[PATCH] testsuites/samples/fileio - Increase of stack size
Fri Oct 9 13:32:48 UTC 2020
This is interesting. When I teach RTEMS classes, I always run this
application and the last time, this BSP was the one used. It was a rare
case of all Zynq users with no LEON users. :)
What version of RTEMS and how did you configure it?
This sounds like it may need a ticket since it likely needs to be included
on the 5 branch.pa
I don't doubt it crashed. Just want details so we can apply the patch
properly.
--joel
On Fri, Oct 9, 2020 at 8:07 AM Frank Kuehndel <
frank.kuehndel at embedded-brains.de> wrote:
> When I use the 'shell' from the fileio sample with the command below:
>    env QEMU_AUDIO_DRV="none" \
>    qemu-system-arm -no-reboot -net none -nographic -M realview-pbx-a9 -m
> 256M \
>    -kernel build/arm/realview_pbx_a9_qemu/testsuites/samples/fileio.exe
> The executable crashes with an "BLOWN STACK!!!" as soon as I try to login
> as 'root' with password. (The logins without password work fine.)
> Increasing
> the stack size of the affected thread a bit solves the issue. Hence,
> I suggest this patch.
>  testsuites/samples/fileio/init.c | 2 +-
>  1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/testsuites/samples/fileio/init.c
> b/testsuites/samples/fileio/init.c
> index 86b34b99dd..c552d33613 100644
> --- a/testsuites/samples/fileio/init.c
> +++ b/testsuites/samples/fileio/init.c
> @@ -630,7 +630,7 @@ static void fileio_start_shell(void)
>    printf(" =========================\n");
>    rtems_shell_init(
>      "SHLL",                          /* task_name */
> -    RTEMS_MINIMUM_STACK_SIZE * 4,    /* task_stacksize */
> +    RTEMS_MINIMUM_STACK_SIZE * 5,    /* task_stacksize */
>      100,                             /* task_priority */
>      "/dev/foobar",                   /* devname */
>      /* device is currently ignored by the shell if it is not a pty */
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201009/ece23e24/attachment.html>
