[PATCH v3] c-user: Generate I/O Manager documentation
Tue Oct 6 22:06:24 UTC 2020
On 7/10/20 4:04 am, Sebastian Huber wrote:
> On 06/10/2020 17:06, Gedare Bloom wrote:
>> I just have one minor complaint now. In the HTML, I don't like that
>> "RETURN VALUES:"
>> appears to be about the same size/level/style as each of the list
>> elements below it. If you can make them more distinctive that would be
>> great. The PDF list isn't as bad because of the whitespace for the
>> list grouping.
> I think this can be done via the CSS:
> build/c-user/html/partition/directives.html:<p class="rubric">RETURN VALUES:</p>
> I don't know off hand how this works.
I can sort this out once the change is pushed.
