Old network stack and aarch64
Joel Sherrill
joel at rtems.org
Tue Oct 6 13:26:39 UTC 2020
On Tue, Oct 6, 2020 at 2:30 AM Sebastian Huber <
> Hello,
> building the old network stack for aarch64 fails with:
> cpukit/librpc/src/xdr/xdr_float.c:121:2: error: #error "xdr_float.c:
> unknown CPU"
> 121 | #error "xdr_float.c: unknown CPU"
> Should we enable RTEMS_NETWORKING more selectively similar to RTEMS_SMP
> and RTEMS_MULTIPROCESSING?
Yes for sure. In the autoconf system, we just excluded a few CPUs.
But should we go farther in waf? I see two possibilities:
+ Force legacy stack off for the same CPUs as autoconf build plus
all the BSPs that have new stack support.
+ Only enable it for the specific BSPs that have HAS_NETWORKING
in their Makefile.am? A quick grep shows 37 of 84 families would be
white listed this way.
The first is very easy. The second is a bit more painful but puts us on
a path of identifying specifically what has to transition.
With a bit of discussion on the rules for being white listed to use the
legacy stack, I would lean to the second solution.
--joel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201006/6175af27/attachment.html>
