1.cfg
@@ -16,12 +16,11 @@ Summary:   Libtool v%{libtool_version} for host %{_host}
 Version:   %{libtool_version}
 Release:   %{release}
 URL: 	   http://www.gnu.org/software/libtool/
 # Source
-%source set libtool ftp://ftp.gnu.org/gnu/libtool/libtool-%{libtool_version}.tar.gz
+%source set libtool https://ftp.gnu.org/gnu/libtool/libtool-%{libtool_version}.tar.gz
@@ -54,6 +53,7 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
   fi
   export CFLAGS CFLAGS_FOR_BUILD CC
+  CC=%{__cc} \
   ./configure \
diff --git a/source-builder/config/libusb-1-1.cfg b/source-builder/config/libusb-1-1.cfg
index 271d5e0..803f326 100644
--- a/source-builder/config/libusb-1-1.cfg
+++ b/source-builder/config/libusb-1-1.cfg
@@ -12,7 +12,6 @@ Summary:   LibUSB v%{libusb_version} for target %{_target} on host %{_host}
 Version:   %{libusb_version}
 Release:   %{release}
 URL: 	   http://libusb.org/
 # Source
@@ -34,8 +33,10 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
   cd libusb-%{libusb_version}
+  LIBUSB_CFLAGS_FOR_BUILD="-g -O2 -Wall"
 %endif
+  CFLAGS_FOR_BUILD=${LIBUSB_CFLAGS_FOR_BUILD} \
   ./configure \
diff --git a/source-builder/config/m4-1-1.cfg b/source-builder/config/m4-1-1.cfg
index c77e4a3..dc47c6b 100644
--- a/source-builder/config/m4-1-1.cfg
+++ b/source-builder/config/m4-1-1.cfg
@@ -12,12 +12,11 @@ Summary:   M4 v%{m4_version} for host %{_host}
 Version:   %{m4_version}
 Release:   %{release}
 URL: 	   http://www.gnu.org/software/m4/
 # Source
-%source set m4 ftp://ftp.gnu.org/gnu/m4/m4-%{m4_version}.tar.gz
+%source set m4 https://ftp.gnu.org/gnu/m4/m4-%{m4_version}.tar.gz
diff --git a/source-builder/config/net-snmp-5-1.cfg b/source-builder/config/net-snmp-5-1.cfg
index 3bdaa9f..c82e310 100644
--- a/source-builder/config/net-snmp-5-1.cfg
+++ b/source-builder/config/net-snmp-5-1.cfg
@@ -13,12 +13,11 @@ Summary:   NetSNMP is a SNMP v1, v2c and v3 Management Agent with MIB-II support
 Version:   %{net_snmp_version}
 Release:   %{release}
 URL: 	   http://www.net-snmp.org/
 # NetSNMP Source
-%source set net-snmp https://downloads.sourceforge.net/project/net-snmp/net-snmp/%{net_snmp_version}/net-snmp-%{net_snmp_version}.tar.gz
+%source set net-snmp http://downloads.sourceforge.net/project/net-snmp/net-snmp/%{net_snmp_version}/net-snmp-%{net_snmp_version}.tar.gz
@@ -44,6 +43,7 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
   CFLAGS="${CFLAGS} %{net_snmp_cflags}"
+  LIBS="-lbsd -lm -lz -lrtemsdefaultconfig" \
   ../${source_dir_net_snmp}/configure \
     --host=%{_host} \
     --prefix=%{_prefix} \
diff --git a/source-builder/config/ntp-4-1.cfg b/source-builder/config/ntp-4-1.cfg
index 014c935..a7d5982 100644
--- a/source-builder/config/ntp-4-1.cfg
+++ b/source-builder/config/ntp-4-1.cfg
@@ -13,7 +13,6 @@ Summary:   NTP is the Network Time Protocol.
 Version:   %{ntp_version}
 Release:   %{release}
 URL: 	   http://www.ntp.org/
 # NTP Source
diff --git a/source-builder/config/or1ksim-1-1.cfg b/source-builder/config/or1ksim-1-1.cfg
index fb77567..468f524 100644
--- a/source-builder/config/or1ksim-1-1.cfg
+++ b/source-builder/config/or1ksim-1-1.cfg
@@ -13,7 +13,6 @@ Summary:   or1ksim-github
 Version:   %{or1ksim_version}
 Release:   %{release}
 URL: 	   https://github.com/openrisc/or1ksim
 # Source
diff --git a/source-builder/config/pixman-0-1.cfg b/source-builder/config/pixman-0-1.cfg
index f02c3d6..fc393e8 100644
--- a/source-builder/config/pixman-0-1.cfg
+++ b/source-builder/config/pixman-0-1.cfg
@@ -15,7 +15,6 @@ Summary:   Pixman is a low-level software library for pixel manipulation,
 Version:   %{pixman_version}
 Release:   %{release}
 URL: 	   http://www.pixman.org/
 # Source
diff --git a/source-builder/config/protobuf-2-1.cfg b/source-builder/config/protobuf-2-1.cfg
index f5b49c8..408c56f 100644
--- a/source-builder/config/protobuf-2-1.cfg
+++ b/source-builder/config/protobuf-2-1.cfg
@@ -15,12 +15,11 @@ Summary:   Protocol buffers are Googles language-neutral,
 Version:   %{protobuf_version}
 Release:   %{release}
 URL: 	   https://developers.google.com/protocol-buffers/
 # Protocol Buffers Source
-%source set protobuf https://github.com/google/protobuf/releases/download/v%{protobuf_version}/protobuf-%{protobuf_version}.tar.gz
+%source set protobuf https://github.com/protocolbuffers/protobuf/releases/download/v%{protobuf_version}/protobuf-%{protobuf_version}.tar.gz
diff --git a/source-builder/config/qemu-1-1.cfg b/source-builder/config/qemu-1-1.cfg
index c19419f..5d78f68 100644
--- a/source-builder/config/qemu-1-1.cfg
+++ b/source-builder/config/qemu-1-1.cfg
@@ -4,103 +4,6 @@
 # This configuration file configure's, make's and install's QEMU.
-%if %{release} == %{nil}
-%define release 1
-%endif
+%define qemu_disables --disable-smartcard-nss
-%select qemu-snapshot
-# The description.
-Name:      qemu-%{qemu_version}-%{_host}-%{release}
-Summary:   Qemu is a simulator of various processors.
-Version:   %{qemu_version}
-URL: 	   http://www.qemu.org/
-# Source
-%source set qemu http://wiki.qemu-project.org/download/qemu-%{qemu_version}.tar.bz2
-%prep
-  build_top=$(pwd)
-  source_dir_qemu="qemu-%{qemu_version}"
-  %source setup qemu -q -n qemu-%{qemu_version}
-  %patch setup qemu -p1
-  cd ${build_top}
-%build
-  build_top=$(pwd)
-  cd ${build_dir}
-  %if %{pkgconfig check vdeplug}
-    VDE_CONFIG="--enable-vde"
-    VDE_CFLAGS="%{pkgconfig cflags vdeplug}"
-    VDE_LDFLAGS="%{pkgconfig ldflags vdeplug} %{pkgconfig libs vdeplug}"
-  %endif
-    CROSS_PREFIX_OPTION="--cross-prefix=%{_host}-"
-  fi
-  SYSROOT=$SB_TMPPREFIX
-  # The --extra-cflags and --extra-ldflags do not work as expected.
-  # Hack warning: MSYS2 does not seem to convert the path to
-  #               a shell path from Windows so we keep them
-  #               separate and handle it in the pkgconfig tool.
-  PKG_CONFIG_DEFAULT_PATH=${PKG_CONFIG_PATH} \
-  PKG_CONFIG_PATH=$SYSROOT/lib/pkgconfig \
-  PKG_CONFIG_BUILD_TOP_DIR=$SB_TMPROOT \
-  %{_ld_library_path}=$SYSROOT/lib \
-  LDFLAGS="-Wl,-rpath -Wl,/$SB_PREFIX_CLEAN/lib ${VDE_LDFLAGS}" \
-  CFLAGS="${CFLAGS} ${VDE_CFLAGS}" \
-  ../${source_dir_qemu}/configure \
-    --prefix=%{_prefix} \
-    ${CROSS_PREFIX_OPTION} \
-    --make=%{__make} \
-    ${VDE_CONFIG} \
-    --disable-smartcard-nss \
-    --disable-tools \
-    --disable-pie \
-    --disable-vnc \
-    --disable-sdl \
-    --disable-gtk \
-    --disable-opengl \
-    --disable-netmap
-  cd ${build_top}
-%install
-  build_top=$(pwd)
-  cd ${build_dir}
-  cd ${build_top}
+%include %{_configdir}/qemu-common-1.cfg
diff --git a/source-builder/config/sqlite-3-1.cfg b/source-builder/config/sqlite-3-1.cfg
index a748848..a0863bd 100644
--- a/source-builder/config/sqlite-3-1.cfg
+++ b/source-builder/config/sqlite-3-1.cfg
@@ -11,16 +11,16 @@
 Summary:   SQLite is an in-process library that implements a
            self-contained, serverless, zero-configuration,
-	   transactional SQL database engine.
+           transactional SQL database engine.
 Version:   %{sqlite_version}
 Release:   %{release}
-URL: 	   http://www.sqlite.org/
+URL:       https://www.sqlite.org/
 # Sqlite Source
-%source set sqlite http://www.sqlite.org/%{sqlite_src_year}/sqlite-src-%{sqlite_src_version}.zip
+%source set sqlite \
+    https://www.sqlite.org/%{sqlite_src_year}/sqlite-autoconf-%{sqlite_src_version}.tar.gz
@@ -28,8 +28,8 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
 %prep
   build_top=$(pwd)
-  source_dir_sqlite="sqlite-src-%{sqlite_src_version}"
-  %source setup sqlite -q -n sqlite-src-%{sqlite_src_version}
+  source_dir_sqlite="sqlite-autoconf-%{sqlite_src_version}"
+  %source setup sqlite -q -n sqlite-autoconf-%{sqlite_src_version}
   %patch setup sqlite -p1
   cd ${build_top}
@@ -44,7 +44,21 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
   %{host_build_flags}
-  CFLAGS="${CFLAGS} -DSQLITE_OMIT_WAL=1 -DSQLITE_ENABLE_COLUMN_METADATA=1"
+  # RTEMS-specific SQLite configuration options.
+  # See also
+  # - https://sqlite.org/wal.html#noshm
+  # - https://sqlite.org/malloc.html
+  # Many other compile-time options may be passed in via CFLAGS.
+  #   See also https://sqlite.org/compile.html
+  # RTEMS filesystems do not support POSIX advisory file locks.  Applications
+  # must choose an appropriate SQLite VFS which avoids them, such as unix-none
+  # (no locking at all: Application logic must avoid collisions) or
+  # unix-dotfile.  This step must be performed at application startup time.
+  #   See also https://sqlite.org/c3ref/vfs_find.html
+  CFLAGS="${CFLAGS} -DSQLITE_MAX_MMAP_SIZE=0 -DSQLITE_DEFAULT_LOCKING_MODE=1 -DSQLITE_ENABLE_MEMSYS5"
   ../${source_dir_sqlite}/configure \
     --host=%{_host} \
@@ -58,17 +72,10 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
     --disable-largefile \
-    --disable-tcl \
-    --disable-readline \
-    --disable-amalgamation
+    --disable-readline
   %{__make} %{?_smp_mflags} sqlite3.h libsqlite3.la
-  # Create the sqlite shell executable so the install works.
-  touch sqlite3
   cd ${build_top}
 %install
@@ -77,10 +84,8 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
   cd ${build_dir}
+  # Warning: The unusual install targets avoid attempting to compile and link
+  # the SQLite3 command-line shell.  The SQLite3 shell is not supported by
+  # RTEMS.
+  %{__make} DESTDIR=$SB_BUILD_ROOT install-data install-libLTLIBRARIES
   cd ${build_top}
-  # Remove the sqlite shell as it is just a touch.
-  %{__rm} $SB_BUILD_ROOT%{_bindir}/sqlite3
diff --git a/source-builder/defaults.mc b/source-builder/defaults.mc
index c65fa22..8ed7003 100644
--- a/source-builder/defaults.mc
+++ b/source-builder/defaults.mc
@@ -40,6 +40,7 @@ nil:                 none,    none,     ''
 # Set to invalid values.
 _bset:               none,    none,     ''
+_bset_tmp:           none,    none,     ''
 name:                none,    none,     ''
 version:             none,    none,     ''
 release:             none,    none,     ''
@@ -55,20 +56,37 @@ _build:              triplet, required, ''
 _target:             none,    optional, ''
 # RTEMS release URL
-rtems_release_url:   none,    none,     'ftp://ftp.rtems.org/pub/rtems/releases/%{rtems_version}'
+rtems_release_url:   none,    none,     'https://ftp.rtems.org/pub/rtems/releases/%{rtems_version}'
 # The user
-_uid:                none,    convert,  '%(%{__id_u} -n)'
+_uid:                none,    convert,  '%(%{__id_u})'
 # Default flags that can be overridded to supply specific host or build
 # flags and include paths to the tools. The host is the final platform
 # the tools will run on and build is the host building the tools.
-host_cflags:         none,    convert,  '-O2 -pipe'
-host_cxxflags:       none,    convert,  '-O2 -pipe'
+host_cflags:         none,    convert,  '-O2 -g -pipe'
+host_cxxflags:       none,    convert,  '-O2 -g -pipe'
+host_ldflags:        none,    convert,  ''
 host_includes:       none,    convert,  ''
-build_cflags:        none,    convert,  '-O2 -pipe'
-build_cxxflags:      none,    convert,  '-O2 -pipe'
+host_libs:           none,    convert,  ''
+build_cflags:        none,    convert,  '-O2 -g -pipe'
+build_cxxflags:      none,    convert,  '-O2 -g -pipe'
+build_ldflags:       none,    convert,  ''
 build_includes:      none,    convert,  ''
+build_libs:          none,    convert,  ''
+# Build and staging paths.
+buildroot:           dir,     none,     '%{_tmppath}/%{buildname}-%{_uid}'
+buildcxcroot:        dir,     none,     '%{_tmppath}/%{buildname}-%{_uid}-cxc'
+buildxcroot:         dir,     none,     '%{_tmppath}/%{buildname}-%{_uid}-xx'
+stagingroot:         dir,     none,     '%{_tmppath}/sb-%{_uid}-staging'
+# Install mode can be installing or staging. Defaults to installing.
+install_mode:        none,    none,     'installing'
 # Extra path a platform can override.
 _extra_path:         none,    none,     '%{_sbdir}'
@@ -89,13 +107,11 @@ _buildcxcdir:        dir,     optional, '%{_topdir}/build/%{buildname}-cxc'
 _buildxcdir:         dir,     optional, '%{_topdir}/build/%{buildname}-xc'
 _docdir:             dir,     none,     '%{_defaultdocdir}'
 _tmppath:            dir,     none,     '%{_topdir}/build/tmp'
-_tmproot:            dir,     none,     '%{_tmppath}/sb-%{_uid}/%{_bset}'
-_tmpcxcroot:         dir,     none,     '%{_tmppath}/sb-%{_uid}-cxc/%{_bset}'
-buildroot:           dir,     none,     '%{_tmppath}/%{buildname}-%{_uid}'
-buildcxcroot:        dir,     none,     '%{_tmppath}/%{buildname}-%{_uid}-cxc'
-buildxcroot:         dir,     none,     '%{_tmppath}/%{buildname}-%{_uid}-xx'
+_tmproot:            dir,     none,     '%{_tmppath}/sb-%{_uid}/%{_bset_tmp}'
+_tmpcxcroot:         dir,     none,     '%{_tmppath}/sb-%{_uid}-cxc/%{_bset_tmp}'
 _datadir:            dir,     none,     '%{_prefix}/share'
 _defaultdocdir:      dir,     none,     '%{_prefix}/share/doc'
+_dry_run:            none,    none,     '0'
 _exeext:             none,    none,     ''
 _exec_prefix:        dir,     none,     '%{_prefix}'
 _bindir:             dir,     none,     '%{_exec_prefix}/bin'
@@ -123,6 +139,9 @@ _usrsrc:             dir,     none,     '%{_usr}/src'
 _var:                dir,     none,     '/usr/local/var'
 _varrun:             dir,     none,     '%{_var}/run'
+# Get source state
+_rsb_getting_source: none,    none,     '0'
 # Defaults, override in platform specific modules.
 ___setup_shell:      exe,     required, '/bin/sh'
 __aclocal:           exe,     optional, 'aclocal'
@@ -138,15 +157,16 @@ __bash:              exe,     optional, '/bin/bash'
 __bison:             exe,     required, '/usr/bin/bison'
 __bzip2:             exe,     required, '/usr/bin/bzip2'
 __cat:               exe,     required, '/bin/cat'
-__cc:                exe,     required, '/usr/bin/gcc'
+__cc:                exe,     required, 'gcc'
 __chgrp:             exe,     required, '/usr/bin/chgrp'
 __chmod:             exe,     required, '/bin/chmod'
 __chown:             exe,     required, '/usr/sbin/chown'
+__cmake:             exe,     optional, '/usr/bin/cmake'
 __cp:                exe,     required, '/bin/cp'
 __cpp:               exe,     none,     '%{__cc} -E'
 __cvs:               exe,     optional, '/usr/bin/cvs'
 __cvs_z:             none,    none,     '%{__cvs} -z 9'
-__cxx:               exe,     required, '/usr/bin/g++'
+__cxx:               exe,     required, 'g++'
 __flex:              exe,     required, '/usr/bin/flex'
 __git:               exe,     required, '/usr/bin/git'
 __grep:              exe,     required, '/usr/bin/grep'
@@ -179,7 +199,7 @@ __sed:               exe,     required, '/usr/bin/sed'
 __setup_post:        exe,     none,     '%{__chmod} -R a+rX,g-w,o-w .'
 __sh:                exe,     required, '/bin/sh'
 __tar:               exe,     required, '/usr/bin/tar'
-__tar_extract:       exe,     none,     '%{__tar} -xvvf'
+__tar_extract:       exe,     none,     '%{__tar} -xvv'
 __touch:             exe,     required, '/usr/bin/touch'
 __unzip:             exe,     required, '/usr/bin/unzip'
 __xz:                exe,     required, '/usr/bin/xz'
@@ -190,7 +210,7 @@ ___build_cmd:        none,    none,     '%{?_sudo:%{_sudo} }%{?_remsh:%{_remsh}
 ___build_post:       none,    none,     'exit 0'
 # Prebuild set up script.
-___build_pre:        none,    none,     '''# ___build_pre in as set up in defaults.py
+___build_pre:        none,    none,     '''# ___build_pre as set up in defaults.py
 # Save the original path away.
 export SB_ORIG_PATH=${PATH}
 # Directories
@@ -198,20 +218,24 @@ export SB_ORIG_PATH=${PATH}
 %{?_prefix:SB_PREFIX_CLEAN=$(echo "%{_prefix}" | %{__sed} -e 's/^\///')}
 SB_SOURCE_DIR="%{_sourcedir}"
 SB_BUILD_DIR="%{_builddir}"
-# host == build, use build; host != build , host uses host and build uses build
-SB_HOST_CFLAGS="%{host_cflags} %{host_includes}"
-SB_HOST_CXXFLAGS="%{host_cxxflags} %{host_includes}"
-SB_HOST_LDFLAGS="%{?host_ldflags:%{host_ldflags}}%{?_tmproot:-L%{_tmproot}/${SB_PREFIX_CLEAN}/lib}"
+# host == build, use build; host != build, host uses host and build uses build
+SB_HOST_CPPFLAGS="%{host_includes}"
+# Optionally do not add includes to c/cxx flags as newer configure's complain
+SB_HOST_CFLAGS="%{host_cflags} %{!?host_cflags_no_includes %{host_includes}}"
+SB_HOST_CXXFLAGS="%{host_cxxflags} %{!?host_cflags_no_includes %{host_includes}}"
+SB_HOST_LDFLAGS="%{host_ldflags} %{?_tmproot:-L%{_tmproot}/${SB_PREFIX_CLEAN}/lib}"
+SB_HOST_LIBS="%{host_libs}"
 SB_BUILD_CFLAGS="%{build_cflags} %{?_tmproot:-I%{_tmproot}/${SB_PREFIX_CLEAN}/include}"
 SB_BUILD_CXXFLAGS="%{build_cxxflags} %{?_tmproot:-I%{_tmproot}/${SB_PREFIX_CLEAN}/include}"
-SB_BUILD_LDFLAGS="%{?build_ldflags:%{build_ldflags}}%{?_tmproot:-L%{_tmproot}/${SB_PREFIX_CLEAN}/lib}"
+SB_BUILD_LDFLAGS="%{build_ldflags} %{?_tmproot:-L%{_tmproot}/${SB_PREFIX_CLEAN}/lib}"
+SB_BUILD_LBS="%{build_libs}"
 SB_CFLAGS="${SB_BUILD_CFLAGS} %{build_includes}"
 SB_CXXFLAGS="${SB_BUILD_CXXFLAGS} %{build_includes}"
 SB_ARCH="%{_arch}"
 SB_OS="%{_os}"
 export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
-export SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS
-export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS
+export SB_HOST_CPPFLAGS SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS SB_HOST_LIBS
+export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS SB_BUILD_LIBS
 export SB_CFLAGS SB_CXXFLAGS
 # Documentation
 SB_DOC_DIR="%{_docdir}"
@@ -298,7 +322,9 @@ FFLAGS="${FFLAGS:-${SB_CFLAGS}}" ; export FFLAGS ;
 # Build script support.
 build_directory:     none,    none,     '''
-  if test -z "%{_target}" ; then
+  # Cross-build (Xc) if no target or the host and target match.
+  # Canadian-cross (Cxc) if build, host and target are all different.
+  if test -z "%{_target}" -o "%{_host}" == "%{_target}" ; then
     build_dir="build-xc"
   else
     build_dir="build-cxc"
@@ -316,13 +342,19 @@ if test "%{_build}" != "%{_host}" ; then
   # Cross build
   CC=$(echo "%{_host}-%{_host_cc}" | sed -e 's,-std=gnu99 ,,')
   CXX=$(echo "%{_host}-%{_host_cxx}" | sed -e 's,-std=gnu99 ,,')
+  CPPFLAGS="${SB_HOST_CPPFLAGS}"
   CFLAGS="${SB_HOST_CFLAGS}"
   CXXFLAGS="${SB_HOST_CXXFLAGS}"
   LDFLAGS="${SB_HOST_LDFLAGS}"
+  LDLIBS="${SB_HOST_LIBS}"
+  LIBS="${SB_HOST_LIBS}"
   # Host
+  CPPFLAGS_FOR_HOST="${SB_HOST_CPPFLAGS}"
   CFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
   CXXFLAGS_FOR_HOST="${SB_HOST_CXXFLAGS}"
   LDFLAGS_FOR_HOST="${SB_HOST_LDFLAGS}"
+  LDLIBS_FOR_HOST="${SB_HOST_LIBS}"
+  LIBS_FOR_HOST="${SB_HOST_LIBS}"
   CXXFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
   CC_FOR_HOST=$(echo "%{_host_cc} ${SB_HOST_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
   CXX_FOR_HOST=$(echo "%{_host_cxx} ${SB_HOST_CXXFLAGS}" | sed -e 's,-std=gnu99 ,,')
@@ -330,30 +362,35 @@ if test "%{_build}" != "%{_host}" ; then
   CFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
   CXXFLAGS_FOR_BUILD="${SB_BUILD_CXXFLAGS}"
   LDFLAGS_FOR_BUILD="${SB_BUILD_LDFLAGS}"
+  LDLIBS_FOR_BUILD="${SB_BUILD_LIBS}"
+  LIBS_FOR_BUILD="${SB_BUILD_LIBS}"
   CXXFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
   CC_FOR_BUILD=$(echo "%{__cc} ${SB_BUILD_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
   CXX_FOR_BUILD=$(echo "%{__cxx} ${SB_BUILD_CXXFLAGS}" | sed -e 's,-std=gnu99 ,,')
 else
   LDFLAGS="${SB_BUILD_LDFLAGS}"
+  LDLIBS="${SB_BUILD_LIBS}"
+  LIBS="${SB_BUILD_LIBS}"
   CC=$(echo "%{__cc} ${SB_BUILD_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
   CXX=$(echo "%{__cxx} ${SB_BUILD_CXXFLAGS}" | sed -e 's,-std=gnu99 ,,')
   CC_FOR_BUILD=${CC}
   CXX_FOR_BUILD=${CXX}
 fi
-export CC CXX CFLAGS CXXFLAGS LDFLAGS
-export CC_FOR_HOST CXX_FOR_HOST CFLAGS_FOR_HOST CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST
-export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD LDFLAGS_FOR_BUILD'''
+export CC CXX CPPFLAGS CFLAGS CXXFLAGS LDFLAGS LIBS LDLIBS
+export CC_FOR_HOST CXX_FOR_HOST CPPFLAGS_FOR_HOST CFLAGS_FOR_HOST CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST LDLIBS_FOR_HOST LIBS_FOR_HOST
+export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD LDFLAGS_FOR_BUILD LDLIBS_FOR_BUILS LIBS_FOR_BUILS'''
 # Build/build flags.
 build_build_flags:    none,    none,     '''
 # Build and build flags means force build == host
 # gcc is not ready to be compiled with -std=gnu99
+LIBS="${SB_HOST_LIBS}"
 CC=$(echo "%{__cc} ${SB_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
 CXX=$(echo "%{__cxx} ${SB_CXXFLAGS}" | sed -e 's,-std=gnu99 ,,')
 CC_FOR_BUILD=${CC}
-export CC CXX CC_FOR_BUILD CXX_FOR_BUILD CFLAGS LDFLAGS'''
+export CC CXX CC_FOR_BUILD CXX_FOR_BUILD CFLAGS LDFLAGS LIBS'''
 # Default package settings
 _forced_static:     none,         none, '-Xlinker -Bstatic ${LIBS_STATIC} -Xlinker -Bdynamic'
@@ -361,7 +398,7 @@ __xz:                exe,     required, '/usr/bin/xz'
 # Mail Support
 _mail_smtp_host:   none,         none, 'localhost'
-_mail_tools_to:    none,         none, 'rtems-tooltestresults at rtems.org'
+_mail_tools_to:    none,         none, 'build at rtems.org'
 # Newlib ICONV encodings
 _newlib_iconv_encodings: none,      none, '''big5,cp775,cp850,cp852,cp855,\
@@ -372,3 +409,20 @@ iso_ir_111,koi8_r,koi8_ru,koi8_u,koi8_uni,ucs_2,ucs_2_internal,\
 ucs_2be,ucs_2le,ucs_4,ucs_4_internal,ucs_4be,ucs_4le,us_ascii,\
 utf_16,utf_16be,utf_16le,utf_8,win_1250,win_1251,win_1252,\
 win_1253,win_1254,win_1255,win_1256,win_1257,win_1258'''
+# Waf build root suffix, only use for win32 mingw ming32 OSs
+# If on Windows we need to add the driver prefix to the built root as waf
+# strips the driver prefix from the prefix path when joining it to the
+# destdir path. Waf is correct in doing this and the RSB is design to match
+# the configure behaviour which treats the whole path including the drive
+# prefix as part of the path as just a path.
