BSP Count (rtems-bsps, autoconf, and waf)
Wed Oct 7 13:24:10 UTC 2020
On Wed, Oct 7, 2020 at 8:18 AM Sebastian Huber <
> On 07/10/2020 14:57, Joel Sherrill wrote:
> > How is clang vs gcc done in waf?
> It is a configuration option:
> # Selects the compiler used to build the BSP (allowed values are "gcc" and
> # "clang").  Please note that the values of some options depend on the
> compiler
> # selection and changing the compiler may lead to unpredictable behaviour
> if
> # these options are not adjusted as well.  Use the --rtems-compiler
> command line
> # option to get the default values for a particular compiler via
> # ./waf bsp_defaults.
> COMPILER = gcc
Thanks. Just playing with the options, it looks like it lets you set clang
on any BSP even though that isn't going to work.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201007/d0fd96da/attachment.html>
