[PATCH v2] build: Disable RTEMS_NETWORKING for some arch/bsp
Wed Oct 7 07:28:51 UTC 2020
The old network stack is not supported on 64-bit targets.
v2:
Add sparc64 to black list.
 spec/build/cpukit/optnet.yml | 13 ++++++++++++-
 1 file changed, 12 insertions(+), 1 deletion(-)
diff --git a/spec/build/cpukit/optnet.yml b/spec/build/cpukit/optnet.yml
index 8678c8dbb8..8a223423ad 100644
--- a/spec/build/cpukit/optnet.yml
+++ b/spec/build/cpukit/optnet.yml
@@ -10,7 +10,18 @@ default: false
 default-by-variant: []
 description: |
   Enable the legacy TCP/IP network support
-enabled-by: true
+enabled-by:
+  not:
+  - aarch64
+  - powerpc/qoriq_e6500_64
+  - riscv/rv64imac
+  - riscv/rv64imac_medany
+  - riscv/rv64imafd
+  - riscv/rv64imafd_medany
+  - riscv/rv64imafdc
+  - riscv/rv64imafdc_medany
+  - sparc64
+  - x86_64
 links: []
 type: build
2.26.2