+waf_build_root_suffix:   none,  none, ' %(echo %{_prefix} | cut -c 1-2)'
+# Makefile.inc support for staging
+rtems_makefile_inc:      none,  none, '''
+export RTEMS_ROOT=%{rtems_bsp_rtems_root}
+export PROJECT_RELEASE=%{rtems_bsp_prefix}
+export RTEMS_MAKEFILE_PATH=%{rtems_bsp_prefix}
diff --git a/source-builder/pkg-config b/source-builder/pkg-config
index fa251e5..10db546 100755
--- a/source-builder/pkg-config
+++ b/source-builder/pkg-config
@@ -35,7 +35,6 @@ import os
 import sys
 base = os.path.dirname(sys.argv[0])
-sys.path.insert(0, base + '/sb')
 try:
     import argparse
@@ -47,16 +46,12 @@ except:
         print("Incorrect Source Builder installation", file = sys.stderr)
         sys.exit(1)
-try:
-    import pkgconfig
-except ImportError:
-    print("Incorrect Source Builder installation", file = sys.stderr)
-    sys.exit(1)
+import sb.pkgconfig
 # Make trace true to get a file of what happens and what is being asked.
-trace = True
+trace = False
 trace_stdout = False
 logfile = 'pkg-config.log'
 out = None
@@ -65,7 +60,7 @@ srcfd = None
 # Write all the package source parsed to a single file.
-trace_src = True
+trace_src = False
 if trace_src:
     srcfd = open('pkg-src.txt', 'w')
@@ -164,7 +159,7 @@ def run(argv):
                       default = False,
                       help = 'Ignored')
     opts.add_argument('--prefix-variable', dest = 'prefix', action = 'store',
-                      nargs = 1, default = pkgconfig.default_prefix(),
+                      nargs = 1, default = sb.pkgconfig.default_prefix(),
                       help = 'Define the prefix.')
     opts.add_argument('--static', dest = 'static', action = 'store_true',
                       default = False,
@@ -173,7 +168,7 @@ def run(argv):
                       default = False,
                       help = 'Dump the package if one is found.')
-    args = opts.parse_args(argv[1:])
+    args = opts.parse_args(argv)
     if (args.exists and (args.exact_version or args.max_version)) or \
             (args.exact_version and (args.exists or args.max_version)) or \
@@ -181,7 +176,7 @@ def run(argv):
         raise error('only one of --exists, --exact-version, or --max-version')
     if args.dont_define_prefix:
-        args.prefix = pkgconfig.default_prefix(False)
+        args.prefix = sb.pkgconfig.default_prefix(False)
     exists = False
@@ -190,7 +185,7 @@ def run(argv):
     if args.atleast_pkgconfig_version:
         ec = 0
     else:
-        ec, pkg, flags = pkgconfig.check_package(args.libraries, args, log, src)
+        ec, pkg, flags = sb.pkgconfig.check_package(args.libraries, args, log, src)
         if ec == 0:
             if args.cflags:
                 if len(flags['cflags']):
@@ -212,15 +207,15 @@ def run(argv):
 try:
     log('-' * 40)
     log('pkg-config', lf = False)
-    for a in sys.argv[1:]:
+    for a in sys.argv[2:]:
         log(' "%s"' % (a), lf = False)
     log('')
-    ec = run(sys.argv)
+    ec = run(sys.argv[1:])
     log('ec = %d' % (ec))
 except ImportError:
     print("incorrect package config installation", file = sys.stderr)
     sys.exit(1)
-except pkgconfig.error as e:
+except sb.pkgconfig.error as e:
     print('error: %s' % (e), file = sys.stderr)
     sys.exit(1)
 sys.exit(ec)
diff --git a/source-builder/sb-check b/source-builder/sb-check
index d23b799..8c60bf6 100755
--- a/source-builder/sb-check
+++ b/source-builder/sb-check
@@ -20,12 +20,10 @@
 from __future__ import print_function
-import sys, os
-base = os.path.dirname(sys.argv[0])
 try:
-    import check
-    check.run()
+    import sb.check
+    sb.check.run()
 except ImportError:
+    import sys
     sys.exit(1)
diff --git a/source-builder/sb-defaults b/source-builder/sb-defaults
index 790a5e5..2fd2121 100755
--- a/source-builder/sb-defaults
+++ b/source-builder/sb-defaults
@@ -20,12 +20,11 @@
-import sys, os
+import sys
 try:
-    import options
-    options.run(sys.argv)
+    import sb.options
+    sb.options.run(sys.argv)
 except ImportError:
     sys.exit(1)
diff --git a/source-builder/sb-get-sources b/source-builder/sb-get-sources
new file mode 100755
index 0000000..97ee419
--- /dev/null
+++ b/source-builder/sb-get-sources
@@ -0,0 +1,30 @@
+#! /usr/bin/env python
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2010-2019 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Permission to use, copy, modify, and/or distribute this software for any
+# purpose with or without fee is hereby granted, provided that the above
+# copyright notice and this permission notice appear in all copies.
+# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
+# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
+# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
+# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
+# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
+# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
+# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+from __future__ import print_function
+try:
+    import sb.getsources
+    sb.getsources.run()
+except ImportError:
+    import sys
+    print("Incorrect Source Builder installation", file = sys.stderr)
+    sys.exit(1)
diff --git a/source-builder/sb-reports b/source-builder/sb-reports
index 3330be3..194c4ab 100755
--- a/source-builder/sb-reports
+++ b/source-builder/sb-reports
@@ -20,12 +20,11 @@
-import sys, os
+import sys
 try:
-    import reports
-    reports.run(sys.argv)
+    import sb.reports
+    sb.reports.run(sys.argv)
 except ImportError:
     sys.exit(1)
diff --git a/source-builder/sb-rtems-config b/source-builder/sb-rtems-config
index 1633b6b..a84b9c8 100755
--- a/source-builder/sb-rtems-config
+++ b/source-builder/sb-rtems-config
@@ -20,12 +20,11 @@
-import sys, os
+import sys
 try:
-    import rtemsconfig
-    rtemsconfig.run(sys.argv)
+    import sb.rtemsconfig
+    sb.rtemsconfig.run(sys.argv)
 except ImportError:
     sys.exit(1)
diff --git a/source-builder/sb-set-builder b/source-builder/sb-set-builder
index 561199e..96dd919 100755
--- a/source-builder/sb-set-builder
+++ b/source-builder/sb-set-builder
@@ -20,13 +20,10 @@
-import sys, os
 try:
-    import setbuilder
-    setbuilder.run()
+    import sb.setbuilder
+    sb.setbuilder.run()
 except ImportError:
+    import sys
     sys.exit(1)
diff --git a/source-builder/sb-track b/source-builder/sb-track
index 0000000..64daeb8
--- /dev/null
+++ b/source-builder/sb-track
@@ -0,0 +1,29 @@
+try:
+    import sb.track
+    sb.track.run()
+    import sys
+    sys.exit(1)
diff --git a/source-builder/sb/__init__.py b/source-builder/sb/__init__.py
index 0000000..c4275e2
--- /dev/null
+++ b/source-builder/sb/__init__.py
@@ -0,0 +1,20 @@
+# Copyright 2020 Chris Johns (chrisj at rtems.org)
diff --git a/source-builder/sb/build.py b/source-builder/sb/build.py
index b995e6b..16a495b 100644
--- a/source-builder/sb/build.py
+++ b/source-builder/sb/build.py
@@ -1,6 +1,6 @@
-# Copyright 2010-2013 Chris Johns (chrisj at rtems.org)
+# Copyright 2010-2018 Chris Johns (chrisj at rtems.org)
@@ -33,23 +33,42 @@ import stat
 import sys
 try:
-    import check
-    import config
-    import download
-    import error
-    import ereport
-    import execute
-    import log
-    import options
-    import path
-    import sources
-    import version
+    from . import check
+    from . import config
+    from . import download
+    from . import error
+    from . import ereport
+    from . import execute
+    from . import log
+    from . import options
+    from . import path
+    from . import sources
+    from . import version
 except KeyboardInterrupt:
     print('abort: user terminated')
     sys.exit(1)
 except:
-    print('error: unknown application load error')
-    sys.exit(1)
+    raise
+def humanize_number(num, suffix):
+    for unit in ['','K','M','G','T','P','E','Z']:
+        if abs(num) < 1024.0:
+            return "%5.3f%s%s" % (num, unit, suffix)
+        num /= 1024.0
+    return "%.3f%s%s" % (size, 'Y', suffix)
+def short_name(name):
+    # If on Windows use short names to keep the build paths as short as possible.
+    if options.host_windows:
+        buildname = ''
+        add = True
+        for n in name.split('-'):
+            buildname += n[0]
+        return buildname
+    else:
+        return name
 class script:
     """Create and manage a shell script."""
@@ -62,7 +81,15 @@ class script:
         self.lc = 0
     def append(self, text):
+        is_str = False
         if type(text) is str:
+            is_str = True
+        try:
+            if type(text) is unicode:
+                is_str = True
+        except:
+            pass
+        if is_str:
             text = text.splitlines()
         if not log.quiet:
             i = 0
@@ -93,29 +120,9 @@ class script:
 class build:
     """Build a package given a config file."""
-    def _name_(self, name):
-        # If on Windows use shorter names to keep the build paths.
-        if options.host_windows:
-            buildname = ''
-            add = True
-            for c in name:
-                if c == '-':
-                    add = True
-                elif add:
-                    buildname += c
-                    add = False
-            return buildname
-        else:
-            return name
     def _generate_report_(self, header, footer = None):
-        label, result = self.opts.with_arg('error-report')
-        if (label.startswith('without_') and result != 'yes') or \
-           (label.startswith('with_') and result != 'no'):
-            ereport.generate('rsb-report-%s.txt' % self.macros['name'],
-                             self.opts, header, footer)
+        ereport.generate('rsb-report-%s.txt' % self.macros['name'],
+                         self.opts, header, footer)
     def __init__(self, name, create_tar_files, opts, macros = None):
         try:
@@ -127,8 +134,9 @@ class build:
             log.notice('config: ' + name)
             self.set_macros(macros)
             self.config = config.file(name, opts, self.macros)
-            self.script = script()
-            self.macros['buildname'] = self._name_(self.macros['name'])
+            self.script_build = script()
+            self.script_clean = script()
+            self.macros['buildname'] = short_name(self.macros['name'])
         except error.general as gerr:
             log.notice(str(gerr))
             log.stderr('Build FAILED')
@@ -194,7 +202,7 @@ class build:
             not _disable_installing and \
             not _canadian_cross
-    def source(self, name):
+    def source(self, name, strip_components, download_only):
         # Return the list of sources. Merge in any macro defined sources as
         # these may be overridden by user loaded macros.
@@ -229,27 +237,37 @@ class build:
                     if o.startswith('--rsb-file'):
                        os_ = o.split('=')
                        if len(os_) != 2:
-                           raise error.general('invalid --rsb-file option: %s' % (' '.join(args)))
+                           raise error.general('invalid --rsb-file option: %s' % \
+                                               (' '.join(args)))
                        if os_[0] != '--rsb-file':
+                                               (' '.join(args)))
                        file_override = os_[1]
                 opts = [o for o in opts if not o.startswith('--rsb-')]
             url = self.config.expand(' '.join(url))
-            src = download.parse_url(url, '_sourcedir', self.config, self.opts, file_override)
+            src = download.parse_url(url, '_sourcedir',
+                                     self.config, self.opts, file_override)
             download.get_file(src['url'], src['local'], self.opts, self.config)
-            if 'symlink' in src:
-                sname = name.replace('-', '_')
-                src['script'] = '%%{__ln_s} %s ${source_dir_%s}' % (src['symlink'], sname)
-            elif 'compressed' in src:
-                # Zip files unpack as well so do not use tar.
-                src['script'] = '%s %s' % (src['compressed'], src['local'])
-                if src['compressed-type'] != 'zip':
-                    src['script'] += ' | %{__tar_extract} -'
-            else:
-                src['script'] = '%%{__tar_extract} %s' % (src['local'])
-            srcs += [src]
+            if not download_only:
+                if strip_components > 0:
+                    tar_extract = '%%{__tar_extract} --strip-components %d' % \
+                        (strip_components)
+                else:
+                    tar_extract = '%{__tar_extract}'
+                if 'symlink' in src:
+                    sname = name.replace('-', '_')
+                    src['script'] = '%%{__ln_s} %s ${source_dir_%s}' % \
+                        (src['symlink'], sname)
+                elif 'compressed' in src:
+                    # Zip files unpack as well so do not use tar.
+                    src['script'] = '%s %s' % (src['compressed'], src['local'])
+                    if src['compressed-type'] != 'zip':
+                        src['script'] += ' | %s -f -' % (tar_extract)
+                else:
+                    src['script'] = '%s -f %s' % (tar_extract, src['local'])
+                srcs += [src]
         return srcs
     def source_setup(self, package, args):
@@ -257,7 +275,7 @@ class build:
         setup_name = args[1]
         args = args[1:]
         try:
-            opts, args = getopt.getopt(args[1:], 'qDcn:ba')
+            opts, args = getopt.getopt(args[1:], 'qDcn:bas:gE')
         except getopt.GetoptError as ge:
             raise error.general('source setup error: %s' % str(ge))
         quiet = False
@@ -267,7 +285,10 @@ class build:
         deleted_dir = False
         created_dir = False
         changed_dir = False
+        no_errors = False
+        strip_components = 0
         opt_name = None
+        download_only = False
         for o in opts:
             if o[0] == '-q':
                 quiet = True
@@ -281,31 +302,65 @@ class build:
                 unpack_before_chdir = True
             elif o[0] == '-a':
                 unpack_before_chdir = False
+            elif o[0] == '-E':
+                no_errors = True
+            elif o[0] == '-s':
+                if not o[1].isdigit():
+                    raise error.general('source setup error: invalid strip count: %s' % \
+                                        (o[1]))
+                strip_components = int(o[1])
+            elif o[0] == '-g':
+                download_only = True
         name = None
-        for source in self.source(setup_name):
+        for source in self.source(setup_name, strip_components, download_only):
             if name is None:
                 if opt_name is None:
                     if source:
                         opt_name = source['name']
                     else:
-                        raise error.general('setup source tag not found: %d' % (source_tag))
+                        raise error.general('setup source tag not found: %d' % \
+                                            (source_tag))
                 else:
                     name = opt_name
-            self.script.append(self.config.expand('cd %{_builddir}'))
-            if not deleted_dir and  delete_before_unpack:
-                self.script.append(self.config.expand('%{__rm} -rf ' + name))
-                deleted_dir = True
-            if not created_dir and create_dir:
-                self.script.append(self.config.expand('%{__mkdir_p} ' + name))
-                created_dir = True
-            if not changed_dir and (not unpack_before_chdir or create_dir):
-                self.script.append(self.config.expand('cd ' + name))
-                changed_dir = True
-            self.script.append(self.config.expand(source['script']))
-        if not changed_dir and (unpack_before_chdir and not create_dir):
+                self.script_build.append(self.config.expand('cd %{_builddir}'))
+                if not deleted_dir and delete_before_unpack and name is not None:
+                    self.script_build.append(self.config.expand('%{__rm} -rf ' + name))
+                    deleted_dir = True
+                if not created_dir and create_dir and name is not None:
+                    self.script_build.append(self.config.expand('%{__mkdir_p} ' + name))
+                    created_dir = True
+                if not changed_dir and (not unpack_before_chdir or create_dir) and \
+                   name is not None:
+                    self.script_build.append(self.config.expand('cd ' + name))
+                    changed_dir = True
+                # On Windows tar can fail on links if the link appears in the
+                # tar file before the target of the link exists. We can assume the
+                # tar file is correct, that is all files and links are valid,
+                # so on error redo the untar a second time.
+                if options.host_windows or no_errors:
+                    self.script_build.append('set +e')
+                self.script_build.append(self.config.expand(source['script']))
+                if options.host_windows or not no_errors:
+                    self.script_build.append('tar_exit=$?')
+                    self.script_build.append('set -e')
+                    if no_errors:
+                        self.script_build.append(' set +e')
+                        self.script_build.append(' ' + self.config.expand(source['script']))
+                        self.script_build.append(' set -e')
+                    else:
+                        self.script_build.append('if test $tar_exit != 0; then')
+                        self.script_build.append('fi')
+        if not changed_dir and (unpack_before_chdir and not create_dir) and \
+           name is not None and not download_only:
             changed_dir = True
-        self.script.append(self.config.expand('%{__setup_post}'))
+        self.script_build.append(self.config.expand('%{__setup_post}'))
     def patch_setup(self, package, args):
         name = args[1]
@@ -327,7 +382,7 @@ class build:
                 else:
                     url += [pp]
             if len(url) == 0:
-                raise error.general('patch URL not found: %s' % (' '.join(args)))
+                raise error.general('patch URL not found: %s' % (' '.join(opts)))
             # Look for --rsb-file as an option we use as a local file name.
             # This can be used if a URL has no reasonable file name the
@@ -339,9 +394,11 @@ class build:
                        os_ = o.split('=')
                        if len(os_) != 2:
+                                               (' '.join(opts)))
+                                               (' '.join(opts)))
             if len(opts) == 0:
@@ -353,7 +410,8 @@ class build:
             # Parse the URL first in the source builder's patch directory.
-            patch = download.parse_url(url, '_patchdir', self.config, self.opts, file_override)
+            patch = download.parse_url(url, '_patchdir', self.config,
+                                       self.opts, file_override)
             # Download the patch
@@ -363,7 +421,7 @@ class build:
             else:
                 patch['script'] = '%{__cat} ' + patch['local']
             patch['script'] += ' | %%{__patch} %s' % (opts)
-            self.script.append(self.config.expand(patch['script']))
+            self.script_build.append(self.config.expand(patch['script']))
     def run(self, command, shell_opts = '', cwd = None):
         e = execute.capture_execution(log = log.default, dump = self.opts.quiet())
@@ -381,7 +439,7 @@ class build:
             self.mkdir(builddir)
     def prep(self, package):
-        self.script.append('echo "==> %prep:"')
+        self.script_build.append('echo "==> %prep:"')
         _prep = package.prep()
         if _prep:
             for l in _prep:
@@ -403,59 +461,78 @@ class build:
                         sources.hash(args[1:], self.macros, err)
                         self.hash(package, args)
                     else:
-                        self.script.append(' '.join(args))
+                        self.script_build.append(' '.join(args))
     def build(self, package):
-        self.script.append('echo "==> clean %{buildroot}: ${SB_BUILD_ROOT}"')
-        self.script.append('%s ${SB_BUILD_ROOT}' %
-                           (self.config.expand('%{__rmdir}')))
-                           (self.config.expand('%{__mkdir_p}')))
-        self.script.append('echo "==> %build:"')
+        self.script_build.append('echo "==> clean %{buildroot}: ${SB_BUILD_ROOT}"')
+        self.script_build.append('%s ${SB_BUILD_ROOT}' %
+                                 (self.config.expand('%{__rmdir}')))
+                                 (self.config.expand('%{__mkdir_p}')))
+        self.script_build.append('echo "==> %build:"')
         _build = package.build()
         if _build:
             for l in _build:
-                self.script.append(l)
+                self.script_build.append(l)
     def install(self, package):
-        self.script.append('echo "==> %install:"')
+        self.script_build.append('echo "==> %install:"')
         _install = package.install()
         if _install:
             for l in _install:
                 args = l.split()
     def files(self, package):
         if self.create_tar_files \
            and not self.macros.get('%{_disable_packaging'):
-            self.script.append('echo "==> %files:"')
+            self.script_build.append('echo "==> %files:"')
             inpath = path.abspath(self.config.expand('%{buildroot}'))
             tardir = path.abspath(self.config.expand('%{_tardir}'))
-            self.script.append(self.config.expand('if test -d %s; then' % (inpath)))
-            self.script.append(self.config.expand('  %%{__mkdir_p} %s' % tardir))
-            self.script.append(self.config.expand('  cd ' + inpath))
+            self.script_build.append(self.config.expand('if test -d %s; then' % (inpath)))
+            self.script_build.append(self.config.expand('  %%{__mkdir_p} %s' % tardir))
+            self.script_build.append(self.config.expand('  cd ' + inpath))
             tar = path.join(tardir, package.long_name() + '.tar.bz2')
             cmd = self.config.expand('  %{__tar} -cf - . ' + '| %{__bzip2} > ' + tar)
-            self.script.append(cmd)
-            self.script.append(self.config.expand('  cd %{_builddir}'))
-            self.script.append('fi')
+            self.script_build.append(cmd)
+            self.script_build.append(self.config.expand('  cd %{_builddir}'))
     def clean(self, package):
-        self.script.append('echo "==> %clean:"')
+        self.script_clean.reset()
+        self.script_clean.append(self.config.expand('%{___build_template}'))
+        self.script_clean.append('echo "=> ' + package.name() + ': CLEAN"')
+        self.script_clean.append('echo "==> %clean:"')
         _clean = package.clean()
         if _clean is not None:
             for l in _clean:
                 args = l.split()
+                self.script_clean.append(' '.join(args))
+    def sizes(self, package):
+        def _sizes(package, what, path):
+            package.set_size(what, path)
+            s = humanize_number(package.get_size(what), 'B')
+            log.trace('size: %s (%s): %s (%d)' % (what, path, s, package.get_size(what)))
+            return s
+        s = {}
+        for p in [('build', '%{_builddir}'),
+                  ('build', '%{buildroot}'),
+                  ('installed', '%{buildroot}')]:
+            hs = _sizes(package, p[0], self.config.expand(p[1]))
+            s[p[0]] = hs
+        log.notice('sizes: %s: %s (installed: %s)' % (package.name(),
+                                                      s['build'],
+                                                      s['installed']))
     def build_package(self, package):
         if self.canadian_cross():
             if not self.config.defined('%{allow_cxc}'):
                 raise error.general('Canadian Cross is not allowed')
-            self.script.append('echo "==> Candian-cross build/target:"')
-            self.script.append('SB_CXC="yes"')
+            self.script_build.append('echo "==> Candian-cross build/target:"')
+            self.script_build.append('SB_CXC="yes"')
         else:
-            self.script.append('SB_CXC="no"')
+            self.script_build.append('SB_CXC="no"')
         self.build(package)
         self.install(package)
         self.files(package)
@@ -501,18 +578,24 @@ class build:
                 log.trace('---- macro maps %s' % ('-' * 55))
                 log.trace('%s' % (str(self.config.macros)))
                 log.trace('-' * 70)
-                self.script.reset()
-                self.script.append(self.config.expand('%{___build_template}'))
-                self.script.append('echo "=> ' + name + ':"')
+                self.script_build.reset()
+                self.script_build.append(self.config.expand('%{___build_template}'))
+                self.script_build.append('echo "=> ' + name + ': BUILD"')
                 self.prep(package)
                 self.build_package(package)
                 if not self.opts.dry_run():
                     self.builddir()
-                    sn = path.join(self.config.expand('%{_builddir}'), 'doit')
-                    log.output('write script: ' + sn)
-                    self.script.write(sn)
+                    build_sn = path.join(self.config.expand('%{_builddir}'), 'do-build')
+                    log.output('write script: ' + build_sn)
+                    self.script_build.write(build_sn)
+                    clean_sn = path.join(self.config.expand('%{_builddir}'), 'do-clean')
+                    log.output('write script: ' + clean_sn)
+                    self.script_clean.write(clean_sn)
                     log.notice('building: %s%s' % (cxc_label, name))
-                    self.run(sn)
+                    self.run(build_sn)
+                    self.sizes(package)
+                    log.notice('cleaning: %s%s' % (cxc_label, name))
+                    self.run(clean_sn)
@@ -539,6 +622,22 @@ class build:
         package = packages['main']
         return package.disabled()
+    def get_build_size(self):
+        package = self.main_package()
+        if package.disabled():
+            return 0
+        return package.get_size('build')
+    def get_installed_size(self):
+            return 0
+        return package.get_size('installed')
+    def includes(self):
+        if self.config:
+            return self.config.includes()
 def get_configs(opts):
     def _scan(_path, ext):
@@ -552,10 +651,17 @@ def get_configs(opts):
         return configs
     configs = { 'paths': [], 'files': [] }
-    for cp in opts.defaults.expand('%{_configdir}').split(':'):
+    paths = opts.defaults.expand('%{_configdir}').split(':')
+    root = path.host(os.path.commonprefix(paths))
+    configs['root'] = root
+    configs['localpaths'] = [lp[len(root):] for lp in paths]
+    for cp in paths:
         hcp = path.host(path.abspath(cp))
         configs['paths'] += [hcp]
-        configs['files'] += _scan(hcp, ['.cfg', '.bset'])
+        hpconfigs = sorted(set(_scan(hcp, ['.cfg', '.bset'])))
+        hcplocal = hcp[len(root):]
+        configs[hcplocal] = [path.join(hcplocal, c) for c in hpconfigs]
+        configs['files'] += hpconfigs
     configs['files'] = sorted(set(configs['files']))
     return configs
@@ -576,7 +682,7 @@ def run(args):
     try:
         optargs = { '--list-configs': 'List available configurations' }
         opts = options.load(args, optargs)
-        log.notice('RTEMS Source Builder, Package Builder, %s' % (version.str()))
+        log.notice('RTEMS Source Builder, Package Builder, %s' % (version.string()))
         opts.log_info()
         if not check.host_setup(opts):
             if not opts.force():
diff --git a/source-builder/sb/check.py b/source-builder/sb/check.py
index ef8f6a4..7e23223 100644
--- a/source-builder/sb/check.py
+++ b/source-builder/sb/check.py
@@ -23,16 +23,16 @@
-import os
-import error
-import execute
 import fnmatch
-import log
-import options
-import path
+import os
 import re
-import version
+from . import error
+from . import execute
+from . import log
+from . import options
+from . import path
+from . import version
 def _check_none(_opts, macro, value, constraint):
     return True
@@ -104,20 +104,24 @@ def path_check(opts, silent = False):
     if 'PATH' in os.environ:
         paths = os.environ['PATH'].split(os.pathsep)
         for p in paths:
-            if len(p.strip()) == 0:
-                if not silent:
-                    log.notice('error: environment PATH contains an empty path')
-                return False
-            elif not options.host_windows and (p.strip() == '.' or p.strip() == '..'):
+            try:
+                if len(p.strip()) == 0:
+                    if not silent:
+                        log.notice('error: environment PATH contains an empty path')
+                    return False
+                elif not options.host_windows and (p.strip() == '.' or p.strip() == '..'):
+                    if not silent:
+                        log.notice('error: environment PATH invalid path: %s' % (p))
+                    return False
+                elif not path.exists(p):
+                    if not silent and opts.warn_all():
+                        log.notice('warning: environment PATH not found: %s' % (p))
+                elif not path.isdir(p):
+                        log.notice('warning: environment PATH not a directory: %s' % (p))
+            except Exception as e:
                 if not silent:
-                    log.notice('error: environment PATH invalid path: %s' % (p))
-                return False
-            elif not path.exists(p):
-                if not silent and opts.warn_all():
-                    log.notice('warning: environment PATH not found: %s' % (p))
-            elif not path.isdir(p):
-                    log.notice('warning: environment PATH not a directory: %s' % (p))
+                    log.notice('warning: environment PATH suspicious path: %s' % (e))
     return True
@@ -264,7 +268,7 @@ def run():
     import sys
     try:
         _opts = options.load(args = sys.argv, logfile = False)
-        log.notice('RTEMS Source Builder - Check, %s' % (version.str()))
+        log.notice('RTEMS Source Builder - Check, %s' % (version.string()))
         orphans = _opts.parse_args('--check-orphans', error = False, extra = False)
         if orphans:
diff --git a/source-builder/sb/config.py b/source-builder/sb/config.py
index f5bd81c..cd0bf94 100644
--- a/source-builder/sb/config.py
+++ b/source-builder/sb/config.py
@@ -1,6 +1,6 @@
-# Copyright 2010-2016 Chris Johns (chrisj at rtems.org)
@@ -34,28 +34,31 @@ import re
 import sys
 try:
-    import error
-    import execute
-    import log
-    import options
-    import path
-    import pkgconfig
-    import sources
+    from . import log
+    from . import pkgconfig
     print('user terminated', file = sys.stderr)
     sys.exit(1)
 except:
-    print('error: unknown application load error', file = sys.stderr)
-    sys.exit(1)
+    raise
 def _check_bool(value):
+    istrue = None
     if value.isdigit():
         if int(value) == 0:
             istrue = False
         else:
             istrue = True
     else:
-        istrue = None
+        if type(value) is str and len(value) == 2 and value[0] == '!':
+            istrue = _check_bool(value[1])
+            if type(istrue) is bool:
+                istrue = not istrue
     return istrue
 def _check_nil(value):
@@ -73,6 +76,7 @@ class package:
         self.directives = {}
         self.infos = {}
+        self.sizes = {}
     def __str__(self):
@@ -218,6 +222,16 @@ class package:
     def disabled(self):
         return len(self.name()) == 0
+    def set_size(self, what, path_):
+        if what not in self.sizes:
+            self.sizes[what] = 0
+        self.sizes[what] += path.get_size(path_)
+    def get_size(self, what):
+        if what in self.sizes:
+            return self.sizes[what]
+        return 0
 class file:
     """Parse a config file."""
