[PATCH] shell: Remove not functioning fdisk mount/unmount command
Sun Oct 11 23:07:45 UTC 2020
Frank,
As Gedare has said great analysis. Thank you.
I have no idea why I did not test the `fdisk mound/unmount` command, maybe I did
not know it existed, but it has proved to be a good way for us to know the old
interface is not used.
The change is OK to push.
On 10/10/20 3:03 am, Peter Dufault wrote:
> Yes, and you don't want to support two ways to do something if it hasn't been noticed in ten years.
Yes and the mount command I added had a universal way to pass in specific file
system options.
>> On Oct 9, 2020, at 11:37 , Gedare Bloom <gedare at rtems.org> wrote:
>> Excellent analysis. I would like Chris to weigh in, but the rationale
>> to remove instead of try to fix makes sense because it is basically an
>> undocumented shell API.
