Documentation image source
Thu Oct 8 01:12:44 UTC 2020
On 8/10/20 12:04 pm, Joel Sherrill wrote:
> On Wed, Oct 7, 2020, 8:01 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     Hi,
>     In an update of my rtems-docs.git repo I noticed some new image source formats:
>     $ find . -name \*.dot
>     ./images/eng/bld-bsp.dot
>     ./images/eng/bld-deps2.dot
>     ./images/eng/bld-bsp2.dot
>     ./images/eng/bld-deps.dot
>     Do we have a policy on what image source types can be used? Any additional image
>     source needs to support FreeBSD and Linux.
>     Images can be difficult to get right so I understand there is a need for
>     flexibility and tolerance but I think we need to consider how we manage the
>     process and quality so we maintained high quality documentation. For example on
>     my desktop I cannot read the HTML `bld-deps.png` and clicking on it loads a
>     small image which is clearer but small. The page is ...
>     https://docs.rtems.org/branches/master/eng/build-system.html#build-specification-items
>     The PDF view looks OK.
>     I can see we have as image source the following extensions:
>      .puml
>      .ditaa
>      .svg
>      .dot
>      .odg
>     Some formats are old and imported so we live with those but maybe we need
>     tickets to have them move to something that is simpler to maintain.
>     I see generated .png and .pdf for some images which I am questioning we need.
>     The user document images I have contributed are only .png files so I am not sure
>     why a PDF is needed for some.
>     How are the .dot image sources converted to the required output format(s)? I
>     cannot see any information on what to do, what packages I need to install and
>     the options I need. For the puml and ditaa source I contributed I added waf
>     support, tested on Linux and FreeBSD and update the top level doco.
> Graphviz.
Thanks but I was hoping for something a little more specific, like a `pkg
install ...` command and a command line to run. I think it is important when
wanting to maintaining quality. :)
> If you can build Doxygen with graphics, you should have dot. We want dot for sure.
Sure, happy to be dot source integrated and managed.
>     Sorry to be a pain about this but I think it is better we sort this out before
>     we all move on and forget how they are created.
>     Chris
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org <mailto:devel at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/devel