@@ -268,6 +282,7 @@ class file:
         return s
     def _reset(self, name):
+        self.parent = 'root'
         self.name = name
         self.load_depth = 0
         self.configpath = []
@@ -312,16 +327,18 @@ class file:
             log.output(text)
     def _error(self, msg):
-        err = 'error: %s' % (self._name_line_msg(msg))
-        log.stderr(err)
-        log.output(err)
-        self.in_error = True
-            log.stderr('warning: switched to dry run due to errors')
-            self.opts.set_dry_run()
+            if self.opts.keep_going():
+                err = 'error: %s' % (self._name_line_msg(msg))
+                log.stderr(err)
+                log.output(err)
+                self.in_error = True
+                log.stderr('warning: switched to dry run due to errors')
+                self.opts.set_dry_run()
+        raise error.general(self._name_line_msg(msg))
     def _label(self, name):
-        if name.startswith('%{') and name[-1] is '}':
+        if name.startswith('%{') and name[-1] == '}':
             return name
         return '%{' + name.lower() + '}'
@@ -402,29 +419,66 @@ class file:
             print('-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=')
         return macros
-    def _shell(self, line):
-        sl = self.sf.findall(line)
-        if len(sl):
-            e = execute.capture_execution()
-            for s in sl:
+    def _shell(self, line, nesting = 0):
+        # Parse the line and handle nesting '()' pairs. If on Windows
+        # handle embedded '"' (double quotes) as the command is run as
+        # a double quoted string.
+        def _exec(shell_macro):
+            output = ''
+            if len(shell_macro) > 3:
+                e = execute.capture_execution()
-                    cmd = '%s -c "%s"' % (self.macros.expand('%{__sh}'), s[2:-1])
+                    shell_cmd = \
+                        ''.join([c if c != '"' else '\\' + c for c in shell_macro[2:-1]])
+                    cmd = '%s -c "%s"' % (self.macros.expand('%{__sh}'), shell_cmd)
                 else:
-                    cmd = s[2:-1]
+                    cmd = shell_macro[2:-1]
                 exit_code, proc, output = e.shell(cmd)
                 log.trace('shell-output: %d %s' % (exit_code, output))
-                if exit_code == 0:
-                    line = line.replace(s, output)
-                else:
-                    raise error.general('shell macro failed: %s:%d: %s' % (s, exit_code, output))
+                if exit_code != 0:
+                    raise error.general('shell macro failed: %s: %d: %s' % (cmd,
+        exit_code,
+        output))
+            return output
+        if nesting > 200:
+            raise error.general('shell macro failed: too many nesting levels')
+        updating = True
+        while updating:
+            updating = False
+            pos = line.find('%(')
+            if pos >= 0:
+                braces = 0
+                for p in range(pos + 2, len(line)):
+                    if line[p] == '(':
+                        braces += 1
+                    elif line[p] == ')':
+                        if braces > 0:
+                            braces -= 1
+                        else:
+                            shell_cmd = '%(' + \
+                                self._shell(line[pos + 2:p], nesting + 1) + ')'
+                            line = line[:pos] + _exec(shell_cmd) + line[p + 1:]
+                            updating = True
+                            break
         return line
     def _pkgconfig_check(self, test):
         # Hack to by pass pkgconfig checks when just wanting to download the
         # source.
-        if self.macros['_dry_run'] == '1' and self.macros['with_download'] == '1':
+        if self.macros['_dry_run'] == '1' and \
+           ('with_download' in self.macros and self.macros['with_download'] == '1'):
             return '0'
         ok = False
+        log.trace('pkgconfig: check: crossc=%d pkg_crossc=%d prefix=%s'
+                  % ( self._cross_compile(),
+                      self.pkgconfig_crosscompile,
+                      self.pkgconfig_prefix))
+        log.trace('pkgconfig: check: test=%s' % (test))
         if type(test) == str:
             test = test.split()
         if not self._cross_compile() or self.pkgconfig_crosscompile:
@@ -445,6 +499,7 @@ class file:
             except pkgconfig.error as pe:
                 self._error('pkgconfig: check: %s' % (pe))
             except:
+                raise
                 raise error.internal('pkgconfig failure')
         if ok:
             return '1'
@@ -462,13 +517,14 @@ class file:
                 if pkg_flags and self.pkgconfig_filter_flags:
                     fflags = []
                     for f in pkg_flags.split():
-                        if not f.startswith('-f') and not f.startswith('-W'):
+                        if not f.startswith('-W'):
                             fflags += [f]
                     pkg_flags = ' '.join(fflags)
-                log.trace('pkgconfig: %s: %s' % (flags, pkg_flags))
+                log.trace('pkgconfig: %s:  %s' % (flags, pkg_flags))
-                self._error('pkgconfig: %s: %s' % (flags, pe))
+                self._error('pkgconfig: %s:  %s' % (flags, pe))
             except:
+                raise
         if pkg_flags is None:
             pkg_flags = ''
@@ -543,7 +599,8 @@ class file:
                 elif m.startswith('%{expand'):
                     colon = m.find(':')
                     if colon < 8:
-                        log.warning('malformed expand macro, no colon found')
+                        log.warning(self._name_line_msg('malformed expand macro, ' \
+                                                        'no colon found'))
                     else:
                         e = self._expand(m[colon + 1:-1].strip())
                         s = s.replace(m, self._label(e))
@@ -562,7 +619,7 @@ class file:
                     mn = None
                 elif m.startswith('%{echo'):
                     if not m.endswith('}'):
-                        log.warning("malformed conditional macro '%s'" % (m))
+                        log.warning(self._name_line_msg("malformed conditional macro '%s'" % (m)))
                         mn = None
                     else:
                         e = self._expand(m[6:-1].strip())
@@ -586,31 +643,84 @@ class file:
                         s = s.replace(m, '1')
                     expanded = True
                     mn = None
+                elif m.startswith('%{triplet'):
+                    triplet = m[len('%{triplet'):-1].strip().split()
+                    ok = False
+                    if len(triplet) == 2:
+                        macro = self._expand(triplet[0])
+                        value = self._expand(triplet[1])
+                        vorig = value
+                        arch_value = ''
+                        vendor_value = ''
+                        os_value = ''
+                        dash = value.find('-')
+                        if dash >= 0:
+                            arch_value = value[:dash]
+                            value = value[dash + 1:]
+                        if dash >= 0:
+                            vendor_value = value[:dash]
+                        if len(value):
+                            os_value = value
+                        self.macros[macro] = vorig
+                        self.macros[macro + '_cpu'] = arch_value
+                        self.macros[macro + '_arch'] = arch_value
+                        self.macros[macro + '_vendor'] = vendor_value
+                        self.macros[macro + '_os'] = os_value
+                        ok = True
+                    if ok:
+                        s = s.replace(m, '')
+                    else:
+                        self._error('triplet error: %s' % (' '.join(triplet)))
+                    mn = None
                 elif m.startswith('%{path '):
                     pl = m[7:-1].strip().split()
                     ok = False
-                    if len(pl) == 2:
-                        ok = True
-                        epl = []
-                        for p in pl[1:]:
-                            epl += [self._expand(p)]
-                        p = ' '.join(epl)
-                        if pl[0].lower() == 'prepend':
+                    result = ''
+                    pl_0 = pl[0].lower()
+                    if pl_0 == 'prepend':
+                        if len(pl) == 2:
+                            ok = True
+                            p = ' '.join([self._expand(pp) for pp in pl[1:]])
                             if len(self.macros['_pathprepend']):
                                 self.macros['_pathprepend'] = \
                                     '%s:%s' % (p, self.macros['_pathprepend'])
                             else:
                                 self.macros['_pathprepend'] = p
-                        elif pl[0].lower() == 'postpend':
+                    elif pl_0 == 'postpend':
+                        if len(pl) == 2:
+                            ok = True
                                     '%s:%s' % (self.macros['_pathprepend'], p)
                             else:
-                        else:
-                            ok = False
+                    elif pl_0 == 'check':
+                        if len(pl) == 3:
+                            pl_1 = pl[1].lower()
+                            p = ' '.join([self._expand(pp) for pp in pl[2:]])
+                            if pl_1 == 'exists':
+                                ok = True
+                                if path.exists(p):
+                                    result = '1'
+                                else:
+                                    result = '0'
+                            elif pl_1 == 'isdir':
+                                ok = True
+                                if path.isdir(p):
+                                    result = '1'
+                                else:
+                                    result = '0'
+                            elif pl_1 == 'isfile':
+                                ok = True
+                                if path.isfile(p):
+                                    result = '1'
+                                else:
+                                    result = '0'
                     if ok:
-                        s = s.replace(m, '')
+                        s = s.replace(m, result)
                     else:
                         self._error('path error: %s' % (' '.join(pl)))
                     mn = None
@@ -634,7 +744,7 @@ class file:
                     colon = m[start:].find(':')
                     if colon < 0:
                             mn = None
                         else:
                             mn = self._label(m[start:-1])
@@ -676,21 +786,21 @@ class file:
     def _disable(self, config, ls):
         if len(ls) != 2:
-            log.warning('invalid disable statement')
+            log.warning(self._name_line_msg('invalid disable statement'))
         else:
             if ls[1] == 'select':
                 self.macros.lock_read_map()
-                log.trace('config: %s: %3d: _disable_select: %s' % (self.name, self.lc,
+                log.trace('config: %s: %3d:  _disable_select: %s' % (self.name, self.lc,
        ls[1]))
             else:
-                log.warning('invalid disable statement: %s' % (ls[1]))
+                log.warning(self._name_line_msg('invalid disable statement: %s' % (ls[1])))
     def _select(self, config, ls):
         if len(ls) != 2:
-            log.warning('invalid select statement')
+            log.warning(self._name_line_msg('invalid select statement'))
         else:
             r = self.macros.set_read_map(ls[1])
-            log.trace('config: %s: %3d: _select: %s %s %r' % \
+            log.trace('config: %s: %3d:  _select: %s %s %r' % \
                            r, ls[1], self.macros.maps()))
@@ -702,7 +812,7 @@ class file:
     def _define(self, config, ls):
         if len(ls) <= 1:
-            log.warning('invalid macro definition')
+            log.warning(self._name_line_msg('invalid macro definition'))
         else:
             d = self._label(ls[1])
             if self.disable_macro_reassign:
@@ -713,7 +823,7 @@ class file:
                     else:
                         self.macros[d] = ' '.join([f.strip() for f in ls[2:]])
                 else:
-                    log.warning("macro '%s' already defined" % (d))
+                    log.warning(self._name_line_msg("macro '%s' already defined" % (d)))
             else:
                 if len(ls) == 2:
                     self.macros[d] = '1'
@@ -722,14 +832,14 @@ class file:
     def _undefine(self, config, ls):
         if len(ls) <= 1:
         else:
             mn = self._label(ls[1])
             if mn in self.macros:
                 del self.macros[mn]
     def _ifs(self, config, ls, label, iftrue, isvalid, dir, info):
-        log.trace('config: %s: %3d: _ifs[%i]: dir=%s %i %r' % \
+        log.trace('config: %s: %3d:  _ifs[%i]: dir=%s %i %r' % \
                   (self.name, self.lc, self.if_depth, str(dir), len(ls), ls))
         in_dir = dir
         in_iftrue = True
@@ -749,7 +859,7 @@ class file:
                     self._error(label + ' without %endif')
                     raise error.general('terminating build')
                 if r[1] == '%endif':
-                    log.trace('config: %s: %3d: _ifs[%i]: %%endif: dir=%s %s %s %r' % \
+                    log.trace('config: %s: %3d:  _ifs[%i]: %%endif: dir=%s %s %s %r' % \
                                str(dir), r[1], this_isvalid, data))
                     if in_dir is None:
@@ -757,7 +867,8 @@ class file:
                             dir, info, data = self._process_directive(r, dir, info, data)
                     else:
                         if in_dir != dir:
-                            self._error('directives cannot change scope across if statements')
+                            self._error('directives cannot change' \
+                                        ' scope across if statements')
                     return data
                 if r[1] == '%else':
@@ -785,7 +896,7 @@ class file:
         sls = reduce(add, ls[1:], '').split()
         cls = sls
-        log.trace('config: %s: %3d: _if[%i]: %s' % (self.name, self.lc,
+        log.trace('config: %s: %3d:  _if[%i]: %s' % (self.name, self.lc,
                                                     self.if_depth, sls))
         self.if_depth += 1
@@ -800,22 +911,25 @@ class file:
                 elif cls[0] == '&&':
                     join_op = 'and'
                 cls = cls[1:]
-                log.trace('config: %s: %3d: _if[%i]: joining: %s' % (self.name, self.lc,
-        self.if_depth,
-        join_op))
+                log.trace('config: %s: %3d:  _if[%i]: joining: %s' % \
+                          (self.name, self.lc,
+                           self.if_depth,
+                           join_op))
             ori = 0
             andi = 0
             i = len(cls)
             if '||' in cls:
                 ori = cls.index('||')
-                log.trace('config: %s: %3d: _if[%i}: OR found at %i' % (self.name, self.lc,
-        self.if_depth,
-        ori))
+                log.trace('config: %s: %3d:  _if[%i}: OR found at %i' % \
+                           self.if_depth,
+                           ori))
             if '&&' in cls:
                 andi = cls.index('&&')
-                log.trace('config: %s: %3d: _if[%i]: AND found at %i' % (self.name, self.lc,
-        self.if_depth,
-        andi))
+                log.trace('config: %s: %3d:  _if[%i]: AND found at %i' % \
+                           self.if_depth,
+                           andi))
             if ori > 0 or andi > 0:
                 if ori == 0:
                     i = andi
@@ -825,9 +939,10 @@ class file:
                     i = andi
                 else:
                     i = andi
-                log.trace('config: %s: %3d: _if[%i]: next OP found at %i' % (self.name, self.lc,
-        self.if_depth,
-                i))
+                log.trace('config: %s: %3d:  _if[%i]: next OP found at %i' % \
+                           self.if_depth,
+                           i))
             ls = cls[:i]
             if len(ls) == 0:
                 self._error('invalid if expression: ' + reduce(add, sls, ''))
@@ -924,10 +1039,10 @@ class file:
             else:
                 cistrue = istrue
-            log.trace('config: %s: %3d: _if[%i]:  %s %s %s %s' % (self.name, self.lc,
-        self.if_depth,
-        ifls, str(cistrue),
-        join_op, str(istrue)))
+            log.trace('config: %s: %3d:  _if[%i]:  %s %s %s %s' % (self.name, self.lc,
+        self.if_depth,
+        ifls, str(cistrue),
+        join_op, str(istrue)))
         if invert:
             cistrue = not cistrue
@@ -936,8 +1051,8 @@ class file:
         self.if_depth -= 1
-        log.trace('config: %s: %3d: _if[%i]: %r' % (self.name, self.lc,
-                                                    self.if_depth, ifs_return))
+        log.trace('config: %s: %3d:  _if[%i]: %r' % (self.name, self.lc,
+                                                     self.if_depth, ifs_return))
         return ifs_return
@@ -945,17 +1060,30 @@ class file:
         isos = False
         if isvalid:
             os = self.define('_os')
-            for l in ls:
+            ls = ' '.join(ls).split()
+            for l in ls[1:]:
                 if l in os:
                     isos = True
                     break
         return self._ifs(config, ls, '%ifos', isos, isvalid, dir, info)
+    def _ifnos(self, config, ls, isvalid, dir, info):
+        isnos = True
+        if isvalid:
+            os = self.define('_os')
+            for l in ls[1:]:
+                if l in os:
+                    isnos = False
+                    break
+        return self._ifs(config, ls, '%ifnos', isnos, isvalid, dir, info)
     def _ifarch(self, config, positive, ls, isvalid, dir, info):
         isarch = False
         if isvalid:
             arch = self.define('_arch')
-            for l in ls:
+            for l in ls[1:]:
                 if l in arch:
                     isarch = True
                     break
@@ -970,22 +1098,38 @@ class file:
             line = line[0:-1]
             b = line.find('#')
             if b >= 0:
-                line = line[1:b]
+                line = line[1:b] + ('\\' if line[-1] == '\\' else '')
             return line.strip()
+        def _clean_and_pack(line, last_line):
+            leading_ws = ' ' if len(line) > 0 and line[0].isspace() else ''
+            line = _clean(line)
+            if len(last_line) > 0:
+                line = last_line + leading_ws + line
+            return line
         # Need to add code to count matching '{' and '}' and if they
         # do not match get the next line and add to the string until
         # they match. This closes an opening '{' that is on another
         # line.
+        ll = ''
         for l in config:
             self.lc += 1
-            l = _clean(l)
+            l = _clean_and_pack(l, ll)
             if len(l) == 0:
                 continue
-            log.trace('config: %s: %0d: %s %s' % \
-                          (self.name, self.lc, str(isvalid), l))
+            if l[-1] == '\\':
+                ll = l[0:-1]
+                continue
+            ll = ''
+            if isvalid:
+                indicator = '>'
+            else:
+                indicator = ' '
+            log.trace('config: %s: %3d:%s%s [%s]' % \
+                          (self.name, self.lc, indicator, l, str(isvalid)))
             lo = l
             if isvalid:
                 l = self._expand(l)
@@ -1038,17 +1182,21 @@ class file:
                 elif ls[0] == '%if':
                     d = self._if(config, ls, isvalid, dir, info)
                     if len(d):
-                        log.trace('config: %s: %3d: %%if: %s' % (self.name, self.lc, d))
+                        log.trace('config: %s: %3d:  %%if: %s' % (self.name, self.lc, d))
                         return ('data', d)
                 elif ls[0] == '%ifn':
                     d = self._if(config, ls, isvalid, dir, info, True)
                     if len(d):
-                        log.trace('config: %s: %3d: %%ifn: %s' % (self.name, self.lc, d))
+                        log.trace('config: %s: %3d:  %%ifn: %s' % (self.name, self.lc, d))
                         return ('data', d)
                 elif ls[0] == '%ifos':
                     d = self._ifos(config, ls, isvalid, dir, info)
                     if len(d):
                         return ('data', d)
+                elif ls[0] == '%ifnos':
+                    d = self._ifnos(config, ls, isvalid, dir, info)
+                    if len(d):
+                        return ('data', d)
                 elif ls[0] == '%ifarch':
                     d = self._ifarch(config, True, ls, isvalid, dir, info)
                     if len(d):
@@ -1060,11 +1208,11 @@ class file:
                 elif ls[0] == '%endif':
                     if roc:
                         return ('control', '%endif', '%endif')
-                    log.warning("unexpected '" + ls[0] + "'")
+                    log.warning(self._name_line_msg("unexpected '" + ls[0] + "'"))
                 elif ls[0] == '%else':
                     if roc:
                         return ('control', '%else', '%else')
                 elif ls[0].startswith('%defattr'):
                     return ('data', [l])
                 elif ls[0] == '%bcond_with':
@@ -1086,10 +1234,11 @@ class file:
                     if isvalid:
                         for d in self._directive:
                             if ls[0].strip() == d:
-                                log.trace('config: %s: %0d: _parse: directive: %s' % \
+                                log.trace('config: %s: %3d:  _parse: directive: %s' % \
                                           (self.name, self.lc, ls[0].strip()))
                                 return ('directive', ls[0].strip(), ls[1:])
-                        log.warning("unknown directive: '" + ls[0] + "'")
+                        log.warning(self._name_line_msg("unknown directive: '" + \
+                                                        ls[0] + "'"))
                         return ('data', [lo])
             else:
@@ -1110,7 +1259,8 @@ class file:
                 _package = results[2][0]
             else:
                 if results[2][0].strip() != '-n':
-                    log.warning("unknown directive option: '%s'" % (' '.join(results[2])))
+                    log.warning(self._name_line_msg("unknown directive option: '%s'" % \
+                                                    (' '.join(results[2]))))
                 _package = results[2][1].strip()
             self._set_package(_package)
         if directive and directive != results[1]:
@@ -1120,7 +1270,8 @@ class file:
         return (directive, info, data)
     def _process_data(self, results, directive, info, data):
-        log.trace('config: %s: %3d: _process_data: result=#%r# directive=#%s# info=#%r# data=#%r#' % \
+        log.trace('config: %s: %3d:  _process_data: result=#%r# ' \
+                  'directive=#%s# info=#%r# data=#%r#' % \
                   (self.name, self.lc, results, directive, info, data))
         new_data = []
         for l in results[1]:
@@ -1132,11 +1283,11 @@ class file:
                 log.output(l[4:])
             elif l.startswith('%warning'):
                 l = self._expand(l)
-                log.warning(l[9:])
+                log.warning(self._name_line_msg(l[9:]))
             if not directive:
                 l = self._expand(l)
                 ls = self.tags.split(l, 1)
-                log.trace('config: %s: %3d: _tag: %s %s' % (self.name, self.lc, l, ls))
+                log.trace('config: %s: %3d:  _tag: %s %s' % (self.name, self.lc, l, ls))
                 if len(ls) > 1:
                     info = ls[0].lower()
                     if info[-1] == ':':
@@ -1147,10 +1298,12 @@ class file:
                 if info is not None:
                     self._info_append(info, info_data)
                 else:
-                    log.warning("invalid format: '%s'" % (info_data[:-1]))
+                    log.warning(self._name_line_msg("invalid format: '%s'" % \
+                                                    (info_data[:-1])))
             else:
                 l = self._expand(l)
-                log.trace('config: %s: %3d: _data: %s %s' % (self.name, self.lc, l, new_data))
+                log.trace('config: %s: %3d:  _data: %s %s' % \
+                          (self.name, self.lc, l, new_data))
                 new_data.append(l)
         return (directive, info, data + new_data)
@@ -1166,7 +1319,8 @@ class file:
         self.package = _package
     def _directive_extend(self, dir, data):
-        log.trace('config: %s: %3d: _directive_extend: %s: %r' % (self.name, self.lc, dir, data))
+        log.trace('config: %s: %3d:  _directive_extend: %s: %r' % \
+                  (self.name, self.lc, dir, data))
         self._packages[self.package].directive_extend(dir, data)
     def _info_append(self, info, data):
@@ -1191,7 +1345,6 @@ class file:
             return end
         if self.load_depth == 0:
-            self._reset(name)
             self._packages[self.package] = package(self.package,
                                                    self.define('%{_arch}'),
                                                    self)
@@ -1199,6 +1352,7 @@ class file:
         self.load_depth += 1
         save_name = self.name
+        save_parent = self.parent
         save_lc = self.lc
@@ -1239,13 +1393,15 @@ class file:
                 raise error.general('no config file found: %s' % (cfgname))
         try:
-            log.trace('config: %s: _open: %s' % (self.name, path.host(configname)))
+            log.trace('config: %s:  _open: %s' % (self.name, path.host(configname)))
             config = open(path.host(configname), 'r')
         except IOError as err:
             raise error.general('error opening config file: %s' % (path.host(configname)))
         self.configpath += [configname]
-        self._includes += [configname]
+        self._includes += [configname + ':' + self.parent]
+        self.parent = configname
         self.name = self._relative_path(configname)
         self.lc = 0
@@ -1261,7 +1417,7 @@ class file:
                 elif r[0] == 'control':
                     if r[1] == '%end':
                         break
-                    log.warning("unexpected '%s'" % (r[1]))
+                    log.warning(self._name_line_msg("unexpected '%s'" % (r[1])))
                 elif r[0] == 'directive':
                     if r[1] == '%include':
                         self.load(r[2][0])
@@ -1276,13 +1432,12 @@ class file:
         except:
             config.close()
             raise
-        config.close()
-        self.name = save_name
-        self.lc = save_lc
-        self.load_depth -= 1
+        finally:
+            config.close()
+            self.name = save_name
+            self.parent = save_parent
+            self.lc = save_lc
+            self.load_depth -= 1
     def defined(self, name):
         return name in self.macros
@@ -1319,7 +1474,7 @@ class file:
             raise error.general('package "' + _package + '" not found')
         if name not in self._packages[_package].directives:
             raise error.general('directive "' + name + \
-                                    '" not found in package "' + _package + '"')
+                                '" not found in package "' + _package + '"')
         return self._packages[_package].directives[name]
     def abspath(self, rpath):
diff --git a/source-builder/sb/cvs.py b/source-builder/sb/cvs.py
index 2ff7417..673488e 100644
--- a/source-builder/sb/cvs.py
+++ b/source-builder/sb/cvs.py
@@ -25,11 +25,10 @@ from __future__ import print_function
 import os
-import error
-import execute
-import log
-import options
-import path
+from . import log
+from . import path
 class repo:
     """An object to manage a cvs repo."""
@@ -147,6 +146,7 @@ class repo:
 if __name__ == '__main__':
     import sys
     opts = options.load(sys.argv, defaults = 'defaults.mc')
     ldir = 'cvs-test-rm-me'
     c = repo(ldir, opts)
diff --git a/source-builder/sb/darwin.py b/source-builder/sb/darwin.py
index d79cf47..95a2a4e 100644
--- a/source-builder/sb/darwin.py
+++ b/source-builder/sb/darwin.py
@@ -24,7 +24,7 @@
 import os
-import execute
 def load():
     uname = os.uname()
@@ -52,6 +52,7 @@ def load():
         '_var':             ('dir',     'optional', '/usr/local/var'),
         '_prefix':          ('dir',     'optional', '%{_usr}'),
         '__ldconfig':       ('exe',     'none',     ''),
+        '__cmake':          ('exe',     'optional', 'cmake'),
         '__cvs':            ('exe',     'optional', 'cvs'),
         '__xz':             ('exe',     'required', 'xz'),
         'with_zlib':        ('none',    'none',     '--with-zlib=no'),
diff --git a/source-builder/sb/download.py b/source-builder/sb/download.py
index f8dd305..9b76c8d 100644
--- a/source-builder/sb/download.py
+++ b/source-builder/sb/download.py
@@ -24,6 +24,7 @@
+import base64
 import hashlib
 import os
 import re
@@ -36,13 +37,13 @@ except ImportError:
     import urllib2 as urllib_request
     import urlparse as urllib_parse
-import cvs
-import error
-import git
-import log
-import path
-import sources
-import version
+from . import cvs
+from . import git
+from . import log
+from . import path
+from . import sources
 def _do_download(opts):
     download = True
@@ -108,8 +109,13 @@ def _hash_check(file_, absfile, macros, remove = True):
             raise
         if _in is not None:
             _in.close()
-        log.output('checksums: %s: %s => %s' % (file_, hasher.hexdigest(), hash[1]))
-        if hasher.hexdigest() != hash[1]:
+        hash_hex = hasher.hexdigest()
+        hash_base64 = base64.b64encode(hasher.digest()).decode('utf-8')
+        log.output('checksums: %s: (hex: %s) (b64: %s) => %s' % (file_,
+        hash_hex,
+        hash_base64,
+        hash[1]))
+        if hash_hex != hash[1] and hash_base64 != hash[1]:
             log.warning('checksum error: %s' % (file_))
             failed = True
         if failed and remove:
@@ -181,12 +187,13 @@ def _http_parser(source, pathkey, config, opts):
                 raise error.general('gitweb.cgi path missing p or h: %s' % (url))
             source['file'] = '%s-%s.patch' % (p, h)
-        # Check the source file name for any extra request query data and remove if
-        # found. Some hosts do not like file names containing them.
