[PATCH] user: Add a Languages section
chrisj at rtems.org
chrisj at rtems.org
Fri Oct 9 05:41:49 UTC 2020
user/index.rst | 2 +
user/languages/c.rst | 14 ++
user/languages/cpp.rst | 312 +++++++++++++++++++++++++++++++++++++++
user/languages/index.rst | 21 +++
4 files changed, 349 insertions(+)
create mode 100644 user/languages/c.rst
create mode 100644 user/languages/cpp.rst
create mode 100644 user/languages/index.rst
diff --git a/user/index.rst b/user/index.rst
index a91aa55..32667f4 100644
--- a/user/index.rst
+++ b/user/index.rst
@@ -42,6 +42,8 @@ RTEMS User Manual (|version|).
bld/index
bsps/index
+ languages/index
exe/index
testing/index
tracing/index
diff --git a/user/languages/c.rst b/user/languages/c.rst
new file mode 100644
index 0000000..c3965eb
--- /dev/null
+++ b/user/languages/c.rst
@@ -0,0 +1,14 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2020 Chris Johns <chrisj at rtems.org>
+.. index:: C
+.. index:: C Programming Language
+C
+.. index:: C
+RTEMS supports the C programming language.
+TBD.
diff --git a/user/languages/cpp.rst b/user/languages/cpp.rst
index 0000000..8a8cb86
--- /dev/null
+++ b/user/languages/cpp.rst
@@ -0,0 +1,312 @@
+.. index:: C++
+.. index:: C++ Programming Language
+C++
+.. index:: C++
+RTEMS supports the C++ programming language and its standard library. The
+supported language versions are C++11, C++14, and C++17.
+The C++ standard library provides a rich set of interfaces to support
+multi-threaded programming. The Thread support library provides
+``std::lock_guard`` as a means to manage ``std::mutex`` or similar objects
+within a code block while execution remains within that block. The
+``std::promise`` and ``std::future`` supports provides a controlled means for
+threads to end, clean-up and return a status value of some type. The Atomic
+operations library provdes a range of methods to atomically acess data as well
+as establish inter-thread synchronization and order non-atomic memory
+accesses.
+The Thread support library maps to the RTEMS POSIX ``pthread`` interface and
+the various sychronisation primatives such as mutual exclusion, condition
+variables, and futures map to the high performance self-contained RTEMS
+interface. These objects have a fast execution profile and their storage is
+self-contained which means it does not have to be accounted for in the
+configuration and work-space settings. C++ applications do not need to be
+concerned about the number of locks being used and can implement fine grain
+locking protocols.
+RTEMS Threads
+RTEMS provides an alternative Thread interface that lets you specify the
+attributes of a thread when it is constructed. This is an extension to the
+standard and is not based on any current or pending standards efforts. The
+goal is to make the interface as close as possible to the existing standard to
+minimise the impact on code being ported to RTEMS.
+The following compiler option must be used as the implementation uses the
+``std::invoke`` call which is only available with C++17:
+.. code-block:: c++
+ --std=c++17
+The standard Thread support library specifies the thread constructor as:
+ template< class Function, class... Args >
+ explicit thread( Function&& f, Args&&... args );
+A thread constructed using this interface will have a default set of initial
+values. An important atribute of a thread is the stack size and this cannot be
+specified or altered with this interface. On Unix systems virtual memory can
+be used to manage a thread's stack size and stack handling is more complex
+when security is considered so manually controlling the stack size of a thread
+is not needed or wanted.
+Attributes
+The ``rtems::thread::attributes`` class provides an interface to control the
+various attributes a thread has. The header file is:
+ #include <rtems/thread.hpp>
+The default constructor initialises the attributes to the executing thread's
+settings and the stack size is set to the configured minimum. You can then
+alter the attributes to match the requirements of the new thread. It is easy
+to set a name, stack size and priority:
+ rtems::thread::attribute attr;
+ attr.set_name("blue");
+ attr.set_stack_size(16 * 1024);
+ attr.set_priority(attr.get_priority() + 1);
+The ``update()`` method will read the attributes of the currently executing
+thread and update the attribute instance making the call. The stack size is
+not read and updated, there is no public interface in RTEMS to obtain the
+executing thread's stack size.
+An attribute object can be used to start a number of threads. The thread does
+not referenced the attribute object once running.
+An attribute object can be used to alter an attribute of a thread after it has
+started by calling the ``commit()`` method. The ``commit()`` method does not
+change the name or stack size of the executing thread.
+The attribute controls the scheduler policy, this is based on the POSIX
+standard. The policies are:
+``sched_other``
+ A CPU budget algorthim with timeslicing where the timeslice is reset.
+``sched_fifo``
+ A CPU budget algorthim with no timeslicing.
+``sched_roundrobin``
+ A CPU budget algorthim with timeslicing where the timeslice is exhausted.
