[PATCH] grlib: Add and use irqmp_has_timestamp()
Joel Sherrill
joel at rtems.org
Thu Oct 8 13:09:47 UTC 2020
Looks OK to push.
Do you want to cite the ticket number for the build failures in the
comments?
Should I go ahead and push the fatal error patch or will you do that?
Is this needed on 5? I thought these all built on 5 but could be wrong.
On Thu, Oct 8, 2020 at 12:52 AM Sebastian Huber <
> Replace leon3_irqmp_has_timestamp() with irqmp_has_timestamp() and move
> it to grlib.h.
> Close #4128.
> bsps/riscv/griscv/clock/clockdrv.c | 2 +-
> bsps/shared/grlib/btimer/tlib_ckinit.c | 2 +-
> bsps/sparc/leon3/clock/ckinit.c | 4 ++--
> bsps/sparc/leon3/include/leon.h | 7 -------
> bsps/sparc/leon3/start/cpucounter.c | 2 +-
> 5 files changed, 5 insertions(+), 12 deletions(-)
> diff --git a/bsps/riscv/griscv/clock/clockdrv.c
> b/bsps/riscv/griscv/clock/clockdrv.c
> index c94c167fdf..4cf15fe4f8 100644
> --- a/bsps/riscv/griscv/clock/clockdrv.c
> +++ b/bsps/riscv/griscv/clock/clockdrv.c
> @@ -171,7 +171,7 @@ static void grlib_clock_initialize(void)
> volatile struct irqmp_timestamp_regs *irqmp_ts =
> &GRLIB_IrqCtrl_Regs->timestamp[0];
> - if (!grlib_irqmp_has_timestamp(irqmp_ts)) {
> + if (!irqmp_has_timestamp(irqmp_ts)) {
> bsp_fatal(GRLIB_FATAL_CLOCK_NO_IRQMP_TIMESTAMP_SUPPORT);
> #endif
> diff --git a/bsps/shared/grlib/btimer/tlib_ckinit.c
> b/bsps/shared/grlib/btimer/tlib_ckinit.c
> index 4f679984d8..5a34d97c00 100644
> --- a/bsps/shared/grlib/btimer/tlib_ckinit.c
> +++ b/bsps/shared/grlib/btimer/tlib_ckinit.c
> @@ -126,7 +126,7 @@ static rtems_device_driver tlib_clock_find_timer(void)
> volatile struct irqmp_timestamp_regs *irqmp_ts;
> irqmp_ts = &LEON3_IrqCtrl_Regs->timestamp[0];
> - if (leon3_irqmp_has_timestamp(irqmp_ts)) {
> + if (irqmp_has_timestamp(irqmp_ts)) {
> priv.ops = &ops_irqamp;
> return RTEMS_SUCCESSFUL;
> diff --git a/bsps/sparc/leon3/clock/ckinit.c
> b/bsps/sparc/leon3/clock/ckinit.c
> index f485123f6b..bf0c506ec0 100644
> --- a/bsps/sparc/leon3/clock/ckinit.c
> +++ b/bsps/sparc/leon3/clock/ckinit.c
> @@ -176,13 +176,13 @@ static void leon3_clock_initialize(void)
> tc->tc_frequency = leon3_up_counter_frequency();
> #ifdef RTEMS_PROFILING
> - if (!leon3_irqmp_has_timestamp(irqmp_ts)) {
> bsp_fatal(LEON3_FATAL_CLOCK_NO_IRQMP_TIMESTAMP_SUPPORT);
> #endif
> leon3_tc_tick = leon3_tc_tick_irqmp_timestamp_init;
> - } else if (leon3_irqmp_has_timestamp(irqmp_ts)) {
> + } else if (irqmp_has_timestamp(irqmp_ts)) {
> /* Use the interrupt controller timestamp counter if available */
> tc->tc_get_timecount = _SPARC_Get_timecount_up;
> tc->tc_frequency = ambapp_freq_get(&ambapp_plb, LEON3_Timer_Adev);
> diff --git a/bsps/sparc/leon3/include/leon.h
> b/bsps/sparc/leon3/include/leon.h
> index afe0d91ca4..d25825c8e8 100644
> --- a/bsps/sparc/leon3/include/leon.h
> +++ b/bsps/sparc/leon3/include/leon.h
> @@ -454,13 +454,6 @@ static inline uint32_t
> leon3_get_data_cache_config_register(void)
> return leon3_get_system_register(0xc);
> -static inline bool leon3_irqmp_has_timestamp(
> - volatile struct irqmp_timestamp_regs *irqmp_ts
> - return (irqmp_ts->control >> 27) > 0;
> static inline uint32_t leon3_up_counter_low(void)
> uint32_t asr23;
> diff --git a/bsps/sparc/leon3/start/cpucounter.c
> b/bsps/sparc/leon3/start/cpucounter.c
> index 007bb6d8ec..1d96e3b221 100644
> --- a/bsps/sparc/leon3/start/cpucounter.c
> +++ b/bsps/sparc/leon3/start/cpucounter.c
> @@ -43,7 +43,7 @@ static void leon3_counter_initialize(void)
> counter->read = _SPARC_Counter_read_asr23;
> leon3_counter_frequency = leon3_up_counter_frequency();
> counter->read_isr_disabled = _SPARC_Counter_read_up;
> counter->read = _SPARC_Counter_read_up;
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201008/55ad2ec9/attachment.html>