+        # Wipe out everything special in the file name.
-        if '?' in source['file']:
-            qmark = source['file'].find('?')
-            source['file'] = source['file'][:qmark]
+        source['file'] = re.sub(r'[^a-zA-Z0-9.\-]+', '-', source['file'])
+        max_file_len = 127
+        if len(source['file']) > max_file_len:
+            raise error.general('file name length is greater than %i (maybe use --rsb-file=FILE option): %s' % \
+                                (max_file_len, source['file']))
     # Check local path
@@ -327,6 +334,9 @@ def parse_url(url, pathkey, config, opts, file_override = None):
         log.output('download: file-override: %s' % (file_override))
         source['file'] = file_override
         source['options'] += ['file-override']
+    question_mark = source['file'].find('?')
+    if question_mark >= 0:
+        source['file'] = source['file'][:question_mark]
     source['name'], source['ext'] = path.splitext(source['file'])
     if source['name'].endswith('.tar'):
         source['name'] = source['name'][:-4]
@@ -506,6 +516,15 @@ def _git_downloader(url, local, config, opts):
             log.notice('git: reset: %s' % (us[0]))
             if _do_download(opts):
                 repo.reset(arg)
+                repo.submodule_foreach(['reset'] + arg)
+        elif _as[0] == 'clean':
+            arg = []
+            if len(_as) > 1:
+                arg = ['--%s' % (_as[1])]
+            log.notice('git: clean: %s' % (us[0]))
+            if _do_download(opts):
+                repo.clean(arg)
+                repo.submodule_foreach(['clean'] + arg)
         elif _as[0] == 'protocol':
             pass
         else:
@@ -590,16 +609,19 @@ def get_file(url, local, opts, config):
         raise error.general('source not found: %s' % (path.host(local)))
     # Check if a URL has been provided on the command line. If the package is
-    # released push to the start the RTEMS URL unless overrided by the command
-    # line option --with-release-url. The variant --without-release-url can
-    # override the released check.
+    # released push the release path URLs to the start the RTEMS URL list
+    # unless overriden by the command line option --without-release-url. The
+    # variant --without-release-url can override the released check.
     url_bases = opts.urls()
+    if url_bases is None:
+        url_bases = []
     try:
         rtems_release_url_value = config.macros.expand('%{release_path}')
     except:
         rtems_release_url_value = None
     rtems_release_url = None
+    rtems_release_urls = []
     if version.released() and rtems_release_url_value:
         rtems_release_url = rtems_release_url_value
     with_rel_url = opts.with_arg('release-url')
@@ -618,18 +640,17 @@ def get_file(url, local, opts, config):
     elif with_rel_url[0] == 'without_release-url' and with_rel_url[1] == 'yes':
     if rtems_release_url is not None:
-        log.trace('release url: %s' % (rtems_release_url))
-        # If the URL being fetched is under the release path do not add the
-        # sources release path because it is already there.
-        if not url.startswith(rtems_release_url):
-            if url_bases is None:
-                url_bases = [rtems_release_url]
-            else:
-                url_bases.append(rtems_release_url)
+        rtems_release_urls = rtems_release_url.split(',')
+        for release_url in rtems_release_urls:
+            log.trace('release url: %s' % (release_url))
+            # If the URL being fetched is under the release path do not add
+            # the sources release path because it is already there.
+            if not url.startswith(release_url):
+                url_bases = [release_url] + url_bases
     urls = []
-    if url_bases is not None:
+    if len(url_bases) > 0:
         # Split up the URL we are being asked to download.
@@ -645,7 +666,7 @@ def get_file(url, local, opts, config):
             # Hack to fix #3064 where --rsb-file is being used. This code is a
             # mess and should be refactored.
-            if version.released() and base == rtems_release_url:
+            if version.released() and base in rtems_release_urls:
                 url_file = path.basename(local)
             if base[-1:] != '/':
                 base += '/'
diff --git a/source-builder/sb/ereport.py b/source-builder/sb/ereport.py
index 88aaa16..d8fb5f6 100755
--- a/source-builder/sb/ereport.py
+++ b/source-builder/sb/ereport.py
@@ -1,6 +1,6 @@
-# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
+# Copyright 2010-2017 Chris Johns (chrisj at rtems.org)
 # This file is part of the RTEMS Tools package in 'rtems-testing'.
@@ -21,36 +21,40 @@
 # Create an error log.
 import os
-import error
-import log
+from . import log
 def generate(name, opts, header = None, footer = None):
-    r = ['RTEMS Tools Project - Source Builder Error Report'] + []
-    if header:
-        r += [' %s' % (header)]
-    r += [opts.info()]
-    if opts.defaults.get_value('%{_sbgit_valid}') == '1':
-        r += [' %s/%s' % (opts.defaults.get_value('%{_sbgit_remotes}'),
-                          opts.defaults.get_value('%{_sbgit_id}'))]
-    else:
-        r += [' RSB: not a valid repo']
-    if os.name == 'nt':
-        r += [' Windows']
-    else:
-        r += [' %s' % (' '.join(os.uname()))]
-    r += []
-    r += ['Tail of the build log:']
-    r += log.tail()
-    if footer:
-        r += [footer]
-    try:
-        name = name.replace('/', '-')
-        l = open(name, 'w')
-        l.write(os.linesep.join(r))
-        l.close()
-        log.notice('  See error report: %s' % (name))
-    except:
-        log.stderr('error: failure to create error report')
-        raise
+    label, result = opts.with_arg('error-report')
+    if (label.startswith('without_') and result != 'yes') or \
+       (label.startswith('with_') and result != 'no'):
+        r = ['RTEMS Tools Project - Source Builder Error Report'] + []
+        if header:
+            r += [' %s' % (header)]
+        r += [opts.info()]
+        if opts.defaults.get_value('%{_sbgit_valid}') == '1':
+            r += [' %s/%s' % (opts.defaults.get_value('%{_sbgit_remotes}'),
+                              opts.defaults.get_value('%{_sbgit_id}'))]
+        else:
+            r += [' RSB: not a valid repo']
+        if os.name == 'nt':
+            r += [' Windows']
+        else:
+            r += [' %s' % (' '.join(os.uname()))]
+        r += []
+        r += ['Tail of the build log:']
+        r += log.tail()
+        if footer:
+            r += [footer]
+        try:
+            name = name.replace('/', '-')
+            with open(name, 'w') as l:
+                l.write(os.linesep.join(r))
+            log.notice('  See error report: %s' % (name))
+        except:
+            log.stderr('error: failure to create error report')
+            raise
diff --git a/source-builder/sb/error.py b/source-builder/sb/error.py
index 6a99b0e..5ea19d3 100644
--- a/source-builder/sb/error.py
+++ b/source-builder/sb/error.py
@@ -33,12 +33,12 @@ class error(Exception):
 class general(error):
     """Raise for a general error."""
     def __init__(self, what):
-        self.set_output('error: ' + what)
+        self.set_output('error: ' + str(what))
 class internal(error):
     """Raise for an internal error."""
-        self.set_output('internal error: ' + what)
+        self.set_output('internal error: ' + str(what))
 class exit(error):
     """Raise for to exit."""
diff --git a/source-builder/sb/execute.py b/source-builder/sb/execute.py
index 12d8114..3db9abc 100755
--- a/source-builder/sb/execute.py
+++ b/source-builder/sb/execute.py
@@ -1,6 +1,6 @@
@@ -8,7 +8,7 @@
@@ -16,6 +16,7 @@
 # Execute commands or scripts.
@@ -26,14 +27,20 @@
 import functools
+import io
 import os
 import re
 import sys
 import subprocess
 import threading
+import time
+import traceback
+from . import log
-import error
-import log
+# Trace exceptions
+trace_threads = False
 # Redefine the PIPE from subprocess
 PIPE = subprocess.PIPE
@@ -86,89 +93,271 @@ def arg_subst_str(command, subst):
     def add(x, y): return x + ' ' + str(y)
     return functools.reduce(add, cmd, '')
-class execute:
-    """Execute commands or scripts. The 'output' is a funtion
-    that handles the output from the process."""
-    def __init__(self, output = None, error_prefix = '', verbose = False):
+class execute(object):
+    """Execute commands or scripts. The 'output' is a funtion that handles the
+    output from the process. The 'input' is a function that blocks and returns
+    data to be written to stdin"""
+    def __init__(self, output = None, input = None, cleanup = None,
+                 error_prefix = '', verbose = False):
+        self.lock = threading.Lock()
         self.output = output
+        self.input = input
+        self.cleanup = cleanup
         self.error_prefix = error_prefix
         self.verbose = verbose
         self.shell_exe = None
         self.shell_commands = False
         self.path = None
         self.environment = None
-    def capture(self, proc, timeout = None):
-        """Create 2 threads to read stdout and stderr and send to the
-        output handler. Based on the 'communicate' code in the subprocess
-        module."""
-        def _readthread(fh, out, prefix = ''):
+        self.outputting = False
+        self.timing_out = False
+        self.proc = None
+    def capture(self, proc, command = 'pipe', timeout = None):
+        """Create 3 threads to read stdout and stderr and send to the output handler
+        and call an input handler is provided. Based on the 'communicate' code
+        in the subprocess module."""
+        def _writethread(exe, fh, input):
+            """Call the input handler and write it to the stdin. The input handler should
+            block and return None or False if this thread is to exit and True if this
+            is a timeout check."""
+            if trace_threads:
+                print('execute:_writethread: start')
+            encoding = True
+            try:
+                tmp = bytes('temp', sys.stdin.encoding)
+            except:
+                encoding = False
+            input_types = [str, bytes]
+            try:
+                # Unicode is not valid in python3, not added to the list
+                input_types += [unicode]
+            except:
+                pass
+            try:
+                while True:
+                    if trace_threads:
+                        print('execute:_writethread: call input', input)
+                    lines = input()
+                    if trace_threads:
+                        print('execute:_writethread: input returned:', type(lines))
+                    if type(lines) in input_types:
+                        try:
+                            if encoding:
+                                lines = bytes(lines, sys.stdin.encoding)
+                            fh.write(lines)
+                            fh.flush()
+                        except:
+                            break
+                    if lines == None or \
+                       lines == False or \
+                       (lines == True and fh.closed):
+                        break
+            except:
+                if trace_threads:
+                    print('execute:_writethread: exception')
+                    print(traceback.format_exc())
+                pass
+            try:
+                fh.close()
+            except:
+                pass
+            if trace_threads:
+                print('execute:_writethread: finished')
+        def _readthread(exe, fh, out, prefix = ''):
             """Read from a file handle and write to the output handler
             until the file closes."""
-            count = 0
-            while True:
-                line = fh.readline()
-                # str and bytes are the same type in Python2
-                if type(line) is not str and type(line) is bytes:
-                    line = line.decode(sys.stdout.encoding)
-                count += 1
-                if len(line) == 0:
-                    break
+            def _output_line(line, exe, prefix, out, count):
+                #exe.lock.acquire()
+                #exe.outputting = True
+                #exe.lock.release()
                 if out:
                     out(prefix + line)
                 else:
                     log.output(prefix + line)
                     if count > 10:
                         log.flush()
-                        count = 0
-        def _timerthread(proc, timer):
-            """Timer thread calls the timer handler if one
-            is present once a second. The user provides a handler
-            and returns False to kill the process or True continue."""
-            while True:
+            if trace_threads:
+                print('execute:_readthread: start')
+            count = 0
+            line = ''
+            try:
+                while True:
+                    # The io module file handling return up to the size passed
+                    # in to the read call. The io handle has the default
+                    # buffering size. On any error assume the handle has gone
+                    # and the process is shutting down.
+                    try:
+                        data = fh.read1(4096)
+                    except:
+                        data = ''
+                    if len(data) == 0:
+                        if len(line) > 0:
+                            _output_line(line + '\n', exe, prefix, out, count)
+                        break
+                    # str and bytes are the same type in Python2
+                    if type(data) is not str and type(data) is bytes:
+                        data = data.decode(sys.stdout.encoding)
+                    last_ch = data[-1]
+                    sd = (line + data).split('\n')
+                    if last_ch != '\n':
+                        line = sd[-1]
+                    else:
+                        line = ''
+                    sd = sd[:-1]
+                    if len(sd) > 0:
+                        for l in sd:
+                            if trace_threads:
+                                print('execute:_readthread: output-line:',
+                                      count, type(l))
+                            _output_line(l + '\n', exe, prefix, out, count)
+                            count += 1
+                        if count > 10:
+                            count -= 10
+            except:
+                raise
+                if trace_threads:
+                    print('execute:_readthread: exception')
+                pass
+            try:
+                fh.close()
+            except:
+                pass
+            if len(line):
+                _output_line(line, exe, prefix, out, 100)
+            if trace_threads:
+                print('execute:_readthread: finished')
+        def _timerthread(exe, interval, function):
+            """Timer thread is used to timeout a process if no output is
+            produced for the timeout interval."""
+            count = interval
+            while exe.timing_out:
                 time.sleep(1)
-                if not timer(proc):
-                    proc.stdout.close()
-                    proc.stderr.close()
+                if count > 0:
+                    count -= 1
+                exe.lock.acquire()
+                if exe.outputting:
+                    count = interval
+                    exe.outputting = False
+                exe.lock.release()
+                if count == 0:
+                    try:
+                        proc.kill()
+                    except:
+                        pass
+                    else:
+                        function()
+                    break
+        name = os.path.basename(command[0])
+        stdin_thread = None
+        stdout_thread = None
+        stderr_thread = None
+        timeout_thread = None
         if proc.stdout:
             stdout_thread = threading.Thread(target = _readthread,
-                                             args = (proc.stdout,
+                                             name = '_stdout[%s]' % (name),
+                                             args = (self,
+                                                     io.open(proc.stdout.fileno(),
+                                                             mode = 'rb',
+                                                             closefd = False),
                                                      self.output,
-            stdout_thread.setDaemon(True)
+            stdout_thread.daemon = True
             stdout_thread.start()
         if proc.stderr:
             stderr_thread = threading.Thread(target = _readthread,
-                                             args = (proc.stderr,
+                                             name = '_stderr[%s]' % (name),
+                                             args = (self,
+                                                     io.open(proc.stderr.fileno(),
+                                                             mode = 'rb',
+                                                             closefd = False),
                                                      self.output,
                                                      self.error_prefix))
-            stderr_thread.setDaemon(True)
+            stderr_thread.daemon = True
             stderr_thread.start()
-        if proc.stdout:
-            stdout_thread.join()
-        if proc.stderr:
-            stderr_thread.join()
-        return proc.wait()
+        if self.input and proc.stdin:
+            stdin_thread = threading.Thread(target = _writethread,
+                                            name = '_stdin[%s]' % (name),
+                                            args = (self,
+                                                    proc.stdin,
+                                                    self.input))
+            stdin_thread.daemon = True
+            stdin_thread.start()
+        if timeout:
+            self.timing_out = True
+            timeout_thread = threading.Thread(target = _timerthread,
+                                              name = '_timeout[%s]' % (name),
+                                              args = (self,
+                                                      timeout[0],
+                                                      timeout[1]))
+            timeout_thread.daemon = True
+            timeout_thread.start()
+        try:
+            self.lock.acquire()
+            try:
+                self.proc = proc
+            except:
+                raise
+            finally:
+                self.lock.release()
+            exitcode = proc.wait()
+        except:
+            proc.kill()
+            raise
+        finally:
+            try:
+                self.proc = None
+            except:
+                raise
+            finally:
+            if self.cleanup:
+                self.cleanup(proc)
+            if timeout_thread:
+                timeout_thread.join(10)
+            if stdin_thread:
+                stdin_thread.join(2)
+            if stdout_thread:
+                stdout_thread.join(2)
+            if stderr_thread:
+                stderr_thread.join(2)
+        return exitcode
     def open(self, command, capture = True, shell = False,
              cwd = None, env = None,
-             stdin = None, stdout = None, stderr = None):
+             stdin = None, stdout = None, stderr = None,
+             timeout = None):
         """Open a command with arguments. Provide the arguments as a list or
         a string."""
+        if self.output is None:
+            raise error.general('capture needs an output handler')
+        cs = command
+        if type(command) is list:
+            def add(x, y): return x + ' ' + str(y)
+            cs = functools.reduce(add, command, '')[1:]
+        what = 'spawn'
+        if shell:
+            what = 'shell'
+        cs = what + ': ' + cs
         if self.verbose:
-            s = command
-            if type(command) is list:
-                def add(x, y): return x + ' ' + str(y)
-                s = functools.reduce(add, command, '')[1:]
-            what = 'spawn'
-            if shell:
-                what = 'shell'
-            log.output(what + ': ' + s)
+            log.output(what + ': ' + cs)
+        log.trace('exe: %s' % (cs))
         if shell and self.shell_exe:
             command = arg_list(command)
             command[:0] = self.shell_exe
+        if not stdin and self.input:
+            stdin = subprocess.PIPE
         if not stdout:
             stdout = subprocess.PIPE
         if not stderr:
@@ -191,10 +380,13 @@ class execute:
             proc = subprocess.Popen(command, shell = shell,
                                     cwd = cwd, env = env,
                                     stdin = stdin, stdout = stdout,
-                                    stderr = stderr)
+                                    stderr = stderr,
+                                    close_fds = False)
             if not capture:
                 return (0, proc)
-            exit_code = self.capture(proc)
+            exit_code = self.capture(proc, command, timeout)
             if self.verbose:
                 log.output('exit: ' + str(exit_code))
         except OSError as ose:
@@ -204,23 +396,26 @@ class execute:
         return (exit_code, proc)
     def spawn(self, command, capture = True, cwd = None, env = None,
+              timeout = None):
         """Spawn a command with arguments. Provide the arguments as a list or
         a string."""
         return self.open(command, capture, False, cwd, env,
-                         stdin, stdout, stderr)
+                         stdin, stdout, stderr, timeout)
     def shell(self, command, capture = True, cwd = None, env = None,
+              timeout = None):
         """Execute a command within a shell context. The command can contain
         argumments. The shell is specific to the operating system. For example
         it is cmd.exe on Windows XP."""
         return self.open(command, capture, True, cwd, env,
     def command(self, command, args = None, capture = True, shell = False,
+                timeout = None):
         """Run the command with the args. The args can be a list
         or a string."""
         if args and not type(args) is list:
@@ -230,18 +425,21 @@ class execute:
             cmd.extend(args)
         return self.open(cmd, capture = capture, shell = shell,
-                         stdin = stdin, stdout = stdout, stderr = stderr)
+                         stdin = stdin, stdout = stdout, stderr = stderr,
+                         timeout = timeout)
     def command_subst(self, command, substs, capture = True, shell = False,
+                      timeout = None):
         """Run the command from the config data with the
         option format string subsituted with the subst variables."""
         args = arg_subst(command, substs)
         return self.command(args[0], args[1:], capture = capture,
                             shell = shell or self.shell_commands,
     def set_shell(self, execute):
         """Set the shell to execute when issuing a shell command."""
@@ -275,6 +473,37 @@ class execute:
         self.environment = environment
         return old_environment
+    def kill(self):
+        try:
+            if self.proc is not None:
+                self.proc.kill()
+        except:
+            raise
+        finally:
+    def terminate(self):
+        try:
+                self.proc.terminate()
+        except:
+            raise
+        finally:
+    def send_signal(self, signal):
+        try:
+                print("sending sig")
+                self.proc.send_signal(signal)
+        except:
+            raise
+        finally:
 class capture_execution(execute):
     """Capture all output as a string and return it."""
@@ -303,13 +532,14 @@ class capture_execution(execute):
                          verbose = verbose)
     def open(self, command, capture = True, shell = False, cwd = None, env = None,
+             stdin = None, stdout = None, stderr = None, timeout = None):
         if not capture:
             raise error.general('output capture must be true; leave as default')
         #self.snapper.get_and_clear()
         exit_code, proc = execute.open(self, command, capture = True, shell = shell,
         return (exit_code, proc, self.snapper.get_and_clear())
     def set_output(self, output):
@@ -333,11 +563,18 @@ if __name__ == "__main__":
         if ec == 0:
             print('piping input into ' + commands['pipe'][0] + ': ' + \
                   commands['pipe'][2])
-            proc.stdin.write(bytes(commands['pipe'][2], sys.stdin.encoding))
+            try:
+                out = bytes(commands['pipe'][2], sys.stdin.encoding)
+            except:
+                out = commands['pipe'][2]
+            proc.stdin.write(out)
             proc.stdin.close()
             e.capture(proc)
             del proc
+    def capture_output(text):
+        print(text, end = '')
     cmd_shell_test = 'if "%OS%" == "Windows_NT" (echo It is WinNT) else echo Is is not WinNT'
     sh_shell_test = 'x="me"; if [ $x = "me" ]; then echo "It was me"; else "It was him"; fi'
@@ -363,7 +600,7 @@ if __name__ == "__main__":
     print(arg_subst(['nothing', 'xx-%0-yyy', '%1', '%2-something'],
                     ['subst0', 'subst1', 'subst2']))
-    e = execute(error_prefix = 'ERR: ', verbose = True)
+    e = execute(error_prefix = 'ERR: ', output = capture_output, verbose = True)
     if sys.platform == "win32":
         run_tests(e, commands['windows'], False)
         if os.path.exists('c:\\msys\\1.0\\bin\\sh.exe'):
diff --git a/source-builder/sb/freebsd.py b/source-builder/sb/freebsd.py
index 87d4f41..8d08b4b 100644
--- a/source-builder/sb/freebsd.py
+++ b/source-builder/sb/freebsd.py
@@ -27,9 +27,9 @@
 import pprint
 import os
-import check
-import error
-import execute
+from . import check
 def load():
     uname = os.uname()
@@ -57,16 +57,20 @@ def load():
         '_host_cpu':        ('none',    'none',     cpu),
         '_host_alias':      ('none',    'none',     '%{nil}'),
         '_host_arch':       ('none',    'none',     cpu),
+        'host_includes':    ('none',    'convert',  '-I%{_usr}/include'),
+        'host_ldflags':     ('none',    'convert',  '-L%{_usr}/lib'),
         '_usr':             ('dir',     'required', '/usr/local'),
         '__bash':           ('exe',     'optional', '/usr/local/bin/bash'),
         '__bison':          ('exe',     'required', '/usr/local/bin/bison'),
+        '__cmake':          ('exe',     'optional', '/usr/local/bin/cmake'),
         '__git':            ('exe',     'required', '/usr/local/bin/git'),
-        '__svn':            ('exe',     'required', '/usr/local/bin/svn'),
+        '__svn':            ('exe',     'optional', '/usr/local/bin/svn'),
+        '__unzip':          ('exe',     'optional', '/usr/local/bin/unzip'),
         '__xz':             ('exe',     'optional', '/usr/bin/xz'),
         '__make':           ('exe',     'required', 'gmake'),
         '__patch_opts':     ('none',     'none',    '-E')
     defines['_build']        = defines['_host']
     defines['_build_vendor'] = defines['_host_vendor']
@@ -107,9 +111,11 @@ def load():
         if check.check_exe(cvs, cvs):
             defines['__cvs'] = cvs
-        # Fix the mess iconv is on FreeBSD 10.0.
+        # Fix the mess iconv is on FreeBSD 10.0 and higher.
-        defines['iconv_includes'] = ('none', 'none', '-I/usr/local/include -L/usr/local/lib')
+        defines['iconv_includes'] = ('none', 'none', '%{host_includes} %{host_ldflags}')
+        if fb_version >= 12:
+            defines['iconv_prefix'] = ('none', 'none', '%{_usr}')
         # On 11.0+ makeinfo and install-info have moved to /usr/local/...
@@ -117,6 +123,11 @@ def load():
         if fb_version >= 11:
             defines['__install_info'] = ('exe', 'optional', '/usr/local/bin/install-info')
             defines['__makeinfo']     = ('exe', 'required', '/usr/local/bin/makeinfo')
+        # On 12.0+ unzip is in /usr/bin
+            defines['__unzip'] = ('exe', 'optional', '/usr/bin/unzip')
     else:
         for gv in ['49', '48', '47']:
             gcc = '%s-portbld-freebsd%s-gcc%s' % (cpu, version, gv)
diff --git a/source-builder/sb/getsources.py b/source-builder/sb/getsources.py
new file mode 100644
index 0000000..d348da4
--- /dev/null
+++ b/source-builder/sb/getsources.py
@@ -0,0 +1,138 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2010-2019 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Permission to use, copy, modify, and/or distribute this software for any
+# purpose with or without fee is hereby granted, provided that the above
+# copyright notice and this permission notice appear in all copies.
+# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
+# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
+# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
+# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
+# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
+# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
+# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+# This code builds a package compiler tool suite given a tool set. A tool
+# set lists the various tools. These are specific tool configurations.
+from __future__ import print_function
+import argparse
+import copy
+import datetime
+import os
+import sys
+try:
+    from . import build
+    from . import error
+    from . import log
+    from . import simhost
+    from . import version
+except KeyboardInterrupt:
+    print('abort: user terminated', file = sys.stderr)
+    sys.exit(1)
+except:
+    raise
+def run(args = sys.argv):
+    ec = 0
+    get_sources_error = True
+    try:
+        # The RSB options support cannot be used because it loads the defaults
+        # for the host which we cannot do here.
+        description  = 'RTEMS Get Sources downloads all the source a build set '
+        description += 'references for all hosts.'
+        argsp = argparse.ArgumentParser(prog = 'rtems-get-sources',
+                                        description = description)
+        argsp.add_argument('--rtems-version', help = 'Set the RTEMS version.',
+                           type = str,
+                           default = version.version())
+        argsp.add_argument('--list-hosts', help = 'List the hosts.',
+                           action = 'store_true')
+        argsp.add_argument('--list-bsets', help = 'List the hosts.',
+        argsp.add_argument('--download-dir', help = 'Download directory.',
+                           type = str)
+        argsp.add_argument('--clean', help = 'Clean the download directory.',
+        argsp.add_argument('--tar', help = 'Create a tarball of all the source.',
+        argsp.add_argument('--log', help = 'Log file.',
+                           type = str,
+                           default = simhost.log_default('getsource'))
+        argsp.add_argument('--trace', help = 'Enable trace logging for debugging.',
+        argsp.add_argument('bsets', nargs='*', help = 'Build sets.')
