Need help debugging sp16.exe
Gedare Bloom
gedare at rtems.org
Thu Oct 8 16:17:37 UTC 2020
On Thu, Oct 8, 2020 at 9:38 AM Richi Dubey <richidubey at gmail.com> wrote:
> Hi,
> I have been trying to debug sp16 for the last few days. I am using the new Strong APA scheduler we worked on during this GSoC. The scheduler fails only for the following tests:
> sp02.exe
> sp16.exe
> sp30.exe
> sp31.exe
> sp37.exe
> sp42.exe
> spfatal29.exe
> tm24.exe
> On executing sp16.exe, I get the following output:
> *** BEGIN OF TEST SP 16 ***
> *** TEST VERSION: 5.0.0.61ccb9c05dcd695114541960aa6bfc1315f30514-modified
> *** TEST STATE: EXPECTED_PASS
> *** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
> *** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB 5 (0b7e87143b76), Newlib fbaa096)
> TA1 - rtems_region_ident - rnid => 32010001
> TA1 - rtems_region_get_segment - wait on 1000 byte segment from region 2
> TA1 - got segment from region 2 - 0x00000040
> TA1 - rtems_region_get_segment - wait on 3K segment from region 3
> TA1 - got segment from region 3 - 0x00000080
> TA1 - rtems_region_get_segment - get 3080 byte segment from region 1 - NO_WAIT
> TA1 - got segment from region 1 - 0x00000040
> TA1 - rtems_task_wake_after - yield processor
> TA2 - rtems_region_get_segment - wait on 2K segment from region 1
> TA1 - rtems_region_return_segment - return segment to region 1 - 0x00000040
> TA1 - rtems_region_get_segment - wait 10 seconds for 3K segment from region 1
> TA2 - got segment from region 1 - 0x00000040
> TA2 - rtems_region_return_segment - return segment to region 1 - 0x00000040
> TA2 - rtems_task_set_priority - make self highest priority task
> TA2 - rtems_region_get_segment - wait on 3750 byte segment
> TA1 - rtems_region_return_segment - return segment to region 2 - 0x00000040
> TA2 - got segment from region 2 - 0x00000040
> TA2 - rtems_region_return_segment - return segment to region 2 - 0x00000040
> TA2 - rtems_task_exit
> TA3 - rtems_region_get_segment - wait on 3750 byte segment from region 2
> TA3 - got segment from region 2 - 0x00000040
> TA3 - rtems_region_get_segment - wait on 2K segment from region 3
> TA1 - rtems_task_delete - delete TA3
> TA4 - rtems_region_get_segment - wait on 1.5K segment from region 1
> TA5 - rtems_region_get_segment - wait on 1.5K segment from region 1
> TA4 - got and returned 0x00000040
> TA5 - got and returned 0x000006c0
> TA4 - rtems_region_get_segment - wait on 3K segment from region 1
> TA5 - rtems_region_get_segment - wait on 3K segment from region 1
> TA1 - rtems_task_delete - delete TA4
> TA5 - got segment from region 1 - 0x00000040
> TA5 - rtems_region_return_segment - return segment to region 1 - 0x00000040
> TA5 - rtems_task_exit
> and it doesn't progress further from here. It gets stuck in some kind of loop. While debugging with gdb, I realized the loop is:
> Clock_isr (arg=0x0) at /home/richi/quick-start/src/rtems/bsps/arm/include/../../shared/dev/clock/clockimpl.h:155
> 155 _Thread_Heir == _Thread_Executing && _Thread_Executing->is_idle
> (gdb)
> 0x001042fa 155 _Thread_Heir == _Thread_Executing && _Thread_Executing->is_idle
> (gdb)
> 0x001042fc 155 _Thread_Heir == _Thread_Executing && _Thread_Executing->is_idle
> (gdb)
> 0x001042fe 155 _Thread_Heir == _Thread_Executing && _Thread_Executing->is_idle
> (gdb)
> 0x00104302 155 _Thread_Heir == _Thread_Executing && _Thread_Executing->is_idle
> (gdb)
> 0x00104304 155 _Thread_Heir == _Thread_Executing && _Thread_Executing->is_idle
> (gdb)
> 0x00104306 155 _Thread_Heir == _Thread_Executing && _Thread_Executing->is_idle
> (gdb)
> 0x0010430a 155 _Thread_Heir == _Thread_Executing && _Thread_Executing->is_idle
> (gdb)
> 154 while (
> (gdb)
> 0x0010430e 154 while (
> (gdb)
> (gdb)
> 0x00104314 155 _Thread_Heir == _Thread_Executing && _Thread_Executing->is_idle
> (gdb)
> 0x00104316 155 _Thread_Heir == _Thread_Executing && _Thread_Executing->is_idle
> (gdb)
> 0x00104318 155 _Thread_Heir == _Thread_Executing && _Thread_Executing->is_idle
> (gdb)
> 0x0010431c 155 _Thread_Heir == _Thread_Executing && _Thread_Executing->is_idle
> (gdb)
> 0x0010431e 155 _Thread_Heir == _Thread_Executing && _Thread_Executing->is_idle
> (gdb)
> 0x00104322 155 _Thread_Heir == _Thread_Executing && _Thread_Executing->is_idle
> (gdb)
> 0x00104324 155 _Thread_Heir == _Thread_Executing && _Thread_Executing->is_idle
> (gdb)
> 159 _Timecounter_Acquire(&lock_context);
> (gdb)
> 0x001042d2 159 _Timecounter_Acquire(&lock_context);
> (gdb)
> 0x001042d4 159 _Timecounter_Acquire(&lock_context);
> (gdb)
> 0x001042d8 159 _Timecounter_Acquire(&lock_context);
> (gdb)
> 0x001042dc 159 _Timecounter_Acquire(&lock_context);
> (gdb)
> 162 (*tc->tc_get_timecount)(tc),
> (gdb)
> 0x001042e2 162 (*tc->tc_get_timecount)(tc),
> (gdb)
> 160 _Timecounter_Tick_simple(
> (gdb)
> 0x001042e6 160 _Timecounter_Tick_simple(
> (gdb)
> 0x001042e8 160 _Timecounter_Tick_simple(
> (gdb)
> 0x001042ea 160 _Timecounter_Tick_simple(
> (gdb)
> 0x001042ee 160 _Timecounter_Tick_simple(
> (gdb)
> 0x001042f0 160 _Timecounter_Tick_simple(
> (gdb)
> 0x001042f2 160 _Timecounter_Tick_simple(
> (gdb)
> (gdb)
> (gdb)
> (gdb)
> (gdb)
> (gdb)
> (gdb)
> (gdb)
> (gdb)
> 154 while (
> (gdb)
> (gdb)
> (gdb)
> (gdb)
> (gdb)
> (gdb)
> (gdb)
> (gdb)
> (gdb)
> (gdb)
> (gdb)
> (gdb)
> (gdb)
> (gdb)
> (gdb)
> (gdb)
> and so on...
> I cannot figure out what is wrong. Like Dr. Sherill suggested in a different .exe debug earlier, I set breakpoints and checked values of variables passed to the function and it all looks okay. I am quite sure this is because of the scheduler.
> How do I progress further? Please let me know.
The loop is spinning with an idle thread only, advancing the time
counters still. The last message from TA1 is a yield. You need to dig
into where TA1 got lost or why it doesn't get back the processor when
TA5 exits.
> Thanks,
> Richi.
> devel mailing list
> devel at rtems.org
