Documentation image source
Chris Johns
chrisj at rtems.org
Thu Oct 8 03:29:03 UTC 2020
On 8/10/20 2:23 pm, Joel Sherrill wrote:
> On Wed, Oct 7, 2020, 8:12 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> On 8/10/20 12:04 pm, Joel Sherrill wrote:
> > On Wed, Oct 7, 2020, 8:01 PM Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>> wrote:
> > Hi,
> > In an update of my rtems-docs.git repo I noticed some new image source
> formats:
> > $ find . -name \*.dot
> > ./images/eng/bld-bsp.dot
> > ./images/eng/bld-deps2.dot
> > ./images/eng/bld-bsp2.dot
> > ./images/eng/bld-deps.dot
> > Do we have a policy on what image source types can be used? Any
> additional image
> > source needs to support FreeBSD and Linux.
> > Images can be difficult to get right so I understand there is a need for
> > flexibility and tolerance but I think we need to consider how we
> manage the
> > process and quality so we maintained high quality documentation. For
> example on
> > my desktop I cannot read the HTML `bld-deps.png` and clicking on it
> loads a
> > small image which is clearer but small. The page is ...
> https://docs.rtems.org/branches/master/eng/build-system.html#build-specification-items
> > The PDF view looks OK.
> > I can see we have as image source the following extensions:
> > .puml
> > .ditaa
> > .svg
> > .dot
> > .odg
> > Some formats are old and imported so we live with those but maybe we need
> > tickets to have them move to something that is simpler to maintain.
> > I see generated .png and .pdf for some images which I am questioning
> we need.
> > The user document images I have contributed are only .png files so I
> am not sure
> > why a PDF is needed for some.
> > How are the .dot image sources converted to the required output
> format(s)? I
> > cannot see any information on what to do, what packages I need to
> install and
> > the options I need. For the puml and ditaa source I contributed I
> added waf
> > support, tested on Linux and FreeBSD and update the top level doco.
> > Graphviz.
> Thanks but I was hoping for something a little more specific, like a `pkg
> install ...` command and a command line to run. I think it is important when
> wanting to maintaining quality. :)
> That is the name of the package. May vary with upper or lower case. CentOS RPM
> is graphviz.
I am sure it is something like that on FreeBSD. I have not looked.
> Are there any figures we do not appear to have source for? Or they aren't in an
> open format? I thought we had killed all those in our last Google Code In.
Good question, I think there are some I did a long time ago that might need to
be redone. The svg ones. I have not checked.
> > If you can build Doxygen with graphics, you should have dot. We want dot
> for sure.
> Sure, happy to be dot source integrated and managed.
> I surprised one of my sons by using dot to show them the dependency graph for
> them to graduate on time. Coloured nodes based on semester offered and could
> visually identify longest sequence of courses and which had no prerequisites
> left for him.
That is such a nerd Dad solution! Well done, I love it :)
> PlantUML can draw more types of figures and they often look better but it can
> embed dot.
OK, I have not used dot so I do not know. The concern is not so much the tool
but the options used to make something work and be just right. We need to
capture what is used.