+        argopts = argsp.parse_args(args[1:])
+        simhost.load_log(argopts.log)
+        log.notice('RTEMS Source Builder - Get Sources, %s' % (version.string()))
+        log.tracing = argopts.trace
+        opts = simhost.load_options(args, argopts, extras = ['--with-download'])
+        configs = build.get_configs(opts)
+        if argopts.list_hosts:
+            simhost.list_hosts()
+        elif argopts.list_bsets:
+            simhost.list_bset_files(opts, configs)
+        else:
+            if argopts.clean:
+                if argopts.download_dir is None:
+                    raise error.general('cleaning of the default download directories is not supported')
+                if path.exists(argopts.download_dir):
+                    log.notice('Cleaning source directory: %s' % (argopts.download_dir))
+                    path.removeall(argopts.download_dir)
+            all_bsets = simhost.get_bset_files(configs)
+            if len(argopts.bsets) == 0:
+                bsets = all_bsets
+            else:
+                bsets = argopts.bsets
+            for bset in bsets:
+                b = None
+                try:
+                    for host in simhost.profiles:
+                        b = simhost.buildset(bset, configs, opts)
+                        get_sources_error = False
+                        b.build(host)
+                        del b
+                except error.general as gerr:
+                    log.stderr(str(gerr))
+                    log.stderr('Build FAILED')
+                b = None
+        if get_sources_error:
+        ec = 1
+    except error.internal as ierr:
+            log.stderr(str(ierr))
+        log.stderr('Internal Build FAILED')
+        ec = 1
+    except error.exit as eerr:
+        pass
+    except KeyboardInterrupt:
+        log.notice('abort: user terminated')
+        ec = 1
+    except:
+        raise
+        log.notice('abort: unknown error')
+        ec = 1
+    sys.exit(ec)
+if __name__ == "__main__":
+    run()
diff --git a/source-builder/sb/git.py b/source-builder/sb/git.py
index f35c335..237e690 100644
--- a/source-builder/sb/git.py
+++ b/source-builder/sb/git.py
 import os
-import error
-import execute
-import log
-import options
-import path
+from . import log
+from . import path
 class repo:
     """An object to manage a git repo."""
@@ -70,9 +69,9 @@ class repo:
         if len(gvs) < 3:
             raise error.general('invalid version string from git: %s' % (output))
         vs = gvs[2].split('.')
-        if len(vs) != 4:
+        if len(vs) not in [3, 4]:
             raise error.general('invalid version number from git: %s' % (gvs[2]))
-        return (int(vs[0]), int(vs[1]), int(vs[2]), int(vs[3]))
+        return tuple(map(int, vs))
     def clone(self, url, _path):
         ec, output = self._run(['clone', url, path.host(_path)], check = True)
@@ -105,14 +104,36 @@ class repo:
     def submodule(self, module):
         ec, output = self._run(['submodule', 'update', '--init', module], check = True)
+    def submodule_foreach(self, args = []):
+        if type(args) == str:
+            args = [args.split(args)]
+        ec, output = self._run(['submodule',
+                                'foreach',
+                                '--recursive',
+                                self.git] + args, check = True)
+    def submodules(self):
+        smodules = {}
+        ec, output = self._run(['submodule'], check = True)
+        if ec == 0:
+            for l in output.split('\n'):
+                ms = l.split()
+                if len(ms) == 3:
+                    smodules[ms[1]] = (ms[0], ms[2][1:-1])
+        return smodules
     def clean(self, args = []):
             args = [args]
         ec, output = self._run(['clean'] + args, check = True)
-    def status(self):
+    def status(self, submodules_always_clean = False):
         _status = {}
         if path.exists(self.path):
+            if submodules_always_clean:
+                submodules = self.submodules()
+            else:
+                submodules = {}
             ec, output = self._run(['status'])
             if ec == 0:
                 state = 'none'
@@ -133,16 +154,22 @@ class repo:
                         if l[0].isspace():
                             l = l.strip()
                             if l[0] != '(':
-                                if state not in _status:
-                                    _status[state] = []
-                                l = l[1:]
                                 if ':' in l:
                                     l = l.split(':')[1]
-                                _status[state] += [l.strip()]
+                                if len(l.strip()) > 0:
+                                    l = l.strip()
+                                    ls = l.split()
+                                    if state != 'unstaged' or ls[0] not in submodules:
+                                        if state not in _status:
+                                            _status[state] = [l]
+                                        else:
+                                            _status[state] += [l]
         return _status
     def dirty(self):
         _status = self.status()
+        _status.pop('untracked', None)
+        _status.pop('detached', None)
         return not (len(_status) == 1 and 'branch' in _status)
     def valid(self):
@@ -200,13 +227,19 @@ class repo:
         return hash
+    import os.path
     import sys
-    opts = options.load(sys.argv)
+    from . import options
+    defaults = path.join(path.dirname(path.dirname(path.shell(sys.argv[0]))),
+                         'defaults.mc')
+    opts = options.load(sys.argv, defaults = defaults)
     g = repo('.', opts)
-    print(g.git_version())
-    print(g.valid())
-    print(g.status())
-    print(g.clean())
-    print(g.remotes())
-    print(g.email())
-    print(g.head())
+    print('g.git_version():', g.git_version())
+    print('g.valid():', g.valid())
+    print('g.submodules():', g.submodules())
+    print('g.status():', g.status())
+    print('g.status():', g.status(True))
+    print('g.dirty():', g.dirty())
+    print('g.remotes():', g.remotes())
+    print('g.email():', g.email())
+    print('g.head():', g.head())
diff --git a/source-builder/sb/linux.py b/source-builder/sb/linux.py
index e6c5470..d89377b 100644
--- a/source-builder/sb/linux.py
+++ b/source-builder/sb/linux.py
@@ -22,29 +22,15 @@
 # RTEMS project's spec files.
+import multiprocessing
+import platform
 import pprint
 import os
-import platform
-import execute
-import path
+from . import path
 def load():
     uname = os.uname()
-    smp_mflags = ''
-    processors = '/bin/grep processor /proc/cpuinfo'
-    exit_code, proc, output = e.shell(processors)
-    ncpus = 0
-        try:
-            for l in output.split('\n'):
-                count = l.split(':')[1].strip()
-                if int(count) > ncpus:
-                    ncpus = int(count)
-        except:
-            pass
-    ncpus = str(ncpus + 1)
     if uname[4].startswith('arm'):
         cpu = 'arm'
     else:
@@ -52,7 +38,7 @@ def load():
     version = uname[2]
     defines = {
-        '_ncpus':           ('none',    'none',     ncpus),
+        '_ncpus':           ('none',    'none',     str(multiprocessing.cpu_count())),
         '_os':              ('none',    'none',     'linux'),
         '_host':            ('triplet', 'required', cpu + '-linux-gnu'),
         '_host_vendor':     ('none',    'none',     'gnu'),
@@ -69,13 +55,17 @@ def load():
         '__tar':            ('exe',     'required', '/bin/tar')
-    # Works for LSB distros
-    try:
-        distro = platform.dist()[0]
-        distro_ver = float(platform.dist()[1])
-    except ValueError:
-        # Non LSB distro found, use failover"
-        pass
+    # platform.dist() was removed in Python 3.8
+    if hasattr(platform, 'dist'):
+        # Works for LSB distros
+        try:
+            distro = platform.dist()[0]
+            distro_ver = float(platform.dist()[1])
+        except ValueError:
+         # Non LSB distro found, use failover"
+         pass
+    else:
+         distro = ''
     # Non LSB - fail over to issue
     if distro == '':
@@ -94,7 +84,7 @@ def load():
             distro = 'redhat'
     elif distro in ['centos', 'fedora']:
         distro = 'redhat'
-    elif distro in ['Ubuntu', 'ubuntu', 'LinuxMint', 'linuxmint']:
+    elif distro in ['Ubuntu', 'ubuntu', 'MX', 'LinuxMint', 'linuxmint']:
         distro = 'debian'
     elif distro in ['Arch']:
         distro = 'arch'
@@ -120,6 +110,12 @@ def load():
                      '__chown':        ('exe',     'required', '/usr/bin/chown') },
         'suse'   : { '__chgrp':        ('exe',     'required', '/usr/bin/chgrp'),
                      '__chown':        ('exe',     'required', '/usr/sbin/chown') },
+        'gentoo' : { '__bzip2':        ('exe',     'required', '/bin/bzip2'),
+                     '__chgrp':        ('exe',     'required', '/bin/chgrp'),
+                     '__chown':        ('exe',     'required', '/bin/chown'),
+                     '__gzip':         ('exe',     'required', '/bin/gzip'),
+                     '__grep':         ('exe',     'required', '/bin/grep'),
+                     '__sed':          ('exe',     'required', '/bin/sed') },
     if distro in variations:
diff --git a/source-builder/sb/log.py b/source-builder/sb/log.py
index 301bd96..7ad4763 100755
--- a/source-builder/sb/log.py
+++ b/source-builder/sb/log.py
@@ -1,6 +1,6 @@
-# Copyright 2010-2012 Chris Johns (chrisj at rtems.org)
@@ -26,13 +26,18 @@ from __future__ import print_function
 import os
 import sys
-import error
 # A global log.
 default = None
+# A global capture handler.
+capture = None
 # Global parameters.
@@ -70,6 +75,8 @@ def stderr(text = os.linesep, log = None):
     for l in text.replace(chr(13), '').splitlines():
         print(l, file = sys.stderr)
         sys.stderr.flush()
+    if capture is not None:
+        capture(text)
 def output(text = os.linesep, log = None):
     if not quiet:
@@ -80,10 +87,12 @@ def notice(text = os.linesep, log = None):
             print(l)
         sys.stdout.flush()
+            capture(text)
     _output(text, log)
 def trace(text = os.linesep, log = None):
-    if tracing:
+    if not quiet and tracing:
         _output(text, log)
 def warning(text = os.linesep, log = None):
@@ -105,7 +114,7 @@ def tail(log = None):
 class log:
     """Log output to stdout or a file."""
-    def __init__(self, streams = None, tail_size = 200):
+    def __init__(self, streams = None, tail_size = 400):
         self.tail = []
         self.tail_size = tail_size
         self.fhs = [None, None]
diff --git a/source-builder/sb/macros.py b/source-builder/sb/macros.py
index cf25783..6ca87ed 100644
--- a/source-builder/sb/macros.py
+++ b/source-builder/sb/macros.py
@@ -27,8 +27,8 @@ import re
 import os
 import string
-import error
-import path
+from . import path
 # Macro tables
@@ -53,7 +53,8 @@ class macros:
         def iterkeys(self):
             return self.keys
-    def _unicode_to_str(self, us):
+    @staticmethod
+    def _unicode_to_str(us):
         try:
             if type(us) == unicode:
                 return us.encode('ascii', 'replace')
@@ -122,6 +123,7 @@ class macros:
                 lc = 0
                 for l in ds:
                     lc += 1
+                    l = self._unicode_to_str(l)
                     while len(l):
                         if indent:
                             text += ' %21s %10s %12s' % (' ', ' ', ' ')
@@ -174,14 +176,14 @@ class macros:
                             'override', 'undefine', 'convert']:
             raise TypeError('bad value tuple (attrib field): %s' % (value[1]))
         if value[1] == 'convert':
-            value = self.expand(value)
+            value = (value[0], value[1], self.expand(value[2]))
         self.macros[self.write_map][self.key_filter(key)] = value
     def __delitem__(self, key):
         self.undefine(key)
     def __contains__(self, key):
-        return self.has_key(key)
+        return self.has_key(self._unicode_to_str(key))
     def __len__(self):
         return len(list(self.keys()))
@@ -201,6 +203,7 @@ class macros:
         return sorted(set(keys))
     def has_key(self, key):
+        key = self._unicode_to_str(key)
         if type(key) is not str:
             raise TypeError('bad key type (want str): %s' % (type(key)))
         if self.key_filter(key) not in list(self.keys()):
@@ -230,7 +233,7 @@ class macros:
         return [rm[5:] for rm in self.read_maps]
     def key_filter(self, key):
-        if key.startswith('%{') and key[-1] is '}':
+        if key.startswith('%{') and key[-1] == '}':
             key = key[2:-1]
         return key.lower()
@@ -266,28 +269,28 @@ class macros:
                     print(']]]]]]]] c:%s(%d) s:%s t:"%s" m:%r M:%s' % \
                         (c, ord(c), state, token, macro, map))
                 l_remaining = l_remaining[1:]
-                if c is '#' and not state.startswith('value'):
+                if c == '#' and not state.startswith('value'):
                     break
                 if c == '\n' or c == '\r':
-                    if not (state is 'key' and len(token) == 0) and \
+                    if not (state == 'key' and len(token) == 0) and \
                             not state.startswith('value-multiline'):
                         raise error.general('malformed macro line:%d: %s' % (lc, l))
-                if state is 'key':
+                if state == 'key':
                     if c not in string.whitespace:
-                        if c is '[':
+                        if c == '[':
                             state = 'map'
-                        elif c is '%':
+                        elif c == '%':
                             state = 'directive'
-                        elif c is ':':
+                        elif c == ':':
                             macro += [token]
                             token = ''
                             state = 'attribs'
-                        elif c is '#':
+                        elif c == '#':
                             break
                         else:
                             token += c
-                elif state is 'map':
-                    if c is ']':
+                elif state == 'map':
+                    if c == ']':
                         if token not in macros:
                             macros[token] = {}
                         map = token
@@ -297,7 +300,7 @@ class macros:
                         token += c
                     else:
                         raise error.general('invalid macro map:%d: %s' % (lc, l))
-                elif state is 'directive':
+                elif state == 'directive':
                     if c in string.whitespace:
                         if token == 'include':
                             self.load(_clean(l_remaining))
@@ -308,7 +311,7 @@ class macros:
                         token += c
                     else:
                         raise error.general('invalid macro directive:%d: %s' % (lc, l))
-                elif state is 'include':
+                elif state == 'include':
                     if c is string.whitespace:
                             state = 'include'
@@ -316,49 +319,49 @@ class macros:
                         token += c
                     else:
-                elif state is 'attribs':
+                elif state == 'attribs':
-                        if c is ',':
+                        if c == ',':
                             macro += [token]
                             token = ''
                             if len(macro) == 3:
                                 state = 'value-start'
                         else:
                             token += c
-                elif state is 'value-start':
-                    if c is "'":
+                elif state == 'value-start':
+                    if c == "'":
                         state = 'value-line-start'
-                elif state is 'value-line-start':
-                    if c is "'":
+                elif state == 'value-line-start':
+                    if c == "'":
                         state = 'value-multiline-start'
                     else:
                         state = 'value-line'
                         token += c
-                elif state is 'value-multiline-start':
-                    if c is "'":
+                elif state == 'value-multiline-start':
+                    if c == "'":
                         state = 'value-multiline'
                     else:
                         macro += [token]
                         state = 'macro'
-                elif state is 'value-line':
-                    if c is "'":
+                elif state == 'value-line':
+                    if c == "'":
                         macro += [token]
                         state = 'macro'
                     else:
                         token += c
-                elif state is 'value-multiline':
-                    if c is "'":
+                elif state == 'value-multiline':
+                    if c == "'":
                         state = 'value-multiline-end'
                     else:
                         token += c
-                elif state is 'value-multiline-end':
-                    if c is "'":
+                elif state == 'value-multiline-end':
+                    if c == "'":
                         state = 'value-multiline-end-end'
                     else:
                         token += "'" + c
-                elif state is 'value-multiline-end-end':
-                    if c is "'":
+                elif state == 'value-multiline-end-end':
+                    if c == "'":
                         macro += [token]
                         state = 'macro'
                     else:
@@ -366,7 +369,7 @@ class macros:
                         token += "''" + c
                 else:
                     raise error.internal('bad state: %s' % (state))
-                if state is 'macro':
+                if state == 'macro':
                     macros[map][self._unicode_to_str(macro[0].lower())] = \
                                 (self._unicode_to_str(macro[1]),
                                  self._unicode_to_str(macro[2]),
@@ -452,6 +455,7 @@ class macros:
     def expand(self, _str):
         """Simple basic expander of config file macros."""
+        _str = self._unicode_to_str(_str)
         expanded = True
         while expanded:
             expanded = False
diff --git a/source-builder/sb/mailer.py b/source-builder/sb/mailer.py
index b9ef812..ff25df5 100644
--- a/source-builder/sb/mailer.py
+++ b/source-builder/sb/mailer.py
@@ -27,9 +27,9 @@ import os
 import smtplib
 import socket
-import error
-import options
-import path
+from . import error
+from . import options
+from . import path
 def append_options(opts):
     opts['--mail'] = 'Send email report or results.'
@@ -92,9 +92,13 @@ class mail:
         from_addr = self.from_address()
         msg = "From: %s\r\nTo: %s\r\nSubject: %s\r\n\r\n" % \
             (from_addr, to_addr, subject) + body
+        if type(to_addr) is str:
+            to_addr = to_addr.split(',')
+        if type(to_addr) is not list:
+            raise error.general('invalid to_addr type')
         try:
             s = smtplib.SMTP(self.smtp_host())
-            s.sendmail(from_addr, [to_addr], msg)
+            s.sendmail(from_addr, to_addr, msg)
         except smtplib.SMTPException as se:
             raise error.general('sending mail: %s' % (str(se)))
         except socket.error as se:
diff --git a/source-builder/sb/netbsd.py b/source-builder/sb/netbsd.py
index c7420c3..3398290 100644
--- a/source-builder/sb/netbsd.py
+++ b/source-builder/sb/netbsd.py
@@ -27,8 +27,8 @@
 import pprint
 import os
-import check
-import execute
+from . import execute
 def load():
     uname = os.uname()
diff --git a/source-builder/sb/options.py b/source-builder/sb/options.py
index 7d1856b..d6bffd0 100644
--- a/source-builder/sb/options.py
+++ b/source-builder/sb/options.py
@@ -29,16 +29,17 @@ import pprint
 import re
 import os
 import string
-import error
-import execute
-import git
-import log
-import macros
-import path
 import sys
-import version
+from . import download
+from . import git
+from . import log
+from . import macros
+from . import path
+from . import version
 basepath = 'sb'
@@ -53,12 +54,13 @@ class command_line:
     def __init__(self, argv, optargs, _defaults, command_path):
         self._long_opts = {
-            # key                 macro                handler            param  defs   init
+            # key                       macro                handler            param  defs   init
             '--prefix'               : ('_prefix',           self._lo_path,     True,  None,  False),
             '--topdir'               : ('_topdir',           self._lo_path,     True,  None,  False),
             '--configdir'            : ('_configdir',        self._lo_path,     True,  None,  False),
             '--builddir'             : ('_builddir',         self._lo_path,     True,  None,  False),
             '--sourcedir'            : ('_sourcedir',        self._lo_path,     True,  None,  False),
+            '--patchdir'             : ('_patchdir',         self._lo_path,     True,  None,  False),
             '--tmppath'              : ('_tmppath',          self._lo_path,     True,  None,  False),
             '--jobs'                 : ('_jobs',             self._lo_jobs,     True,  'max', True),
             '--log'                  : ('_logfile',          self._lo_string,   True,  None,  False),
@@ -82,6 +84,9 @@ class command_line:
             '--host'                 : ('_host',             self._lo_triplets, True,  None,  False),
             '--build'                : ('_build',            self._lo_triplets, True,  None,  False),
             '--target'               : ('_target',           self._lo_triplets, True,  None,  False),
+            '--rtems-tools'          : ('_rtems_tools',      self._lo_string,   True,  None,  False),
+            '--rtems-bsp'            : ('_rtems_bsp',        self._lo_string,   True,  None,  False),
+            '--rtems-version'        : ('_rtems_version',    self._lo_string,   True,  None,  False),
             '--help'                 : (None,                self._lo_help,     False, None,  False)
@@ -95,7 +100,9 @@ class command_line:
         for lo in self._long_opts:
             self.opts[lo[2:]] = self._long_opts[lo][3]
             if self._long_opts[lo][4]:
-                self.defaults[self._long_opts[lo][0]] = ('none', 'none', self._long_opts[lo][3])
+                self.defaults[self._long_opts[lo][0]] = ('none',
+                                                         'none',
+                                                         self._long_opts[lo][3])
     def __str__(self):
         def _dict(dd):
@@ -194,7 +201,7 @@ class command_line:
     def help(self):
         print('%s: [options] [args]' % (self.command_name))
-        print('RTEMS Source Builder, an RTEMS Tools Project (c) 2012-2015 Chris Johns')
+        print('RTEMS Source Builder, an RTEMS Tools Project (c) 2012-2019 Chris Johns')
         print('Options and arguments:')
         print('--force                : Force the build to proceed')
         print('--quiet                : Quiet output (not used)')
@@ -214,6 +221,7 @@ class command_line:
         print('--configdir path       : Path to the configuration directory, default: ./config')
         print('--builddir path        : Path to the build directory, default: ./build')
         print('--sourcedir path       : Path to the source directory, default: ./source')
+        print('--patchdir path        : Path to the patches directory, default: ./patches')
         print('--tmppath path         : Path to the temp directory, default: ./tmp')
         print('--macros file[,[file]  : Macro format files to load after the defaults')
         print('--log file             : Log file where all build out is written too')
@@ -235,20 +243,22 @@ class command_line:
         raise error.exit()
     def process(self):
+        for a in self.args:
+            if a == '-?' or a == '--help':
+                self.help()
         arg = 0
         while arg < len(self.args):
             a = self.args[arg]
-            if a == '-?':
-                self.help()
-            elif a.startswith('--'):
-                los = a.split('=')
+            if a.startswith('--'):
+                los = a.split('=', 1)
                 lo = los[0]
                 if lo in self._long_opts:
                     long_opt = self._long_opts[lo]
                     if len(los) == 1:
                         if long_opt[2]:
                             if arg == len(self.args) - 1:
-                                raise error.general('option requires a parameter: %s' % (lo))
+                                raise error.general('option requires a parameter: %s' % \
+                                                    (lo))
                             arg += 1
                             value = self.args[arg]
                         else:
@@ -262,8 +272,14 @@ class command_line:
                             value = los[1]
                         else:
                             value = '1'
-                        self.defaults[los[0][2:].replace('-', '_').lower()] = ('none', 'none', value)
+                        self.defaults[los[0][2:].replace('-', '_').lower()] = \
+                            ('none', 'none', value)
+                    else:
+                        if lo not in self.optargs:
+                            raise error.general('unknown option: %s' % (lo))
             else:
+                if a.startswith('-'):
+                    raise error.general('short options not supported; only "-?"')
                 self.opts['params'].append(a)
             arg += 1
@@ -276,8 +292,9 @@ class command_line:
                               '--with-download',
                               '--quiet',
                               '--without-log',
-                              '--without-error-report',
-                              '--without-release-url']
+                              '--without-error-report']
+            if a == '--dry-run':
+                self.args += ['--without-error-report']
             arg += 1
     def post_process(self, logfile = True):
@@ -302,7 +319,9 @@ class command_line:
         # Default prefix
         prefix = self.parse_args('--prefix')
         if prefix is None:
-            value = path.join(self.defaults['_prefix'], 'rtems', str(version.version()))
+            value = path.join(self.defaults['_prefix'],
+                              'rtems',
+                              str(self.defaults['rtems_version']))
             self.opts['prefix'] = value
             self.defaults['_prefix'] = value
         # Manage the regression option
@@ -326,7 +345,8 @@ class command_line:
         if um:
             checked = path.exists(um)
             if False in checked:
-                raise error.general('macro file not found: %s' % (um[checked.index(False)]))
+                raise error.general('macro file not found: %s' % \
+                                    (um[checked.index(False)]))
             for m in um:
                 self.defaults.load(m)
         # Check if the user has a private set of macros to load
@@ -341,7 +361,7 @@ class command_line:
     def sb_released(self):
         if version.released():
             self.defaults['rsb_released'] = '1'
-        self.defaults['rsb_version'] = version.str()
+        self.defaults['rsb_version'] = version.string()
     def sb_git(self):
         repo = git.repo(self.defaults.expand('%{_sbdir}'), self)
@@ -409,10 +429,13 @@ class command_line:
         _host = self.defaults.expand('%{_host}')
         _build = self.defaults.expand('%{_build}')
         _target = self.defaults.expand('%{_target}')
-        if len(_target):
-            return len(_host) and len(_build) and (_target) and \
-                _host != _build and _host != _target
-        return len(_host) and len(_build) and _host != _build
+        # The removed fix has been put back. I suspect
+        # this was done as a result of another issue that
+        # has been fixed.
+        return len(_target) and len(_host) and len(_build) \
+            and _host != _build and _host != _target
     def user_macros(self):
@@ -474,7 +497,7 @@ class command_line:
                 lhs = None
                 rhs = None
                 if '=' in self.args[a]:
-                    eqs = self.args[a].split('=')
+                    eqs = self.args[a].split('=', 1)
                     lhs = eqs[0]
                     if len(eqs) > 2:
                         rhs = '='.join(eqs[1:])
@@ -573,6 +596,12 @@ class command_line:
             if self.get_arg('--with-tools') is not None:
                 raise error.general('--rtems-tools and --with-tools cannot be used together')
             self.args.append('--with-tools=%s' % (rtems_tools[1]))
+        rtems_version = self.parse_args('--rtems-version')
+        if rtems_version is None:
+            rtems_version = str(version.version())
+        else:
+            rtems_version = rtems_version[1]
+        self.defaults['rtems_version'] = rtems_version
         rtems_arch_bsp = self.parse_args('--rtems-bsp')
         if rtems_arch_bsp is not None:
             if self.get_arg('--target') is not None:
@@ -580,11 +609,6 @@ class command_line:
             ab = rtems_arch_bsp[1].split('/')
             if len(ab) != 2:
                 raise error.general('invalid --rtems-bsp option')
-            rtems_version = self.parse_args('--rtems-version')
-            if rtems_version is None:
-                rtems_version = version.version()
-            else:
-                rtems_version = rtems_version[1]
             self.args.append('--target=%s-rtems%s' % (ab[0], rtems_version))
             self.args.append('--with-rtems-bsp=%s' % (ab[1]))
@@ -602,7 +626,7 @@ def load(args, optargs = None, defaults = '%{_sbdir}/defaults.mc', logfile = Tru
     # The path to this command.
-    command_path = path.dirname(args[0])
+    command_path = path.dirname(path.abspath(args[0]))
     if len(command_path) == 0:
         command_path = '.'
