[PATCH v2 3/3] testsuite/rcxx01: Add examples for use in the User manual
chrisj at rtems.org chrisj at rtems.org
Thu Oct 8 23:52:29 UTC 2020
 spec/build/testsuites/libtests/rcxx01.yml     |   3 +
 testsuites/libtests/rcxx01/init.c             |   2 +-
 testsuites/libtests/rcxx01/thread.cpp         |  21 +++-
 testsuites/libtests/rcxx01/user-example-1.cpp |  49 ++++++++
 testsuites/libtests/rcxx01/user-example-2.cpp |  68 +++++++++++
 testsuites/libtests/rcxx01/user-example-3.cpp | 113 ++++++++++++++++++
 6 files changed, 251 insertions(+), 5 deletions(-)
 create mode 100644 testsuites/libtests/rcxx01/user-example-1.cpp
 create mode 100644 testsuites/libtests/rcxx01/user-example-2.cpp
 create mode 100644 testsuites/libtests/rcxx01/user-example-3.cpp
diff --git a/spec/build/testsuites/libtests/rcxx01.yml b/spec/build/testsuites/libtests/rcxx01.yml
index 864ad4d9d6..49bd9cff66 100644
--- a/spec/build/testsuites/libtests/rcxx01.yml
+++ b/spec/build/testsuites/libtests/rcxx01.yml
@@ -13,6 +13,9 @@ links: []
 source:
 - testsuites/libtests/rcxx01/init.c
 - testsuites/libtests/rcxx01/thread.cpp
+- testsuites/libtests/rcxx01/user-example-1.cpp
+- testsuites/libtests/rcxx01/user-example-2.cpp
+- testsuites/libtests/rcxx01/user-example-3.cpp
 stlib: []
 target: testsuites/libtests/rcxx01.exe
 type: build
diff --git a/testsuites/libtests/rcxx01/init.c b/testsuites/libtests/rcxx01/init.c
index 87d3155c7f..bea71d14c7 100644
--- a/testsuites/libtests/rcxx01/init.c
+++ b/testsuites/libtests/rcxx01/init.c
@@ -72,7 +72,7 @@ rtems_task Init(
 #define CONFIGURE_MEMORY_OVERHEAD (2024)
 #define CONFIGURE_MAXIMUM_TASKS  1
-#define CONFIGURE_MAXIMUM_POSIX_THREADS 2
+#define CONFIGURE_MAXIMUM_POSIX_THREADS 5
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
diff --git a/testsuites/libtests/rcxx01/thread.cpp b/testsuites/libtests/rcxx01/thread.cpp
index 05a9de8c48..f977a340a9 100644
--- a/testsuites/libtests/rcxx01/thread.cpp
+++ b/testsuites/libtests/rcxx01/thread.cpp
@@ -36,6 +36,10 @@ using namespace std::chrono_literals;
 extern "C" void rcxx_run_test(void);
+void example_1();
+void example_2();
+void example_3();
 struct test_thread
   test_thread();
@@ -96,13 +100,22 @@ bool test_thread::running()
   return finished == false;
+void test_1()
+  test_thread tt;
+  tt.start();
+  while (tt.running())
+    std::this_thread::sleep_for(1s);
   try {
-    test_thread tt;
-    tt.start();
-    while (tt.running())
-      std::this_thread::sleep_for(1s);
+    test_1();
+    /* From the user manual */
+    example_1();
+    example_2();
+    example_3();
   } catch (...) {
     std::cout << "Thread: ouch" << std::endl;
     throw;
diff --git a/testsuites/libtests/rcxx01/user-example-1.cpp b/testsuites/libtests/rcxx01/user-example-1.cpp
new file mode 100644
index 0000000000..dfc0992193
--- /dev/null
+++ b/testsuites/libtests/rcxx01/user-example-1.cpp
@@ -0,0 +1,49 @@
+ * Copyright (C) 2020 Chris Johns (http://contemporary.software)
+ * are met:
+#include <chrono>
+#include <iostream>
+#include <rtems/thread.hpp>
+static void wait_for(size_t seconds)
+  while (seconds--) {
+    std::this_thread::sleep_for(std::chrono::seconds(1));
+    std::cout << "Seconds: " << seconds << std::endl;
+void example_1()
+  std::cout << "Start example 1" << std::endl;
+  rtems::thread::thread t(wait_for, 5);
+  t.join();
+  std::cout << "End example 1" << std::endl;
diff --git a/testsuites/libtests/rcxx01/user-example-2.cpp b/testsuites/libtests/rcxx01/user-example-2.cpp
index 0000000000..05090fc73c
--- /dev/null
+++ b/testsuites/libtests/rcxx01/user-example-2.cpp
@@ -0,0 +1,68 @@
+ * are met:
+#include <chrono>
+static void wait_for(std::string me, size_t seconds, size_t announce)
+  size_t count = 0;
+  while (count < seconds) {
+    if ((count % announce) == 0)
+      std::cout << me << ": " << count << std::endl;
+    count++;
+void example_2()
+  std::cout << "Start example 2" << std::endl;
+  rtems::thread::attributes attr;
+  attr.set_stack_size(16 * 1024);
+  attr.set_priority(100);
+  attr.set_name("T1");
+  rtems::thread::thread t1(attr, wait_for, "T1", 10, 1);
+  attr.set_priority(101);
+  attr.set_name("T2");
+  rtems::thread::thread t2(attr, wait_for, "T2", 10, 2);
+  attr.set_priority(attr.get_priority());
+  attr.set_name("T3");
+  rtems::thread::thread t3(attr, wait_for, "T3", 15, 3);
+  t1.join();
+  t2.join();
+  t3.join();
+  std::cout << "End example 2" << std::endl;
diff --git a/testsuites/libtests/rcxx01/user-example-3.cpp b/testsuites/libtests/rcxx01/user-example-3.cpp
index 0000000000..bdc6328bb3
--- /dev/null
+++ b/testsuites/libtests/rcxx01/user-example-3.cpp
@@ -0,0 +1,113 @@
+ * are met:
+#include <atomic>
+#include <chrono>
+#include <mutex>
+class ticker
+  public:
+    ticker(const size_t life_time);
+    void run();
+    bool finished();
+    size_t seconds();
+  private:
+    void timer();
+    rtems::thread::thread tocker;
+    std::mutex            lock;
+    std::atomic<bool>     done;
+    bool                  running;
+    const size_t          life_time;
+    std::atomic<size_t>   the_seconds;
+ticker::ticker(const size_t life_time)
+  : done(false),
+    running(false),
+    life_time(life_time),
+    the_seconds(0)
+void ticker::run()
+  std::lock_guard<std::mutex> guard(lock);
+  if (!running) {
+    attr.set_name("CLCK");
+    attr.set_stack_size(8 * 1024);
+    attr.set_priority(10);
+    running = true;
+    tocker = rtems::thread::thread(attr, &ticker::timer, this);
+bool ticker::finished()
+  return done.load();
+size_t ticker::seconds()
+  return the_seconds.load();
+void ticker::timer()
+  while (the_seconds.load() < life_time) {
+    the_seconds++;
+  done = true;
+  running = false;
+void example_3()
+  std::cout << "Start example 3" << std::endl;
+  ticker my_ticker(10);
+  my_ticker.run();
+  while (!my_ticker.finished()) {
+    std::this_thread::sleep_for(std::chrono::seconds(2));
+    std::cout << "Ticker is " << my_ticker.seconds() << std::endl;
+  std::cout << "End example 3" << std::endl;
2.24.1
