[PATCH] build: Disable RTEMS_NETWORKING for some arch/bsp
Sebastian Huber
Wed Oct 7 05:52:33 UTC 2020
The old network stack is not supported on 64-bit targets.
spec/build/cpukit/optnet.yml | 12 +++++++++++-
1 file changed, 11 insertions(+), 1 deletion(-)
diff --git a/spec/build/cpukit/optnet.yml b/spec/build/cpukit/optnet.yml
index 8678c8dbb8..7b0acf9083 100644
--- a/spec/build/cpukit/optnet.yml
+++ b/spec/build/cpukit/optnet.yml
@@ -10,7 +10,17 @@ default: false
default-by-variant: []
description: |
Enable the legacy TCP/IP network support
-enabled-by: true
+enabled-by:
+ not:
+ - aarch64
+ - powerpc/qoriq_e6500_64
+ - riscv/rv64imac
+ - riscv/rv64imac_medany
+ - riscv/rv64imafd
+ - riscv/rv64imafd_medany
+ - riscv/rv64imafdc
+ - riscv/rv64imafdc_medany
+ - x86_64
links: []
type: build
2.26.2