@@ -619,7 +643,7 @@ def load(args, optargs = None, defaults = '%{_sbdir}/defaults.mc', logfile = Tru
     overrides = None
     if os.name == 'nt':
         try:
-            import windows
+            from . import windows
             overrides = windows.load()
             host_windows = True
             host_posix = False
@@ -629,26 +653,26 @@ def load(args, optargs = None, defaults = '%{_sbdir}/defaults.mc', logfile = Tru
         uname = os.uname()
         try:
             if uname[0].startswith('MINGW64_NT'):
-                import windows
                 host_windows = True
             elif uname[0].startswith('CYGWIN_NT'):
-                import windows
             elif uname[0] == 'Darwin':
-                import darwin
+                from . import darwin
                 overrides = darwin.load()
             elif uname[0] == 'FreeBSD':
-                import freebsd
+                from . import freebsd
                 overrides = freebsd.load()
             elif uname[0] == 'NetBSD':
-                import netbsd
+                from . import netbsd
                 overrides = netbsd.load()
             elif uname[0] == 'Linux':
-                import linux
+                from . import linux
                 overrides = linux.load()
             elif uname[0] == 'SunOS':
-                import solaris
+                from . import solaris
                 overrides = solaris.load()
         except error.general as ge:
             raise error.general('failed to load %s host support: %s' % (uname[0], ge))
@@ -671,14 +695,30 @@ def load(args, optargs = None, defaults = '%{_sbdir}/defaults.mc', logfile = Tru
     # Load the release settings
-    version.load_release_settings(o.defaults)
+    def setting_error(msg):
+        raise error.general(msg)
+    hashes = version.load_release_settings('hashes')
+    for hash in hashes:
+        hs = hash[1].split()
+        if len(hs) != 2:
+            raise error.general('invalid release hash in VERSION')
+        sources.hash((hs[0], hash[0], hs[1]), o.defaults, setting_error)
+    release_path = version.load_release_setting('version', 'release_path',
+                                                raw = True)
+    if release_path is not None:
+        try:
+            release_path = ','.join([rp.strip() for rp in release_path.split(',')])
+        except:
+            raise error.general('invalid release path in VERSION')
+        download.set_release_path(release_path, o.defaults)
     return o
 def run(args):
     try:
-        _opts = load(args = args, defaults = 'defaults.mc')
-        log.notice('RTEMS Source Builder - Defaults, %s' % (version.str()))
+        dpath = path.dirname(args[0])
+        _opts = load(args = args,
+                     defaults = path.join(dpath, 'defaults.mc'))
+        log.notice('RTEMS Source Builder - Defaults, %s' % (version.string()))
         _opts.log_info()
         log.notice('Options:')
         log.notice(str(_opts))
diff --git a/source-builder/sb/path.py b/source-builder/sb/path.py
index b86df0d..b27cf14 100644
--- a/source-builder/sb/path.py
+++ b/source-builder/sb/path.py
@@ -1,6 +1,6 @@
-# Copyright 2010-2016 Chris Johns (chrisj at rtems.org)
+# Copyright 2010-2018 Chris Johns (chrisj at rtems.org)
@@ -25,15 +25,18 @@
-import log
 import os
 import shutil
 import stat
 import string
+import sys
-import error
+from . import log
+windows_posix = sys.platform == 'msys'
 windows = os.name == 'nt'
 win_maxpath = 254
 def host(path):
@@ -53,19 +56,16 @@ def host(path):
                 path = u'\\'.join([u'\\\\?', path])
     return path
-def is_abspath(path):
-    if path is not None:
-        return '/' == path[0]
-    return False
 def shell(path):
+    if isinstance(path, bytes):
+        path = path.decode('ascii')
-        if windows:
-            path = path.encode('ascii', 'ignore')
+        if windows or windows_posix:
+            path = path.encode('ascii', 'ignore').decode('ascii')
             if path.startswith('\\\\?\\'):
                 path = path[4:]
             if len(path) > 1 and path[1] == ':':
-                path = '/%s%s' % (path[0], path[2:])
+                path = '/%s%s' % (path[0].lower(), path[2:])
             path = path.replace('\\', '/')
         while '//' in path:
             path = path.replace('//', '/')
@@ -79,6 +79,11 @@ def dirname(path):
     path = shell(path)
     return shell(os.path.dirname(path))
+def is_abspath(path):
+    if path is not None and len(path) > 0:
+        return '/' == path[0]
+    return False
 def join(path, *args):
     path = shell(path)
     for arg in args:
@@ -218,7 +223,6 @@ def removeall(path):
         _remove_node(path)
 def expand(name, paths):
-    path = shell(path)
     l = []
     for p in paths:
         l += [join(shell(p), name)]
@@ -305,6 +309,58 @@ def copy_tree(src, dst):
         else:
             raise error.general('copying tree (4): %s -> %s: %s' % (hsrc, hdst, str(why)))
+def get_size(path, depth = -1):
+    # Get the size the directory tree manually to the required depth.
+    # This makes sure on Windows the files are correctly encoded to avoid
+    # the file name size limit. On Windows the os.walk fails once we
+    # get to the max path length on Windows.
+    def _isdir(path):
+        hpath = host(path)
+        return os.path.isdir(hpath) and not os.path.islink(hpath)
+    def _node_size(path):
+        size = 0
+        if not os.path.islink(hpath):
+            size = os.path.getsize(hpath)
+        return size
+    def _get_size(path, depth, level = 0):
+        level += 1
+        dirs = []
+        size = 0
+        for name in listdir(path):
+            path_ = join(path, shell(name))
+            hname = host(path_)
+            if _isdir(path_):
+                dirs += [shell(name)]
+            else:
+                size += _node_size(path_)
+        if depth < 0 or level < depth:
+            for name in dirs:
+                dir = join(path, name)
+                size += _get_size(dir, depth, level)
+        return size
+    path = shell(path)
+    size = 0
+    if os.path.exists(hpath):
+        size = _get_size(path, depth)
+    return size
+def get_humanize_size(path, depth = -1):
+    size = get_size(path, depth)
+    for unit in ['','K','M','G','T','P','E','Z']:
+        if abs(size) < 1024.0:
+            return "%5.3f%sB" % (size, unit)
+        size /= 1024.0
+    return "%.3f%sB" % (size, 'Y')
     print(host('/a/b/c/d-e-f'))
     print(host('//a/b//c/d-e-f'))
@@ -312,6 +368,10 @@ if __name__ == '__main__':
     print(basename('/as/sd/df/fg/me.txt'))
     print(dirname('/as/sd/df/fg/me.txt'))
     print(join('/d', 'g', '/tyty/fgfg'))
+    print('size of . depth all: ', get_size('.'))
+    print('size of . depth   1: ', get_size('.', 1))
+    print('size of . depth   2: ', get_size('.', 2))
+    print('size of . as human : ', get_humanize_size('.'))
     windows = True
diff --git a/source-builder/sb/pkgconfig.py b/source-builder/sb/pkgconfig.py
index 519e858..198ec80 100755
--- a/source-builder/sb/pkgconfig.py
+++ b/source-builder/sb/pkgconfig.py
@@ -43,7 +43,7 @@ import re
 import shlex
 import sys
-import path
+from . import path
 def default_prefix(common = True):
     paths = []
@@ -91,6 +91,7 @@ class package(object):
     no_dup_flags = ['-I', '-l', '-L']
     dual_opts = ['-D', '-U', '-I', '-l', '-L']
     lib_list_splitter = re.compile('[\s,]+')
+    loaded_prefixes = None
     loaded = {}
     @staticmethod
@@ -101,6 +102,22 @@ class package(object):
         dst.fields = copy.copy(src.fields)
         dst.nodes = copy.copy(src.nodes)
+    @staticmethod
+    def _is_string(us):
+        if type(us) == str:
+            return True
+        try:
+            if type(us) == unicode:
+                return True
+        except:
+            pass
+        try:
+            if type(us) == bytes:
+                return True
+        except:
+            pass
+        return False
     @staticmethod
     def is_version(v):
         for n in v.split('.'):
@@ -213,7 +230,8 @@ class package(object):
             prefix = default_prefix()
         if prefix:
             self._log('prefix: %s' % (prefix))
-            if type(prefix) is str:
+            if self._is_string(prefix):
+                prefix = str(prefix)
                 self.prefix = []
                 for p in prefix.split(os.pathsep):
                     self.prefix += [path.shell(p)]
@@ -416,15 +434,15 @@ class package(object):
         return ok
     def load(self, name):
-        if name in package.loaded:
-            package._copy(package.loaded[name], self)
-            return
         self._log('loading: %s' % (name))
         if self.name_:
             self._clean()
         self.name_ = name
         file = self._find_package(name)
         if file:
+            if file in package.loaded:
+                package._copy(package.loaded[file], self)
+                return
             self._log('load: %s (%s)' % (name, file))
             if self.src:
                 self.src('==%s%s' % ('=' * 80, os.linesep))
@@ -474,8 +492,9 @@ class package(object):
             if requires:
                 for r in package.splitter(requires):
                     if r[0] not in self.nodes[nt]:
-                        if r[0] in package.loaded:
-                            pkg = package.loaded[r[0]]
+                        file = self._find_package(r[0])
+                            pkg = package.loaded[file]
                         else:
                             pkg = package(r[0], self.prefix, self.output)
                         ver = pkg.get('version')
@@ -486,8 +505,8 @@ class package(object):
                             self._log('failed: %s (%s %s %s)' % (r[0], ver, r[1], r[2]))
                             self.nodes['failed'][r[0]] = pkg
         if self.exists():
-            self._log('load: exists')
-            package.loaded[name] = self
+            self._log('load: exists and loaded; cache as loaded')
+            package.loaded[self.file_] = self
     def get(self, label, private = True):
         self._log('get: %s (%s)' % (label, ','.join(self.fields)))
diff --git a/source-builder/sb/reports.py b/source-builder/sb/reports.py
index 9d3a342..a20b29e 100644
--- a/source-builder/sb/reports.py
+++ b/source-builder/sb/reports.py
@@ -30,27 +30,22 @@ import datetime
 import os
 import sys
-import pprint
-pp = pprint.PrettyPrinter(indent = 2)
 try:
-    import build
-    import check
-    import config
-    import error
-    import git
-    import log
-    import options
-    import path
-    import setbuilder
-    import sources
-    import version
+    from . import check
+    from . import config
+    from . import git
+    from . import log
+    from . import path
+    from . import sources
     print('user terminated', file = sys.stderr)
     sys.exit(1)
 except:
-    print('error: unknown application load error', file = sys.stderr)
-    sys.exit(1)
+    raise
 _line_len = 78
@@ -241,13 +236,16 @@ class markdown_formatter(formatter):
             self.line(self._strong('Remotes:'))
             self.line('')
             rc = 1
-            for r in remotes:
-                if 'url' in remotes[r]:
-                    text = remotes[r]['url']
-                else:
-                    text = 'no URL found'
-                self.line('%d. %s: %s' % (rc, r, text))
-                rc += 1
+            if not remotes:
+                self.line('[ remotes removed, contact sender for details ]')
+            else:
+                for r in remotes:
+                    if 'url' in remotes[r]:
+                        text = remotes[r]['url']
+                    else:
+                        text = 'no URL found'
+                    self.line('%d. %s: %s' % (rc, r, text))
+                    rc += 1
             self.line('')
             self.line(self._strong('Status:'))
             self.line('')
@@ -427,14 +425,17 @@ class text_formatter(formatter):
         if valid:
             self.line('%s Remotes:' % (self.cini))
             rc = 0
-            for r in remotes:
-                rc += 1
-                else:
-                text = '%s: %s' % (r, text)
-                self.line('%s  %2d: %s' % (self.cini, rc, text))
+            if not remotes:
+            else:
+                for r in remotes:
+                    rc += 1
+                    else:
+                    text = '%s: %s' % (r, text)
+                    self.line('%s  %2d: %s' % (self.cini, rc, text))
             self.line('%s Status:' % (self.cini))
             if dirty:
                 self.line('%s  Repository is dirty' % (self.cini))
@@ -603,7 +604,7 @@ def _merge(_dict, new):
 class report:
     """Report the build details about a package given a config file."""
-    def __init__(self, formatter, _configs, opts, macros = None):
+    def __init__(self, formatter, sanitize, _configs, opts, macros = None):
         if type(formatter) == str:
             if formatter == 'text':
                 self.formatter = text_formatter()
@@ -621,6 +622,7 @@ class report:
             self.formatter = formatter
         self.configs = _configs
         self.opts = opts
+        self.sanitize = sanitize
         if macros is None:
             self.macros = opts.defaults
         else:
@@ -645,11 +647,14 @@ class report:
         pass
     def release_status(self):
-        self.formatter.release_status(version.str())
+        self.formatter.release_status(version.string())
     def git_status(self):
         r = git.repo('.', self.opts, self.macros)
-        self.formatter.git_status(r.valid(), r.dirty(), r.head(), r.remotes())
+        if self.sanitize:
+            self.formatter.git_status(r.valid(), r.dirty(), r.head(), None)
+        else:
+            self.formatter.git_status(r.valid(), r.dirty(), r.head(), r.remotes())
     def introduction(self, name, intro_text = None):
         now = datetime.datetime.now().ctime()
@@ -855,6 +860,7 @@ class report:
                 raise error.general('writing output file: %s: %s' % (name, err))
     def generate(self, name, tree = None, opts = None, macros = None):
+        from . import setbuilder
         self.buildset_start(name)
         if tree is None:
             tree = self.tree
@@ -889,14 +895,16 @@ class report:
 def run(args):
     try:
         optargs = { '--list-bsets':   'List available build sets',
                     '--list-configs': 'List available configurations',
                     '--format':       'Output format (text, html, markdown, ini, xml)',
-                    '--output':       'File name to output the report' }
+                    '--output':       'File name to output the report',
+                    '--sanitize':     'Remove Remotes information from report'}
         opts = options.load(args, optargs, logfile = False)
         if opts.get_arg('--output') and len(opts.params()) > 1:
             raise error.general('--output can only be used with a single config')
-        print('RTEMS Source Builder, Reporter, %s' % (version.str()))
+        print('RTEMS Source Builder, Reporter, %s' % (version.string()))
         opts.log_info()
         if not check.host_setup(opts):
             log.warning('forcing build with known host setup problems')
@@ -922,7 +930,10 @@ def run(args):
                     formatter = xml_formatter()
                 else:
                     raise error.general('invalid format: %s' % (format_opt[1]))
-            r = report(formatter, configs, opts)
+            sanitize = False
+            if opts.get_arg('--sanitize'):
+                sanitize = True
+            r = report(formatter, sanitize, configs, opts)
             for _config in opts.params():
                 if output is None:
                     outname = path.splitext(_config)[0] + formatter.ext()
@@ -934,8 +945,6 @@ def run(args):
                     raise error.general('config file not found: %s' % (_config))
                 r.create(config, outname)
             del r
-        else:
-            raise error.general('invalid config type: %s' % (config))
         print(gerr)
         sys.exit(1)
diff --git a/source-builder/sb/rtems-build-dep b/source-builder/sb/rtems-build-dep
new file mode 100755
index 0000000..48a0823
--- /dev/null
+++ b/source-builder/sb/rtems-build-dep
@@ -0,0 +1,169 @@
+#! /bin/sh
+# Copyright 2018 Chris Johns (chrisj at rtems.org)
+# Host Build Dependence
+# This script finds a file that is part of the compiler's default
+# build environment. The file can be header or a library.
+# Header files:
+#  - Get the list of include directories from the compiler.
+#  - Search the include paths for the header file.
+# Library:
+#  - Ask the compiler to print the library paths, add on any user
+#    paths and search with a wilecard.
+set -e
+op=
+name=
+includes=
+libraries=
+compile=
+verbose=no
+debug=no
+if [ $# -eq 0 ]; then
+    echo 'Usage: rtems-build-dep [-c compiler] [-H header] [-I header-paths]
+                       [-l library] [-L library-paths] [-v] [-d]'
+    exit 2
+fi
+while [ $# -gt 0 ]
+do
+    case "$1"
+    in
+	-c)
+	    if [ $# -eq 1 ]; then
+		echo 'error: no compiler (-c) provided'
+		exit 2
+	    fi
+	    compiler="$2"; shift;
+            shift;;
+	-H)
+		echo 'error: no header (-H) provided'
+		exit 2
+	    fi
+	    op="header"
+            name="$2"; shift;
+            shift;;
+	-I)
+		echo 'error: no header path (-I) provided'
+		exit 2
+	    fi
+            includes="${includes} $2"; shift;
+            shift;;
+	-l)
+		echo 'error: no library (-l) provided'
+		exit 2
+	    fi
+	    op="library"
+            name="$2"; shift;
+            shift;;
+	-L)
+		echo 'error: no library path (-L) provided'
+		exit 2
+	    fi
+            libraries="$2"; shift;
+            shift;;
+	-v)
+	    verbose=yes
+            shift;;
+	-d)
+	    debug=yes
+            shift;;
+	    break;
+    esac
+done
+if [ ${debug} = yes ]; then
+    set -x
+fi
+if [ -z "${op}" ]; then
+    echo "error: no header or library file to find found."
+    exit 2
+fi
+if [ -z "${compiler}" ]; then
+    echo "error: no compiler provided."
+    exit 2
+fi
+if [ -z "${name}" ]; then
+    echo "error: no name found."
+    exit 2
+fi
+# Header file.
+if [ ${op} = "header" ]; then
+    inc_paths=$(echo | LC_ALL=C ${compiler} ${includes} -xc -E -v - 2>&1 | tr -d '\r' | \
+	       awk 'BEGIN {flag=0;} /starts here/{flag=1;next}/End/{flag=0}flag')
+    for p in ${inc_paths}
+    do
+	if [ ${verbose} = yes ]; then
+	    echo "Include: ${p}"
+	fi
+	if [ -f "${p}/${name}" ]; then
+	    echo "found"
+	    exit 0
+	fi
+    done
+    echo "not-found"
+    exit 0
+fi
+# Library file
+if [ ${op} = "library" ]; then
+    if [ "${OS}" = "Windows_NT" -a "${OSTYPE}" != "cygwin" ]; then
+	sep=';'
+    else
+	sep=':'
+    fi
+    lib_paths_1=$(LC_ALL=C ${compiler} -print-search-dirs 2>&1 | tr -d '\r' | \
+		      grep libraries | \
+		      sed -e 's/libraries:.*=//' | \
+		      awk 'BEGIN {FS="'${sep}'"} {for (i=0;++i<=NF;) print $i;}')
+    lib_paths_2=$(echo ${libraries} | \
+		      awk 'BEGIN {FS="-L"} {for (i=0;++i<=NF;) if (length($i) > 0) print $i;}')
+    for p in ${lib_paths_1} ${lib_paths_2}
+    do
+	    echo "Library: ${p}/${name}"
+	fi
+	if ls ${p}/${name} 1> /dev/null 2>&1; then
+	    echo "found"
+	    exit 0
+	fi
+    done
+    echo "not-found"
+    exit 0
+fi
+exit 1
diff --git a/source-builder/sb/rtems-check-command b/source-builder/sb/rtems-check-command
index 0000000..1cbe5c9
--- /dev/null
+++ b/source-builder/sb/rtems-check-command
@@ -0,0 +1,26 @@
+#! /bin/sh
+# Copyright 2019 Chris Johns (chrisj at rtems.org)
+# Check is a command exists
+set +e
+command -v $*
+exit 0
diff --git a/source-builder/sb/rtemsconfig.py b/source-builder/sb/rtemsconfig.py
index 6ac894e..0ad6c5c 100644
--- a/source-builder/sb/rtemsconfig.py
+++ b/source-builder/sb/rtemsconfig.py
@@ -28,11 +28,11 @@ import sys
 import threading
 import time
-import error
-import log
-import options
-import path
-import version
+from . import log
+from . import path
 def _collect(path_, file):
     confs = []
@@ -193,7 +193,7 @@ def run(args):
         bsp = bsp_config(opts, prefix, opts.get_arg('--rtems-bsp')[1])
         if opts.get_arg('--list'):
-            log.notice('RTEMS Source Builder - RTEMS Configuration, %s' % (version.str()))
+            log.notice('RTEMS Source Builder - RTEMS Configuration, %s' % (version.string()))
             opts.log_info()
             configs = list(bsp.keys())
             for c in sorted(configs.keys()):
diff --git a/source-builder/sb/setbuilder.py b/source-builder/sb/setbuilder.py
index 17b781a..b0e2b23 100644
--- a/source-builder/sb/setbuilder.py
+++ b/source-builder/sb/setbuilder.py
@@ -1,6 +1,6 @@
@@ -33,22 +33,30 @@ import sys
 import textwrap
 try:
-    import build
-    import check
-    import error
-    import log
-    import mailer
-    import options
-    import path
-    import reports
-    import sources
-    import version
+    from . import log
+    from . import mailer
+    from . import reports
+    from . import shell
     sys.exit(1)
 except:
-    sys.exit(1)
+    raise
+def macro_expand(macros, _str):
+    cstr = None
+    while cstr != _str:
+        cstr = _str
+        _str = macros.expand(_str)
+        _str = shell.expand(macros, _str)
+    return _str
 class log_capture(object):
     def __init__(self):
@@ -71,21 +79,21 @@ class buildset:
     """Build a set builds a set of packages."""
     def __init__(self, bset, _configs, opts, macros = None):
-        log.trace('_bset: %s: init' % (bset))
+        log.trace('_bset:   : %s: init' % (bset))
         self.opts = opts
         if macros is None:
             self.macros = copy.copy(opts.defaults)
         else:
             self.macros = copy.copy(macros)
-        log.trace('_bset: %s: macro defaults' % (bset))
+        log.trace('_bset:   : %s: macro defaults' % (bset))
         log.trace(str(self.macros))
         self.bset = bset
-        _target = self.macros.expand('%{_target}')
+        _target = macro_expand(self.macros, '%{_target}')
         if len(_target):
             pkg_prefix = _target
         else:
-            pkg_prefix = self.macros.expand('%{_host}')
+            pkg_prefix = macro_expand(self.macros, '%{_host}')
         self.bset_pkg = '%s-%s-set' % (pkg_prefix, self.bset)
         self.mail_header = ''
         self.mail_report = ''
@@ -120,6 +128,25 @@ class buildset:
     def get_mail_report(self):
         return self.mail_report
+    def mail_single_report(self):
+        return self.macros.get('%{mail_single_report}') != 0
+    def mail_active(self, mail, nesting_count = 1):
+        return mail is not None and not (self.mail_single_report() and nesting_count > 1)
+    def mail_send(self, mail):
+        if True: #not self.opts.dry_run():
+            mail_subject = '%s on %s' % (self.bset, self.macros.expand('%{_host}'))
+            if mail['failure'] is not None:
+                mail_subject = 'FAILED %s (%s)' % (mail_subject, mail['failure'])
+            else:
+                mail_subject = 'PASSED %s' % (mail_subject)
+            mail_subject = 'Build %s: %s' % (reports.platform(mode = 'system'),
+                                             mail_subject)
+            body = mail['log']
+            body += (os.linesep * 2).join(mail['reports'])
+            mail['mail'].send(mail['to'], mail_subject, body)
     def copy(self, src, dst):
         log.output('copy: %s => %s' % (path.host(src), path.host(dst)))
         if not self.opts.dry_run():
@@ -152,7 +179,7 @@ class buildset:
             else:
                 raise error.general('invalid report format: %s' % (format))
             buildroot = _build.config.abspath('%{buildroot}')
-            prefix = _build.macros.expand('%{_prefix}')
+            prefix = macro_expand(_build.macros, '%{_prefix}')
             name = _build.main_package().name() + ext
             log.notice('reporting: %s -> %s' % (_config, name))
             if not _build.opts.get_arg('--no-report'):
@@ -161,7 +188,7 @@ class buildset:
                     outname = path.host(path.join(outpath, name))
                 else:
                     outname = None
-                r = reports.report(format, self.configs,
+                r = reports.report(format, False, self.configs,
                                    copy.copy(opts), copy.copy(macros))
                 r.introduction(_build.config.file_name())
                 r.generate(_build.config.file_name())
@@ -171,7 +198,7 @@ class buildset:
                     r.write(outname)
                 del r
             if mail:
-                r = reports.report('text', self.configs,
+                r = reports.report('text', True, self.configs,
@@ -182,17 +209,25 @@ class buildset:
     def root_copy(self, src, dst):
         what = '%s -> %s' % \
             (os.path.relpath(path.host(src)), os.path.relpath(path.host(dst)))
-        log.trace('_bset: %s: collecting: %s' % (self.bset, what))
+        log.trace('_bset:   : %s: collecting: %s' % (self.bset, what))
         self.copy(src, dst)
-    def install(self, name, buildroot, prefix):
-        dst = prefix
-        src = path.join(buildroot, prefix)
-        log.notice('installing: %s -> %s' % (name, path.host(dst)))
+    def install(self, mode, name, src, dst):
+        log.trace('_bset:   : %s: copy %s -> %s' % (mode, src, dst))
+        log.notice('%s: %s -> %s' % (mode, name, path.host(dst)))
         self.copy(src, dst)
+    def install_mode(self):
+        return macro_expand(self.macros, '%{install_mode}')
+    def installing(self):
+        return self.install_mode() == 'installing'
+    def staging(self):
+        return not self.installing()
     def canadian_cross(self, _build):
-        log.trace('_bset: Cxc for build machine: _build => _host')
+        log.trace('_bset:   : Cxc for build machine: _build => _host')
         macros_to_copy = [('%{_host}',        '%{_build}'),
                           ('%{_host_alias}',  '%{_build_alias}'),
                           ('%{_host_arch}',   '%{_build_arch}'),
@@ -204,7 +239,7 @@ class buildset:
                           ('%{_builddir}',    '%{_buildcxcdir}')]
         cxc_macros = _build.copy_init_macros()
         for m in macros_to_copy:
-            log.trace('_bset: Cxc: %s <= %s' % (m[0], cxc_macros[m[1]]))
+            log.trace('_bset:   : Cxc: %s <= %s' % (m[0], cxc_macros[m[1]]))
             cxc_macros[m[0]] = cxc_macros[m[1]]
         _build.set_macros(cxc_macros)
         _build.reload()
@@ -229,12 +264,15 @@ class buildset:
         if (self.opts.get_arg('--bset-tar-file') or self.opts.canadian_cross()) \
            and not _build.macros.get('%{_disable_packaging}'):
             path.mkdir(tardir)
-            tar = path.join(tardir, _build.config.expand('%s.tar.bz2' % (_build.main_package().name())))
+            tar = path.join(tardir,
+                            _build.config.expand('%s.tar.bz2' % \
+                                                 (_build.main_package().name())))
             log.notice('tarball: %s' % (os.path.relpath(path.host(tar))))
                 tmproot = _build.config.expand('%{_tmproot}')
                 cmd = _build.config.expand('"cd ' + tmproot + \
-                                               ' && %{__tar} -cf - . | %{__bzip2} > ' + tar + '"')
+                                           ' && %{__tar} -cf - . | %{__bzip2} > ' + \
+                                           tar + '"')
                 _build.run(cmd, shell_opts = '-c', cwd = tmproot)
     def parse(self, bset):
@@ -249,7 +287,7 @@ class buildset:
         bsetname = bset
         if not path.exists(bsetname):
-            for cp in self.macros.expand('%{_configdir}').split(':'):
+            for cp in macro_expand(self.macros, '%{_configdir}').split(':'):
                 configdir = path.abspath(cp)
                 bsetname = path.join(configdir, bset)
                 if path.exists(bsetname):
@@ -258,7 +296,7 @@ class buildset:
             if bsetname is None:
                 raise error.general('no build set file found: %s' % (bset))
         try:
-            log.trace('_bset: %s: open: %s' % (self.bset, bsetname))
+            log.trace('_bset:   : %s: open: %s' % (self.bset, bsetname))
             bset = open(path.host(bsetname), 'r')
         except IOError as err:
             raise error.general('error opening bset file: %s' % (bsetname))
@@ -272,7 +310,7 @@ class buildset:
                 l = _clean(l)
                 if len(l) == 0:
                     continue
-                log.trace('_bset: %s: %03d: %s' % (self.bset, lc, l))
+                log.trace('_bset:   : %s: %03d: %s' % (self.bset, lc, l))
                 ls = l.split()
                 if ls[0][-1] == ':' and ls[0][:-1] == 'package':
                     self.bset_pkg = ls[1].strip()
@@ -288,8 +326,8 @@ class buildset:
                             self.macros.define(ls[1].strip())
                     elif ls[0] == '%undefine':
                         if len(ls) > 2:
-                            raise error.general('%s:%d: %undefine requires just the name' % \
-                                                    (self.bset, lc))
+                            raise error.general('%s:%d: %undefine requires ' \
+                                                'just the name' % (self.bset, lc))
                         self.macros.undefine(ls[1].strip())
                     elif ls[0] == '%include':
                         configs += self.parse(ls[1].strip())
@@ -301,7 +339,8 @@ class buildset:
                     l = l.strip()
                     c = build.find_config(l, self.configs)
                     if c is None:
-                        raise error.general('%s:%d: cannot find file: %s' % (self.bset, lc, l))
+                        raise error.general('%s:%d: cannot find file: %s' % (self.bset,
+        lc, l))
                     configs += [c]
         except:
             bset.close()
@@ -320,8 +359,12 @@ class buildset:
         if self.bset.endswith('.cfg'):
             configs = [self.bset]
         else:
-            exbset = self.macros.expand(self.bset)
+            exbset = macro_expand(self.macros, self.bset)
             self.macros['_bset'] = exbset
+            bset_tmp = build.short_name(exbset)
+            if bset_tmp.endswith('.bset'):
+                bset_tmp = bset_tmp[:-5]
+            self.macros['_bset_tmp'] = bset_tmp
             root, ext = path.splitext(exbset)
             if exbset.endswith('.bset'):
                 bset = exbset
@@ -336,30 +379,59 @@ class buildset:
         nesting_count += 1
-        if mail:
+        if self.mail_active(mail, nesting_count):
             mail['output'].clear()
+            mail['log'] = ''
+            mail['reports'] = []
+            mail['failure'] = None
-        log.trace('_bset: %s: make' % (self.bset))
+        log.trace('_bset: %2d: %s: make' % (nesting_count, self.bset))
         log.notice('Build Set: %s' % (self.bset))
-        mail_subject = '%s on %s' % (self.bset,
-                                     self.macros.expand('%{_host}'))
         current_path = os.environ['PATH']
         start = datetime.datetime.now()
         mail_report = False
         have_errors = False
+        interrupted = False
-        if mail:
-            mail['output'].clear()
+        # If this is the outter most buildset it's files are installed. Nested
+        # build sets staged their installed file. The staged files are install
+        # when the outtter most build finishes.
