Need help debugging sp16.exe
Richi Dubey
richidubey at gmail.com
Sat Oct 10 15:46:37 UTC 2020
Hi Mr. Huber,
Thanks for checking in.
I suggested to enable your new scheduler implementation as the default
> to check if it is in line with the standard schedulers. I would first
> get some high level data. Select a BSP with good test results on a
> simulator (for example sparc/leon3 or arm/realview_pbx_a9_qemu). Run the
> tests and record the test data. Then enable the SMP EDF scheduler as the
> default, run the tests, record the data. Then enable your scheduler as
> the default, run the tests, record the data. Then get all tests which
> fail only with your scheduler.
Yes, this is something I've already done based on your previous suggestion.
I set SCHEDULER_STRONG_APA(the current RTEMS master's version) as the
default scheduler for both sp and SMP and ran the test (on both sparc/leon3
and arm/realview_pbx_a9_qemu). Then I set SCHEDULER_STRONG_APA(my version)
as the default scheduler for both sp and SMP and ran the test and compared
it with the master's strong apa result. The following (extra) tests failed:
sp02.exe
sp16.exe
sp30.exe
sp31.exe
sp37.exe
sp42.exe
spfatal29.exe
tm24.exe
Do a high level analysis of all failing
tests. Try to figure out a new scenario for the test smpstrongapa01.
Okay, I would look into this. This is a great suggestion, thanks!
Do all the development with RTEMS_DEBUG enabled!
> Add _Assert() stuff to your scheduler. Check pre- and post-conditions of
> all operations. Check invariants.
How do I check postconditions? Using _Assert() or by manually debugging
each function call?
On Sat, Oct 10, 2020 at 6:09 PM Sebastian Huber <
> Hello Richi,
> fail only with your scheduler. Do a high level analysis of all failing
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201010/1149976a/attachment.html>