+``sched_sporadic``
+ A CPU budget algorthim with a priorty, low priority and a replenish period.
+Thread
+The ``rtems::thread::thread`` class provides a thread interface to start a new
+thread executing using the provided attributes. The header file is:
+The ``thread`` provides the same constructor as the C++ standard's Thread
+support library:
+ template<typename F, typename... Args>
+ explicit thread (F&& func, Args&&... args);
+A thread can be run using the default parameters:
+ #include <chrono>
+ #include <iostream>
+ static void wait_for(size_t seconds)
+ while (seconds--) {
+ std::this_thread::sleep_for(std::chrono::seconds(1));
+ std::cout << "Seconds: " << seconds << std::endl;
+ void example_1()
+ std::cout << "Start example 1" << std::endl;
+ rtems::thread::thread t(wait_for, 5);
+ t.join();
+ std::cout << "End example 1" << std::endl;
+The ``thread`` provides a way to construct a thread with attributes:
+ template <typename A, typename F, typename ...Args,
+ class = enable_if_attributes<A>>
+ explicit thread (A&& attr, F&& func, Args&&... args);
+To create threads with different names and priorities use the ``attribute``
+class and pass it to the ``thread`` class when constructing:
+ #include <chrono>
+ static void wait_for(std::string me, size_t seconds, size_t announce)
+ size_t count = 0;
+ while (count < seconds) {
+ if ((count % announce) == 0)
+ std::cout << me << ": " << count << std::endl;
+ count++;
+ void example_2()
+ std::cout << "Start example 2" << std::endl;
+ rtems::thread::attributes attr;
+ attr.set_priority(100);
+ attr.set_name("T1");
+ rtems::thread::thread t1(attr, wait_for, "T1", 10, 1);
+ attr.set_priority(101);
+ attr.set_name("T2");
+ rtems::thread::thread t2(attr, wait_for, "T2", 10, 2);
+ attr.set_priority(attr.get_priority());
+ attr.set_name("T3");
+ rtems::thread::thread t3(attr, wait_for, "T3", 15, 3);
+ t1.join();
+ t2.join();
+ t3.join();
+ std::cout << "End example 2" << std::endl;
+A more powerful example shows the encapsulation of threads in a class or
+structure to provide a concurrent interface. The example uses a thread in a
+class to count seconds. The example shows the use of atomics and a mutex to
+access to some elements in the class sequentially:
+ #include <atomic>
+ #include <chrono>
+ #include <mutex>
+ class ticker
+ public:
+ ticker();
+ void start(const size_t life_time);
+ bool finished();
+ size_t seconds();
+ private:
+ void timer(const size_t life_time);
+ rtems::thread::thread tocker;
+ std::mutex lock;
+ std::atomic<bool> done;
+ bool running;
+ std::atomic<size_t> the_seconds;
+ ticker::ticker()
+ : done(false),
+ running(false),
+ the_seconds(0)
+ void ticker::start(const size_t life_time)
+ std::lock_guard<std::mutex> guard(lock);
+ if (!running) {
+ attr.set_name("CLCK");
+ attr.set_stack_size(8 * 1024);
+ attr.set_priority(10);
+ running = true;
+ tocker = rtems::thread::thread(attr, &ticker::timer, this, life_time);
+ bool ticker::finished()
+ return done.load();
+ size_t ticker::seconds()
+ return the_seconds.load();
+ void ticker::timer(const size_t life_time)
+ while (the_seconds.load() < life_time) {
+ the_seconds++;
+ done = true;
+ running = false;
+ void example_3()
+ std::cout << "Start example 3" << std::endl;
+ ticker my_ticker;
+ my_ticker.start(5);
+ while (!my_ticker.finished()) {
+ std::this_thread::sleep_for(std::chrono::seconds(2));
+ std::cout << "Ticker is " << my_ticker.seconds() << std::endl;
+ std::cout << "End example 3" << std::endl;
+The thread object's constructor provides the arguments to the new thread. The
+first argument is the ``this`` pointer and that is required because the class
+method is not static. The remaining arguments are optional and they only need
+to match the signature of the method being used as the thread. In the example
+the value passed to the ``start`` method is passed to the thread's body by it
+arguments. Note, the arguments are copied so do not reference or use
+references to local variables held in the context of the constructing
+thread. If passing pointers wrap them in a ``std::unique_ptr`` or
+``std::shared_ptr`` object.
diff --git a/user/languages/index.rst b/user/languages/index.rst
index 0000000..f27e324
--- /dev/null
+++ b/user/languages/index.rst
@@ -0,0 +1,21 @@
+.. _Languages:
+Languages
+.. index:: Languages
+.. index:: Programming Languages
+This section discusses the languages you can use to develop RTEMS
+applications with. The RTEMS Application Programming Interfaces (API)
+are specified a C language bindings but this does not limit the
+languages RTEMS supports.
+.. toctree::
+ c
+ cpp
+ ada
2.24.1