+        if nesting_count != 1:
+            if self.installing():
+                self.macros['install_mode'] = 'staging'
+        # Only the outter build set can have staging to install. Get the staging
+        # root via the config because it could require a valid config.
+        have_staging = False
         try:
             configs = self.load()
-            log.trace('_bset: %s: configs: %s'  % (self.bset, ','.join(configs)))
+            log.trace('_bset: %2d: %s: configs: %s'  % (nesting_count,
+                                                        self.bset, ', '.join(configs)))
+            if nesting_count == 1 and len(configs) > 1:
+                # Prepend staging areas, bin directory to the
+                # path. Lets the later package depend on the earlier
+                # ones.
+                pathprepend = ['%{stagingroot}/bin'] + \
+                    macro_expand(self.macros, '%{_pathprepend}').split(':')
+                pathprepend = [pp for pp in pathprepend if len(pp)]
+                if len(pathprepend) == 1:
+                    self.macros['_pathprepend'] = pathprepend[0]
+                else:
+                    self.macros['_pathprepend'] = ':'.join(pathprepend)
+            sizes_valid = False
             builds = []
             for s in range(0, len(configs)):
                 b = None
@@ -372,14 +444,20 @@ class buildset:
                     opts = copy.copy(self.opts)
                     macros = copy.copy(self.macros)
                     if configs[s].endswith('.bset'):
-                        log.trace('_bset: == %2d %s' % (nesting_count + 1, '=' * 75))
+                        log.trace('_bset: %2d: %s %s' % (nesting_count,
+                                                         configs[s],
+                                                         '=' * (74 - len(configs[s]))))
                         bs = buildset(configs[s], self.configs, opts, macros)
                         bs.build(deps, nesting_count, mail)
+                            have_staging = True
                         del bs
                     elif configs[s].endswith('.cfg'):
                         if mail:
                             mail_report = True
-                        log.trace('_bset: -- %2d %s' % (nesting_count + 1, '-' * 75))
+                                                         configs[s],
                         try:
                             b = build.build(configs[s],
                                             self.opts.get_arg('--pkg-tar-files'),
@@ -410,8 +488,8 @@ class buildset:
                         # Dump post build macros.
-                        log.trace('_bset: macros post-build')
-                        log.trace(str(macros))
+                        log.trace('_bset:   : macros post-build')
+                        log.trace(str(b.macros))
                     else:
                         raise error.general('invalid config type: %s' % (configs[s]))
@@ -434,65 +512,151 @@ class buildset:
                     else:
                         raise
-            # Installing ...
+            # Installing or staging ...
-            log.trace('_bset: installing: deps:%r no-install:%r' % \
-                      (deps is None, self.opts.no_install()))
-            if deps is None \
-               and not self.opts.no_install() \
-               and not have_errors:
+            log.trace('_bset: %2d: %s: deps:%r no-install:%r' % \
+                      (nesting_count, self.install_mode(),
+                       deps is None, self.opts.no_install()))
+            log.trace('_bset: %2d: %s: builds: %s' % \
+                       ', '.join([b.name() for b in builds])))
+            if deps is None and not self.opts.no_install() and not have_errors:
                 for b in builds:
-                    log.trace('_bset: installing: %r' % b.installable())
+                    log.trace('_bset:   : %s: %r' % (self.install_mode(),
+                                                     b.installable()))
                     if b.installable():
-                        self.install(b.name(),
-                                     b.config.expand('%{buildroot}'),
-                                     b.config.expand('%{_prefix}'))
+                        prefix = b.config.expand('%{_prefix}')
+                        buildroot = path.join(b.config.expand('%{buildroot}'), prefix)
+                        if self.staging():
+                            prefix = b.config.expand('%{stagingroot}')
+                        self.install(self.install_mode(), b.name(), buildroot, prefix)
+            # Sizes ...
+            if len(builds) > 1:
+                size_build = 0
+                size_installed = 0
+                size_build_max = 0
+                for b in builds:
+                    s = b.get_build_size()
+                    size_build += s
+                    if s > size_build_max:
+                        size_build_max = s
+                    size_installed += b.get_installed_size()
+                size_sources = 0
+                for p in builds[0].config.expand('%{_sourcedir}').split(':'):
+                    size_sources += path.get_size(p)
+                size_patches = 0
+                for p in builds[0].config.expand('%{_patchdir}').split(':'):
+                    size_patches += path.get_size(p)
+                size_total = size_sources + size_patches + size_installed
+                build_max_size_human = build.humanize_number(size_build_max +
+                                                             size_installed, 'B')
+                build_total_size_human = build.humanize_number(size_total, 'B')
+                build_sources_size_human = build.humanize_number(size_sources, 'B')
+                build_patches_size_human = build.humanize_number(size_patches, 'B')
+                build_installed_size_human = build.humanize_number(size_installed, 'B')
+                build_size = 'usage: %s' % (build_max_size_human)
+                build_size += ' total: %s' % (build_total_size_human)
+                build_size += ' (sources: %s' % (build_sources_size_human)
+                build_size += ', patches: %s' % (build_patches_size_human)
+                build_size += ', installed %s)' % (build_installed_size_human)
+                sizes_valid = True
+            # Cleaning ...
             if deps is None and \
                     (not self.opts.no_clean() or self.opts.always_clean()):
                 for b in builds:
                     if not b.disabled():
                         log.notice('cleaning: %s' % (b.name()))
                         b.cleanup()
+            # Log the build size message
+                log.notice('Build Sizes: %s' % (build_size))
+            # Clear out the builds ...
             for b in builds:
                 del b
+            # If builds have been staged install into the finaly prefix.
+            if have_staging and not self.opts.no_install() and not have_errors:
+                stagingroot = macro_expand(self.macros, '%{stagingroot}')
+                have_stagingroot = path.exists(stagingroot)
+                log.trace('_bset: %2d: install staging, present: %s' % \
+                          (nesting_count, have_stagingroot))
+                if have_stagingroot:
+                    prefix = macro_expand(self.macros, '%{_prefix}')
+                    self.install(self.install_mode(), self.bset, stagingroot, prefix)
+                    staging_size = path.get_size(stagingroot)
+                    if not self.opts.no_clean() or self.opts.always_clean():
+                        log.notice('clean staging: %s' % (self.bset))
+                        log.trace('removing: %s' % (stagingroot))
+                        if not self.opts.dry_run():
+                            if path.exists(stagingroot):
+                                path.removeall(stagingroot)
+                    log.notice('Staging Size: %s' % \
+                               (build.humanize_number(staging_size, 'B')))
             if not build_error:
             raise
-            mail_report = False
+            interrupted = True
             raise
         except:
             self.build_failure = 'RSB general failure'
             raise
         finally:
             end = datetime.datetime.now()
             os.environ['PATH'] = current_path
             build_time = str(end - start)
-            if mail_report and not self.macros.defined('mail_disable'):
-                self.write_mail_header('Build Time: %s' % (build_time), True)
-                self.write_mail_header('', True)
+            if self.mail_single_report() and nesting_count == 1:
+                mail_report = True
+            if interrupted or self.macros.defined('mail_disable'):
+                mail_report = False
+            if mail_report and mail is not None:
+                    self.write_mail_header('Build Time: %s' % (build_time), True)
+                    self.write_mail_header('', True)
+                    self.write_mail_header(mail['header'], True)
+                    self.write_mail_header('')
+                    log.notice('Mailing report: %s' % (mail['to']))
+                    mail['log'] += self.get_mail_header()
+                    if sizes_valid:
+                        mail['log'] += 'Sizes' + os.linesep
+                        mail['log'] += '=====' + os.linesep + os.linesep
+                        mail['log'] += \
+                            'Maximum build usage: ' + build_max_size_human + os.linesep
+                        mail['log'] += \
+                            'Total size: ' + build_total_size_human + os.linesep
+                        mail['log'] += \
+                            'Installed : ' + build_installed_size_human + os.linesep
+                        mail['log'] += 'Sources: ' + build_sources_size_human + os.linesep
+                        mail['log'] += 'Patches: ' + build_patches_size_human + os.linesep
+                    mail['log'] += os.linesep
+                    mail['log'] += 'Output' + os.linesep
+                    mail['log'] += '======' + os.linesep + os.linesep
+                    mail['log'] += os.linesep.join(mail['output'].get())
+                    mail['log'] += os.linesep + os.linesep
+                    mail['log'] += 'Report' + os.linesep
+                mail['reports'] += [self.get_mail_report()]
                 if self.build_failure is not None:
-                    mail_subject = 'FAILED %s (%s)' % \
-                        (mail_subject, self.build_failure)
-                else:
-                    mail_subject = 'PASSED %s' % (mail_subject)
-                mail_subject = 'Build %s: %s' % (reports.platform(mode = 'system'),
-                                                 mail_subject)
-                self.write_mail_header(mail['header'], True)
-                self.write_mail_header('')
-                log.notice('Mailing report: %s' % (mail['to']))
-                body = self.get_mail_header()
-                body += 'Output' + os.linesep
-                body += '======' + os.linesep + os.linesep
-                body += os.linesep.join(mail['output'].get())
-                body += os.linesep + os.linesep
-                body += 'Report' + os.linesep
-                body += self.get_mail_report()
-                if not opts.dry_run():
-                    mail['mail'].send(mail['to'], mail_subject, body)
+                    mail['failure'] = self.build_failure
+                    try:
+                        self.mail_send(mail)
+                        log.notice('Mail Send Failure: %s' % (gerr))
             log.notice('Build Set: Time %s' % (build_time))
 def list_bset_cfg_files(opts, configs):
@@ -517,6 +681,7 @@ def run():
     try:
         optargs = { '--list-configs':  'List available configurations',
+                    '--list-configs':  'List available configuration files.',
                     '--list-deps':     'List the dependent files.',
                     '--bset-tar-file': 'Create a build set tar file',
                     '--pkg-tar-files': 'Create package tar files',
@@ -525,15 +690,18 @@ def run():
         mailer.append_options(optargs)
         opts = options.load(sys.argv, optargs)
         if opts.get_arg('--mail'):
-            mail = { 'mail'  : mailer.mail(opts),
-                     'output': log_capture() }
+            mail = { 'mail'   : mailer.mail(opts),
+                     'output' : log_capture(),
+                     'log'    : '',
+                     'reports': [],
+                     'failure': None }
             to_addr = opts.get_arg('--mail-to')
             if to_addr is not None:
                 mail['to'] = to_addr[1]
             else:
-                mail['to'] = opts.defaults.expand('%{_mail_tools_to}')
+                mail['to'] = macro_expand(opts.defaults, '%{_mail_tools_to}')
             mail['from'] = mail['mail'].from_address()
-        log.notice('RTEMS Source Builder - Set Builder, %s' % (version.str()))
+        log.notice('RTEMS Source Builder - Set Builder, %s' % (version.string()))
         opts.log_info()
             raise error.general('host build environment is not set up correctly')
@@ -551,7 +719,7 @@ def run():
         else:
             deps = None
         if not list_bset_cfg_files(opts, configs):
-            prefix = opts.defaults.expand('%{_prefix}')
+            prefix = macro_expand(opts.defaults, '%{_prefix}')
             if opts.canadian_cross():
                 opts.disable_install()
diff --git a/source-builder/sb/shell.py b/source-builder/sb/shell.py
index 0000000..ecb8188
--- /dev/null
+++ b/source-builder/sb/shell.py
@@ -0,0 +1,74 @@
+try:
+    from . import execute
+    from . import log
+    sys.exit(1)
+except:
+    raise
+def expand(macros, line):
+    # Parse the line and handle nesting '()' pairs.
+    def _exec(shell_macro):
+        output = ''
+        if len(shell_macro) > 3:
+            e = execute.capture_execution()
+            if options.host_windows:
+                cmd = '%s -c "%s"' % (macros.expand('%{__sh}'), shell_macro[2:-1])
+            else:
+                cmd = shell_macro[2:-1]
+            exit_code, proc, output = e.shell(cmd)
+            log.trace('shell-output: %d %s' % (exit_code, output))
+            if exit_code != 0:
+                raise error.general('shell macro failed: %s: %d: %s' % (cmd,
+        exit_code,
+        output))
+        return output
+    updating = True
+    while updating:
+        updating = False
+        pos = line.find('%(')
+        if pos >= 0:
+            braces = 0
+            for p in range(pos + 2, len(line)):
+                if line[p] == '(':
+                    braces += 1
+                elif line[p] == ')':
+                    if braces > 0:
+                        braces -= 1
+                    else:
+                        line = line[:pos] + _exec(line[pos:p + 1]) + line[p + 1:]
+                        updating = True
+                        break
+    return line
diff --git a/source-builder/sb/simhost.py b/source-builder/sb/simhost.py
index 0000000..1ff98e8
--- /dev/null
+++ b/source-builder/sb/simhost.py
@@ -0,0 +1,656 @@
+# Copyright 2010-2020 Chris Johns (chrisj at rtems.org)
+import copy
+import datetime
+import os
+try:
+    from . import git
+    from . import log
+    from . import macros
+    sys.exit(1)
+except:
+    raise
+# Define host profiles so it can simulated on another host.
+profiles = {
+    'darwin':  { '_os':              ('none',    'none',     'darwin'),
+                 '_host':            ('triplet', 'required', 'x86_64-apple-darwin18.5.0'),
+                 '_host_vendor':     ('none',    'none',     'apple'),
+                 '_host_os':         ('none',    'none',     'darwin'),
+                 '_host_os_version': ('none',    'none',     '18.5.0'),
+                 '_host_cpu':        ('none',    'none',     'x86_64'),
+                 '_host_alias':      ('none',    'none',     '%{nil}'),
+                 '_host_arch':       ('none',    'none',     'x86_64'),
+                 '_usr':             ('dir',     'optional', '/usr/local'),
+                 '_var':             ('dir',     'optional', '/usr/local/var') },
+    'freebsd': { '_os':              ('none',    'none',     'freebsd'),
+                 '_host':            ('triplet', 'required', 'x86_64-freebsd12.0-RELEASE-p3'),
+                 '_host_vendor':     ('none',    'none',     'pc'),
+                 '_host_os':         ('none',    'none',     'freebsd'),
+                 '_host_os_version': ('none',    'none',     '12.0-RELEASE-p3'),
+    'linux':   { '_os':              ('none',    'none',     'linux'),
+                 '_host':            ('triplet', 'required', 'x86_64-linux-gnu'),
+                 '_host_vendor':     ('none',    'none',     'gnu'),
+                 '_host_os':         ('none',    'none',     'linux'),
+                 '_host_os_version': ('none',    'none',     '4.18.0-16'),
+    'netbsd':  { '_os':              ('none',    'none',     'netbsd'),
+                 '_host':            ('triplet', 'required', 'x86_64-netbsd8.0'),
+                 '_host_os':         ('none',    'none',     'netbsd'),
+                 '_host_os_version': ('none',    'none',     '8.0'),
+    'solaris': { '_os':              ('none',    'none',     'solaris'),
+                 '_host':            ('triplet', 'required', 'x86_64-pc-solaris2'),
+                 '_host_os':         ('none',    'none',     'solaris'),
+                 '_host_os_version': ('none',    'none',     '2'),
+    'win32':   { '_os':              ('none',    'none',     'win32'),
+                 '_windows_os':      ('none',    'none',     'mingw32'),
+                 '_host':            ('triplet', 'required', 'x86_64-w64-mingw32'),
+                 '_host_os':         ('none',    'none',     'win32'),
+                 '_host_os_version': ('none',    'none',     '10'),
+    'cygwin':  { '_os':              ('none',    'none',     'win32'),
+                 '_windows_os':      ('none',    'none',     'cygwin'),
+                 '_host':            ('triplet', 'required', 'x86_64-w64-cygwin'),
+                 '_host_vendor':     ('none',    'none',     'microsoft'),
+class log_capture(object):
+    def __init__(self):
+        self.log = []
+        log.capture = self.capture
+    def __str__(self):
+        return os.linesep.join(self.log)
+    def capture(self, text):
+        self.log += [l for l in text.replace(chr(13), '').splitlines()]
+    def get(self):
+        return self.log
+    def clear(self):
+        self.log = []
+def find_bset_config(bset_config, macros):
+    '''Find the build set or config file using the macro config defined path.'''
+    name = bset_config
+    if not path.exists(name):
+        for cp in macros.expand('%{_configdir}').split(':'):
+            configdir = path.abspath(cp)
+            name = path.join(configdir, bset_config)
+            if path.exists(name):
+                break
+            name = None
+        if name is None:
+            raise error.general('no build set file found: %s' % (bset_config))
+    return name
+# A skinny options command line class to get the configs to load.
+class options(object):
+    def __init__(self, argv, argopts, defaults, extras):
+        command_path = path.dirname(path.abspath(argv[0]))
+        if len(command_path) == 0:
+            command_path = '.'
+        self.command_path = command_path
+        self.command_name = path.basename(argv[0])
+        extras += ['--dry-run',
+                   '--quiet',
+                   '--without-log',
+                   '--without-error-report',
+                   '--without-release-url']
+        self.argv = argv
+        self.args = argv[1:] + extras
+        self.defaults = macros.macros(name = defaults,
+                                      sbdir = command_path)
+        self.load_overrides()
+        self.opts = { 'params' :  extras }
+        self.sb_git()
+        self.rtems_bsp()
+        if 'download_dir' in argopts and argopts.download_dir is not None:
+            self.defaults['_sourcedir'] = ('dir',
+                                           'optional',
+                                           path.abspath(argopts.download_dir))
+            self.defaults['_patchdir'] = ('dir',
+                                          'optional',
+    def load_overrides(self):
+        overrides = None
+        if os.name == 'nt':
+            try:
+                overrides = windows.load()
+                host_windows = True
+                host_posix = False
+            except:
+                raise error.general('failed to load Windows host support')
+        elif os.name == 'posix':
+            uname = os.uname()
+            try:
+                if uname[0].startswith('MINGW64_NT'):
+                elif uname[0].startswith('CYGWIN_NT'):
+                elif uname[0] == 'Darwin':
+                    overrides = darwin.load()
+                elif uname[0] == 'FreeBSD':
+                    overrides = freebsd.load()
+                elif uname[0] == 'NetBSD':
+                    overrides = netbsd.load()
+                elif uname[0] == 'Linux':
+                    overrides = linux.load()
+                elif uname[0] == 'SunOS':
+                    overrides = solaris.load()
+            except error.general as ge:
+                raise error.general('failed to load %s host support: %s' % (uname[0], ge))
+            except:
+                raise error.general('failed to load %s host support' % (uname[0]))
+        else:
+            raise error.general('unsupported host type; please add')
+        if overrides is None:
+            raise error.general('no hosts defaults found; please add')
+        for k in overrides:
+            self.defaults[k] = overrides[k]
+    def parse_args(self, arg, error = True, extra = True):
+        for a in range(0, len(self.args)):
+            if self.args[a].startswith(arg):
+                lhs = None
+                rhs = None
+                if '=' in self.args[a]:
+                    eqs = self.args[a].split('=')
+                    lhs = eqs[0]
+                    if len(eqs) > 2:
+                        rhs = '='.join(eqs[1:])
+                    else:
+                        rhs = eqs[1]
+                elif extra:
+                    lhs = self.args[a]
+                    a += 1
+                    if a < len(self.args):
+                        rhs = self.args[a]
+                return [lhs, rhs]
+            a += 1
+        return None
+    def rtems_bsp(self):
+        self.defaults['rtems_version'] = str(version.version())
+        self.defaults['_target'] = 'arch-rtems'
+        self.defaults['rtems_host'] = 'rtems-arch'
+        self.defaults['with_rtems_bsp'] = 'rtems-bsp'
+    def sb_git(self):
+        repo = git.repo(self.defaults.expand('%{_sbdir}'), self)
+        repo_mail = None
+        if repo.valid():
+            repo_valid = '1'
+            repo_head = repo.head()
+            repo_clean = not repo.dirty()
+            repo_remotes = '%{nil}'
+            remotes = repo.remotes()
+            if 'origin' in remotes:
+                repo_remotes = '%s/origin' % (remotes['origin']['url'])
+                repo_id = repo_head
+            if not repo_clean:
+                repo_id += '-modified'
+                repo_mail = repo.email()
+        else:
+            repo_valid = '0'
+            repo_head = '%{nil}'
+            repo_clean = '%{nil}'
+            repo_id = 'no-repo'
+        self.defaults['_sbgit_valid'] = repo_valid
+        self.defaults['_sbgit_head']  = repo_head
+        self.defaults['_sbgit_clean'] = str(repo_clean)
+        self.defaults['_sbgit_remotes'] = str(repo_remotes)
+        self.defaults['_sbgit_id']    = repo_id
+        if repo_mail is not None:
+            self.defaults['_sbgit_mail'] = repo_mail
+    def get_arg(self, arg):
+        if self.optargs is None or arg not in self.optargs:
+            return None
+        return self.parse_args(arg)
+    def with_arg(self, label, default = 'not-found'):
+        # the default if there is no option for without.
+        result = default
+        for pre in ['with', 'without']:
+            arg_str = '--%s-%s' % (pre, label)
+            arg_label = '%s_%s' % (pre, label)
+            arg = self.parse_args(arg_str, error = False, extra = False)
+            if arg is not None:
+                if arg[1] is  None:
+                    result = 'yes'
+                else:
+                    result = arg[1]
+                break
+        return [arg_label, result]
+    def dry_run(self):
+        return True
+    def keep_going(self):
+        return False
+    def quiet(self):
+            return True
+    def no_clean(self):
+        return True
+    def always_clean(self):
+        return False
+    def no_install(self):
+        return True
+    def download_disabled(self):
+        return False
+    def disable_install(self):
+        return True
+    def urls(self):
+        return None
+    def info(self):
+        s = ' Command Line: %s%s' % (' '.join(self.argv), os.linesep)
+        s += ' Python: %s' % (sys.version.replace('\n', ''))
+        return s
+class buildset:
+    """Build a set builds a set of packages."""
+    def __init__(self, bset, _configs, opts, macros = None):
+        log.trace('_bset: %s: init' % (bset))
+        self.parent = 'root'
+        self._includes = []
+        self._errors = []
+        self.configs = _configs
+        self.opts = opts
+        if macros is None:
+            self.macros = copy.copy(opts.defaults)
+        else:
+            self.macros = copy.copy(macros)
+        self.macros.define('_rsb_getting_source')
+        log.trace('_bset: %s: macro defaults' % (bset))
+        log.trace(str(self.macros))
+        self.bset = bset
+        _target = self.macros.expand('%{_target}')
+        if len(_target):
+            pkg_prefix = _target
+        else:
+            pkg_prefix = self.macros.expand('%{_host}')
+        self.bset_pkg = '%s-%s-set' % (pkg_prefix, self.bset)
+        self.build_failure = None
+    def _add_includes(self, includes, parent = None):
+        if parent is None:
+            parent = self.parent
+        if not isinstance(includes, list):
+            includes = [includes]
+        self._includes += [i + ':' + parent for i in includes]
+    def _rebase_includes(self, includes, parent):
+        rebased = []
+        for i in includes:
+            if i.split(':', 2)[1] == 'root':
+                rebased += [i.split(':', 2)[0] + ':' + parent]
+            else:
+                rebased += [i]
+        return rebased
+    def includes(self):
+        return sorted(list(set(self._includes)))
+    def errors(self):
+        return sorted(list(set(self._errors)))
+    def build_package(self, _config, _build):
+        if not _build.disabled():
+            _build.make()
+    def parse(self, bset):
+        # Ouch, this is a copy of the setbuilder.py code.
+        def _clean(line):
+            line = line[0:-1]
+            b = line.find('#')
+            if b >= 0:
+                line = line[1:b]
+            return line.strip()
+        bsetname = find_bset_config(bset, self.macros)
+        try:
+            log.trace('_bset: %s: open: %s' % (self.bset, bsetname))
+            bsetf = open(path.host(bsetname), 'r')
+        except IOError as err:
+            raise error.general('error opening bset file: %s' % (bsetname))
+        self._add_includes(bsetname)
+        self.parent = bsetname
+        configs = []
+        try:
+            lc = 0
+            for l in bsetf:
+                lc += 1
+                l = _clean(l)
+                if len(l) == 0:
+                    continue
+                log.trace('_bset: %s: %03d: %s' % (self.bset, lc, l))
+                ls = l.split()
+                if ls[0][-1] == ':' and ls[0][:-1] == 'package':
+                    self.bset_pkg = ls[1].strip()
+                    self.macros['package'] = self.bset_pkg
+                elif ls[0][0] == '%':
+                    def err(msg):
+                        raise error.general('%s:%d: %s' % (self.bset, lc, msg))
+                    if ls[0] == '%define':
+                        if len(ls) > 2:
+                            self.macros.define(ls[1].strip(),
+                                               ' '.join([f.strip() for f in ls[2:]]))
+                        else:
+                            self.macros.define(ls[1].strip())
+                    elif ls[0] == '%undefine':
+                        if len(ls) > 2:
+                            raise error.general('%s:%d: %undefine requires just the name' \
+                                                % (self.bset, lc))
+                        self.macros.undefine(ls[1].strip())
+                    elif ls[0] == '%include':
+                        configs += self.parse(ls[1].strip())
+                    elif ls[0] in ['%patch', '%source']:
+                        sources.process(ls[0][1:], ls[1:], self.macros, err)
+                    elif ls[0] == '%hash':
+                        sources.hash(ls[1:], self.macros, err)
+                else:
+                    l = l.strip()
+                    c = build.find_config(l, self.configs)
+                    if c is None:
+                                            % (self.bset, lc, l))
+                    configs += [c + ':' + self.parent]
+        finally:
+            bsetf.close()
+            self.parent = parent
+        return configs
+    def load(self):
+        # If the build set file ends with .cfg the user has passed to the
+        # buildset builder a configuration so we just return it.
+        if self.bset.endswith('.cfg'):
+            self._add_includes(self.bset)
+            configs = [self.bset]
+        else:
+            exbset = self.macros.expand(self.bset)
+            self.macros['_bset'] = exbset
+            self.macros['_bset_tmp'] = build.short_name(exbset)
+            root, ext = path.splitext(exbset)
+            if exbset.endswith('.bset'):
+                bset = exbset
+            else:
+                bset = '%s.bset' % (exbset)
+            configs = self.parse(bset)
+        return configs
+    def set_host_details(self, host, opts, macros):
+        if host not in profiles:
+            raise error.general('invalid host: ' + host)
+        for m in profiles[host]:
+            opts.defaults[m] = profiles[host][m]
+            macros[m] = profiles[host][m]
+        macros_to_copy = [('%{_build}',        '%{_host}'),
+                          ('%{_build_alias}',  '%{_host_alias}'),
+                          ('%{_build_arch}',   '%{_host_arch}'),
+                          ('%{_build_cpu}',    '%{_host_cpu}'),
+                          ('%{_build_os}',     '%{_host_os}'),
+                          ('%{_build_vendor}', '%{_host_vendor}')]
+        for m in macros_to_copy:
+            opts.defaults[m[0]] = opts.defaults[m[1]]
+            macros[m[0]] = macros[m[1]]
+        # Look for a valid cc and cxx.
