[PATCH v2] rtems: Generate <rtems/io.h>
Sebastian Huber
Fri Oct 9 07:09:33 UTC 2020
On 08/10/2020 20:51, Peter Dufault wrote:
> I have a minor issue with the ordering. *I haven't looked too much through earlier documents.*
> I don't think this has anything to do with Sebastians work, but I think it is odd that "close" comes before directives like "I/O control" (or whatever it's called) that need to be invoked when the interface is open. If the ordering is intended to correspond to normal usage, as I think Joel said, this is wrong and "close" should be at the end.
> If that's how the current documentation is structured we should stick with it and change it later.
This is the current order of the IO Manager directives:
https://docs.rtems.org/branches/master/c-user/io/directives.html