+        for cc in ['/usr/bin/cc', '/usr/bin/clang', '/usr/bin/gcc']:
+            if check.check_exe(cc, cc):
+                opts.defaults['__cc'] = cc
+                macros['__cc'] = cc
+                break
+        if not macros.defined('__cc'):
+            raise error.general('no valid cc found')
+        for cxx in ['/usr/bin/c++', '/usr/bin/clang++', '/usr/bin/g++']:
+            if check.check_exe(cxx, cxx):
+                opts.defaults['__cxx'] = cxx
+                macros['__cxx'] = cxx
+        if not macros.defined('__cxx'):
+            raise error.general('no valid c++ found')
+    def build(self, host, nesting_count = 0):
+        build_error = False
+        nesting_count += 1
+        log.trace('_bset: %s for %s: make' % (self.bset, host))
+        log.notice('Build Set: %s for %s' % (self.bset, host))
+                                     self.macros.expand('%{_host}'))
+        current_path = os.environ['PATH']
+        start = datetime.datetime.now()
+        have_errors = False
+        try:
+            configs = self.load()
+            log.trace('_bset: %s: configs: %s'  % (self.bset, ','.join(configs)))
+            builds = []
+            for s in range(0, len(configs)):
+                bs = None
+                b = None
+                try:
+                    # Each section of the build set gets a separate set of
+                    # macros so we do not contaminate one configuration with
+                    # another.
+                    opts = copy.copy(self.opts)
+                    macros = copy.copy(self.macros)
+                    self.set_host_details(host, opts, macros)
+                    config, parent = configs[s].split(':', 2)
+                    if config.endswith('.bset'):
+                        log.trace('_bset: == %2d %s' % (nesting_count + 1, '=' * 75))
+                        bs = buildset(config, self.configs, opts, macros)
+                        bs.build(host, nesting_count)
+                        self._includes += \
+                            self._rebase_includes(bs.includes(), parent)
+                        del bs
+                    elif config.endswith('.cfg'):
+                        log.trace('_bset: -- %2d %s' % (nesting_count + 1, '-' * 75))
+                        try:
+                            b = build.build(config,
+                                            False,
+                                            opts,
+                                            macros)
+                                self._rebase_includes(b.includes(), parent)
+                        except:
+                            build_error = True
+                            raise
+                        self.build_package(config, b)
+                        builds += [b]
+                        # Dump post build macros.
+                        log.trace('_bset: macros post-build')
+                        log.trace(str(macros))
+                    else:
+                        raise error.general('invalid config type: %s' % (config))
+                except error.general as gerr:
+                    have_errors = True
+                    if b is not None:
+                        if self.build_failure is None:
+                            self.build_failure = b.name()
+                        self._includes += b.includes()
+                    self._errors += [find_bset_config(config, opts.defaults) + ':' + parent] + self._includes
+                    raise
+            for b in builds:
+                del b
+            if not build_error:
+                log.stderr(str(gerr))
+            raise
+        except KeyboardInterrupt:
+            raise
+        except:
+            self.build_failure = 'RSB general failure'
+            raise
+        finally:
+            end = datetime.datetime.now()
+            os.environ['PATH'] = current_path
+            build_time = str(end - start)
+            log.notice('Build Set: Time %s' % (build_time))
+def list_hosts():
+    hosts = sorted(profiles.keys())
+    max_os_len = max(len(h) for h in hosts)
+    max_host_len = max(len(profiles[h]['_host'][2]) for h in hosts)
+    for h in hosts:
+        print('%*s: %-*s %s' % (max_os_len, h, max_host_len,
+                                profiles[h]['_host'][2],
+                                profiles[h]['_host'][2]))
+def get_files(configs, ext, localpath):
+    files = []
+    if localpath:
+        for cp in configs['localpaths']:
+            files += [c for c in configs[cp] if c.endswith(ext)]
+    else:
+        files = [c for c in configs['files'] if c.endswith(ext)]
+    return files
+def get_config_files(configs, localpath = False):
+    return get_files(configs, '.cfg', localpath)
+def get_bset_files(configs, localpath = False):
+    return get_files(configs, '.bset', localpath)
+def get_root(configs):
+    return configs['root']
+def list_bset_files(opts, configs):
+    for p in configs['paths']:
+        print('Examining: %s' % (os.path.relpath(p)))
+    for b in get_bset_files(configs):
+        print(' %s' % (b[:b.rfind('.')]))
+def load_log(logfile):
+    log.default = log.log(streams = [logfile])
+def log_default(name):
+    return 'rsb-log-%s-%s.txt' % (name, datetime.datetime.now().strftime('%Y%m%d-%H%M%S'))
+def load_options(argv, argopts, defaults = '%{_sbdir}/defaults.mc', extras = []):
+    opts = options(argv, argopts, defaults, extras)
+    opts.defaults['rtems_version'] = str(argopts.rtems_version)
+    return opts
diff --git a/source-builder/sb/solaris.py b/source-builder/sb/solaris.py
index 8d9498a..231fd34 100644
--- a/source-builder/sb/solaris.py
+++ b/source-builder/sb/solaris.py
@@ -25,9 +25,9 @@
 import pprint
 import os
-import check
-import error
-import execute
+from . import check
 def load():
     uname = os.uname()
diff --git a/source-builder/sb/sources.py b/source-builder/sb/sources.py
index fb6d819..1d62cb7 100644
--- a/source-builder/sb/sources.py
+++ b/source-builder/sb/sources.py
@@ -21,7 +21,7 @@
 # Manage sources and patches
-import log
+from . import log
 def _args(args):
     return [i for s in [ii.split() for ii in args] for i in s]
@@ -34,23 +34,29 @@ def add(label, args, macros, error):
     if len(args) < 2:
         error('%%%s requires at least 2 arguments' % (label))
     _map = '%s-%s' % (label, args[0])
+    _value = ' '.join(args[1:])
     macros.create_map(_map)
     index = 0
     while True:
         key = _make_key(label, index)
         if key not in macros.map_keys(_map):
             break
+        macros.set_read_map(_map)
+        value = macros.get_value(key)
+        macros.unset_read_map(_map)
+        if value == _value:
+            error('%%%s duplicate add: %s' % (label, _value))
         index += 1
     macros.set_write_map(_map)
-    macros.define(key, ' '.join(args[1:]))
+    macros.define(key, _value)
     macros.unset_write_map()
     return None
 def set(label, args, macros, error):
     args = _args(args)
     if len(args) < 2:
-        error('%%%s requires at least 2 arguments' % (label))
-        return
+        error('%%%s set requires at least 2 arguments' % (label))
+        return []
     key = _make_key(label, 0)
@@ -63,12 +69,26 @@ def set(label, args, macros, error):
 def setup(label, args, macros, error):
     args = _args(args)
     if len(args) < 2:
-        error('%%%s requires at least 2 arguments: %s' % (label, ' '.join(args)))
+        error('%%%s setup requires at least 2 arguments: %s' % (label, ' '.join(args)))
     ss = '%%setup %s %s' % (label, ' '.join(args))
     if 'setup' in macros.map_keys(_map):
         error('%%%s already setup source: %s' % (label, ' '.join(args)))
-        return
+        return []
+    macros.set_write_map(_map)
+    macros.define('setup', ss)
+    macros.unset_write_map()
+    return [ss]
+def download(label, args, macros, error):
+    args = _args(args)
+    if len(args) != 1:
+        error('%%%s download requires 1 argument: %s' % (label, ' '.join(args)))
+    ss = '%%setup %s %s -g' % (label, ' '.join(args))
+    _map = '%s-%s' % (label, args[0])
+    if 'setup' in macros.map_keys(_map):
+        error('%%%s already setup source: %s' % (label, ' '.join(args)))
+        return []
@@ -79,15 +99,14 @@ def process(label, args, macros, error):
         error('invalid source type: %s' % (label))
     args = _args(args)
     log.trace('sources: %s' % (' '.join(args)))
-    if len(args) < 3:
-        error('%%%s requires at least 3 arguments: %s' % (label, ' '.join(args)))
-        return
     if args[0] == 'set':
         return set(label, args[1:], macros, error)
     elif args[0] == 'add':
         return add(label, args[1:], macros, error)
     elif args[0] == 'setup':
         return setup(label, args[1:], macros, error)
+    elif args[0] == 'download':
+        return download(label, args[1:], macros, error)
     error('invalid %%%s command: %s' % (label, args[0]))
 def hash(args, macros, error):
@@ -97,13 +116,17 @@ def hash(args, macros, error):
         return
     _map = 'hashes'
     _file = macros.expand(args[1])
-    if _file in macros.map_keys(_map):
-        error('hash already set: %s' % (args[1]))
-        return
-    macros.create_map(_map)
-    macros.set_write_map(_map)
-    macros.define(_file, '%s %s' % (args[0], args[2]))
-    macros.unset_write_map()
+    new_value = '%s %s' % (args[0], args[2])
+    existing_value = get_hash(_file, macros)
+    if existing_value is not None:
+        if existing_value != new_value:
+            error('conflicting hash definitions for: %s' % (args[1]))
+            return
+    else:
+        macros.create_map(_map)
+        macros.define(_file, new_value)
     return None
 def get(label, name, macros, error):
diff --git a/source-builder/sb/track.py b/source-builder/sb/track.py
new file mode 100644
index 0000000..cf33a00
--- /dev/null
+++ b/source-builder/sb/track.py
@@ -0,0 +1,250 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2020 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Permission to use, copy, modify, and/or distribute this software for any
+# purpose with or without fee is hereby granted, provided that the above
+# copyright notice and this permission notice appear in all copies.
+# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
+# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
+# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
+# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
+# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
+# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
+# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+# This code builds a package compiler tool suite given a tool set. A tool
+# set lists the various tools. These are specific tool configurations.
+from __future__ import print_function
+import argparse
+import copy
+import datetime
+import os
+import sys
+try:
+    from . import build
+    from . import error
+    from . import git
+    from . import log
+    from . import simhost
+    from . import version
+except KeyboardInterrupt:
+    print('abort: user terminated', file = sys.stderr)
+    sys.exit(1)
+except:
+    raise
+def unique(l):
+    return sorted(list(set(l)))
+def filter_deps(deps, ext):
+    rdeps = []
+    for d in deps:
+        ds = d.split(':', 2)
+        if ds[0].endswith(ext):
+            rdeps += [ds[0] + ':' + ds[1]]
+    return sorted(rdeps)
+def normalise_paths(includes, root):
+    normalised = []
+    for inc in unique(includes):
+        config, parent = inc.split(':', 2)
+        if config.startswith(root):
+            config = config[len(root):]
+        if parent.startswith(root):
+            parent = parent[len(root):]
+        normalised += [config + ':' + parent]
+    return normalised
+def process_dependencies(includes):
+    deps = {}
+    incs = [i.split(':', 2) for i in includes]
+    for config, parent in incs:
+        if parent not in deps:
+            deps[parent] = []
+        for inc in incs:
+            if inc[1] == parent:
+                deps[parent] += [inc[0]]
+    for d in deps:
+        deps[d] = unique(deps[d])
+    return deps
+def includes_str(includes):
+    o = []
+    deps = [i.split(':', 2) for i in includes]
+    ll = max([len(d[1]) for d in deps])
+    for d in deps:
+        o += ['%*s %s' % (ll, d[1], d[0])]
+    return o
+def deps_str(deps):
+    def print_node(deps, node, level = 0, prefix = '', indent = ''):
+        o = []
+        if node != 'root':
+            level += 1
+            if level == 1:
+                o += ['']
+            o += [prefix + '+-- ' +  node]
+        if node in deps:
+            prefix += indent
+            for c, child in enumerate(deps[node], start = 1):
+                if c < len(deps[node]) and level > 1:
+                    indent = '|    '
+                else:
+                    indent = '     '
+                o += print_node(deps, child, level, prefix, indent)
+        return o
+    return print_node(deps, 'root')
+def run(args = sys.argv):
+    ec = 0
+    output = []
+    try:
+        # The RSB options support cannot be used because it loads the defaults
+        # for the host which we cannot do here.
+        description  = 'RTEMS Track Dependencies a build set has for all hosts.'
+        argsp = argparse.ArgumentParser(prog = 'sb-dep-check',
+                                        description = description)
+        argsp.add_argument('--rtems-version', help = 'Set the RTEMS version.',
+                           type = str,
+                           default = version.version())
+        argsp.add_argument('--list-hosts', help = 'List the hosts.',
+                           action = 'store_true')
+        argsp.add_argument('--list-bsets', help = 'List the hosts.',
+        argsp.add_argument('--output', help = 'Output file.',
+                           type = str,
+                           default = None)
+        argsp.add_argument('--log', help = 'Log file.',
+                           type = str,
+                           default = simhost.log_default('trackdeps'))
+        argsp.add_argument('--trace', help = 'Enable trace logging for debugging.',
+        argsp.add_argument('--not-referenced',
+                           help = 'Write out the list of config files not referenced.',
+        argsp.add_argument('bsets', nargs='*', help = 'Build sets.')
+        argopts = argsp.parse_args(args[1:])
+        simhost.load_log(argopts.log)
+        log.notice('RTEMS Source Builder - Track Dependencies, %s' % (version.string()))
+        log.tracing = argopts.trace
+        opts = simhost.load_options(args, argopts, extras = ['---keep-going'])
+        configs = build.get_configs(opts)
+        if argopts.list_hosts:
+            simhost.list_hosts()
+        elif argopts.list_bsets:
+            simhost.list_bset_files(opts, configs)
+        else:
+            all_bsets = simhost.get_bset_files(configs)
+            if len(argopts.bsets) == 0:
+                bsets = all_bsets
+            else:
+                bsets = argopts.bsets
+            includes = []
+            errors = []
+            for bset in bsets:
+                b = None
+                try:
+                    for host in simhost.profiles:
+                        b = simhost.buildset(bset, configs, opts)
+                        b.build(host)
+                        includes += b.includes()
+                        errors += b.errors()
+                        del b
+                    log.stderr('Build FAILED')
+                    if b:
+                b = None
+            root = simhost.get_root(configs)
+            all_configs = simhost.get_config_files(configs, True)
+            includes = normalise_paths(includes, root)
+            bsets = filter_deps(includes, '.bset')
+            configs = filter_deps(includes, '.cfg')
+            deps_tree = deps_str(process_dependencies(bsets + configs))
+            bsets = unique([b.split(':', 2)[0] for b in bsets])
+            configs = unique([i.split(':', 2)[0] for i in configs])
+            not_used_configs = [c for c in all_configs if c not in configs]
+            if len(errors) > 0:
+                errors = [e.split(':', 2)[0] for e in normalise_paths(errors, root)]
+                errs = []
+                for e in errors:
+                    if e not in bsets + configs:
+                        errs += [e]
+                errors = errs
+            output = ['RSB Dependency Tracker',
+                      'Total buildsets: %d' % (len(all_bsets)),
+                      'Total configs: %d' % (len(all_configs)),
+                output += ['Errored File Set (%d):' % (len(errors)),
+                           errors + \
+            if len(configs) > 0:
+                output += ['Include Tree(s):',
+                           deps_tree + \
+            if len(bsets) > 0:
+                output += ['Buildsets (%d):' % (len(bsets)),
+                           bsets + \
+                output += ['Configurations (%d):' % (len(configs)),
+                           configs + \
+            if argopts.not_referenced and len(not_used_configs) > 0:
+                output += ['Not referenced (%d): ' % (len(not_used_configs)),
+                           not_used_configs
+            output = os.linesep.join(output)
+            if argopts.output:
+                o = open(argopts.output, "w")
+                o.write(output)
+                o.close
+            else:
+                print()
+                print(output)
+        ec = 1
+    except error.internal as ierr:
+        log.stderr(str(ierr))
+        log.stderr('Internal Build FAILED')
+        ec = 1
+    except error.exit as eerr:
+        pass
+        log.notice('abort: user terminated')
+        ec = 1
+    except:
+        raise
+        log.notice('abort: unknown error')
+        ec = 1
+    sys.exit(ec)
+if __name__ == "__main__":
+    run()
diff --git a/source-builder/sb/version.py b/source-builder/sb/version.py
index ec6bde7..cfc5e1f 100644
--- a/source-builder/sb/version.py
+++ b/source-builder/sb/version.py
@@ -1,36 +1,84 @@
-# Permission to use, copy, modify, and/or distribute this software for any
-# purpose with or without fee is hereby granted, provided that the above
-# copyright notice and this permission notice appear in all copies.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
-# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
-# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
-# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
-# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
-# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
-# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
-# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
-# To release the RSB create a git archive and then add a suitable VERSION file
-# to the top directory.
+# Releasing RTEMS Tools
+# Format:
+#  The format is INI. The file requires a `[version`] section and a `revision`
+#  option:
+#   [version]
+#   revision = <version-string>
+#  The `<version-string>` has the `version` and `revision` delimited by a
+#  single `.`. An example file is:
+#   [version]
+#   revision = 5.0.not_released
+#  where the `version` is `5` and the revision is `0` and the package is not
+#  released. The label `not_released` is reversed to mean the package is not
+#  released. A revision string can contain extra characters after the
+#  `revision` number for example `5.0-rc1` or is deploying a package
+#  `5.0-nasa-cfs`
+#  Packages can optionally add specialised sections to a version configuration
+#  files. These can be accessed via the:
+#   load_release_settings: Return the items in a section
+#   load_release_setting: Return an item from a section
+# User deployment:
+#  Create a git archive and then add a suitable VERSION file to the top
+#  directory of the package. The package assumes your python executable is
+#  location in `bin` directory which is one below the top of the package's
+#  install prefix.
+# Notes:
+#  This module uses os.apth for paths and assumes all paths are in the host
+#  format.
+import os
 import sys
-import download
-import error
-import git
-import path
-import sources
+from . import error
+from . import git
+from . import path
 # Default to an internal string.
@@ -40,6 +88,7 @@ _revision = 'not_released'
 _version_str = '%s.%s' % (_version, _revision)
 _released = False
 _git = False
+_is_loaded = False
 def _top():
     top = path.dirname(sys.argv[0])
@@ -48,83 +97,147 @@ def _top():
     return top
 def _load_released_version_config():
+    '''Local worker to load a configuration file.'''
     top = _top()
-    for ver in [top, '..']:
-        if path.exists(path.join(ver, 'VERSION')):
+    for ver in [path.join(top, 'VERSION'),
+                path.join('..', 'VERSION')]:
+        if path.exists(path.join(ver)):
             try:
                 import configparser
             except ImportError:
                 import ConfigParser as configparser
             v = configparser.SafeConfigParser()
             try:
-                v.read(path.join(ver, 'VERSION'))
-            except:
-                raise error.general('Invalid VERSION file')
-            return v
-    return None
+                v.read(path.host(ver))
+            except Exception as e:
+                raise error.general('Invalid version config format: %s: %s' % (ver,
+        e))
+            return ver, v
+    return None, None
 def _load_released_version():
+    '''Load the release data if present. If not found the package is not released.
+    A release can be made by adding a file called `VERSION` to the top level
+    directory of a package. This is useful for user deploying a package and
+    making custom releases.
+    The RTEMS project reserves the `rtems-version.ini` file for it's
+    releases. This is the base release and should not be touched by users
+    deploying a package.
+    global _version
+    global _revision
     global _released
     global _version_str
-    v = _load_released_version_config()
-    if v is not None:
-        try:
-            _version_str = v.get('version', 'release')
-        except:
-        _released = True
+    global _is_loaded
+    if not _is_loaded:
+        vc, v = _load_released_version_config()
+        if v is not None:
+            try:
+                ver_str = v.get('version', 'revision')
+                raise error.general('Invalid version file: %s: %s' % (vc, e))
+            ver_split = ver_str.split('.', 1)
+            if len(ver_split) < 2:
+                raise error.general('Invalid version release value: %s: %s' % (vc,
+        ver_str))
+            ver = ver_split[0]
+            rev = ver_split[1]
+            try:
+                _version = int(ver)
+            except:
+                raise error.general('Invalid version config value: %s: %s' % (vc,
+        ver))
+            _revision = rev
+            if 'not_released' not in ver:
+                _released = True
+            _version_str = ver_str
+            _is_loaded = True
     return _released
 def _load_git_version():
+    global _version
+    global _revision
     global _git
     global _version_str
-    repo = git.repo(_top())
-    if repo.valid():
-        head = repo.head()
-        if repo.dirty():
-            modified = ' modified'
-        else:
-            modified = ''
-        _version_str = '%s (%s%s)' % (_version, head[0:12], modified)
-        _git = True
+    global _is_loaded
+        repo = git.repo(_top())
+        if repo.valid():
+            head = repo.head()
+            if repo.dirty():
+                modified = 'modified'
+                revision_sep = '-'
+                sep = ' '
+            else:
+                modified = ''
+                revision_sep = ''
+                sep = ''
+            _revision = '%s%s%s' % (head[0:12], revision_sep, modified)
+            _version_str = '%s (%s%s%s)' % (_version, head[0:12], sep, modified)
+            _git = True
+            _is_loaded = True
     return _git
+def load_release_settings(section, error = False):
+    items = []
+    if v is not None:
+        try:
+            items = v.items(section)
+            if not isinstance(error, bool):
+                error(e)
+            elif error:
+                raise error.general('Invalid config section: %s: %s: %s' % (vc,
+        section,
+        e))
+    return items
+def load_release_setting(section, option, raw = False, error = False):
+    value = None
+    if v is not None:
+        try:
+            value = v.get(section, option, raw = raw)
+                error(e)
+            elif error:
+                raise error.general('Invalid config section: %s: %s: %s.%s' % (vc,
+        section,
+        option,
+        e))
+    return value
 def released():
     return _load_released_version()
 def version_control():
     return _load_git_version()
-def str():
-    if not _released and not _git:
-        if not _load_released_version():
-            _load_git_version()
+def string():
+    _load_released_version()
+    _load_git_version()
     return _version_str
-def load_release_settings(macros):
-    def setting_error(msg):
-        raise error.general(msg)
-    if released():
-        if v is not None:
-            try:
-                hashes = v.items('hashes')
-            except:
-                hashes = []
-            try:
-                release_path = v.get('version', 'release_path', raw = True)
-            except:
-                release_path = None
-            for hash in hashes:
-                hs = hash[1].split()
-                if len(hs) != 2:
-                    raise error.general('invalid release hash in VERSION')
-                sources.hash((hs[0], hash[0], hs[1]), macros, setting_error)
-            download.set_release_path(release_path, macros)
 def version():
     return _version
+def revision():
+    return _revision
 if __name__ == '__main__':
-    print('Version: %s' % (str()))
+    print('Version: %s' % (str(version())))
+    print('Revision: %s' % (str(revision())))
+    print('String: %s' % (string()))
+    if version() == 'undefined':
+        raise Exception('version is undefined')
diff --git a/source-builder/sb/windows.py b/source-builder/sb/windows.py
index f4eb85c..ceca24f 100644
--- a/source-builder/sb/windows.py
+++ b/source-builder/sb/windows.py
@@ -1,6 +1,6 @@
-# Copyright 2010-2013 Chris Johns (chrisj at rtems.org)
+# Copyright 2010-2018 Chris Johns (chrisj at rtems.org)
@@ -21,12 +21,12 @@
 # Windows specific support and overrides.
-import error
-import pprint
 import os
 import sys
-import execute
+from . import execute
+from . import path
 def load():
     # Default to the native Windows Python.
@@ -78,6 +78,7 @@ def load():
     defines = {
         '_ncpus':            ('none',    'none',     ncpus),
+        '_windows_os':       ('none',    'none',     uname),
         '_build':            ('triplet', 'required', build_triple),
         '_build_vendor':     ('none',    'none',     'microsoft'),
         '_build_os':         ('none',    'none',     'win32'),
@@ -101,6 +102,7 @@ def load():
         '__chgrp':           ('exe',     'required', 'chgrp'),
         '__chmod':           ('exe',     'required', 'chmod'),
         '__chown':           ('exe',     'required', 'chown'),
+        '__cmake':           ('exe',     'optional', 'cmake'),
         '__cp':              ('exe',     'required', 'cp'),
         '__cvs':             ('exe',     'optional', 'cvs'),
         '__cxx':             ('exe',     'required', cxx),
@@ -125,7 +127,7 @@ def load():
         '__rm':              ('exe',     'required', 'rm'),
         '__sed':             ('exe',     'required', 'sed'),
         '__sh':              ('exe',     'required', 'sh'),
-        '__tar':             ('exe',     'required', 'bsdtar'),
+        '__tar':             ('exe',     'required', 'tar'),
         '__touch':           ('exe',     'required', 'touch'),
         '__unzip':           ('exe',     'required', 'unzip'),
         '__xz':              ('exe',     'required', 'xz'),
@@ -146,9 +148,15 @@ def load():
     #  6. W64/Python2 - Ok if machsize is 32
     #  7. W64/Python3 - gdb-7.9 needs python2.
-    if sys.platform == 'win32' and 'MSC' in sys.version:
-        raise error.general('python.org Pythons are built with MSC and cannot be linked with GDB')
+    # Find a suitable python2 and python3.
+    for p in os.environ['PATH'].split(os.pathsep):
+        sh = os.path.join(p, 'sh.exe')
+        if os.path.exists(sh) and os.path.isfile(sh):
+            break
+        sh = None
+    if sh is None:
+        raise error.general('cannot find a shell (sh.exe) in the PATH')
     # Search the MSYS2 install tree for a suitable python.
@@ -166,23 +174,19 @@ def load():
             raise error.general('cannot locate MSYS root mount point')
         if install_point[1] != ':':
             raise error.general('invalid MSYS root mount point: %s' % install_point)
-        install_point = '/%s%s' % (install_point[0], install_point[2:])
-        bin = '/mingw%s/bin' % (machsize)
-        bin_list = os.listdir(bin)
-        exe = None
-        for python in ['python2.exe']:
-            for f in bin_list:
-                if f == python:
-                    exe = install_point + os.path.join(bin, f)
-                    break;
-            if exe is not None:
-                break
-        if exe is None:
-            raise error.general('no valid python found; you need a mingw%s python2 installed' % (machsize))
-        defines['with_python_path'] = exe
+        install_point = path.shell(install_point)
+        mingw = path.join(install_point, 'mingw%s' % (machsize))
+        if not path.exists(mingw) or not path.isdir(mingw):
+            raise error.general('cannot find MinGW install: %s' % (path.host(mingw)))
+        for version in ['2', '3']:
+            python = 'python%s' % (version)
+            exe = path.join(mingw, 'bin', '%s.exe' % (python))
+            if not path.exists(exe) or not path.isdir(exe):
+                defines['gdb_python%s' % (version)] = exe
+                header = path.join(mingw, python)
     return defines
+    import pprint
     pprint.pprint(load())
diff --git a/source-builder/sha512-base64 b/source-builder/sha512-base64
new file mode 100755
index 0000000..e6c8e1a
--- /dev/null
+++ b/source-builder/sha512-base64
@@ -0,0 +1,2 @@
+#! /bin/sh
+openssl dgst -binary -sha512 $1 | openssl base64 | sed '{N;s/\n//;}'
2.24.1
